View Full Version : 1st Gen 95-99
- Looking for oem cams
- Steering squeal
- Swap sohc 16v for dohc in 97 manual tranny
- 1997 speedo help
- Cam Gears, Magnaflow Exhaust
- Yet another starting problem...
- Won't Start. Pops into neutral
- looking for a place to get dyno tuned. pittsburgh area
- need help
- Neon main seal
- 1999 ply. neon SOHC cam position sensor
- Please help, runny funny, key flick code
- new car stereo blows a fuse.
- 96 Neon Sport Fuel Sending Unit
- 98 Neon missesd at idle
- car turns off
- Friend in wreck, need new hood.
- cranks no start
- 96 Neon Sport Diag Codes
- 96 Neon Sport gas gauge problems
- RPM's slow to back off between shifts.!
- 1st Gen FAQ's
- 99 Neon DOHC won't start
- Woohoo I fixed the radiator!!
- Battery light on dash!!!!
- freebies?
- 95 neon code 44
- torque spec
- rocker arm torque 96 neon?
- turning right what the f*ck
- Crusie Control
- Where Do's This Ground Wire Go???
- crank
- 1998 Neon Rad Fan not coming on
- So I had to repair the radiator...
- wont start need help
- neon doesnt want to shift right away
- 97 neon dies randomly code 12
- headlight bulbs...
- 95 clunking noise and wheel play...
- Check Engine Light & Hesitations
- code 72
- Suspension issues
- Self Radiator repair?
- car stumbles then dies
- turbo questions!!
- 1999 neon highline shoc
- Quick neon question for a friend
- 96 neon trouble codes
- stealth .... neon??
- Alternator replacement
- water pump replacement
- car shuts off/ only starts sometimes
- Injectors
- would this work??
- Need some advice...
- What is best way to get to alternator?
- Codes after timing belt change
- New front, left axle options; help me decide
- where is torque converter solenoid located?
- tourqe converter lock up
- 1997 Dodge Neon - Crazy problem, dont think any1 is goin 2 know what 2 do but plz try
- 97 Dodge Neon Tie Rod
- srt4 exhaust
- Bad ECU, 97 Neon.
- 95 non ac radiator (half sized)
- pimping a 96 neon
- Has anyone done a SOHC Magnum head swap?
- Need to change the Front Strut Mounts
- Fuel System Problem
- 1998 Noen Going Bonkers!
- new project
- radiator fan relay?
- the longest lasting brake pads
- neon 97 wheels over heating melting hubs
- 95-98 engine swap
- 1995 front wheel bearing suggestions
- switch in the ecu
- problems?
- 2.4 swap help?
- fuel pump?
- 96 neon help
- Bad Efficiency
- DIY 3.0L Intake
- Help Me PLEASE My Neon Shifts hard
- Clicking and grinding on the front end
- Neon Engine issues
- help!!!!
- yeaaa.. emissions and exhaust problems
- removing hand brake
- Mopar gear oil for 1995 Dodge Neon is expensive!
- 95 Neon Surges
- Cylinder #2 not firing
- Suggestions for rough running 1996 plymouth neon
- 1996 Dodge Neon Transmission
- transmission troubles
- oil around #4 sparkplug
- exhaust....?
- Mopar Performance PCM
- Problems with overheating
- Problems after 60k maintenance
- HELP!!98 Dodge Neon SPORT DOHC; where are the timing marks
- 97 neon Code questions
- How do I replace my starter?
- Radiator Fan Problem
- i have a 2.0 sohc and i want to swap with a srt4 neon engine
- Overheats when air conditioning is on
- Overheating when engine off..weird
- I drove my Neon for the first time in 16 months!
- Just got my Neon
- Rebuilt Motor Leaking From Head - Why?
- would you use this??
- neon, cooling fan(s) continue to run
- 97 plymouth neon will not turn on to start
- Installed new Clutch Cable! HOORAY!
- How to Replace 2.0 DOHC EGR Valve
- problem when driving
- 99 Neon Overheating on hwy
- awww my poor baby
- 98 ac problems
- Worth racing an ACR Neon?
- Looking to get a Neon
- Help! Problems after clutch install
- 1999 Neon DOHC Problems
- 1998 inconsistent starts
- 96 Dodge Neon shifting problem
- 1997 Dodge Neon SOHC radiator fan relay
- Irregular engin activities and engine codes
- Dead gauges .... speed, gas and temp all read zero no matter what.
- head bolts ??
- Unknown connectors Dodge Neon
- Anyone having problems with their Speedo?
- no ac compressor or power steering
- misc gen 1 parts for sale
- 1998 Neon A/C doesn't work - Need Help!
- 98 Neon water pump and timing belt
- gear problems
- What goes on end of clutch cable?
- Wiring Halos
- neon reliability?
- 98 Neon Trunk Light
- Ignition Lock Cylinder
- Removing stock tape deck from 98 Neon
- performance?
- 98 Plymouth Neon problem
- 2.0L sohc to 2.0L dohc conversion questions
- Piston
- Window Crank
- 95 Neon Ignition Switch Jammed
- 96 Neon Start Problem
- Exhaust question!
- Wired sandy metal noise when driving (95 Neon)
- 95 Neon Gauge Problem
- 95 Neon hard starts
- 95 neon won't hold a charge
- No AC in 97 Neon
- 92 Neon will not go in reverse
- 95 sohc rebuild
- 98 NEON running issue
- airbag and horn problems
- 95-99 neon question
- grounding hub install
- 95 neon
- 95 Neon Check Engine (Code 12,Code 21)
- Running
- Cruise Control, 1997 Neon
- Death of a Neon
- Safc Ii
- Head Gasket Help!!!!!
- wont turn over, need help with gauges too
- 1995 code 43
- Please help me find a left motor mount (transmission) 1995 Dodge Neon standard
- exhaust question....
- compression
- 98 voyager motor into 2005 neon???
- TEMP Gage wacks out and my car doesnt start unless I tap the nut on the starter
- water looks muddy
- 99 Neon-CEL on and here's the fault code
- 99' r/t computer problems
- oil pans compatable?
- what do you guys think of my mirrors?
- 96 Plymouth Neon Won't Start
- 95 neon wont go over 55
- Don't buy the Pacesetter Exhaust
- it says to connect to parking lights
- '97 Neon's Paint Peeling Off !! --> Is this common?!
- 96 neon 5 speed clutch question
- 97 Neon transmission problem
- starter problems 95/98 dohc
- 98 neon CS help please!
- how much tranny fluid?
- little shock when i close the door
- reverse switch on a 97 Neon
- 95 Neon Dying Out Codes 24 and 31
- My 97 dodge neon
- Non Power accessories to Power
- Help...99 Dodge Neon
- 96 neon wont start (something with electrical) pleaaaase help!!!!
- Rockers and Lifters
- 97 dodge neon having overheating problem
- 99'sohc-loud tapping for 1 minute at start
- drilled slotted rotors
- 96 neon (service engine soon)
- 98 Neon will nt start
- 1998 neon auto help
- no back up lights
- Engine/transmission swap procedure help
- 02 delete
- engine timeing
- Porting intake manifold
- 96 Neon Trouble Code 72
- Window adjustment
- a few questions
- '95 Neon problem
- Battery box sensor
- Dies out after it starts
- Auto Tranny Valve Body replacement advice?
- Quick Neon Question
- What is that clunking??
- 97 dodge neon
- 95 dodge neon hard to start
- nitrous
- lol code 31?
- Motor building help
- I wants others opinions PLEASE! 98 neon rims..
- problems with my 96 neon expresso 4dr sohc
- defrost froze???
- Fixed headlights and now this....
- "Neon Knock"
- 96 neon won't start, blows fuel pump fuse
- Clutch problem on '96 SOHC
- transmission gasket, use or don't use?
- 95 neon engine shut down and will not start
- map+iat sensor question 95 sohc neon
- Anybody want a non-modular stage 3 clutch?
- plymouth neon tranny trouble
- code p0743 help!!!
- How do you torque the lugs???
- aluminum flywheel help!
- 95 neon fan problems
- possible pcm problems???
- damn f*ckin thing
- 95 neon flash out codes
- just started
- were can i buy cheap headers for a 96 sohc neon
- 95 Neon Sohc problem
- cooling fan operation
- I might be buying a 1998 Dodge Neon..Need your advice.
- Auto Tranny Trouble 98 sport (follow up, and question)
