View Full Version : Camaro Discussions
- florida
- high flow catylitic converter
- Ready to sell my bird but l need to fix couple things!!!
- LS6 Intake manifold question
- 1992 camaro RS 5.0 wouldn't start??????
- still beatiful!!!!!
- Rims Bent
- Wheel locations...
- quick question
- Help me understand - what makes it stop
- before l sell, need to fix couple more things!
- 700R4 HP/TQ ratings?
- paint
- 75 trans am killed by porsche
- roller rocker swap HELP!!!
- Cobra and Trans Am
- 1989 RS Won't start
- Header opinions..
- Finally! (my new TA inside)
- i would like to congradulate
- headers/change of cats nessacary
- Spoiler Swap
- V6's... fun
- Where does this go???
- 70 camaro that returned to 60 body
- Hello
- Help with Vin# verifying engine i have???
- How to replace a passenger side quarter panel on a 95' Camaro...... need help fast!!!
- Porsche VS. Formula
- Headlight
- '94 LT1 oil pressure
- Much better...
- Help!!
- 1986 trans-am stroker motor
- A fuel Problem.... 1990 IROC
- Oil Pressure
- 1989 T/A ECM question...
- Help Please!!! Problem with CD!!!
- good deal!! check this out guys!!!
- New Camaro to be joined by other rwd cars
- New toy...
- weird stuff going on
- Found the T/A's problem...
- 1991 rs305 v8camaro will bearly run
- rear end?
- T/A or Mach 1
- TA's and Formula's
- installing a ram jet in place of 3.1 v6 what are some things I should know?
- headlight question - motor loose
- lq9 questions
- hehehe......the precious.....and pics of it...
- Where is the Set Timing connector wire for an 87 Camaro?
- New Pics Of My Car, link For Cardomain.com, Come Check it out
- Magnaflow exhaust tailpipe question
- chip for 305 tbi
- '89 Camero trouble starting 2nd time
- They Goofed - BIG TIME!
- bulb replacement
- In need of horsepower
- 1993 Camaro LT1 starts fine the first time
- should i disconnect the battery when installing headers?
- Hypertech Power Programmers
- CAT CONV glowing red hot/ engine rough idle/rough ride
- Take a Horsepower Guess!
- Wire Short + Transmission Fluid Problems + MoRe
- posi swap
- advancing distibutor
- '67 gauge pilars
- What do you think about bandit now!
- Simple Question about Rotors and Pads
- Worked on headlights today
- NOS illegal in MA
- Will T-56 allow more top end?
- Changing Hydraulic(sp?) please.
- waiting on weather to start
- LT1 headers!
- SLP Perfomance Package
- Vin # Checking
- Not a gear head..
- Flowmaster vs Magnaflow
- lighter fuse?
- machine shops
- reverse burnout
- tape player to cd player swap
- 1000ft times!!
- Exhaust Questions
- PCV Valve leaking oil..
- sway bar compatibility
- Trans am Trasmission trouble
- Bad Draw
- Thought I had it fixed.............
- how about these?
- Timing Off! Help!
- LT1 ??'s
- headlight 86 transam
- Question
- Lid or Cover
- I found my overheating problem
- turn on headlights to start it????????
- Insurance
- rims
- Estimate Please
- Vapor Lock?
- The Dark Side of the Force...
- Foot Launch Technique (A4) side effects
- Oil in Exhaust
- damn shift lever, please help!!!
- I will be Camaro-less for a little while possibly.
- Please Help, i love this car!
- True Duals
- Damn shift lever!!! help please!
- Help!!!!!
- 97 camaro hard starting when cold cranks fine
- cut out wiring help please
- '92 Rs 305 TBI DIES!!!!!! PLEASE HELP
- Firebird to Trans Am Conversion is it possible?
- 350 Modifications
- 1967 Camro Mod Help
- aceleration HELP!!!!!
- Compression question.
- 3rd gen plugs
- Starting HELP!
- F-body help!
- Sandblasting Calipers
- 94 camaro z28 for sale
- Fm13???
- lt1 top speed
- 94 camaro z28 or 2005 lancer evo 8
- 91 firebird hell!!!
- another 94 camaro z28 problem
- Need VIN info.
- Total newbie needs direction for info
- Gas?
- pictures of cut out installed?
- help! crate motor overheating!
- Supercharger
- top speed?
- some questions
- need help with buying a air filter
- speed of a 80Z28
- Changing the Heater Core, Help..
- GM Got the Memo: 2009 Pontiac Firebird
- 03-04 Cobra or 02 WS6???
- Compression Ratios...
- 91 vats bypass?
- Big 1,000
- track times...
- Gear Ratio
- 1991 V6 camaro rs 3.1L
- That weird syrup smell, who knows what causes it ??
- Replacing the headlights on a 1990 Firebird
- Window Motors....
- Are These Headers Any Good For My Application???
- Reply Quickly!!
- pacesetter headers
- 1989 Camaro ignition issue
- TH400 transmission
- Time for new U-joints
- TPI injectors peak and hold or saturated
- electric cut out wires? header bolt torque?
- LT1 or LS1?
- headers......
- 1991 Camaro RS with no heat!
- Gonna do the T-Top conversion.
- 67 camaro exhaust question
- key pellet value???
- 3.4L Intake Backfires
- Which one?
- 1972 Ford mustang Mach 1 or 2002 trans am WS6??
- 94 camaro z28 shuttin off
- As usual vats prob. i think :(
- 95 camaro 3.4 wont start
- 94 camaro z28 running help
- spoiler swap
- Shaker Or Air Cleaner?
- Monsoon on stereo = does it make a diffrence?
- immediate help abaout blinkers!
- Fuel Pump help
- CALLING ALL TBI GURU's
- Supercharge or Turbo???
- 1990 RS Camaro, 700r4 trans prob
- Throttle Body ?'s
- Throttle Body ?'s
- Warming up takes forever
- stock radio replacement or not
- high idle and stalling
- question about intake manifolds and heads...
- Who would win?
- Removing water flow restricter in heater hose
- Thinking about...
- What oil to use
- Rattling??
- help
- Z06 rims
- My car's trade in value???
- Help :(
- 95 camaro 3.4L HELP WITH OVERHEAT!
- Track Day
- Track Day
- heaters not up to par
- convertible top leaking
- cant buy a damn race....
- is it worth it?
- auto bras --- dumb or cool?
- old guy liked my car
- bazer won't start
- AC - low pressure rubber seal ring... where can I buy a replacement?
- Alarm settings for a 95 firebird
- how hard is it to change an oil pump
- rear end ?
- Good buy?
- 350 swap pics!
- Lous thump when accelerating
- Service Engine Soon Light!!!
- Electric Cooling Fan Won't Come On
- 93 Z28 Keyless Remote
- Power Problems!!!
- Service Engine Soon LIght - Am I Doomed?
- could i?
- Snapped strut
- Question about auto vs. manual
- 89' TA i had..
- 350 Exhaust Manifolds
- remove oil dipstick?
- damn!
- Race??
- In need of great WAX
- another overheating problem
- 1991 V6 3.1 chip?
- 91 Rs Not Starting!!
- can someone help
- Removing factory battery tray, why did I start this
- when twisting wires just wont work anymore i need your help.
- "LOW - TRAC" light -- whats this?
- NEW Firebird hood coming to the market!
- It's all fun and games till someone gets hurt...
- engine question
- What's next?
- Emergency Brake Cable
- No!!!!!
- radar dectors - whats good?
- 6L80e?
- Power steering pump?
- Buying Ram Air... HELP
- o2 sensor "bank2 sensor1"
- ECM question...
- general 350 street performance tips?
- When the time comes to buy new tires what do you suggest?
