View Full Version : 2nd Gen 00-05
- Pass Motor Mount Plate - Stuck...
- dang a#$$ neon
- rebuilding a three speed out of a 2001 neon
- My neon shuts down, help!!!
- Help my neon plzzz
- Just Changed Engine need help with codes.
- P0750, shift solenoid A malfunction
- cruise control
- Transmission Flush
- 2002 Transmission Codes P700 and P740
- IAC sensor location
- P0441 code
- 2003 SXT Fog Light Replacement - HELP!
- Timing Belt replacement
- 1st/2nd Generation
- 2000 Throttle Body Tube collapes.
- Spark Plug Cables,
- 2001 neon sunroof leak
- SRT bumpers
- a Complete switch from sxt to SRT-4 ?
- messed with my fuses in my 2000 dodge neon, help please :)
- 2000 Neon Rubbing noise
- How can i make my neon go faster!!!
- transmission seems to be slipping after only 46,000 miles
- 2002 SE Automatic drives fine but no reverse
- 00 neon cold weather plug fouling
- Motor mounts
- fog light
- 2000 Chrysler Noen has no reverse
- 2000 - fuse problem -Indicator/radio/dome
- Oil Sender
- crazy instrument cluster
- Smelly Fan
- looking to sell my 00 plymouth neon,need help ??
- 03-04 neon transmission problems
- camshaft position error??
- Intermittent no start...
- fitting guide
- eyelids
- 2001 Chrysler Neon(Grinding noise)
- Timing Belt
- Engine swap
- Possible CV Jointy Noise only under load?
- no gear engaguement
- How to DISCONNECT Car Alarm...????
- your opinions on this?
- Crank Case vent tube?!?!
- rear brake conversion
- Hard (early) Shifting - 2003 Dodge Neon SXT (automatic)
- neon coeds
- instrument cluster swap
- oil pump location and removal?
- 01 motor swap
- High gear problem??
- Air flow problem with heater/defrost/ac
- battery loses charge
- turn signals ??
- neon engine noise
- front end troubles?
- 03 Neon SXT Over heating.
- 2002 Dodge Neon Electrical Problem
- 04 05 Motor Swap
- Possible leaking Heater Core
- HP / Performance Upgrades
- oil on the # 3 spark plug?
- apexi n1 catback exhaust questions
- need pcm code help PO 601?
- 2002 neon transmission only 1st and reverse
- 2004 Dodge Neon Troubles
- Dodge Auto Parts
- Driver Side Mirror - Remove linkage cover
- need help
- 2000 plymouth neon
- 2000 Dodge neon brakes
- 05 SXT clutch?
- 05 SXT High Idle
- tapping noise front front of engine
- need help
- 2004 Dodge Neon SXT not moving
- *Help! 04 Atx Dodge Neon Es P0700*
- dodge sx series
- 01 neon problem
- Vavle Cover gaskets
- strange noise from under the glove compartment
- cold start problems. help!
- Codes P0441 & P0513
- 2001 neon, low gear problem??
- i need help asap.....
- Need Help....2nd Generation neon
- Camshaft Position Sensor Replacement
- Fog lights?
- Lights Dim
- 00 neon eye lids
- Fuel Pump in 2003 Neon SXT?
- CPR needed for my Neon
- 02 neon starter problem
- 2005 Neon wanting to do engine swap to srt4 engine need advise!!
- 03 Neon, engine code P0340
- bad multifunction switch?
- check engine light
- 2000 Neon
- HELP. tierod
- PITA electrical
- 05 Neon start/Won't run
- transmission and coolent fluid leaking...
- 2002 Neon SXT
- 2000 Neon Chk Eng codes P0601 & P1684
- '01 high idle problems
- 2001 Plymouth Neon LX overheating
- 2001 neon, oil questions
- 03 Neon won't Start
- Blowing fuses
- car idiot---right here
- Neon won't stay running
- '02 Neon doesn't start
- Engine problems
- oil pan question
- need help pleaseeeeeeeee
- SPARCO shifter knob, question//
- Brakes...
- Huge Plans For My 2001 Dodge Neon!!!! Want Opinions/reviews
- Cold Air Intake Problem??
- Turbo
- 2000 neon
- crazy intrument panel
- 2000 Neon. some quick questions.
- '01 passenger side Humming
- Any know how to...
- I can't understand this problem
- 01 fuel problems
- 2000 Dodge Neon Transmition
- wont kick into 3rd or 4th gear
- 01 burning to much oil
- Stock upgrade questions
- 04 Neon Remote Entry
- neons hasnt been started in about a year
- Clicking from under car?
- 2004 Se Neon Problem
- engine swaps
- 01 rim and tire
- 2000 neon transmission
- 2002 misfire
- HELP!! 2003 dodge neon sxt
- love some real help
- 2005 sx2 neon is clicking and won't start,HELP
- Neon 2000 driving belt tensioner
- 2002 Neon SXT Transmission problem
- my 2003 dodge neon se
- 2000 neon cruise control doesn't work
- FWSCCA autoX
- more acceraltion
- 2003 Dodge Neon (Low Idle)
- 2002 Dodge Neon
- engine
- 02 neon Tranny + electrical isssues
- cam shaft sensor location 4 2002 neon
- minor transmission clunk
- Dodge Neon 2002
- 2000 Neon Water Leak
- 01 Dodge Neon 2.0L steering wheel wobble...
- Engine Swaps For 2003 Neon??
- Location of the TCU on a 2002 neon
- trip/odometer flashes FUSE
- question about neons...
- aftermarket gauge... ????
- replacing rear springs
- Overheating Problem - Need Help!!!
- 03 R/T rims
- .:Urgent Help Needed:.
- HELP!!! I don't know what's wrong with my car!
- Neon with a timed knock
- ignition switch
- can you convert the 2.0 sohc engine to a dohc engine?
- for sale: SRT-4 front & rear swaybars
- My neon shakes a lot HELP!!
- oem cd changer to aftermarket deck
- can uguys help me
- Ignition Coil Primary Circuit
- Rough Idle- 2001 Plymouth Neon
- 2001 Dodge Neon squeak/squeal from the motor
- 05 Neon Rediculously bright lights!!
- I need to check the fuel pressure!
- Headlights quit at random!!!
- Dome light problems on an '03
- '01 oil light problems... HELP!!!
- 17" Wheels on the Neon
- camshaft sensor problem?
- Need Help! 02 R/t
- Please Help
- 2005 Dodge Neon
- whats a good neon
- '04 Neon SXT - Squealling and jumping almost to the point of stalling
- instrument cluster went dead
- scanner problem..
- need some help..
- supercharger??
- Dodge Neon 03 - Rough Idle, Lights Flickering
- New Member
- 02 Neon 2 liter hole in throttle body hose, whats the cause??
- turbocharger
- 01 neon R/T what ya suggest?
- dtc p2305 and p1697
- exhaust
- wiring diagrams?
- Make it go Faster?
- Neon 2001 wont start
- Oil pressure drops as RPM's increase? Help?
- Locked up PCM
- No Heat....Help its getting cold outside
- 00 neon heater core
- broken lug bolt
- water leak in trunk
- help brake problem
- wheel swap
- Mods For Sxt?????
- Need a little information
- Keyless Remote Programming Instructions?
- 2005 neon headlamp bulb change?
- "tapping" noise in cool weather
- Need Help!!!
- Code P1494 & P1684
- Spring Fell Off Strut!
- 00 Neon Cold Air Intake
- 2000 Dodge Neon No Brakes!!
- 2000 Neon Replacement 5 speed cost
- Would it be okto drive?
- Door Open showing on dash
- humming sound
- Engine Oil all over spark plugs
- E-Break Light Comming On
- All neons squeal at -40
- apexi safc 2 wiring
- noise
- Cat for pacesetter manifold
- Engine overheating and car choking
- axle-back exhausts for 03 neon r/t
- 2001 Plymouth Neon struts
- No Dome Light!!!!2000 Dodge Neon
- Neon Dome Light
- SUP UP suggestions for 2003 neon sxt???
- 2001 evo 5 fog lights
- 02 Dodge Neon
- headlights
- 2000 starter problem?
- crazy power door locks!
- 2001 neon shaking when stopped!
- 05 sxt intake
- hello
- 2000 Neon 2.0L
