Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chevrolet
Camaro
F-Bodies (Camaro and Firebird)
> Camaro Discussions |
View Full Version :
Camaro Discussions
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
TA vs. Stang GT
Finally, pictures of my car with the painted hood.
Dropping Pontiac...? Not good.
I Got The Air Foil To Work!!
Camaro I-roc z-28 350 V8 wont turn over wont start HELP
which to choose
Bad relay designs?
327 engine suffix code
Engine Inefficiency
Lack of Power
wow this is nuts!!!
got a couple kills
Discouraged..
HEI Module
cherrybombs
SLP Rocker Arm Package
color...
Overheating
slp LOUDmouth
89 camaro rs wireing probs please help
New Brakes...
Headlight Out...
Estimate Horsepower
reading trouble codes.
Quick question
'85 iroc TPI with a big time engine miss
Venom 400 Performance Control Modules
Car having a "hiccup"
Difference between GM 9 and 10 bolt
dash lights
M22 4 speed transmission
305 to 350 question
Exhaust on 1996 v6
You dont f*ck with Camaro owners
EGR valve/code
91 Camaro Wire Harness
Monsoon System.
turn signals are blinking fast
sad but funny
thirdgen LS1 swap
block identification
I almost lost her yesterday...
fyi camaro enthusiasts
must sell firebird xs
BrAke!! ha stop and look here
Fuel
for all u 3800 owners
clutch replacement finished
HELP! efi to carb swap
95 Firebird elec problems?
oil pan removal 90 3.1
Thinking about selling the Camaro
problem starting- out of ideas!!
91 Camaro ACC Fuse Keeps Blowing...
car seems to be getting better on it own
LT1 vs LS1
HELP!! TPI running excessively rich
86 transmition
clicking noise in engine
automatic shifter question
Sparkplug Wires
subs
1999 Camaro OBDI or OBDII?
1993 camaro keyless probloms
What's the difference 305 IROC engine and 305 truck engine?
3rd gen subwoofer enclosure
how much??
Disarming Integra Doors
May need to replace the "Cradle" on my firebird
'93 Z28 for $2200, is this a good deal?
89 Starting Problems
my camaro vs 99 ls1
Need Advice On This Item
oil type or additive needed?
Yet another attempt at a Camaro...
Rough Idling - Help!!
tired of rude people
tranny noise....
Junkyard Trannies
What kind of headers/ high flow Cat..
Ford Windstar Pwned me ._.
clutch replacement
Power moves, 1/2" then stops!!!
3rd gen owners look at this!!
Cam preference?
Replacing y-pipe
Reduce power Light
from a 2.6 to a 454
bringing Formula back to glory
air filter modification
Emissions Code on CEL
87 Iroc
94 engine question/suggestion
Engine swap Question
Heat only comes through defrost vents
Got my Firebird today. :)
clutch replacement
tire size fit
Bad problems. . .
camaro vs 70 boss 351
CD skipping on 2002 T/A
dual exhaust on third gen?
Bad Idle
Engine Temp ?
350 Timing Problems
Where is 1990 Formula Firebird fuel kill switch?
exterior paint
MAF Sensor
leaking
89 Firebird Belt Issue
ls1 cam for sale
tune-up (spark plug tight corner) 94 camaro
Bad Idle
ingnition problems
attn: Link85X (fan switch sensor)
NEED HELP, 78 Trans AM
Cleaning the rearend housing
L98 Swap
little ticked off
89 Camaro Need Help
which one???
motors for my 81
headders for a 70 camaro with m22 trans
91 Camaro RS
Dual exhaust on a 3rd gen
Need some Tranny advice
after market alarm
1968 Camaro - Radio Suggestion
CD Changer Help!
Ignition headache
cracked radiator
4l60e transmission
What can the 305 be bored out to?
suggestions for engine rebuild kits
What can I do E20?
A/C Blows Through Floor Vents but not Dash Vents
rearend build up
Cold Air Intake
What the??
10 bolt
BAH Help!!!
Now accepting donations
Cost For Suicide Doors On An 80's Camaro.
what to look for?
"Y" Pipe Verses Muffler?
95 camaro z28 9k good deal?
A new video of my car
99 Firebird door panel
Best 200 dollar performance upgrade?
How Much Hp Do Your Camaro's Have?
Camaro Update:
Flushing Cooling System
Engine Compatability Problems
clutch pivot ball stud
Need a posi rear
Monsoon Speaker System
code 42
to those of u who work on ur car...
different headlights
Need some help with starting my '96 Camaro
switching to posi
whats better?
Looking to Replace engine on a 97 FBD, suggestions needed.
It wasnt the coil!!!!!!
Need some exhaust help please
My Camaro Drawing
Head gasket question
distributor wiring help
how to clean my 2000 throttle body
New paint
Whistle on acceleration
Update!
99'SS with some serious issues. :(
Rust on the body
95 transam missing at idle Help!!!!
need to know
Front End Parts
Engine types?
synthetic oil burning
Clear Coat going on 94 Camaro
V6 Maro Vs Mustang
weight shedding......
subframe connectors
throttle position sensor on a 90 rs 3.1
does anyone here know hyudai's...yes i'm embarrassed for asking..
What would you do?
draggin it
oil consumption... member needs help
fan relay
Hood Locks?
98 trans am Transmission
Trunk
H4 into a camaro
10 Bolt R&P
where can i order the parts to convert my 97 front end into a 98-02
question for you LT1 gurus
how do restore my plastic lenses
Tranny swap to a ford c-4
Les Homme Mort
lexan hatch glass
Advice on purchasing a camaro
Mystery squeal is driving me NUTSO!!!
Bored over
Tranny Mounts
3.4 header recommendations?
finally fixed the rear end
3.8 struggling and straining
Mustang wussies... Literally
Killswitch
Starting problem
Hi mileage and climbing
clutch problems
camaro and mustang question
Tranny rebuild
Shifter Question
bad ignition coil...i think
Car bogging
Need Opinions On This Turbo
straigt pipe
Directions on changing the Intake Manifold
Leather Seats
1991 hatch swap
Acceleration Problems
exhaust question
no start
I'm back with...questions >D
Fram???
How the hell...
just got a new one
86 Ta w/ preformance pkg n rear disc VS 82
saging door crap
new problems, need help!
302 pistons
wont stay running
Low Coolant lite 99 SS
new v6 engine
SLP Headers
Window Fogging Problem
Rough Riding
CAI or open element
compression ratio
rearend swap
tires
Mobil 1 15,000 mile oil
So Happy!!!
What the freaking crap is up?
Son Of A...
Wrecked my baby
starter prob
Local Meet
Web
AF
