View Full Version : 1st Gen 95-99
Pages : [1] 2 3 4 5
  1. Timing belt alignment marks
  2. 1998 Neon Rough Idle/trouble code p172
  3. another 95 neon problem...
  4. Many issues with 95 Neon. Please Help
  5. 97 Dodge Neon engine reving
  6. Back-up light help
  7. No compression after cylinder head service
  8. 98 dodge neon - squealing
  9. 96 neon cruise control
  10. new project need advice
  11. Performance parts suggestions
  12. 95 Neon SOHC Wont Start, Help!!!
  13. Omfg!!! Help!!! I hate champion plugs!!
  14. Rear Speaker Removal???
  15. 96 neon woulnt start
  16. Fuel Pump Issue. HELP!
  17. Seafoam treatment
  18. MAP sensor
  19. car finally gave codes while running rough
  20. Oil drain plug size - '99 Neon
  21. 96 neon tranny problem
  22. keeps blowing 20a fuel fuse
  23. 98 Neon Problem-Rad.
  24. 98 Neon
  25. Transmission troubles
  26. Possible bad PCM?
  27. performance
  28. Odd Speedo Problem
  29. 97 Neon DOHC Oil pressure-Relief valve or bearings??
  30. 97 engine swap wont start
  31. adjusatble cam gear
  32. 1997 2.0 into a 1996 motor swap
  33. 1997 Neon Stick shift stuck
  34. sooo
  35. pics of newly painted valve cover
  36. battery light never goes off
  37. Ignition coil help
  38. 97 starter probs
  39. cam angle sensor
  40. 95 neon caliper lockedup
  41. running rough with engine light on
  42. Odd engine shake when rad fan is on.
  43. Gen 2 to gen 1 engine swap
  44. DOHC in Highline?
  45. 96 neon srt swap
  46. 1997 DOHC neon HARDCORE over-heating!!!
  47. gas/oil in with plugs after change??? help
  48. My Darn Radio
  49. 95 neon pops fuel pump fuse every time
  50. SR20DET In A Neon
  51. Flashing check engine light. Idles ROUGH!
  52. 99 belt slipping
  53. Seems when i'm sriving im in neutral, RPM shoots up but car goes nowere.
  54. ignition lock cylinder
  55. '98 Dodge Neon Sport with back fire
  56. 96 Neon
  57. speedo problems
  58. Code 43 (Misfire) and Ground problems
  59. How Hard Is It To Have A 1ST.SRT-4 Conversion?
  60. Will A MTX PCM Mess With My ATX Any?
  61. SRT-4 Gauge Cluster
  62. SRT-4 Brake System
  63. Temp guage question
  64. Bad motor mount cause for transmission slip?
  65. 98 Plymouth Neon
  66. 1995 neon runnung rough
  67. DOHC Head On SOHC Block...
  68. What Computer System Should I Use?
  69. 60mm TB (Throttle Body) For My SOHC
  70. How?
  71. 1996 Neon, How do I set timing for new belt.
  72. With All This, How Fast Do You Think...
  73. What Is A Good Muffler To Use On My SOHC?
  74. My SOHC Belt Broke (Here's The Story)
  75. pics of Iceman CAI?
  76. What Manifold Parts?
  77. Slave Cylinder
  78. SRT-4 Pedals
  79. Crane Cams Are Gone?
  80. Water In The Trunk?
  81. Will SRT-4 Shifter Fit In 1ST Gen Neon?
  82. If I Buy New Valves For My Head, What Should I Get?
  83. My SOHC Rattle
  84. My Neon Won't Start (Here's The Story)
  85. camshaft end play what do i do now????
  86. 99 Neon sohc wont start
  87. Tell Me Everything I Need For A 5-SPD Swap
  88. Rear Windows
  89. engine mount
  90. Transmission Help (Slipping)
  91. Dome light
  92. Just beginning need info
  93. Shifter cable adjustment
  94. 98 backfires when i accelerate
  95. passing gear lever help.
  96. need a little info...
  97. 99 Dodge Neon- Reposted
  98. Oil leak and Gas leak...
  99. what the largest rim size on a 1.75" drop?
  100. 96 neon fuse problem
  101. 99 Dodge Neon Missing After Multiple Repairs
  102. Transmission Question
  103. Spudders at idle Runs fine driving
  104. 95 neon tail lights blowing fuses
  105. hard to start rough idle
  106. When do you need to replace coil pack..?
  107. please help, 98 neon and maybe a couple answers to idling prob
  108. 95 Neon Runs for 10-20 mins, Start up after 2 hours ??
  109. Problem installing timing belt
  110. Is is possible to check the timing on a 98 neon DOHC?
  111. blowing fuses
  112. My Alternator is Toast
  113. 98 Neon Interior Electrical Problem
  114. 97 Highline won't go into drive
  115. 1995 Neon SOHC Error 42
  116. 98 Neon Starting Failure
  117. idleing problems
  118. interior lighting???
  119. aftermarket gauges
  120. 95 plymouth neon ignition problem
  121. No turn signals/blower motor
  122. well that failed
  123. Shift linkage
  124. Plymouth vs Dodge neon??
  125. 95 Neon Highline won't start???
  126. Need help
  127. Inquiring mind
  128. How to tell if the block is cracked?
  129. eagle talon cams for neon?
  130. 95 dohc cams??
  131. 95 dodge neon
  132. 1998 EX Serpentine Belt replacement diagram
  133. High Idle, 1997 Neon
  134. 95 neon engne swap
  135. EGR .....Get Bent..... please help
  136. starting problem with 95 neon
  137. 95 dodge neon
  138. 95 Neon Starting problem
  139. 97 sohc/dohc piston swap
  140. Speedometer and Gas Gauges Stop Working
  141. Gas Tank Removal
  142. Error Code P0743
  143. missed deer hit ditch airbags deployed
  144. 97 dodge neon highline/custom/fasst--stumped mechanic--HELP!!!
  145. installing a turbo and have no idea what im doing
  146. Neon finally gave up
  147. thrown rod maybe?
  148. Cooling Fan Problem
  149. NO Crank problem
  150. Hood from a sohc fit a dohc?
  151. A/c Problems 1997 Dodge Neon
  152. 1996 Neon Electrical Problem?????
  153. 1995 Neon 2.0 SOHC mild mods with problems
  154. Cooling Problems. Really need help on this one.
  155. 95' Plymouth Neon Gauge Cluster
  156. cylinder head bolt torque?
  157. 98 Neon Air Conditioning Recharge...help.
  158. oil in spark plug tubes
  159. 2 things to look out for on your neon.
  160. Wippers stuck in Up postion
  161. 1997 Neon Water Pump
  162. 96 neon keeps dying on me!
  163. 95 Dodge Neon Concerns
  164. replacement fuel pump
  165. Turn signal problem
  166. what size injectors to use
  167. Factory Roof Rack
  168. 98 neon/sohc died wont start
  169. CODE 11 SOLVED (in this case)
  170. 98 neon shifting and shaking ?
  171. stock tire sizes
  172. neon turbo parts
  173. 99 Neon wont start
  174. replace 95 sohc with 03 sohc?
  175. oil all over 4 spark plugs
  176. 98 dodge neon valve cover spark plug seals
  177. Help with 98 Neon
  178. Bet you can't answer me this.
  179. 95 Neon Fuel Pump Fuse
  180. Power steering pump problems in 99 neon
  181. guages don't work
  182. 95 neon valve help plzzzzzzz
  183. Need Help with my 96 noen
  184. Idle problem
  185. Weird electrical issues
  186. Sagging driver's door
  187. overheating, code 35-cant find fan relay 1996
  188. Stupid alternator! We need help
  189. Need help regarding Rough Idle
  190. Key won't even turn!!!
  191. Need advice on 1996 Neon
  192. more electrical confusion
  193. 96 2.0l Sohc Pushing Out Oil Seals
  194. replaced alternator, still problems!! Help Anyone?
  195. it wont turn over
  196. 98 neon shaky idle
  197. neon....buy it or not??
  198. What is the best way to remove the Alternator
  199. not starting again.. bleh
  200. Heater not working
  201. WTB Crankshaft position sensor pigtail
  202. $300 neon
  203. FS: 98 r/t with full srt swap engine and interior
  204. 95 neon rear vibration/wobble?
  205. neon coilpack check?
  206. Bet You Can't Solve This Riddle, Neon Stalling w/ Check Oil Lite-On
  207. srt4 swap 96 neon
  208. strange problem possibly with 96 neon sohc.
  209. FOR SALE - First Gen Neon Aftermarket Muffler
  210. WTB: Rear Disk Brake Set-up for 1995-2002 Neon
  211. HUGE oil leak
  212. Oil Leak
  213. exhaust
  214. help changing belts
  215. head gasket replacment
  216. Shaking/Squeaking
  217. just bought 99 neon r/t wanna turbo
  218. 95 neon hard starting
  219. 97 Sport With problems
  220. srt-4 gauges
  221. mugen style front lip
  222. '97 DOHC won't idle
  223. Odd noise when warm from engine
  224. Upgrades :)
  225. Weird gas guage
  226. can i re-use short block after timing belt snap?
  227. 96 Neon a couple probs
  228. 1st Gen Neon - 2ed Gen Eclips
  229. 1st Gen Aftermarketpart Sites?
  230. 96 Neon SOHC help
  231. Leak from the hood release lever
  232. 98 Neon Horn location ??
  233. new raditor
  234. 98 Neon Trans Prob
  235. Camshaft Position Sensor???
  236. What's up with my baby?
  237. motor swap
  238. 1997 neon 2dr Stalling abruptly. Starts immediately after key off.
  239. 95 neon brake lights are not working
  240. 1999 Plymouth Neon #3 injector flooding cyl
  241. engine/tranny problem
  242. Neon in need
  243. Gauges not working?
  244. 96 Neon trouble codes and power problem.
  245. Misfire, Can't find cause.
  246. 99 neon suspension
  247. Is this right?
  248. Spark plug tube seals
  249. Headlamps fluttter on and off
  250. 98 starter install
