View Full Version : 1st Gen 95-99
Pages : 1 2 3 4 [5]
  1. 96 SOHC ATX problem after flush/band adjustment
  2. 1995 SOHC Auto Dodge Neon Spec's?
  3. 95 engine problems
  4. 99 neon redline?
  5. Direct Interchangeability Of Fuel Injectors For 2.0 SOHC?
  6. 96 neon LH exterior mirror question
  7. Help changeing 95 neon head
  8. 95 neon wont start
  9. 98 Dodge neon wont start
  10. 98 temp gauge problems
  11. 98 neon leaking oil
  12. 95 dodge neon door problems
  13. 95-99 Dodge Neon Ralli Style Dual Halo Headlights
  14. 99 neon srt, fuel problem/humming noise
  15. Strange problem with my 95 neon
  16. 95 Neon Sport Died Anyone help me ?
  17. Horn Not working
  18. 1998 Trans will not shift
  19. tach is not reading correctly please help!?!?
  20. 98 neon speedometer problems
  21. 1996 Neon will not go in park
  22. speedometer
  23. 96 neon oil leak
  24. Harmonically stuck
  25. Help! broken speed sensor
  26. Is this a head gasket problem?
  27. 96 Neon code 72
  28. Head Gasket Replacement
  29. check engine light
  30. 98 neon... crank too long
  31. LOW IDLE then stalls, need HELP!!!
  32. 97 neon dohc problem!!
  33. '99 Neon Problems
  34. 98 neon runs great for 10 min
  35. timing on a 97 neon
  36. 95 neon. cooling fans run all the time
  37. 99 plymouth neon transmission problem
  38. 1999 plymouth neon fuel pump fuse problem
  39. 99 neon noises!?!??
  40. 95 Dodge Neon HELP!!
  41. 95 neon problem??
  42. 1996 Neon Computer Frys! 3rd in 6k miles!
  43. '95 Neon with codes 27 & 43
  44. Where is the fusable link from the alternator on a 1996 neon?
  45. My 96 Neon won't start
  46. 96neon new alternator not charging, why?
  47. A few small problems I need someone elses opinion on
  48. Wet Floorboards
  49. Who has put a Turbo on a 2L DOHC Neon?
  50. 99 Neon, warning lights
  51. Rear disc brake conversion....
  52. 97 Neon Runs In Reverse-dies In Drive
  53. parking brake 96 neon
  54. 97 neon gas mileage?
  55. 99 dodge neon r/t don't know whats wrong
  56. How hot is too hot? 99 Neon
  57. Stalling 1995 Neon
  58. 1996 Neon ATX HRC Turbo Stage 2 Sedan
  59. 95 Neon starter wiring
  60. 95 neon SOHC surges then stalls when hot
  61. 95 Neon Fuel pump fuse Blows
  62. Oil leak behind motor
  63. Head Gasket Replacement -How To
  64. 96 Dodge Neon won't start
  65. 98 Plymouth Neon - Setting Clock + Speedometer..?
  66. 96 Neon fuel filter & PCV valve
  67. 4g63 noen?
  68. 97 Neon and fuel pump
  69. 99' Dodge neon overheating
  70. 1995 plymouth neon---DEAD
  71. 1995 Neon that stalls at lights
  72. service engine soon light wont go out
  73. Steering
  74. 95 Neon opinion
  75. 95 Neon won't run for long
  76. 95 neon se 2.4 motor swap
  77. 1996 Neon problems - need help
  78. 95 sport V.S 97 Ex
  79. A Guide to Removing/Replacing EGR Valve
  80. 99 Neon missing at all speeds
  81. looking for rims
  82. 95 Neon engine surges at 50 mph
  83. i could use a few suggestions
  84. Transmission...
  85. Engine Question.....
  86. 95 neon/ignition -insert key into start car
  87. interchangeable parts?
  88. 1996 Neon CV Joint/Stalling prob
  89. 95 check engine light
  90. 95 Neon Brakes Problem
  91. 95 neon help please
  92. 95 neon ca. special edition
  93. 98 Neon-panel guages go to off then come on again
  94. A lot of probs with 95 need help
  95. 1999 neon
  96. 95 engine swap
  97. 1999 problems with the A/C
  98. airbags in a 95 neon
  99. 95 neon
  100. 98 Neon highline, transmission problems
  101. 97 Neon Headgasket
  102. 97 Neon
  103. Backseat
  104. 2.4 liter (srt-4) parts on 2.0?
  105. 1995 Neon Engine Dead?
  106. 95 Neon Frustrated
  107. 95 Neon Has Everyone Stumped!
  108. 95 neon, help!!!!!
  109. 96 neon
  110. 95 neon cranks but no fuel or spark
  111. 97 Starter How To?
  112. 1999 neon timing belt replace
  113. 98 Neon R/t - Need Opinions
  114. 95 Neon bogging down, poor acceleration
  115. 97 neon wont start
  116. Which exhaust would you pick?
  117. 1995 neon sohc question????
  118. 1998 Dodge Neon Won't Start Help!!1
  119. Rich mixture with header?
  120. one wiper
  121. 95 neon rattling...?
  122. Problems with 96 neon
  123. 96 SOHC Neon?
  124. 96 Neon coil problems?
  125. 98 neon shift knob...
  126. Skunk Stripes
  127. Wheel Hop
  128. dohc muffler on sohc neon
  129. Pacesetter header?
  130. Racing
  131. 1997 braking problems
  132. 96 Neon - Code 44
  133. Valve Cover Gasket
  134. 96 neon having problems starting
  135. Window stickers
  136. 97 Neon Timming
  137. 95 neon photos
  138. door panel removal
  139. 97 Neon Got problems....need help!!!
  140. 3.55 or 3.94
  141. 95 neon speed sensor
  142. 99 Neon code clearing??
  143. 97 neon
  144. 95 neon shift trouble
  145. 96 SOHC running rough?
  146. 96 SOHC running rough?
  147. 1999 neon oxygen sensor
  148. 95 transmission question
  149. 95-99 Tail Lights
  150. 99 wiring headache
  151. 1996 Neon - reverse lights/hazards?
  152. 2.0 to a 2.4
  153. 97 cluster swap
  154. 98 ACR strut upgrad questions
  155. 96 Neon, Elec Cooling Fan Relay
  156. 1995 Tps
  157. 1996 Dodge Neon Head Gasket question
  158. I Need Help - 1995 Neon
  159. 95 Neon Radiator Fan
  160. 98 neon sunroof
  161. 95 neon has problems
  162. Where is the EGR valve on 95 Neon?
  163. 99 neon codes?? 72
  164. 96 Neon
  165. 97 Neon Code 35 Radiator Fan
  166. 96 sohc neon dies on highway only
  167. 97 Neon Speed Sensor / Odometer
  168. 2.0 dsm swap,ever been done before?
  169. 4th & 5th Gear pop out while driving
  170. Speakers
  171. 95 Neon- my endless $ pitt.....
  172. 95 Neon Engine Light....anybody have the codes??
  173. 98 Neon R/T Questions...
  174. can I put dohc head on sohc engine?
  175. Water Leak in '97 Neon
  176. Code 25 Neon 95
  177. 95 neon timing belt urgent question
  178. 95 Neon Problems
  179. standard radio removal from a 95 neon
  180. ?'s on Head Gasket
  181. 1995 Neon - Code 43
  182. 1996 Neon >>> Stereo Question
  183. 96 neon radiator fan won't shut off
  184. 1995 Foglight Bulbs
  185. 95 Engine Swap
  186. 97 headlight prblem
  187. Neon instrument cluster troubles
  188. '95 Plymouth Neon Error Codes
  189. 98 Neon Axels?
  190. Howell Crate engines
  191. turbo on automatic?
  192. 1st gen Neon diagnostics codes
  193. 99 dodge neon tranny problem
  194. 1995 neon shakes when driving
  195. NEON 95 cranks, but will not start. Please help
  196. 98 Neon-Transmission Problem?
  197. 99 Dodge Neon Loaded, CF hood, bdy kit, more MINT!
  198. oil pan replacement
  199. '97 neon knocking --car problems
  200. 95 Plymouth Neon
  201. neon's transmission
  202. 97 Neon Starting Problem
  203. 97 neon
  204. 97 dodge neon
  205. 1st gen DOHC timing pics
  206. timing belt
  207. Clear Third Brake Light
  208. 98 neon stock turbo
  209. 5 speed conversion
  210. 95 neon problem?
  211. ***Just bought xenon bulbs and need help***
  212. 96 wondows ratteling
  213. 98 neon wires?
  214. '95 Neon 'Check Engine' light on
  215. 95 Neon engine swap
  216. I have a 1996 Neon
  217. Speedometer not working???
  218. 97 Buick Speedometer Jumps while in park
  219. Mattz Neon... And it continues...
  220. NEED HELP PIMPING OUT MY 97' NEON....any suggestions? NO WEAK SHIT EITHER
  221. Window Noise
  222. Accessories for the 95-99 Neon
  223. 97 neon overheating........
  224. 95-99 Neon Intruder Body Kit...
  225. Metallic Floormats on the 95-99
  226. 98 neon.... timing belt???
  227. Fuel Efficiency
  228. Help Please?!
  229. advice: buying 95 neon highline
  230. Enigine Swap
  231. 95 dodge neon stalling
  232. dodge neon sport
  233. hey guys im looking for a euro-kit for my neon anyone got one???
  234. help
  235. Another Tire Question
  236. anyone have reliability problems?
