View Full Version : Camaro Discussions
- oil leak
- Breaking in transmission
- white smoke
- 3.4L muffler and exhaust questions
- Header Placement
- Window Problem
- Paint Oxidation
- LMAO - Immediately thought of you Rally! (NSFW!!!!)
- Wanted: 70 Driver's Side Glass.
- Member formally known as Nate305RS
- I need help bad!!!
- New car!!
- 1990 305 tbi timing procedures
- oil pan gasket replacement
- Idle Problem
- car won't start after oil change
- I KNEW IT!!! (those bastards...)
- How to find out what sbc you have..
- Spark plugs access
- 86 Camero
- oxidized drl's
- 1988 Firebird Dies while cruising and shifting into reverse
- Wont to trade my 87 turbo buick
- S> 1987 Iroc-Z
- What rim width for 315 series tire?
- In the name of 'Go Fast'
- 1981 Firebird motor replacement...
- question about filling up the gas
- Where is the Fuel Filter?
- window motors
- Unidentified cable under car
- Engine misfire? Code 0300
- In search of my 1968 Camaro Convertible I had in the summer of 1988
- Differential filler plug
- Manual Shifting an Auto...
- Smog Removal...
- The problem with 15's....
- 79 TA hood
- A.I.R. Thingy...
- Shrader Valve
- Sorry guys, I did it anyway.
- Fuel? Gas Gauge? Pump or something else
- well is back but what about the bird
- Handling difference with springs?
- Exhaust Gaskets
- Officially Camaro production announcement.
- Windshield Wipers
- Turn the key and no crank.
- Wiring / Trans / Backup Lights
- Life's little reminders
- 91 Firebird almost done fixing needs some more help
- wanted Cold Air Intake
- How do I turn off the airbag light?
- New job!!
- Please update with reply
- Tire Suggestions
- thermostat-fan switch suggestion
- 96 camaro ss LT1 bogging but no ses codes
- gEARS?
- check my LT1 & stang's hand made photos!
- Ring and pinion swap question.
- carb problems need urgent assistance
- raise my window from the dead
- Question about interior
- does anyone know if this item works to calibrate?
- Difference in WS6 and a non WS6
- My new ride
- hood scoop
- Need Camaro forum members ride pics.
- 1995 camaro overheating
- BCM Devices Lost Power - Comes Back
- PowerGlide
- What the hell happened to DJ?
- Is this a good deal?
- Is WS.6/ SS faster than Z28 / Trans am?
- Got a new gas saver.
- How much RPM Loss through the Torque Convertor?
- weird electrical problem
- The Unbreakable TA
- 95 Camaro Firebird Auto transmission help
- I wanted to introduce myself, and have a question!
- vibration after opti-spark install
- can i run a inline pump trough tank pump
- B> Trans Am/Formula LT1
- A/C maintanance
- Well...that was a pain
- help with fuel? system?
- still have swirls
- OEM issued 350 small blocks?
- problem with clutch
- how to make fuel pump work oncarb from inj
- Back again!!!
- Can't dc the TV cable
- How does your power steering feel?
- low voltage question
- Electric choke Question
- got my first speeding ticket
- For Sale: Lightly Used LT1 Starter
- problem with dimmer, gauges
- link to pics of all diff gen camaros
- Big problem, Fuel and Spark issue
- Aftermarket SS rear spoiler
- Buying a used TA
- 1999 Camaro 3.8 code P1133
- Why do people think the WS6 is slower then the SS?
- tpi intake question.
- FS: 1993 z28 Camaro
- Y87 Package
- Suspension camaro 5.7 1995
- A/C Compressor
- Check Engine 1995 5.7 Camaro
- Im Back!
- So...
- need help building a cold air intake
- syber junk yard
- F/S: Pyle Indash DVD player
- no taillights
- Should I buy a 89 Camaro?
- 1990 Camaro RS for Sell
- I need your help againg guys
- FS: 1998-2002 Firebird side door emblem
- Supercharger!
- Help me with timing
- 87 IROC mass air flow problem
- I need everyones Opinion
- forced induction v6
- 4th gen brake calipers on a 3rd gen?
- Squealing stops with brakes
- 355 power(hp, torque??)
- Turn sigal lever very hard
- I need YOU!
- Got codes check
- how do i start a burnout in a stick shift firebird
- 91' Firebird 3.1 stalls and won't start when hot
- Its Friggin Hot!!!
- 1991 Z28 FS in Texas
- electrical nightmare
- sorry to ask this...
- 4th gen handling
- Camaro Shocks & Struts
- 1990 firebird fuel filter
- Cat Delete Gains?
- Should I get this car? Help me out guys.....
- Wanted: Heater Control - 70
- trans leak
- LT1 or LS1
- Brake pads
- Transmission helpers
- Dim headlights
- transgo shift kit question
- posi?
- firebird motor swap, help please
- 92' rs f/s...Cheap
- Rear hatch motor lock
- What are these holes for.. (3rd gen question)
- I think I broke part of my ECM. Code 54 help please.
- Lowering Transmission
- drag times
- i need help!!!!!!!!
- Mysterious noise from inside
- parting out 84 Z28
- Windshield Wiper Arm/Blade
- Radiator Fan
- does anyone look at the classifieds or any of the subforums????
- 95 Camaro vs. 97 Mustang
- T/A Olds 403 Power
- Meziere water pump baby!
- American GT
- Donut journey
- Mounting Radar Detector
- 1996 camaro turns over but won't start
- head light problem
- Busy weekend for me!
- what do u all think abou this
- Camaro Z28
- lights & dash lights
- Oil?
- oil pan
- Blu-Ray or HD-DVD?
- RIP Cammie
- 2001 Camaro SS SLP for sale
- 79 camaro hood scoop
- ac compressor assembly
- Header Gaskets
- engine air intake all messed up
- update on life.
- KYB AGX rear shocks
- Looking into it
- Break lights
- '89 camaro engine change
- Brand new 3" harwood fiberglass hood 82-92 Bolt on
- Would this work? Exhaust question
- hooray for me
- Will not start when engine is warm
- okokok... Question on gauges.
- spent timing chain?
- Murdered Acura CL & Celica tonight! funny guy:)
- 05-06 stang GT vs. 05-06 GTO. (STOCK for STOCK)??
- engine troubles
- best frame connectors?
- rear seats and all 4 seat belts
- aluminum driveshaft
- Security system not allowing my car to start?
- Help!!!!! plz
- z28 without valve covers?
- Neat movie for 3rd gen
- need help, 91 camaro rs 3.1
- whats a good motor to swap?
- Owned Me A Maro
- Roof Liner Falling
- 94 Camaro fault lights - (Brakes)
- Early 2 Gen Wiring Diagram - Front Turn Signals???
- Waxed the stang!
- WOW! Just washed 2x, paint cleaner, polished and waxed
- who would win
- bam, wrecked
- 1991 RS Idle Problem
- 88 firebird engine swap help?????
- Carb problems
- 99 z28, what do you guys think?
- Parting Out My 95 Z28
- What Cam?
- seat motors on 02 firebird transam not working
- Fuel Pump
- Should we allow members under age 15?
- Me Dancing In Night Party
- radio and windows just quit
- Subwoofer Fittiment
- 98 T/A Performance
- damn mustangs..
- My Camaro HeadLights Are Constantly Going Out
- 2009 Camaro (video) footage
- motor swaping 350 into a 2.8l firebird
- Looking for a stock lt1 cam!!
- fuel pump or relay?
- Need motor swap advice 1994. please help!
- Window guide pin broke
- I'd be pissed...
- new rubbers
- ECM Testing
- 2002 camaro c/d cassette player
- magnaflow muffler/tips
- how to find out if i have an actual "iroc"
- 99 front end on a 94?
- Chiltons Paradox -Comparing Manuals
- Rewiring, Need stuff, but where to get?
- Is a 454 into a T/A possible?
- Re-Wiring... Confused
- 3.42's
- Your salary...
