View Full Version : Camaro Discussions
  1. What do you think of my car??
  2. cai
  3. Turboing a 305?
  4. 95LT1 stalling sometimes & bogging/stuttering at all speeds
  5. Fuel pump rod get stuck!
  6. 88 camaro 2.8 overheating probs
  7. 97 v-6 stalls intermittently
  8. 2002 SS RPO Codes and shifter M6
  9. What happened?
  10. stalling when i push in clutch
  11. 1998 Camaro Firing order
  12. 1977 T/A eng question
  13. Where is Coolant Temp Sensor?
  14. weatherstripping
  15. anyone heard of edge chips?
  16. Exhaust system
  17. No fire to 2.8 coil
  18. 94 z28 with 383 stroker.....
  19. what brand shifter is in my car
  20. Went to the track tonight....
  21. Rear Shocks for 89 Bird
  22. slotted rotors got some questions
  23. hep with trainy leak
  24. legroom in newer camaros
  25. Replacing Window motor
  26. thinking of buying a 2002 ss
  27. Lid for a V6???
  28. Hood Shocks Installed
  29. camaro for sell.....
  30. 99 T/A fog light replacement
  31. I have some stuff for third gen Camaro's f/s
  32. I need 1980 Pontiac Firebird specs
  33. I have some Firebird/TA stuff for sale
  34. Exhaust header leaks
  35. I fucked up my Z28 @ 120
  36. Opinions of "Manual Fans"...
  37. problem with my system..
  38. holly carb
  39. Grls In Forum Take 2
  40. 1989 Pontiac firebird 2.8
  41. have question about 80 model trans am
  42. ram air on a supercharged z28??????
  43. Near Miss
  44. Anti Theft Steering Wheel
  45. Will too much oil cause the engine to knock?
  46. looking
  47. Please Help - Electric Problem
  48. Stick Tips
  49. Installed SLP air-lid
  50. Camaro Question
  51. What do you guys think of the heat extractor option on the aftermarket hoods?
  52. light question?
  53. anyone know where i can get a rear end for a 94 z28?
  54. 91 z28 Fan Problem
  55. ok, im out
  56. Replacing quarter panels
  57. 1994 Z-28 needs a new home
  58. Short Headers Or Long Headers?
  59. 400hp V6 CAMARO 3RD GEN
  60. Lt 1 Engine ?
  61. killed me a first gen mustang
  62. Any Ideas?
  63. mti ls1 427 swallowing coolant
  64. Firebirds Forever!
  65. Lt1 Driveshaft
  66. lt1 headers?
  67. 84 Z28 camaro
  68. 89 RS boggin out- losing power
  69. LS-1 1/4 mile time Auto VS. 6 Speed...???
  70. Air Lids- Which is the best?
  71. 6 speed in a 92 rs
  72. HP Parts/Body
  73. 86 T/A - Add LS or LT?
  74. making a movie
  75. quick question plz! help, so i can buy quick
  76. oil pressure sending unit??
  77. oil pressure sending unit??
  78. Help...Sugar in Gas Tank...
  79. Help Mah!!!
  80. question about my 1978 camaro
  81. low oil pressure
  82. 1994 Pontiac Firebird Formula...HELP!
  83. Exhaust Question
  84. TB, Carb, FI...
  85. Camaro Videos!
  86. Am I crazy for doing this project in my front yard.
  87. ring &pinon
  88. What the "s"...
  89. Pictures!
  90. camero newbe question
  91. where can i get a role cage for my car?
  92. flowmaster 40...
  93. LS1 octane booster
  94. Cluster Gauges
  95. Back , Kinda.
  96. Slp Maf
  97. 79 camaro new motor question
  98. car dead
  99. Turbocharge a v6???
  100. New to the forum....have a few questions....
  101. 91 Camaro V6. 5spd. Ignition Problems
  102. aaarrggggg!!!!!
  103. Just gabbin 85 Camaro v6
  104. Damn "Check Engine" Light...
  105. Converting V6 - V8 85 Camaro
  106. spark plugs and wires
  107. 82 Z28 Body...
  108. my left signal lights dont blink!
  109. what's the major malfunction?!?!
  110. Short Shifter
  111. Enigine swapin questions
  112. Hurst Shift Knob
  113. need a peice of advice here...
  114. entered in a car show
  115. crossmember installation.
  116. swapping 305 to a 350?
  117. How to remove top dash?
  118. Ls1
  119. how can i make my '97 v6 stock camaro fast???
  120. 99 Camaro won't start
  121. Complete rebuild of 4th gen
  122. Questions about TPS and IAC
  123. should i buy these tires
  124. Forget how to use this multi meter
  125. Best way to install a Panhard Rods
  126. How much HP? Please help!
  127. temp gauge
  128. exhaust flame thrower
  129. Need some help upgrading my ignition...
  130. Any and everything...
  131. power steering belt
  132. Oil pump
  133. D@mmit!
  134. Cheap Cold Air Intake
  135. 11 sec 93 z28
  136. how does bracket racing and street eliminator and all that work i dont get it?
  137. Stock racing vs. modified racing (which one is better)
  138. You think this will work?
  139. Window problem
  140. service engine light
  141. keyless remote programming
  142. CAI and ThermoMaster Computer Chip
  143. what would you recomend?
  144. Burnouts....
  145. RAM Air on 3rd Gen
  146. I have a problem, I loose horspower at high RPM
  147. Tires Question
  148. Pictures of me and my GN
  149. Hello & question
  150. Camaro G2?
  151. 1996/1997 Camaro SS or 1998-2002 camaro SS?????
  152. Camaro- not just a car...also a #@@$!$ over 18 please
  153. thermostat
  154. Q about sig
  155. well its been a while but i got a few problems
  156. upgrading radiator
  157. Cuts Out when Floored
  158. I Hope This Is Normal!!!
  159. My first post! :) Quick Q's about upgradin my v6 3.4L '95 maro
  160. What does a Camaro need to beat 5.0 GT?!
  161. Slp Cold Air Induction Illegal??
  162. overheating and shaking problems
  163. what is the bore of a 327
  164. i have a question about a 400 engine
  165. leaking oil
  166. trunk wont close. i need help plz
  167. Harmonic Balancer Removal
  168. check this out guys
  169. Fan Needs Help Please
  170. m22 tranny
  171. 305 Camshaft
  172. Piston to Valve Clearance
  173. performance Chip for a 305
  174. What would you pay for this exhaust???
  175. Another day another problem...
  176. gauge ? for you guys
  177. 3.8s running 11s!!! For all V6 Camaro owners!
  178. Interior painting?
  179. Steering ?
  180. I dunno whats going on
  181. How can you increase more horse power to a 99 camaro v6 3.8L?
  182. valve covers...
  183. reupholstering seats
  184. Neutral Droping
  185. What kit is this?
  186. Trim swapping?
  187. 327 Ci?
  188. will i need spacer to put 2001 zo6 rims on my 94 z28 and what size?
  189. dodge engine??
  190. Oil Pressure problem
  191. tried something that i was told that wouldnt work, and it worked!
  192. wiring and vacuum diagram for a 92 camaro
  193. replacing window motor
  194. 2002 Trans AM Ws6 or 2002 Firehawk
  195. t-top leak
  196. Easy Tranny
  197. wheels wheels wheels
  198. Chrome Fenders
  199. Selling 1971 Camaro
  200. LT1 Engine swap into 47 Ford Truck
  201. I guess I got burned
  202. race info
  203. headlight switch problem
  204. Car stalls and has no power of line
  205. 1991-1992 Z28 Camaro Shifter Plates
  206. Camaro ss or 2004 GTO
  207. anybody know??
  208. Rear suspension damage HELP!
  209. got a short
  210. Just once more...
  211. Well since we know wat WS6 means now what does Z28 mean>???
  212. Favorite Camaro?
  213. v6 to a v8
  214. new car, new questions
  215. restricter plates???
  216. Posi going out
  217. Transmission Replacement?
  218. me and my boy
  219. Urgent help needed
  220. Stupid question about speed limiters...
  221. thermostat?
  222. wont start
  223. Tell me what you think
  224. Did?
  225. Peanut Port Heads?
  226. What is the best winter beater car when you store you bird for the winter?
  227. is it me or do people that drive mustangs big a$$holes?
  228. Good Night Sweet Prince!
  229. Web-site and Engine question
  230. Bottoming out
  231. tranny question
  232. i hate kids
  233. Holly Carb Bracket
  234. really a better oil???
  235. which one is better?
  236. rocker question
  237. 2000 Trans Am Conv. Sale/Trade
  238. I dropped all my fuggin oil!!!!!!!!!!
  239. Just had my car dynoed
  240. Camaro rear end interchange?
  241. Problem Problems!!!!!!!!!!!!
  242. transmission problems
  243. Do all firebird have the plug for the CD changer?
  244. 350 small block in 55 chevy runs hot...help me
  245. 3800 S.ii
  246. incredible bird
  247. what causes this?
  248. Right Side HeadLamp 1989 TA
  249. 88 firebird v8 formula 4 sale $700.00 obo
  250. tires, tires, tires
