View Full Version : Firebird Discussions
  1. 84 proportioning valve
  2. radiator overheating
  3. 98 firebird head gaskets....
  4. 94 gauges question
  5. Engine swap - will trans fit???
  6. 95 firebird removing door panel and replacing window motor
  7. A plain shame...
  8. 94 fan problems
  9. 98 -3800 - Stumble under load
  10. Some 93 Formula Woes
  11. 2000 TA Cooling Fan question
  12. 93-97 to 98-02 Front Conversion Issue
  13. 2000 Trans Am
  14. 89 GTA Need help
  15. 94 Trans Am hard starting
  16. nose dives
  17. steering wheel
  18. 1994 Pontiac Trans Am Price Question
  19. charging problems
  20. AC Problem Help Please
  21. Are there any Bypass kits for the 79 trans am exhausts?
  22. Do I need anything special to put the LS1 engine into my 79' trans am?
  23. 1987 GTA fire and fuel with no bang
  24. Trans Am Price range?
  25. Bumber painting
  26. Forumla Work Price?
  27. 93 trans am dies when given gas red hot exhaust manifolds
  28. How easy are they to work on?
  29. 87 Pontiac Firebird speedometer isn't working
  30. 89 Firebird wil not run.
  31. 2000 trans am throttle cable plastic connector
  32. 93 trans am runs ruff
  33. starting problems
  34. 94 Ob1 trouble
  35. 95 bird no run
  36. 2002 Firebird Trans Am questions
  37. 92 firebird formula help
  38. 95 Firebird
  39. Odd Sound from Right Headlight Assembly
  40. Play in headlight motors with Video
  41. Misfire please help
  42. headlight VS foglight
  43. Headlight switch problems?
  44. anti slosh valve for first gen tank
  45. keyless entry
  46. 1994 trans am will not start please help me....
  47. 2002 Firebird Horn and alarm
  48. Buying 2000 Firbird 3.8....Common Problems?
  49. 69 Fire-Bird
  50. 1981 turbo trans am vacuum diagram
  51. Buying a Trans Am
  52. Firebird Option codes
  53. front turn signals
  54. 2000 trans am,scraping from front of engine
  55. 79 TA -Fuel pressure goes to 0, engine stops
  56. 1996 Firebird High school project
  57. 87 firebird wont draw power
  58. 94 formula
  59. '91 firebird won't start
  60. Cable Broken
  61. head work/ please help
  62. 305 tpi> 93 LT1
  63. cai or fwi ideas for 91 tpi
  64. help with heads
  65. ls1 swap for my 67 firebird
  66. t-top conversion
  67. PLEASE HELP cat converter
  68. F.A.S.T. Class '74 T/A
  69. firebird dash clock
  70. firebird console
  71. 1997 Friebird Code interpetation
  72. gorillachipz F-40 need help/instructions
  73. 67 F-bird info
  74. starting problem 1988 firebird
  75. this a good deal?
  76. need parts fast
  77. headlight adjustment problem
  78. problem with 98 pontiac firebird exhuast
  79. Good buy? '94 Trans Am LT1
  80. 79 TA 403 w/ bog going up hill
  81. 95 trans lt 1
  82. 1981 Esprit question
  83. ok i got a question
  84. intake gasket leaks at exhaust on a 69 350
  85. Bought....
  86. smokey or paint code 80
  87. Transmission problem
  88. New Owner/ New to Firebirds
  89. clutch plate (las vegas,nv)
  90. ecm swap?
  91. A/C compressor
  92. 32 mpg
  93. Intro and a question
  94. 1977 Transam T/A 6.6 (Bandit model)
  95. T-Tops???
  96. TBB Experiment
  97. does anyone know the price of...
  98. Antenna went out on my 2000 WS6 Trans Am, need to replace
  99. 1997 Firebird Trans Am Question
  100. Question..
  101. 1998 Firebird Question
  102. New to board, have a few questions
  103. 87 firebird no inside lights? HELP!
  104. Red Light behind gear selector?
  105. Wanna know about a 79 espirit
  106. 67 firebird question
  107. where is the computer in the 92firebird
  108. Free Set Of Headers
  109. 98 trans am with tps and traction problems, please help
  110. new here and need help
  111. Can you put a 77 front end on a 76?
  112. Front license plate mounting question, 1994 Formula
  113. Optimal Cruising RPM
  114. hear air being sucked into fuel tank???
  115. How can I program my remote keyless entry?
  116. Price range for 3rd gen. Bird
  117. Info on '71 Formula 455
  118. considering purchasing a firebird
  119. Looking for good source of parts for 1994 Pontiac Firebird (6 cyl)
  120. 1987 Trans Am GTA
  121. Decals
  122. should i trade?
  123. do i need smog?
  124. HID's installed in the TA
  125. Dayum
  126. Does this seem like a good price for a WS6?
  127. '67 Firebird Restoration
  128. new member
  129. father vs son
  130. New Knight Rider TV show!!!
  131. Intake manifold for 2000 Trans Am
  132. 1978 firebird formula??
  133. Trans Am Spare Tire
  134. 1999 v6 Firebird
  135. price of car
  136. 94-97 gen formula or t/a
  137. 1967 Firebird
  138. Trans Am Questions
  139. Oil leaks SUCK
  140. What trans is it?
  141. Check out my 77 Bird with 455
  142. 77 transam motor?
  143. 84 firebird
  144. 1994 Trans Am, is it worth it??
  145. 68 Firebird
  146. reviving my 83 firebird
  147. Trading a 2005 GTO for a mint 68' 350 Firebird
  148. hi everone
  149. New Here!
  150. 86 firebird
  151. New to firebird
  152. 9.2 @ 80 mph in the 1/8
  153. looking at buying a 91 bird need help
  154. fresh firebird newb
  155. Year One Burt Renyolds Ta. LIke It ?
  156. Concerning Restoration
  157. Hi from Puerto Rico
  158. Hey people...
  159. 3rd part auto hauler...ever heard of of BAS ( best auto shippers)
  160. extremely quick 89 firebird 2.8l
  161. Anyone have any parts for sale? HELP
  162. so what do you say?
  163. After Market Tail Lights
  164. Whats your choice 3rd generation
  165. '99 f-body firebird
  166. Has anyone done ....?
  167. Power Antenna Question
  168. Unkown Wire
  169. Window Stabilizers for 95 firebird
  170. 88 iroc and 88 t/z bumper
  171. power locks
  172. power antenna
  173. I'm done.
  174. fuel and heater lines
  175. fire-bird night rider? could it be true?
  176. 396SS vs. 400HO
  177. Just bought a 93 Trans Am, Can somebody check the vin for me?
  178. `95 firebird
  179. Interchangable parts for 94 firebird
  180. 1981 Pontiac Firebird
  181. let myself introduce...ummm...myself
  182. Sold the Trans Am
  183. firebird by 2010!!!!
  184. Speed limiter in T/A 98
  185. 1969 Firebird Question
  186. ARGH, i wish it was running!
  187. Looking to buy a '97 Trans Am Ram Air, need advice
  188. MPG and fuel tank capacity for my T/A
  189. Are you a true Firebird/Camaro driver???
  190. Need advice - 95 Firebird
  191. Friend looking at buying a 93 trans am, any common problems i should know about?
  192. Buying 98 3.8 Firebird with problems, need advice
  193. Need price opinions ASAP
  194. spankin' new WRX STi vs. '99 Trans Am
  195. Fuel pump install....
  196. l had a match with POWER WINDOW today!!!
  197. free wiring diagram for a 1987 Pontiac Firebird
  198. 2007 Camaro.... any hope for firebird?
  199. just got a 99 trans am!!! Now for questions...
  200. new car
  201. I am young not rich
  202. What Trans Am should I buy?
  203. Insurance
  204. alright peeps, convince me
  205. Firebirds!! Help Me Choose!!
  206. Question for you all
  207. Do You Like The 2004 Replacement Of The Firebird Solstice..take My Poll!
  208. I finally got to test drive it!
  209. Got a question...
  210. New 3rd Gen Firebird Owner
  211. 3rd Generation Aftermarket Parts
  212. I have an idea.
