Our Community is 662,000 Strong. Join Us.
View Full Version : 6000
  1. 1987 Pontiac 6000 LE, subwoofer
  2. reds
  3. Engine missing at high idle & above 35 mph
  4. 89 Pontiac 6000 V6 No start
  5. bad coil pak?
  6. 1983 No Spark
  7. 91 pontiac 6000 ~ AC/Heater Blower fan problems
  8. 1990 se awd
  9. Alignment/Struts question '88 LE
  10. 91 6000 3.1 no injector spark
  11. engine losing power and revving high
  12. 88' 6000 Engine Problems
  13. Cruise diaphram
  14. high pressure power steering hose leak
  15. 6000 LE motor noise
  16. post engine work problems
  17. Found: Cheaper parts for your 6000.
  18. Engine Swap?
  19. Hoodliner
  20. a/c compressor cycles on and off
  21. what is fuel delivery
  22. 90 Pontiac 6000
  23. Hard starting in wet, damp weather
  24. 91 6000 LE Fuel Gauge issues.
  25. delco anti theft system
  26. new member question
  27. Car suddenly dies while driving, restarts hours later
  28. Steering wheel removal
  29. 91 6000LE Dead Fuel Pump?
  30. 1988 Pontiac 6000le wont start
  31. 1986 pontiac 6000 STE backing plates
  32. 87 6000 problem
  33. 4T60 to 125C trans. swap
  34. Cruise has stopped working
  35. 1990 Pontiac 6000 - rough idle and backend whine
  36. Hood release cable
  37. C.T.S. Coolant temp sensor
  38. Fill'n the freon
  39. Oxy sensors
  40. '86 STE 2.8L Starter Replacement
  41. Strut removal
  42. Brake Problems
  43. Not a whole lot of heat
  44. Thermostat location
  45. most reliable car ever
  46. Help Please Electrical problem
  47. Oil filter relocation
  48. pontiac 6000 engine problems
  49. 6000 LE loss of voltage
  50. 1990 Pontiac 6000 LE
  51. Ruff idle problem
  52. Need manual!!! help
  53. Engine cuts out at idle in drive.......
  54. '84 AC linked to IDLE?
  55. '90 Pontiac 6000 LE speedometer
  56. cv joint 86 pontiac 6000
  57. 1986 6000 ste charging issues
  58. 6000 LE Performance
  59. Pontiac 6000
  60. '91 6000 LE Stock Speaker Sizes
  61. 86 6000 no spark
  62. Pontiac 6000 1990
  63. 1988 Pontiac 6000 TCC Soleniod
  64. 1990 Pontiac 6000, Starts then stalls
  65. 86 Pontiac 6000 2.8L 2 Barrel Carb
  66. Pontiac 6000 Won't shift into gear, stuck on side of road
  67. Pontiac 6000 (Help Please)
  68. 6000 pontiac 1989 stalling and idling hard
  69. Pontiac 6000 cranks but no run
  70. 6000 Vacuum Line
  71. 6000, wont turn over
  72. 89 6000 died on me to, again, please help
  73. 88 Pont 6000 stalls at startup
  74. Pontiac 6000 head gasket
  75. pontiac 6000 how many miles do you think it will go
  76. Pontiac 6000 86 havin startin problems
  77. 1987 Pontiac 6000 CD Player Installation help
  78. 84 6000 Le ???
  79. 89 6000 le died on me
  80. 89 pontiac 6000 le
  81. starting problem with pontiac6000
  82. 86' pontiac6000le questions
  83. '85 Pontiac 6000 STE (Help me PLEASE)
  84. '90 Pontiac 6000LE - check engine diagnostics
  85. '89 6000LE -- ECM help needed.
  86. pontiac 6000
