View Full Version : 1st Gen 95-99
- 97 Dodge Neon engine reving
- Back-up light help
- No compression after cylinder head service
- 98 dodge neon - squealing
- 96 neon cruise control
- new project need advice
- Performance parts suggestions
- 95 Neon SOHC Wont Start, Help!!!
- Omfg!!! Help!!! I hate champion plugs!!
- Rear Speaker Removal???
- 96 neon woulnt start
- Fuel Pump Issue. HELP!
- Seafoam treatment
- MAP sensor
- car finally gave codes while running rough
- Oil drain plug size - '99 Neon
- 96 neon tranny problem
- keeps blowing 20a fuel fuse
- 98 Neon Problem-Rad.
- 98 Neon
- Transmission troubles
- Possible bad PCM?
- performance
- Odd Speedo Problem
- 97 Neon DOHC Oil pressure-Relief valve or bearings??
- 97 engine swap wont start
- adjusatble cam gear
- 1997 2.0 into a 1996 motor swap
- 1997 Neon Stick shift stuck
- sooo
- pics of newly painted valve cover
- battery light never goes off
- Ignition coil help
- 97 starter probs
- cam angle sensor
- 95 neon caliper lockedup
- running rough with engine light on
- Odd engine shake when rad fan is on.
- Gen 2 to gen 1 engine swap
- DOHC in Highline?
- 96 neon srt swap
- 1997 DOHC neon HARDCORE over-heating!!!
- gas/oil in with plugs after change??? help
- My Darn Radio
- 95 neon pops fuel pump fuse every time
- SR20DET In A Neon
- Flashing check engine light. Idles ROUGH!
- 99 belt slipping
- Seems when i'm sriving im in neutral, RPM shoots up but car goes nowere.
- ignition lock cylinder
- '98 Dodge Neon Sport with back fire
- 96 Neon
- speedo problems
- Code 43 (Misfire) and Ground problems
- How Hard Is It To Have A 1ST.SRT-4 Conversion?
- Will A MTX PCM Mess With My ATX Any?
- SRT-4 Gauge Cluster
- SRT-4 Brake System
- Temp guage question
- Bad motor mount cause for transmission slip?
- 98 Plymouth Neon
- 1995 neon runnung rough
- DOHC Head On SOHC Block...
- What Computer System Should I Use?
- 60mm TB (Throttle Body) For My SOHC
- How?
- 1996 Neon, How do I set timing for new belt.
- With All This, How Fast Do You Think...
- What Is A Good Muffler To Use On My SOHC?
- My SOHC Belt Broke (Here's The Story)
- pics of Iceman CAI?
- What Manifold Parts?
- Slave Cylinder
- SRT-4 Pedals
- Crane Cams Are Gone?
- Water In The Trunk?
- Will SRT-4 Shifter Fit In 1ST Gen Neon?
- If I Buy New Valves For My Head, What Should I Get?
- My SOHC Rattle
- My Neon Won't Start (Here's The Story)
- camshaft end play what do i do now????
- 99 Neon sohc wont start
- Tell Me Everything I Need For A 5-SPD Swap
- Rear Windows
- engine mount
- Transmission Help (Slipping)
- Dome light
- Just beginning need info
- Shifter cable adjustment
- 98 backfires when i accelerate
- passing gear lever help.
- need a little info...
- 99 Dodge Neon- Reposted
- Oil leak and Gas leak...
- what the largest rim size on a 1.75" drop?
- 96 neon fuse problem
- 99 Dodge Neon Missing After Multiple Repairs
- Transmission Question
- Spudders at idle Runs fine driving
- 95 neon tail lights blowing fuses
- hard to start rough idle
- When do you need to replace coil pack..?
- please help, 98 neon and maybe a couple answers to idling prob
- 95 Neon Runs for 10-20 mins, Start up after 2 hours ??
- Problem installing timing belt
- Is is possible to check the timing on a 98 neon DOHC?
- blowing fuses
- My Alternator is Toast
- 98 Neon Interior Electrical Problem
- 97 Highline won't go into drive
- 1995 Neon SOHC Error 42
- 98 Neon Starting Failure
- idleing problems
- interior lighting???
- aftermarket gauges
- 95 plymouth neon ignition problem
- No turn signals/blower motor
- well that failed
- Shift linkage
- Plymouth vs Dodge neon??
- 95 Neon Highline won't start???
- Need help
- Inquiring mind
- How to tell if the block is cracked?
- eagle talon cams for neon?
- 95 dohc cams??
- 95 dodge neon
- 1998 EX Serpentine Belt replacement diagram
- High Idle, 1997 Neon
- 95 neon engne swap
- EGR .....Get Bent..... please help
- starting problem with 95 neon
- 95 dodge neon
- 95 Neon Starting problem
- 97 sohc/dohc piston swap
- Speedometer and Gas Gauges Stop Working
- Gas Tank Removal
- Error Code P0743
- missed deer hit ditch airbags deployed
- 97 dodge neon highline/custom/fasst--stumped mechanic--HELP!!!
- installing a turbo and have no idea what im doing
- Neon finally gave up
- thrown rod maybe?
- Cooling Fan Problem
- NO Crank problem
- Hood from a sohc fit a dohc?
- A/c Problems 1997 Dodge Neon
- 1996 Neon Electrical Problem?????
- 1995 Neon 2.0 SOHC mild mods with problems
- Cooling Problems. Really need help on this one.
- 95' Plymouth Neon Gauge Cluster
- cylinder head bolt torque?
- 98 Neon Air Conditioning Recharge...help.
- oil in spark plug tubes
- 2 things to look out for on your neon.
- Wippers stuck in Up postion
- 1997 Neon Water Pump
- 96 neon keeps dying on me!
- 95 Dodge Neon Concerns
- replacement fuel pump
- Turn signal problem
- what size injectors to use
- Factory Roof Rack
- 98 neon/sohc died wont start
- CODE 11 SOLVED (in this case)
- 98 neon shifting and shaking ?
- stock tire sizes
- neon turbo parts
- 99 Neon wont start
- replace 95 sohc with 03 sohc?
- oil all over 4 spark plugs
- 98 dodge neon valve cover spark plug seals
- Help with 98 Neon
- Bet you can't answer me this.
- 95 Neon Fuel Pump Fuse
- Power steering pump problems in 99 neon
- guages don't work
- 95 neon valve help plzzzzzzz
- Need Help with my 96 noen
- Idle problem
- Weird electrical issues
- Sagging driver's door
- overheating, code 35-cant find fan relay 1996
- Stupid alternator! We need help
- Need help regarding Rough Idle
- Key won't even turn!!!
- Need advice on 1996 Neon
- more electrical confusion
- 96 2.0l Sohc Pushing Out Oil Seals
- replaced alternator, still problems!! Help Anyone?
- it wont turn over
- 98 neon shaky idle
- neon....buy it or not??
- What is the best way to remove the Alternator
- not starting again.. bleh
- Heater not working
- WTB Crankshaft position sensor pigtail
- $300 neon
- FS: 98 r/t with full srt swap engine and interior
- 95 neon rear vibration/wobble?
- neon coilpack check?
- Bet You Can't Solve This Riddle, Neon Stalling w/ Check Oil Lite-On
- srt4 swap 96 neon
- strange problem possibly with 96 neon sohc.
- FOR SALE - First Gen Neon Aftermarket Muffler
- WTB: Rear Disk Brake Set-up for 1995-2002 Neon
- HUGE oil leak
- Oil Leak
- exhaust
- help changing belts
- head gasket replacment
- Shaking/Squeaking
- just bought 99 neon r/t wanna turbo
- 95 neon hard starting
- 97 Sport With problems
- srt-4 gauges
- mugen style front lip
- '97 DOHC won't idle
- Odd noise when warm from engine
- Upgrades :)
- Weird gas guage
- can i re-use short block after timing belt snap?
- 96 Neon a couple probs
- 1st Gen Neon - 2ed Gen Eclips
- 1st Gen Aftermarketpart Sites?
- 96 Neon SOHC help
- Leak from the hood release lever
- 98 Neon Horn location ??
- new raditor
- 98 Neon Trans Prob
- Camshaft Position Sensor???
- What's up with my baby?
- motor swap
- 1997 neon 2dr Stalling abruptly. Starts immediately after key off.
- 95 neon brake lights are not working
- 1999 Plymouth Neon #3 injector flooding cyl
- engine/tranny problem
- Neon in need
- Gauges not working?
- 96 Neon trouble codes and power problem.
- Misfire, Can't find cause.
- 99 neon suspension
- Is this right?
- Spark plug tube seals
- Headlamps fluttter on and off
- 98 starter install
- the hood
- someone help
- Save My Neon!!
- 97 highline gas gauge
