View Full Version : Tips and Maintenance Procedures
  1. Passkey reprogramming procedure
  2. PF52 Filter update
  3. Changing Water Pump In 95 LeSabre - Tips For You
  4. Clearing Flooded Fuel Injection Engine
  5. Fuel Pump Resistor Bypass for '97 - '00 Regal GS
  6. How Do I Drain the Radiator and Cooling System Flush for '97 and Up Regal/Century
  7. fuel pump/relay and DTC 44 troublshooting info
  8. 2000 Lesabre radio replace
  9. Instructional video: How to fix Squeaks and Rattles
  10. How To for fixing a blank display in the dual zone Climate Control Module
  11. Tensioner Assembly Removal for SII 3800 Engine and Bypass Elbows '99 and Up
  12. 4T65E Trans Shift Hard, P1811 DTC
  13. Plastic Coolant Bypass Fitting: *VIN-L 3800*
  14. 4T65E Autotransaxle Diagram for Shift Solenoids, PCS and VSS
  15. Don't miss the hidden hose!
  16. FAQ: MAF, IAC & TPS Location Series II 3800 Engine
  17. diagnostic tips for vats (pass keyII)
  18. Information on GM UIM Plenum and Aftermarket Plenums for SII 3800
  19. Information on Aluminum Framed Lower Intake Manifold Gaskets for SII 3800
  20. how to bypass faulty passlock system
  21. 2000 and Up Buick Century LIM Gasket Procedure
  22. Advisory for All '01-'02 Regal Owners Concerning CAT Convertor
  23. '95-'98 SII 3800 UIM/EGR Stovepipe Documentation
  24. OBD I Code Retrieval and Typical Code List
  25. General Motors Radio Harness Color Coded
  26. Hub Replacement '97 and Up Regal/Century
  27. Power Steering Pump Replacement '97-'04 Regal
  28. RPO Codes - LeSabre Only!
  29. RPO Codes - PA's Only
  30. RPO Codes
  31. PCV Valve Replacement for '95 and Up Buicks with SII 3800 Engine
  32. Guidelines for Posting (Please Read)
  33. Error Codes On Gm Radios What Do They Mean?
  34. 1994 Buick LeSabre Keyless Programming THIS IS HOW TO
  35. Programming Remotes from 1997 to 2004 Lesabre
  36. Programming Remotes from 1996 to 1998 Skylark
  37. Programming Remotes from 1996 to 1999 Riviera
  38. Programming Remotes from 1997 to 2004 Regal
  39. Programming Remotes for 93-95 & 96-99 PA
  40. Programming Remotes from 1997 to 2005 Century
  41. Keyless Entry Remote Synchronization
