View Full Version : 2nd Gen 00-05
Pages : 1 [2] 3
  1. 2002 Dodge Neon
  2. engine
  3. 02 neon Tranny + electrical isssues
  4. cam shaft sensor location 4 2002 neon
  5. minor transmission clunk
  6. Dodge Neon 2002
  7. 2000 Neon Water Leak
  8. 01 Dodge Neon 2.0L steering wheel wobble...
  9. Engine Swaps For 2003 Neon??
  10. Location of the TCU on a 2002 neon
  11. trip/odometer flashes FUSE
  12. question about neons...
  13. aftermarket gauge... ????
  14. replacing rear springs
  15. Overheating Problem - Need Help!!!
  16. 03 R/T rims
  17. .:Urgent Help Needed:.
  18. HELP!!! I don't know what's wrong with my car!
  19. Neon with a timed knock
  20. ignition switch
  21. can you convert the 2.0 sohc engine to a dohc engine?
  22. for sale: SRT-4 front & rear swaybars
  23. My neon shakes a lot HELP!!
  24. oem cd changer to aftermarket deck
  25. can uguys help me
  26. Ignition Coil Primary Circuit
  27. Rough Idle- 2001 Plymouth Neon
  28. 2001 Dodge Neon squeak/squeal from the motor
  29. 05 Neon Rediculously bright lights!!
  30. I need to check the fuel pressure!
  31. Headlights quit at random!!!
  32. Dome light problems on an '03
  33. '01 oil light problems... HELP!!!
  34. 17" Wheels on the Neon
  35. camshaft sensor problem?
  36. Need Help! 02 R/t
  37. Please Help
  38. 2005 Dodge Neon
  39. whats a good neon
  40. '04 Neon SXT - Squealling and jumping almost to the point of stalling
  41. instrument cluster went dead
  42. scanner problem..
  43. need some help..
  44. supercharger??
  45. Dodge Neon 03 - Rough Idle, Lights Flickering
  46. New Member
  47. 02 Neon 2 liter hole in throttle body hose, whats the cause??
  48. turbocharger
  49. 01 neon R/T what ya suggest?
  50. dtc p2305 and p1697
  51. exhaust
  52. wiring diagrams?
  53. Make it go Faster?
  54. Neon 2001 wont start
  55. Oil pressure drops as RPM's increase? Help?
  56. Locked up PCM
  57. No Heat....Help its getting cold outside
  58. 00 neon heater core
  59. broken lug bolt
  60. water leak in trunk
  61. help brake problem
  62. wheel swap
  63. Mods For Sxt?????
  64. Need a little information
  65. Keyless Remote Programming Instructions?
  66. 2005 neon headlamp bulb change?
  67. "tapping" noise in cool weather
  68. Need Help!!!
  69. Code P1494 & P1684
  70. Spring Fell Off Strut!
  71. 00 Neon Cold Air Intake
  72. 2000 Dodge Neon No Brakes!!
  73. 2000 Neon Replacement 5 speed cost
  74. Would it be okto drive?
  75. Door Open showing on dash
  76. humming sound
  77. Engine Oil all over spark plugs
  78. E-Break Light Comming On
  79. All neons squeal at -40
  80. apexi safc 2 wiring
  81. noise
  82. Cat for pacesetter manifold
  83. Engine overheating and car choking
  84. axle-back exhausts for 03 neon r/t
  85. 2001 Plymouth Neon struts
  86. No Dome Light!!!!2000 Dodge Neon
  87. Neon Dome Light
  88. SUP UP suggestions for 2003 neon sxt???
  89. 2001 evo 5 fog lights
  90. 02 Dodge Neon
  91. headlights
  92. 2000 starter problem?
  93. crazy power door locks!
  94. 2001 neon shaking when stopped!
  95. 05 sxt intake
  96. hello
  97. 2000 Neon 2.0L
  98. Please Help, 2k Neon Wont Start!!!!
  99. question about 00' air filter box.
  100. Program Keyless Entry Fob
  101. Aem Cai
  102. 2000 Neon Motor Mounts
  103. HELP ME PLEASE w/2003 Dodge Neon
  104. Just saying hi
  105. side skirts question
  106. Neon rims and tires
  107. Anyone klnow the correct fuel pressure on a `02 Neon????
  108. p0303, Check Engine Light
  109. Color Problems...
  110. Need a new PCM
  111. how to replace the lights in the instrument panel of a 2002 neon
  112. Engine fan question and a few others...
  113. 2k2 Neon Won't Pass Emissions Test
  114. Slight hesitation when accelerating
  115. Check Engine light help.
  116. what should i do
  117. 2000 neon magnum swap
  118. shooting engine codes
  119. Srt-4 motor swap please help
  120. Somebody please help- 2000 Neon issues
  121. help 2001 neon r/t bellhousing
  122. 2002 Neon, no third gear & clunks into drive
  123. 2000 Neon problems
  124. 2000 Neon power door latch/locks
  125. 2000 Neon automatic transmission problem
  126. 2000 Neon replacing tie rod end?
  127. installing a tach on 2000 neon
  128. 2000 neon computer chips
  129. exhuast for 2000 neon
  130. 01 Neon Oil Light
  131. powertrain trouble code help
  132. 2000 Neon Sentry Key Question
  133. 5-spd trans PM
  134. '00 std trans brg noise
  135. 03 problem
  136. 15 inch wheels
  137. Srt-4 cat back exhaust on a 2nd gen neon?
  138. HELP! 2003 Neon Keeps Cutting Off...This is Long!
  139. 19" rims and tire ?
  140. 200 neon le
  141. atx to mtx
  142. 2000 Neon coolant leaking from exhaust
  143. '04 5-spd funky clutch problems... help!
  144. '04 Neon reposessed!
  145. 03 Neon Fuel Gauge problem.
  146. 2002 Neon shifts hard when comming out of drive
  147. Wrecked 2005 Dodge Neon
  148. how to bypass o2 on the cat 2001r/t
  149. 2004 SXT NEON possible bent frame
  150. 2000 Plymoth Neon (Cd player won't work)
  151. 2nd gen DOHC swap
  152. 2nd gen PLEASE HELP!!!
  153. 2003 Doge Neon Question
  154. 02 Neon SE keyless entry
  155. 2000 Neon and P1684 error code
  156. seat cleaning, 2003 Neon
  157. 2001 neon rev limiter
  158. 2005 Dodge Neon SXT
  159. 91 octane gas in R/T model?
  160. 2K3 neon R/T strange noise when cold outside...
  161. '04 Clutch problems
  162. 2000 Neon, backfiring,hesitating,loss of power
  163. 2005 neon tranny conversion....
  164. 01-02 neons
  165. 05 Neon Upgrades
  166. 03 dodge srt-4 wide body kit
  167. Cold Air Intake...04 Neon Sxt
  168. 2002 Neon
  169. SRT-4 front bumper on a 03 neon ?
  170. 2000 Dodge Neon
  171. rim size on 04 sxt
  172. installing Fog lights on 2004 SXT
  173. Does anybody know how to instal a Jet Power Control Module on "00 Neon".......
  174. Check Engine Light '02 Neon
  175. 2000 SOHC Neon
  176. CEL on. running lean, o2 sensors dead??
  177. Is this 2000 Neon worth buying
  178. 2003 neon sxt interior removal
  179. 2000 neon squicky noise, "NEED HELP".
  180. Installing neon lights in a 2004 SXT
  181. 2004 Console Panel
  182. 05 and the dreaded Check Engine Light
  183. water leaking
  184. Crank Position Sensor Location?
  185. 2001 neon motor swap
  186. 2002 Neon won't shift out of 2nd
  187. neon 2001 le ID
  188. 01 Dodge Neon ES
  189. Chip Flasher Help?
  190. 2000 Neon
  191. 2000 neon a/c
  192. intake 4 01 ply neon
  193. 2001 dodge neon doesn't start, ticks
  194. 03 Neon starting mods
  195. Removing Wheel Covers 2000 Neon
  196. Check Engine Light, Car Running Rich???
  197. 01 r/t codes
  198. 2000 - Car moves in park
  199. Whers all the old help??2000 neon front end noise
  200. 2000 neon front end clatter.
  201. 2000 Neon Hit the gas and car goes put-put
  202. 2000 neon transmission fluid
  203. 2002 rpm drop at stop light and dies
  204. 04 Neon/2.0 sx Intake
  205. 01 es swap to srt-4 trany??
  206. 2000 neon turbo and rebuild?
  207. '03 Dodge Neon motor mount problem
  208. '01 neon rt
  209. Power Windows For 04 Neon
  210. Going to buy a 2000 neon with 100k miles
  211. 2ooo Neon Won't start
  212. 2000 Neon with Gas Mileage inmind
  213. 2000 Neon Air Con just stopped
  214. 2002 neon door panel removal
  215. 2000 neon moon roof weatherstrip
  216. 2004 Neon shakes in reverse?
  217. 2001 r/t
  218. 2001 ATX SOHC - Replaced ECU - wont start
  219. 2001 with even more issues
  220. 2001 neon with issues
  221. Adjust the full tire height
  222. 2000 egr location
  223. 2002 neon electrical problems
  224. 2nd gen speaker wire setup help
  225. 2003 Sx2.0
  226. 2003 R/t Questions
  227. 2000 neon engine wont turn off
  228. No Tach instructions have helped me
  229. 04 neon sxt has lots of problems
  230. 2000 Dodge Neon Spark Plug Blew
  231. 2001 Neon tach wire location, color
  232. 2000 Dodge Neon dies sporadically
  233. 2002 neon idle
  234. 2000 neon door lock assembly
  235. 2002 keyless entry
  236. computer sensors for 2002 neon
  237. solid yellow engine light... 01 dodge neon
  238. 2000 neon stalled backing up now won't start
  239. 2000 Plymouth Neon stuck in park
  240. AEM bypass valve
  241. Performance Chip !Help!
  242. 2000 neon 2.0 idle
  243. 01 neon rt headlight problem
  244. 2003 neon sxt questions
  245. !HELP! Will 04 cold air fit 05
  246. Need 05 sxt Exhaust
  247. 2001 exhaust system
  248. 2000 Neon racing and surging.
  249. 2000 Neon Dash and Tail lights wont work..
  250. 2001 Coolant
