Our Community is 705,000 Strong. Join Us.
View Full Version : Cedric | M45 | J30 | Gloria
Pages : [1] 2 3
  1. Unfixable infiniti m35
  2. Power Steering Problem
  3. Cedric headlight problems
  4. Seats and Sounds
  5. Engine rough idle and low rpm
  6. Driver side door wont open at all Infiniti J30t
  7. Breaking news! J30 front lowering springs found!
  8. 93 j30t idle occassionaly fluctuates from 1100rpm-2000rpm
  9. Replacing or Fixing Dimmer Switch
  10. 93 j30 whats size rims fit???
  11. Under Body Cover for Motor
  12. Help in programming keyless entry remote for Gloria
  13. 97J30 fuse location for cirgar lighter
  14. Can anyone please help me?????
  15. Blower Motor
  16. 93 J30 Hiccup
  17. Odometer doesn't work
  18. Ac
  19. 95 j30 parts for sales
  20. Stop lights won't go off Infiniti J30 1994
  21. j30 1995 cruise control not working
  22. Stereo Not Working
  23. Strange Warning Light Problem
  24. Cedric LSD options. *NEW USER*
  25. I need a J30 Engine....
  26. Water pump installation. Pls. help!
  27. Engine knock... please help!
  28. Premium vs. regular?
  29. After a 3 month setback I finally got the J30 back to normal!
  30. thinking about buying a J30-
  31. Cel Code PO 733
  32. 95 Nissan Cedric Control Panel Issues:
  33. 95 Cedric (GranTurismo)
  34. fs: j30 hood struts for sale
  35. Car is possesed or trans is going bad
  36. Sunroof leaks?
  37. AT on J30 at when start blinks 16 times???
  38. j30 tranny auto/manual?
  39. Stock J30 wheels: Any for sale?
  40. Parting out 1997 J30 Motor
  41. Hicas Light
  42. Top speed
  43. No dash lights
  44. Trying a New look on the J30!
  45. J30 Wheels for Sale
  46. parting out a 93j30t
  47. A VG community
  48. J30 Wheel Offset/Backspacing?
  49. Replacement shocks/struts?.....say it ain't so
  50. Engine Changes and Parts for Sale
  51. Anyone know codes?
  52. M30 Transmission question...
  53. How to change Alternator/Water pump belt?
  54. battery will not stay charged
  55. all warning lights came on
  56. Squeeling sound when I turn the wheel
  57. No blinkers working. Help Please!
  58. 94 Cedric problems ^^
  59. FS 4 Infiniti BBS Style J30 Rims With Tires 400 Shipped!
  60. Breathers for 97 j30
  61. Problems with my J30t
  62. Instrument panel/ A.C. control button lights
  63. Any reasons why my idle is so low?
  64. DDL connector
  65. Idle Air Control Valve?
  66. Rumbling sound when car starts???
  67. OEM or Aftermaket Waterpump?
  68. Wiper problems
  69. Door Will Not Unlock
  70. The M45
  71. Pictures put up!
  72. '93 J30 Trunk Lid Repair?
  73. j30 emblem
  74. j30 paint job
  75. CD "Err"
  76. Parts for sale! From a '94 J30
  77. this sounds wrong but it is true
  78. Fan Belt?
  79. Loose Rear End
  80. J30 Air Condition Problem
  81. j30 major issues. Advice needed.
  82. Infinity J30 Instrument Brightness control
  83. 2000 J30 fuel filer location ?
  84. This still makes me laugh
  85. Door Panel
  86. Door Panel
  87. Cigarette Lighter Fuse??Please Help!!
  88. remote door locks
  89. Air Compressor
  90. Need a Mechanic
  91. Correct RPMs
  92. Cruise Control not working
  93. New Exhaust System
  94. ABS Light
  95. Desperate for some help
  96. Transmission Fluid
  97. High Pitched whine
  98. Runs Bad
  99. woot today i burned rubber!
  100. woot today i burned rubber!
  101. J30 Hesitates when warm
  102. Trans
  103. Repair or replace a right exhaust manifold?
  104. what are these?
  105. Time control device?
  106. mdotocr
  107. Alternator removal problems
  108. any other j30 forums
  109. Differential oil
  110. Low Idle
  111. wow
  112. Mechanic
  113. glow gauges
  114. cold air intake
  115. ?? Other J30 forums ??
  116. HELP, HELP, HELP, stabilizer rod!!!
  117. check engine/transmission lights
  118. Brake shims question?
  119. stereo headunit
  120. speed dile
  121. my newly acquired daily driver
  122. Need some info on an M45
  123. cigarette lighter
  124. Help, Starting problem??
  125. Gas Smell
  126. bose unit stopped working
  127. Oil Changes
  128. Alarm Controller
  129. back window
  130. just installed glow gauges
  131. dash bord lights
  132. Alarm problems?
  133. change the air intake system
  134. 94 parts list
  135. Battery light indicator?
  136. 93 j30 radio power goes off
  137. Iridium Vs Platinum Spark plugs?
  138. Seatbelt light
  139. Windshield wiper INT not working?
  140. Underdrive Pulley
  141. emergency brake stuck
  142. Which AIR FILTER?
  143. My J30
  144. Site for my J30
  145. ECU Upgrade For J30
  146. J30 tranny is the same as >blank<
  147. 93 j30
  148. engine heat shield?help please !!!
  149. Fuel Injector Question
  150. stalls on highway if heavy rain
  151. '94 J30 Sunroof won't fully close
  152. J30 1200 obo for sale in Miami FL
  153. Check engine light
  154. anyone ever pulled the crankshaft pulley?
  155. does anybody ever repl to messages?
  156. bad dealerships
  157. Leather Interior
  158. Computer Swap
  159. Power steering/alternator connected?
  160. In Need Of Two Tension Rods For 94 J30 Asap!
  161. J30 front rotor problems
  162. I need a tranny for my 93 J30t
  163. Nissan Cedric Grand Turismo
  164. J30 Exhaust Question
  165. electrical wiring diagram
  166. remote control
  167. locked key in car
  168. 1995 J30 Tan/Beige Door Panel Needed
  169. headlight relay for 1995 infiniti j30t
  170. PROBLEM: Cannot Program Keyless Entry (Please dont ignore)
  171. Infinity J30 1993
  172. 94 parts for sale
  173. Automatic locks
  174. issues starting
  175. I love my car!
  176. Keyless Entry (Key Fob) wont reprogram (Cant erase previous ID Codes)
  177. 96 Infiniti J30 Speedometer,Odometer not working
  178. Paint Job
  179. Instructions on Installing Starter?
  180. Sound System
  181. 1997 J30 power antenna mast installation -- where to begin?
  182. Windshield Wipers Replacements for 97 j30t - Nothing fits at store!
  183. Sold G20, Bought 1997 J30t, many questions, few answers! Help
  184. WTB: Chrome OEM Grill/Emblem
  185. Thinking of purchasing a 1995 J30
  186. 95 J30 Spark Plug Location ??
  187. Pictures of my J - What do you think?
  188. Infiniti J45t
  189. where is my IAT sensor?
  190. chip
  191. My J30 Issues
  192. 97 Antenna Replacement
  193. infiniti j30 tension rod?
  194. problems Headlights and Tail Lights
  195. Hicas, Radio, Dashlights
  196. turbo kits
  197. 94 j30 antenna motor
  198. Buying a 1993 J30 need opionions
  199. engine noise
  200. infiniti A/C blows warm air
  201. infiniti j30 bose radio DIY???
  202. help! shifting problems!~!
  203. J30 Windshield Washer Pump
  204. acceleration problem...
  205. Ashtray compartment does not open
  206. So many but lets........
  207. interchangeable seats?
  208. converter pipe for j30t
  209. Headlights
  210. New Muffler For J30t
  211. "CLUNK" on j30T
  212. PO400 Infinti J30 1997
  213. Some DIY Questions
  214. Stereo Questions from a new J30 owner
  215. Sqweak In Reverse?
  216. cracked exhaust manifolds
  217. Does anyone.........
  218. Stereo Woes
  219. Sunroof Wind Noise
  220. J30 1994 Gas Smell
  221. Free Website
  222. Security System
  223. Fail Safe or Broken Circuit Breakers
  224. J30 mods
  225. Tune up on my car
  226. De-tuning Engine
  227. Fuel pump relay..or??
  228. Gas mileage and tank capacity
  229. Riding until the wheels fall off
  230. speaker sizes
  231. door lock relay install
  232. head light
  233. Best power steering fluid
  234. Manual car alarm shutoff
  235. 95 j30 parking brake adjusted
  236. just bought a j30, sunroof leaking problem, and electric fan conversion question.
  237. J30 Chrome Grill
  238. An old J30 comercial....
  239. 96 j30
  240. 95 J30 service manual
  241. Wrong Bose Head unit.
  242. 95 J30 parking brake adjustment problem
  243. ATTN: Underground_Killah
  244. 93 J30 Door locks.Help?
  245. Aftermarket Speakers
  246. 1994 Subaru Svx
  247. infiniti j30 misses, not getting spark
  248. wiring diagrams....
  249. klunk when i hit the brakes...
  250. For Sale: 94 j30t
