View Full Version : 1st Gen 95-99
- 98 Neon Sport problems
- Exhaust
- 97 Dodge Neon 16 vavle keeps dieing
- 1995 neon transmission
- 96 neon problem list
- 1st Gen Neon manual transmission stuck. Am I screwed?
- Hard Starting
- right turn signal not working........
- Does neons set off the oil light if it gets low on oil or just when pressure drops?
- performance garages? CAI?
- Lean Fuel Mixture on 96 Neon
- I took my '98 Neon
- 98 neon tranny trouble
- ditching the a/c
- 95 Neon
- Engine Noise after water pump replacement
- 98 sport, no start.
- Hard to start
- Neon/Avenger engine interchange?
- Does anyone know of a way to clean stock....
- 1995 Neon Cruise Control
- 98 neon sport
- put a fart can on
- Rack&Pinion for 98 Neon
- what kind of turbo?
- ground problem
- clutch fluid?
- Gauges don't work at all
- 95 neon wont start need help code 35...42
- She'll just die
- 95 neon fuel pump or wiring problem
- 97 neon burnout!
- Muffler Question
- where is the fuse for the ciggerate lighter?
- no more problems...again
- Neon "Projector" headlights
- steering problems
- 99 Plymouth Neon Car is Knocking/ Shaking
- intermittent stalling when cold,code 11
- transmission sludge
- Just boughta 98 Neon
- 1996 Neon starting problem
- 95 neon starting troubles
- 97 neon starting trouble
- power chip question
- Dash Needles Not Working Properly
- transmission fluid
- Doing swap will this work???
- Need Help.. Rad fan not kickin in
- 97 neon pcv valve how to
- Front end question
- dead neon, and i'm confused
- no more engine problem!!!!!..thanks everyone
- Auto start on a 1996 Neon
- Engine problems
- ebay short throw shifter
- 95 neon no accelleration
- 96 plymouth neon engine swap
- new head?
- 98 Neon Crank Pulley
- Hahn turbo kit
- 96neon pcm ?
- PCV location 96 neon
- 96 PLYMOUTH neon problemS
- Headlight switch
- motor bulid
- clicking noise
- Headlights won't turn off
- 99 neon multiple misfire HELP
- Neon doesn't start.
- 2004 srt-4 turbo/1998 2.0L neon
- Speedometer not working
- 95 neon turning problem
- Underdrive Crank Pulley
- 2.0 interchangabilty with 2.4
- 1997 plymouth neon engine noise
- Motor reving
- Reader's Opinions - '97 Ply Neon - Opinions of car?
- Neon motor build
- 97 Neon will not start
- 96 Neon sohc intermittant no start
- 95 Neon auto transmission trouble when cold
- 98 Neon 2.0 DOHC Starting Problem
- Transmission swap question
- 97 neon problem
- 96/srt-4 Turbo Engine Swap Help Please!!!!!!!!
- Thinking About Buying 1997 Neon - Help!
- 2.0 turbo vs 2.4 turbo swap
- 2.2 turbo II turbo and wastegate??
- first gen intake manifold
- Motor Mount Question!
- bottle question
- 1995 Dodge Neon!!!!! Help!!!!!
- Turbo interchangeability
- EGR Valve replacement
- My neon Spudders
- 96 neon engine swap
- 2.0 non turbo
- 95 neon bubbling reservoir
- Subing a Neon
- 99 rt engine swap question
- 1999 Neon shakes & jerky at 50 mph
- what does sohc and dohc stand for?? which do i have??
- A Few Neon Questions
- 96 Neon AT, Help, Reverse Lights Out
- 98 Neon with a stall problem
- 96 neon brakes
- My neon spits and gurgles
- 95 sohc to 98 dohc acr swap, problems please help!!
- 1996 Dodge Neon won't start how do I remove the starter
- 92 mitsubishi eclipse-is it easy to swap out a SOHC 1.8 with a DOHC 2.0/ or TURBO???
- performance intake manofold?
- 1999 dodge neon rough running at low speeds
- speedmeter DEAD!!!!
- Which wheels fit?
- 99 neon with SRT-4 suspension
- The "TAO" of the Neon...long post!
- Gauges don't light up
- 1996 Plymouth Neon
- 1995 Neon Quits After a couple hours driving
- 96 Dodge Neon
- 95 Plymouth Neon
- 95 neon hard to start
- 97 neon tech manual complete pdf
- 96 SOHC neon won't start!!!!
- Code 55
- 1995 neon sport car wont start
- 97 NEON DIES. Confused. Need help.
- 96 Neon Computer Pin-out Map?
- SRT-4 engin in my neon 95??
- rims and tires for my '95 neon???
- my 95 neon won't start
- 96 Neon Fuel Pump
- Coming hard off the clutch?
- 98 Neon Hook-Up Underway!!!
- 95 neon struts
- 97 Neon, I want to install a CD player...
- my 95 neon engine?
- 95 SOHC, alternator specs?
- 95 neon security issues
- 96 neon tranny pump!! help!!
- Electrical problem - any ideas?
- Cylinder head etc
- Power Window does not work!!
- 98 Neon Questions
- Loud noise from hood 96 neon
- "Button" stuck on 96 Neon shifter (auto)
- Considering buying a 97 Neon
- #3 cylinder missfire
- 97 Neon Harness
- 97 Neon 10 - 15 min runtime
- 1999 Neon R/T missing
- 3 speed auto
- 97 neon Auto top speed?
- 97 neon needs answers
- 95 neon
- 1995 neon fan probelms
- 95 Neon ignition issues, Please help!!!
- 95 Transmission Issues
- Dodge Neon 1995 SOHC problems
- Dodge Neon 1999 Oil Pan
- Dodge Neon 1999 how to change time belt
- Dodge Neon 1999 Oil leak
- 98 neon- weird stuff in spark plug tubes
- 95 Neon - code 25
- 96 Neon-Head Gasket still an issue?
- 4g63 swap or hahn turbo kit
- Dodge Neon 1999 hot temperature
- Just bought a 95 neon
- 4g63 swap
- Neon 1999 Oil Leakage
- Why does my 95 neon suck so much gas?
- 95 neon dies mysteriously
- 95 dodge neon tach wire location and color
- '97 neon - been through 3 batteries! help?!
- 96' Stereo Issues
- '98 Neon headgasket job, kind of off-topic question
- 1998 Neon Sport RPM??
- 95neon passing gear ajustment
- 95 sport vs. 95 regular
- 4g63 motor swap 2 1st gen dodge neon
- 96 Neon Instrument Cluster Problem
- 97 dodge neon random misfire
- 99 Weather strpping
- 414hp 1g
- 95 neon instrument interchange???
- srt-4 turbo and manifold on 1st gen dohc
- 1st Gen Neon Tach Install
- EGR?? what and where?
- 99 neon crankshaft damper
- 97 Neon, 90K, Having speedometer issues!
- Gauge installation question
- 1997 neon fan problem
- 95 neon need wiring diagrams
- 95 neon problems
- 95 Neon runs bad please help
- $$$ Engine Pricing
- 96 neon/electrical problem
- Replacing Clutch in 95 Neon
- If anyone knows about exhaust please read this!
- 95 Neon Clutch Problems
- My 95 Neon Is Running Horrible!
- 96 neon fuel gauge dosen't work
- My 96 neon's speedometer won't work!
- HELP! '96 Plymouth Neon - Hi O2, but PCM still sending rich command!
- 95 Dodge Neon Problems
- 97 dodge neon I need advise
- 95 plymoth neon computer
- '95 Neon Running poor
- hard start, engine bogs down
- 1995 eng code 37
- 95 Neon Having Problems
- 95 Neon Misfiring and Stalling
- Tachometer Problem
- My 1996 Dogde Neon Won't Start
- 1995 Neon gauges dead... help!
- flickering headlights in 95 Neon
- 1995 doodge neon hunting problem
- 96 SOHC ATX problem after flush/band adjustment
- 1995 SOHC Auto Dodge Neon Spec's?
- 95 engine problems
- 99 neon redline?
- Direct Interchangeability Of Fuel Injectors For 2.0 SOHC?
- 96 neon LH exterior mirror question
- Help changeing 95 neon head
- 98 Dodge neon wont start
- 98 temp gauge problems
- 98 neon leaking oil
- 95 dodge neon door problems
- 95-99 Dodge Neon Ralli Style Dual Halo Headlights
- 99 neon srt, fuel problem/humming noise
- Strange problem with my 95 neon
- 95 Neon Sport Died Anyone help me ?
- Horn Not working
- 1998 Trans will not shift
- tach is not reading correctly please help!?!?
- 98 neon speedometer problems
- 1996 Neon will not go in park
- speedometer
- 96 neon oil leak
- Harmonically stuck
- Help! broken speed sensor
- Is this a head gasket problem?
- 96 Neon code 72
- Head Gasket Replacement
- check engine light
- 98 neon... crank too long
- LOW IDLE then stalls, need HELP!!!
