View Full Version : 2nd Gen 00-05
- Please Help, 2k Neon Wont Start!!!!
- question about 00' air filter box.
- Program Keyless Entry Fob
- Aem Cai
- 2000 Neon Motor Mounts
- HELP ME PLEASE w/2003 Dodge Neon
- Just saying hi
- side skirts question
- Neon rims and tires
- Anyone klnow the correct fuel pressure on a `02 Neon????
- p0303, Check Engine Light
- Color Problems...
- Need a new PCM
- how to replace the lights in the instrument panel of a 2002 neon
- Engine fan question and a few others...
- 2k2 Neon Won't Pass Emissions Test
- Slight hesitation when accelerating
- Check Engine light help.
- what should i do
- 2000 neon magnum swap
- shooting engine codes
- Srt-4 motor swap please help
- Somebody please help- 2000 Neon issues
- help 2001 neon r/t bellhousing
- 2002 Neon, no third gear & clunks into drive
- 2000 Neon problems
- 2000 Neon power door latch/locks
- 2000 Neon automatic transmission problem
- 2000 Neon replacing tie rod end?
- installing a tach on 2000 neon
- 2000 neon computer chips
- exhuast for 2000 neon
- 01 Neon Oil Light
- powertrain trouble code help
- 2000 Neon Sentry Key Question
- 5-spd trans PM
- '00 std trans brg noise
- 03 problem
- 15 inch wheels
- Srt-4 cat back exhaust on a 2nd gen neon?
- HELP! 2003 Neon Keeps Cutting Off...This is Long!
- 19" rims and tire ?
- 200 neon le
- atx to mtx
- 2000 Neon coolant leaking from exhaust
- '04 5-spd funky clutch problems... help!
- '04 Neon reposessed!
- 03 Neon Fuel Gauge problem.
- 2002 Neon shifts hard when comming out of drive
- Wrecked 2005 Dodge Neon
- how to bypass o2 on the cat 2001r/t
- 2004 SXT NEON possible bent frame
- 2000 Plymoth Neon (Cd player won't work)
- 2nd gen DOHC swap
- 2nd gen PLEASE HELP!!!
- 2003 Doge Neon Question
- 02 Neon SE keyless entry
- 2000 Neon and P1684 error code
- seat cleaning, 2003 Neon
- 2001 neon rev limiter
- 2005 Dodge Neon SXT
- 91 octane gas in R/T model?
- 2K3 neon R/T strange noise when cold outside...
- '04 Clutch problems
- 2000 Neon, backfiring,hesitating,loss of power
- 2005 neon tranny conversion....
- 01-02 neons
- 05 Neon Upgrades
- 03 dodge srt-4 wide body kit
- Cold Air Intake...04 Neon Sxt
- 2002 Neon
- SRT-4 front bumper on a 03 neon ?
- 2000 Dodge Neon
- rim size on 04 sxt
- installing Fog lights on 2004 SXT
- Does anybody know how to instal a Jet Power Control Module on "00 Neon".......
- Check Engine Light '02 Neon
- 2000 SOHC Neon
- CEL on. running lean, o2 sensors dead??
- Is this 2000 Neon worth buying
- 2003 neon sxt interior removal
- 2000 neon squicky noise, "NEED HELP".
- Installing neon lights in a 2004 SXT
- 2004 Console Panel
- 05 and the dreaded Check Engine Light
- water leaking
- Crank Position Sensor Location?
- 2001 neon motor swap
- 2002 Neon won't shift out of 2nd
- neon 2001 le ID
- 01 Dodge Neon ES
- Chip Flasher Help?
- 2000 Neon
- 2000 neon a/c
- intake 4 01 ply neon
- 2001 dodge neon doesn't start, ticks
- 03 Neon starting mods
- Removing Wheel Covers 2000 Neon
- Check Engine Light, Car Running Rich???
- 01 r/t codes
- 2000 - Car moves in park
- Whers all the old help??2000 neon front end noise
- 2000 neon front end clatter.
- 2000 Neon Hit the gas and car goes put-put
- 2000 neon transmission fluid
- 2002 rpm drop at stop light and dies
- 04 Neon/2.0 sx Intake
- 01 es swap to srt-4 trany??
- 2000 neon turbo and rebuild?
- '03 Dodge Neon motor mount problem
- '01 neon rt
- Power Windows For 04 Neon
- Going to buy a 2000 neon with 100k miles
- 2ooo Neon Won't start
- 2000 Neon with Gas Mileage inmind
- 2000 Neon Air Con just stopped
- 2002 neon door panel removal
- 2000 neon moon roof weatherstrip
- 2004 Neon shakes in reverse?
- 2001 r/t
- 2001 ATX SOHC - Replaced ECU - wont start
- 2001 with even more issues
- 2001 neon with issues
- Adjust the full tire height
- 2000 egr location
- 2002 neon electrical problems
- 2nd gen speaker wire setup help
- 2003 Sx2.0
- 2003 R/t Questions
- 2000 neon engine wont turn off
- No Tach instructions have helped me
- 04 neon sxt has lots of problems
- 2000 Dodge Neon Spark Plug Blew
- 2001 Neon tach wire location, color
- 2000 Dodge Neon dies sporadically
- 2002 neon idle
- 2000 neon door lock assembly
- 2002 keyless entry
- computer sensors for 2002 neon
- solid yellow engine light... 01 dodge neon
- 2000 neon stalled backing up now won't start
- 2000 Plymouth Neon stuck in park
- AEM bypass valve
- Performance Chip !Help!
- 2000 neon 2.0 idle
- 01 neon rt headlight problem
- 2003 neon sxt questions
- !HELP! Will 04 cold air fit 05
- Need 05 sxt Exhaust
- 2001 exhaust system
- 2000 Neon racing and surging.
- 2000 Neon Dash and Tail lights wont work..
- 2001 Coolant
- Fuse blows in 2000 neon
- 02' Neon sounds like a diesel!?!?!?!?
- 2003 Neon speedometer
- 2000 NEON valves tapping
- 2000 Neon - Rear Defrost is out. HELP!!!
- 2000 neon falling apart
- 01 underdrive pulley
- 2000 Neon, looking for replacement CD/Cassette player
- 2000 neon will not go into reverse
- 3sp to AOD
- 95 to an 04 questions
- 2000 Neon starts then stalls!!!
- 2001 SE Upgrades
- 2000 neon parts
- 2001 Neon not starting.
- 2003 neon rear defroster
- 2001 Neon Fuse? Electric?
- 2001 auto vibration @ idle???
- 2000 neon brake problem
- 2002 neon stuck in the rain
- 2001 Neon wont start
- 03 neon hop up help
- 2002 neon
- 2000 Neon- NOISY rear brakes
- 04 deoge neon spolier question
- 2000 neon door panel removal
- 2000 Neon Strut replacement
- 2nd Gen drum-to-disk brake conversion
- 2000 Dodge Neon Clicks/won't start!!!!!!!!
- 17 inch fit...
- 2000 Neon No Start Problem
- 2004 Models - Problems
- Are the 2000 & 2001's any good?
- 2002 Neon Remote Programming
- 2002 Power steering pump and tranny
- 2001 Neon Headlight Conversion
- 2000 Neo ES want PT Turbo motor swap
- 2001 power steering rack
- ??pacesetter exhaust??
- 2000 radiator install
- 2K Neon Idle Speed
- 01 neon question
- Just purchased a 2000 and looking for expertise
- engine swap 2000 neon
- Supercharge a neon?
- 2000 and up DODGE NEON TACH HELP
- 2001 Neon
- 2000 DODGE NEON TACH question
- 2001 Dodge Neon Tach Help
- '03 Corner Lights
- 2004 NEON HAS an intermittent bog/hesitation.
- 2.4l in 2gen
- 2001 Neon R/T vs. 2002 Acura RSX-NOT type S
- 2001 Neon R/T converted to SRT-4
- 2000 Dodge Neon Shuts Off?
- squealing noise.....
- 2002 dodge neon (more torque?)
- 2001 Neon might have knock
- 04 neon headlights converted to 00-02
- 2004 Neon SXT parts?
- 2000 Neon Engine Codes
- 2003 with problems...HELP
- 2004 Sxt
- My 2000 Neon Check it Out Tell me what ya think
- 2002 Neon remote programming
- 2000 Neon Power Locks?
- 1st Gen springs on 2nd gen
- SRT-4 engine swap need advice
- 2001 Neon R/T traction problem!!!
- 2001 transmission problem
- 2001 neon with mods info
- 00,neon intermittant dead battery
- 2001 neon obx header HELP!!!
- 2004 Neon SXT
- 2000 Neon- Code PO455
- 00 neon lost pick-up
- 2001 neon intake install HELP
- 2.0 Neon Coolant Block Drain
- 2003 Neon SXT Exhaust Question
- 03 altezza light's
- 2000 Dodge Neon brakes squealing
- 2002 R/T engine swap
- 00-01 foglights
- srt-4 tires on 2003 dodge neon r/t??
- 2000 Front Door Speakers
- 2000 neon 4cd PLAYER
- shaky neon
- Engine codes for a 2001 R/T
- Steering wheel panel? 2000+
- 2001 Dodge Neon ES
- 2001 neon rt tires
- 2002 neon keyless entry
- 2000 Neon Manifold Crack????
- 2001 Neon SE
- for 2nd gen neon owners
