View Full Version : 1st Gen 95-99
Pages : 1 [2] 3 4 5
  1. srt4
  2. 98 Neon
  3. i need major help with my 1998 neon expresso
  4. cooling problems
  5. What should I aim for?
  6. 97 skyline wanna hook it up
  7. car won't start
  8. 1997 Neon trouble code P0743???
  9. 98 ATX Shifter shaft keep freezing
  10. 96 Neon parking lights/console lights not working
  11. Hot Rod Neon Q's
  12. wiper..broken, not multifunction switch
  13. 1995 Neon Engine Noises
  14. 98 neon overheated, won't start
  15. Engine Swap
  16. Transmission Trouble??? HELP!!!
  17. Airbags
  18. 1997 Neon power problem
  19. Fuel Pump Problem??? 1997 neon
  20. what to do?
  21. 1995 Neon Help Please
  22. Newbie with a problem!!
  23. ac/belt help please
  24. 98 Neon-- No power
  25. 1996 Neon Want to make it posi. ???
  26. 98 neon HLP
  27. 98 dohc timing belt sounds like wood chipper
  28. Shaking steering wheel problem
  29. megasquirt
  30. srt-4 swap
  31. Exhaust work need some Assistance
  32. major help soon
  33. Borla exhaust?
  34. 18mpg?
  35. Help with O2 Sensor
  36. 96 neon running really rough
  37. new here please help 96 SOHC dies
  38. Timing
  39. Battery Relocation question
  40. 95 Neon Performance Mods?
  41. 95 Neon Block 4g63?
  42. head throttle body upgrade???
  43. Obx Lsd Issues Help!
  44. inconsistent overheating...puzzling problem
  45. 1999 plymouth neon clutch release cable
  46. 97 dodge neon wont start
  47. 95 transmission
  48. Hit brake, turn signal lights up???
  49. Help
  50. 99 Neon Overheated ... now won't start
  51. im having some engine problems
  52. Lots of parts..turbo kit..wings west kit..misc parts for sale
  53. 97 neon will not start, neeed help asap
  54. AC clicking..?
  55. Won't start
  56. 98 neon
  57. Moving Sale - 1st gen parts
  58. S.O.S. Help With Neon
  59. speed limiter
  60. got hit while parked
  61. 96 Neon Help!
  62. problems with my neon....
  63. Is This Right
  64. Speedometer with a mind of its own
  65. 99 neon tranny problems
  66. 98 Neon 2.0 SOHC
  67. need help
  68. help! air conditioning..
  69. AC condensor..
  70. falls out of gear
  71. 95 Neon wont start HELP!!!!!!!!!
  72. clutch = hydraulic?
  73. oil leak on 99 dodge neon 2.0 dohc
  74. gas mileage?
  75. body parts interchangable?
  76. 96 Dodge Neon Speedo not working
  77. NoFireNeon(code43)
  78. 1998 plymouth neon problems neeed advice asap!
  79. hey all neon fellows..
  80. head gasket replacement cost?
  81. Neon 96 with three codes...
  82. Improvements to my 96' Neon
  83. 98 Radiator size question - Mexico / USA
  84. '99 DOHC to '98 SOHC
  85. spark plug wires
  86. News on Turbonator
  87. Exhaust
  88. Help with 98 neon starting problem
  89. gear oil for 98 neon 5 speed
  90. Door Ajar Light?
  91. Weak E-Brake?
  92. 98' Neon Door Panel Removal?
  93. turn signal lever
  94. Transmission bands ?
  95. Battery compartment sensor ?
  96. pcv valve installation
  97. Temperature Gauge
  98. Fuel Pump fuse keeps blowing. Is it a short or the fuel pump?
  99. my car won't start why?
  100. Guages
  101. parting out 95 dodge neon sport sohc
  102. Air Conditioning??
  103. 1995 Plymouth Neon Turns Over, But Won't Start
  104. how much you think i can get
  105. check engine light not working
  106. Neon Problems Dont Know What Else To Fix??!!help!!
  107. After market gauge hook up?
  108. Electrical problem or mechanical problem?
  109. 96 plymouth neon wit upgrades for sale
  110. 1995 Dodge Neon ACR Part Out!!!!
  111. 99 Neon Camshaft Seal Popped Out-Major Oil Leak
  112. 96 2.0 no Start
  113. engine swap 2.0 dohc to a 3.0 dohc?
  114. WTB '96 Neon Engine
  115. Fuel pump
  116. Problems with 98 Neon
  117. After market engine question
  118. is this intake worth it
  119. 1998 plymouth neon expresso engine specs
  120. 1995 SOHC Automatic transmission issue
  121. Engine Shake, any ideas?
  122. Motor mounts!
  123. Lend Me some help plz!!!
  124. shock or cushion like spring that conects on the underside of the back I NEED HELP?
  125. Cant get it in . . .
  126. Fuel Pump Replacement - easy job? Newbie
  127. Engine Swap-98auto to a 95 manual?
  128. RadiatorLeak/overheating
  129. 95 neon
  130. 95 Neon, No clutch peddle
  131. juss got a question!
  132. 95 trans
  133. Wtb Neon
  134. egr blocked / bad gas mileage / 1997 dodge neon
  135. what is wrong?
  136. Water Pumps Rebuilt or Dealer?
  137. capable power
  138. Gas in Oil Help
  139. Are Coolant Bottles on 1st Gen interchangable?
  140. What's wrong with this car
  141. Can Bad Rotors Cause A Shimmy or Wobble?
  142. 2.0 to 2.4 swapable parts
  143. OBD II trouble code
  144. Car won't start - Alarm system at fault?
  145. Owners Manuel - Gas tank size
  146. water pump
  147. sun roof/moonroof needs fixed
  148. 99 neon and has no acceleration
  149. Crankshaft Pulley Bolt
  150. Anyone have an Engine for a 97 Neon?
  151. Fuel gauge and service/maintenance
  152. Overheating Neon ???
  153. Code 42
  154. overheating ???
  155. Gauges are acting funny
  156. need tail lights for 98 neon
  157. Just got a Neon and have some questions
  158. engine problems
  159. Oil Leak
  160. 98 plymouth neon engine codes
  161. stalled. now cranks, no start
  162. Supposed Timing problems..... a tad lengthy.
  163. 96 Dodge Neon dies after warm-up
  164. No start after engine rebuild...
  165. Automatic neon drive problem
  166. 97 Neon not starting
  167. HELP !! Can you covert a sohc to dohc?
  168. Newbie Neon ? - Clutch spring has come off!
  169. Auto Dynasty
  170. Headlight lens cleaner
  171. Cold air intake that looks like the iceman
  172. 1998 Plymouth Neon
  173. neon help
  174. neon help
  175. Do struts have fluid in them? Or are they gas filled? And yes, I know...
  176. Cold air intake
  177. Radiator replacement 98 Neon
  178. 99 plymouth neon fan belt
  179. coolant codes on 95 neon
  180. no results
  181. Rear Strut: Do I Throw The Car Away Now?
  182. Fuel problems...
  183. where is it?
  184. 96 neon coolant leak
  185. PCM issue
  186. Alternator upgrade
  187. Starter
  188. OBDII code p0401
  189. Question???
  190. For Sale 2 Neons
  191. just a few questions
  192. 1995 Stabilizer bar Came Apart on Freeway
  193. looking for a neon as a project car
  194. 97 Neon left rear brake locked up
  195. 1999 ply. neon code 42
  196. Axle Replacement
  197. Manual transmission fluid??
  198. engine help
  199. helppp wiring probs!!!
  200. Needs a 16v dohc for 98 neon sport
  201. Narrowed down
  202. anyone?
  203. SRT 4 Turbo package on 1st gen
  204. My kid has one now I want one too!
  205. 1995 2.0 engine swap
  206. hot cams for dohc?
  207. Cat
  208. I need a fuel pump . . . i think
  209. Neon Power??
  210. A new problem
  211. I have a few questions about my 97 SOHC neon
  212. 97 dohc to 96 sohc engine swap need help
  213. 95 Standard SOHC Engine Pinging
  214. Alternator
  215. crack in the block
  216. Help!
  217. what would you do.?
  218. 95 neon sputters in mid-range
  219. turbo setup question
  220. lowering springs
  221. Fuel Fuse Issues, 1996 Dodge Neon
  222. please help me
  223. neon 95 question
  224. My floor's all wet.
  225. coilovers
  226. Getting a neon
  227. My car won't start.
  228. eyebrows
  229. dimmer switch?
  230. Idle speed??
  231. Alternator bearings
  232. Overheating fuel pump?
  233. help me please
  234. All kinds of ugly . . .
  235. headgasket
  236. vogtland
  237. Coil Pack replacement? Sputtering.
  238. wont start need help
  239. Engine dies
  240. i hate robbers lol
  241. '98 Neon for sale: $2,500 OBO
  242. Gauges don't work
  243. Pulley?
  244. gauges
  245. 95 shifter question
  246. Easy way to Remove airbox from my DOHC 97?
  247. rms question
  248. Please help!!!!!!
  249. Dynamax or Magnaflow Exhaust
  250. neon won't run after warm up
