Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chevrolet
Camaro
F-Bodies (Camaro and Firebird)
> Camaro Discussions |
View Full Version :
Camaro Discussions
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
88 Iroc idles high
350 engine swap help
Painting camaro
ttops crack
1989 poniac sunbird fule pump
The new Magnuson Supercharger
Start In Drive Or in 1st thanks.
would this console fit
charging system
Electric Supercharger
350 engine rebuild?
2007 5th Generation Camaro
2000 z28 won't start
Door Jam
Tire Help
cylender head question
Need help getting lights to flash when using remote keyless entry
Motor mounts needed !!!!!
1996 High Idling Camero
knock sensor
umm...Help.
Firebird/Auto parts in Orlando???
starting a build up
350 heads on a 305?
87 Iroc(305 tpi) vs. 97 Eclipse GS-T
What to do with fuel pump after conversion?
1994 v6 swap for a ls1 or lt1
Balh!!!!!
Chiltons Vs. Haynes
Transam Wheels on a Firebird - offsets?
firing order for 95 3.4 v6?
How do i program keyless entry remotes?
Rare or not??
what tha ??????????
new engine
rear-end question
95 firebird brake problem
BowTie Vortec heads
ws6 owners.. i have a question
Ring & Pinion
open loop? close loop?
Wanna hear a cam'd LS1 with open headers??
Camero TPI Acceleration from stop
huh.....
63 camaro ss pace car
Got some parts for my car
wierd engine problem
i love sears...sorta....
Looking for new maro
need a irocz front bumper
Cam
New Firebird for me.
never give up never surender
newbie driving
oil pressure guage
sub-frame
blue smoke! not good
3.1 to 305TPI need help
Custom Fiberglass sub box
Iroc with no power options??
Hot water hose
Code 64 popped up... Fuel pump or Fuel injectors
97 Camaro A/C Problem
Camaro Greatness
trunk motor
1988 Camaro Service Manual
How do I get Fast?!
Major smoke problem
nope so i mean it's free
computer help
80 t/a fix
Servo, servo, servo
5.7 tpi idle adjustment
Help me with 91 Z28
Gear/rpm Question
'99 Firebird loses power after 2500rpms
Power Windows
Transmission is locking up
rear hatch shocks keep going out
89 engine swap
please help
Replacing driveshaft in 94 3.4L
Throtel body bypass
what size?
The 3 holes on the digital EGR valve
'79 frt. suspension torque numbers
hopefully it will work
gonna get a new camaro...hopefully
give me a link for servo
Airbag code
88 firebird
87 iroc
Fuel pump and fuel injectors on 94 Z28... Help???
Need bolt pattern info ASAP
350 swap
Camaro V6 Supercharged
Catback and Headers
85 new to me
howling noise
No code flashing and still have.........
bybassing vats 91 firebird
weather strips
corvette servo wont fit?
fuel pump question? please help
Slight Grinding Noise
RPM's and auto trannys
bigger engine help...
Oil/Water Gauge wiring
exhaust...
corvette servo
vortec heads, older style block
So I'm thinking of looking into buying a firebird.
*bogs(hesitates) 2k-3.5k Rpm: Need Help!!!*
Why so much more expensive?
price range of late 2nd gen camaro *pics included* ???????
glass pack
Front end drag
Unknown sensor??
firebird motor is done new toy should be
ponie or muscle
cannot find
trans problems
Exhaust Suggestions..
gas tank gauge
gear ratio T-56/Rear End 200mph?
99 Camaro missing and bucking
Can anyone help?
Window skips
Finally bought my Camaro!!!!
REMOVING EMISSIONS... i got lost?
oil guage
Brand Question
displacement
twisted driveshaft
Code 53 TBI 90RS
supercharger
electric superchager
v6 camaro mods
Low Oil Pressure
starting issues any good idea's
350 swap... cowl induction please. (pics)
New Tires!!! Some suggestions??
more 305 questions
trans problems
2 Cooling Fans Running At Same Time?
rear end swap
fan problems
Gear Install Questions
right side blinker does not work when the veh is cold
how much $ can i get for these panels
RE 5.7 TPIs and standard transmissions
pics of the new look
91Z28 Ghost, PLEASE HELP!
Oil Question
91 Camaro 305 TBI
do i need o2 sensors for my hooker longtube headers?
3.4 Done
has anyone ever tried this?
Got SMOKED real bad
A new appreciation for the 3.8
Look at this pls(interested in buying)
annoying choke
what is this?
Bought a new 92 maro w/ 305 need help with upgrades
4th gen - obd2 or obd1???
Changed My Water Pump Yesterday/Today
Rough shifting - please heeeelp !!!
Cleaning a K&N
need help..what do need to get 300
Flywheel And Balancer
94-95 and 96-97 LT1 Differences???
OMG 69 Camaro SS
What if the air box........
My 86 Firebird trunk won't close
Possibley alternator?
87 Camaro Gas Gauge
Unknown Vacuum Hose
Car over heating!
aaaaaaaaaa booom
90 3.1 to 350 swap
chameleon paint
exhaust on a v6
Got Another Good Kill!!!
Headlight Motor Gear
Camaro's = :pimp:
I need some help from a LT1 owner.
Wanted: Dual Snorkle air cleaner housing
Reduced presence.
To All Camaro Owners
Headers
Yey
K&N, its a start
fan shroud
traction control...use it or not?
$400 to replace spark plug wires?????
Too much back and forth motion in axel
auto door locks
Advancing timing = what gas?
show me your ride
New pics....
0-60 times and 1/4 miles
True Duals?
Fuel filter on a 94 Z28
1998 camaro 3.8 engine problems
95 Firebird nearly no brakes
89 TA no power
Selling my 68 Camaro
Mystery connector?
whats the loudest?
Alternator bracket
Suspension
Car has no power!
modifying an LT1 intake to fit a TPI engine?
Heater Control Unit
Salute to our leader, FormulaLT1
I Need A Response Fast!!!
just ordered SLP intake
90 camaro hell update
Best place for used cars?
New camaro confirmed?
Why are most of the American imported Firebirds in Australia automatic?
1989 Camaro Help (Again)
New Shocks/Struts & tires
cold air intake
94 camaro water pump
brake pads
TBI question
washed.... waxed.... and took pics
help with air fits. on headers
Paint
got the camaro started
body kit question
3rd Generation Firebird 2" Cowl Induction Hood?
89 rs camaro VATS problem
91-92 silver RS emblems
ignition wiring probs
94 camaro
Engine???
computer problems
Headlight Upgrades
EVAP Problem
I need a Camaro Rear end
Spark Plug Firing Order for 91 Camaro
Clutch problems
Trans Am Camaro vs. 440 Road Runner
why is it...
head work
quick taillight question
help!!!!!!!!!
Out of Ideas
Web
AF
