Our Community is 662,000 Strong. Join Us.
View Full Version : 2nd Gen 00-05
Pages : [1] 2 3
  1. 2002 Neon OBD code P1281
  2. late shifing
  3. 02 Neon Kaminari full body kit sale
  4. 03 Neon SE, speedometer and fuel gauge problem
  5. Intermittent timing fault
  6. Power Steering Fluid, Belt and Thermostat Housing question
  7. torque converter selenoid
  8. 2001 neon keeps overheating whats sup
  9. Tempature Going Up And Down
  10. 03 Neon not turning over at all
  11. srt4 neon mod problem
  12. 2002 Neon Alternator Replacement
  13. Bolt size of harmonic balancer?
  14. Replacement key
  15. '05 Dodge Neon will not start
  16. Exhaust for neon
  17. Where can I get wiring diagram
  18. Replacing '03 headlights
  19. 2000 Neon Fuel problem
  20. 2001 Plymouth Neon
  21. 01 Neon tranny problem
  22. '04 Neon died and won't start, everyone stumped, please help!
  23. Battery ran dead now speedometer doesn't work
  24. 2003 Neon code PO441
  25. 05 neon
  26. runs rough at stop lights and low rpms
  27. 2003 Neon SE shuddering after new engine mounts
  28. ploblems with 2000 neon
  29. Im looking into buying a 2004 neon srt-4. Help?
  30. 05 Neon timing belt change/now no start
  31. 2003 neon brakes
  32. need help
  33. 2001 Neon Multifunction Switch connector
  34. neon IAC makes noise
  35. power Hieght Adjust
  36. 2000 neon (5 sp) help
  37. No Power In First Gear
  38. p0441? changed gas cap, still comes on
  39. steering problem... its broke
  40. AC high pressure Low side
  41. 02 transmission problems
  42. neon engine problems
  43. 2002 neon keyless entry problem
  44. is this normal '02 neon PLEASE HELP!!
  45. Shift Knob question.
  46. 01 neon hwy overheating? Help!
  47. new to neon with 4 trouble codes
  48. 2000 no pedal pressure after brake conversion.
  49. 05 neon pcm????
  50. New to Dodge forum, lol
  51. 00 plymouth neon cat problem
  52. Brake Caliper Rubbing on Rim
  53. rear bumper repair/replace
  54. 2002 Neon R/T engine noise
  55. seatbelt situation
  56. 03 neon SXT CD changer problem.
  57. 02 Dodge neon transmission
  58. code p0171
  59. Neon loose's trottle
  60. stuck in 1st gear
  61. Rear Brake replacement
  62. Mounts, a bit confused, how many and where
  63. 2002 2.0 neon radiator, a few questions
  64. neon hidden mount replacement
  65. Vibration when accel'ing and cold
  66. Seat Covers for 2003 Neon
  67. 2000 dodge neon 3 speed transmission issue
  68. Dodge Neon Fuel Prob Please Help
  69. Other "suicide" door design
  70. Pass Motor Mount Plate - Stuck...
  71. dang a#$$ neon
  72. rebuilding a three speed out of a 2001 neon
  73. My neon shuts down, help!!!
  74. Help my neon plzzz
  75. Just Changed Engine need help with codes.
  76. P0750, shift solenoid A malfunction
  77. cruise control
  78. Transmission Flush
  79. 2002 Transmission Codes P700 and P740
  80. IAC sensor location
  81. P0441 code
  82. 2003 SXT Fog Light Replacement - HELP!
  83. Timing Belt replacement
  84. 1st/2nd Generation
  85. 2000 Throttle Body Tube collapes.
  86. Spark Plug Cables,
  87. 2001 neon sunroof leak
  88. SRT bumpers
  89. a Complete switch from sxt to SRT-4 ?
  90. messed with my fuses in my 2000 dodge neon, help please :)
  91. 2000 Neon Rubbing noise
  92. How can i make my neon go faster!!!
  93. transmission seems to be slipping after only 46,000 miles
  94. 2002 SE Automatic drives fine but no reverse
  95. 00 neon cold weather plug fouling
  96. Motor mounts
  97. fog light
  98. 2000 Chrysler Noen has no reverse
  99. 2000 - fuse problem -Indicator/radio/dome
  100. Oil Sender
  101. crazy instrument cluster
  102. Smelly Fan
  103. looking to sell my 00 plymouth neon,need help ??
  104. 03-04 neon transmission problems
  105. camshaft position error??
  106. Intermittent no start...
  107. fitting guide
  108. eyelids
  109. 2001 Chrysler Neon(Grinding noise)
  110. Timing Belt
  111. Engine swap
  112. Possible CV Jointy Noise only under load?
  113. no gear engaguement
  114. How to DISCONNECT Car Alarm...????
  115. your opinions on this?
  116. Crank Case vent tube?!?!
  117. rear brake conversion
  118. Hard (early) Shifting - 2003 Dodge Neon SXT (automatic)
  119. neon coeds
  120. instrument cluster swap
  121. oil pump location and removal?
  122. 01 motor swap
  123. High gear problem??
  124. Air flow problem with heater/defrost/ac
  125. battery loses charge
  126. turn signals ??
  127. neon engine noise
  128. front end troubles?
  129. 03 Neon SXT Over heating.
  130. 2002 Dodge Neon Electrical Problem
  131. 04 05 Motor Swap
  132. Possible leaking Heater Core
  133. HP / Performance Upgrades
  134. oil on the # 3 spark plug?
  135. apexi n1 catback exhaust questions
  136. need pcm code help PO 601?
  137. 2002 neon transmission only 1st and reverse
  138. 2004 Dodge Neon Troubles
  139. Dodge Auto Parts
  140. Driver Side Mirror - Remove linkage cover
  141. need help
  142. 2000 plymouth neon
  143. 2000 Dodge neon brakes
  144. 05 SXT clutch?
  145. 05 SXT High Idle
  146. tapping noise front front of engine
  147. need help
  148. 2004 Dodge Neon SXT not moving
  149. *Help! 04 Atx Dodge Neon Es P0700*
  150. dodge sx series
  151. 01 neon problem
  152. Vavle Cover gaskets
  153. strange noise from under the glove compartment
  154. cold start problems. help!
  155. Codes P0441 & P0513
  156. 2001 neon, low gear problem??
  157. i need help asap.....
  158. Need Help....2nd Generation neon
  159. Camshaft Position Sensor Replacement
  160. Fog lights?
  161. Lights Dim
  162. 00 neon eye lids
  163. Fuel Pump in 2003 Neon SXT?
  164. CPR needed for my Neon
  165. 02 neon starter problem
  166. 2005 Neon wanting to do engine swap to srt4 engine need advise!!
  167. 03 Neon, engine code P0340
  168. bad multifunction switch?
  169. check engine light
  170. 2000 Neon
  171. HELP. tierod
  172. PITA electrical
  173. 05 Neon start/Won't run
  174. transmission and coolent fluid leaking...
  175. 2002 Neon SXT
  176. 2000 Neon Chk Eng codes P0601 & P1684
  177. '01 high idle problems
  178. 2001 Plymouth Neon LX overheating
  179. 2001 neon, oil questions
  180. 03 Neon won't Start
  181. Blowing fuses
  182. car idiot---right here
  183. Neon won't stay running
  184. '02 Neon doesn't start
  185. Engine problems
  186. oil pan question
  187. need help pleaseeeeeeeee
  188. SPARCO shifter knob, question//
  189. Brakes...
  190. Huge Plans For My 2001 Dodge Neon!!!! Want Opinions/reviews
  191. Cold Air Intake Problem??
  192. Turbo
  193. 2000 neon
  194. crazy intrument panel
  195. 2000 Neon. some quick questions.
  196. '01 passenger side Humming
  197. Any know how to...
  198. I can't understand this problem
  199. 01 fuel problems
  200. 2000 Dodge Neon Transmition
  201. wont kick into 3rd or 4th gear
  202. 01 burning to much oil
  203. Stock upgrade questions
  204. 04 Neon Remote Entry
  205. neons hasnt been started in about a year
  206. Clicking from under car?
  207. 2004 Se Neon Problem
  208. engine swaps
  209. 01 rim and tire
  210. 2000 neon transmission
  211. 2002 misfire
  212. HELP!! 2003 dodge neon sxt
  213. love some real help
  214. 2005 sx2 neon is clicking and won't start,HELP
  215. Neon 2000 driving belt tensioner
  216. Neon 2000 driving belt tensioner
  217. 2002 Neon SXT Transmission problem
  218. my 2003 dodge neon se
  219. 2000 neon cruise control doesn't work
  220. FWSCCA autoX
  221. more acceraltion
  222. 2003 Dodge Neon (Low Idle)
  223. 2002 Dodge Neon
  224. engine
  225. 02 neon Tranny + electrical isssues
  226. cam shaft sensor location 4 2002 neon
  227. minor transmission clunk
  228. Dodge Neon 2002
  229. 2000 Neon Water Leak
  230. 01 Dodge Neon 2.0L steering wheel wobble...
  231. Engine Swaps For 2003 Neon??
  232. Location of the TCU on a 2002 neon
  233. trip/odometer flashes FUSE
  234. question about neons...
  235. aftermarket gauge... ????
  236. replacing rear springs
  237. Overheating Problem - Need Help!!!
  238. 03 R/T rims
  239. .:Urgent Help Needed:.
  240. HELP!!! I don't know what's wrong with my car!
  241. Neon with a timed knock
  242. ignition switch
  243. can you convert the 2.0 sohc engine to a dohc engine?
  244. for sale: SRT-4 front & rear swaybars
  245. My neon shakes a lot HELP!!
  246. oem cd changer to aftermarket deck
  247. can uguys help me
  248. Ignition Coil Primary Circuit
  249. Rough Idle- 2001 Plymouth Neon
  250. 2001 Dodge Neon squeak/squeal from the motor
