View Full Version : Pathfinder/Terrano/QX4
- Gassing up with the car running...
- 1995 P/F Reverse prob
- 2005 Pathfinder noise
- Reverse lights
- 97 Pathfinder intermittent no start
- 2001 Pathfinder LE - Rear Power Window Switch Removal?
- pathfinder
- 1997 Pathfinder LE won't start
- Squeaky noise
- What happend to fuse? Check out Pics!
- 91 Pathy electric lock issue
- screeching noise when starting
- clutch pedal sensor?
- Err Message
- alive anyone?
- For sale Nissan factory service manual for 91 truck/pathfinder
- got any repair manuals
- 92 Pathfinder dies sporadically. Help!
- windshield
- A/C Compressor pulley bearing noisy
- caliper pins
- 98 Pathy - Can't open rear side door
- Wipers will not stop on a 95 Pathfinder
- Wiring harness issues-'91 Pathfinder
- heater issues 95 pathfinder
- 94 pathfinder
- 96 pathfinder won't start
- p1140 H02S code
- smoking 2001 pathfinder
- '91Pathfinder fusible link
- 1995 Pathfinder transmission problem
- free manuel or scans - 99 pathfinder
- Need to recharge 01 pathfinder A/C freon
- Strange Problem
- Noise inside Pasenger area Dashboard
- 1998 Nissan Pathfinder Won't Start after replacing the battery
- 94 pathy.. rattle sound?
- 01 qx4 transmission surge
- transmission problem
- QX4 AC Fan will only blow full speed
- 2005 pathfinder lift
- Wiper Motor on 01 Pathfinder
- 2004 Pathfinder fuse for 12volt
- free-running or not?
- 2005 Pathfinder Issue
- Adjusting headlights 2001 QX4
- Charging Sytem Help !
- '91 Pathfinder electrical problem
- 99 pathfinder front brakes
- 02' Pathfinder LE problem
- '01 QX4 Fuse Problem
- Nissan Pathfinder 2005 Sensor Problem
- 97 Pathfinder alarm and door adjar problem
- OBD Freeze Frame help P0171
- 88 pathfinder rear brakes
- 97 QX4 Front End "clunking" noise
- 96 Pathfinder Problems
- 1999 nissan pathfinder HVAC control head
- Deal or not??????
- Help - 95 Pathfinder High Idle, Rough Idle
- 94 Pathfinder restored
- Electronic Adjustable Suspension
- Need help!!!
- Car Lift!!
- Can any one suggest Automotive Car Lift?
- QX4 Grille Guard or Brush Guard
- Substitute Tire Options for Pathfinder
- looking to buy a pathy, what to look for??
- 2000 Spark plug Question
- 98 pathfinder - no low beams
- 87 Pathfinder
- 98 Infiniti QX4 Idle Control Valve Malfunction
- 00 QX4 Idle problem when stopping
- QX4 burnout
- 98 Pathfinder wheels on a 2001
- '91 Pathfinder
- 94 smoking!!!! ADVICE? Thanx!!!
- Gas Smell at startup 94 Pathy
- How to remove rear fender flair (2004 Pathfinder)
- '91 Pathy cruise
- Fuel Injectors
- 00 Pathfinder - Change Drive Belts
- Severe Side-to-Side Rocking on '97 Nissan Pathfinder
- Brake noise on 95 pathfinder
- '91 Pathfinder runs rough
- '91 Pathy rear speakers
- '93 Pathy issues
- 92 Pathfinder replacing the starter
- '91 Pathfinder fuel guage problem
- '91 Pathfinder starts rough
- '91 Pathfinder SE
- Minor Issue
- 2001 Pathfinder - Brake Trouble
- 1995 pathfinder turn signal trouble
- need help
- 88 Nissan Pathfinder V6 Driveability problems?
- 91 Pathfinder XE
- 92 Pathfinder sputters a lot when starting to move.
- '91 Pathy intermittant blower motor
- '94 Nissan Pathfinder ABS brake light reset
- white smoke coming from vents... help!
- more problems
- 3.0L Upgrade 87-95 Pathfinder 4x4
- What could it be?
- Cabin air filters 98 pathy
- '93 Nissan pathfinder...Only starts when it wants to.
- 1995 pathfinder se, no reverse
- QX4 blower problems
- 94 pathy timeing belt question
- Window Washer Pump?
- pathfinder Compatability
- 92 pathfinder won't start
- 93 Pathfinder AC Trouble
- 95 Pathfinder -WONT START - AUTO TRANS
- do i have keyless entry on 2002?
- Airbag light blinking
- 2000 Pathfinder needs transmission fluid change.....
- 94 Nissan Pathfinder Remote Programing Instructions
- New Engine High Idle
- Radio and dome light out
- 1999.5 Pathfinder Keyless entry programming questions
- pathfinder compatability
- 2001 Pathfinder SE 4x4
- 97 Pathfinder P0305 & P0325 - Need Help
- 1989 pathfinder 3.0l petrol, need new starter
- 94 pathy jiggle to start.. mechanics out there HELP!
- 99 pathfinder idle
- Slipping belts?
- Regular versus Premium
- 93 Pathy. Urgent 10-18. Fuel Injection
- tune up
- 99 Pathy turns but won't start
- hard starting
- td27t into d21 pickup
- pathfinder Advice
- 2004 Pathfinder Shifting Lag
- General & Long term PROBLEMS with QX4's -01-04
- 1988 nissan pathfinder-won,t fire!!
- jakes_mom
- 2002 Pathfinder LE
- 02 Pathy no start
- Squeaking Brakes
- 94 td27t nissan terrano help
- 98 pathfinder wont start after stero install
- '85 Pathfinder Intermittent fuel cut-out
- 97 Pathfinder brake bleeding?
- 97 Pathfinder Spark Plug Replacement - Help
- Terrano Round Headlight
- Infinity QX4
- '91 Nissan Pathfinder XE runs cold/cool heat?
- 2000 Pathfinder - bumper repair
- 2002 Pathfinder Bose Issue (CD skipping, no error message)
- Rear View Mirror removal
- Trouble Starting
- replacement parts
- F'd up bose amp need help
- 1996 Nissan Pathfinder Timing Belt Repl
- 95 Pathfinder engine temperature indicator
- 96 - Engine flooding
- 01 QX4 cabin blower gone nutz! Help!!
- 97 qx4 wont start
- 04 pathfinder fuse problem
- Windshield wiper stops working.
- 2002 Pathfinder - Battery Won't Charge
- 06 Pathfinder Ashtray
- 2000 Pathfinder Stalling when in reverse
- hey 88pathoffroad
- squealing drive belts ????? pathfinder 2003
- O2 sensor help - 96 Pathfinder
- 98 3.3L V6 where is the knock sensor?
- what should I watch for when buying 1995 pathfinder
- 1994 nissan pf disconecting the alarm
- Won't Start - Sometimes.
- After market Fog light kit for Pathf. 06
- 1995 pathfinder fuel pump noise after engine shuts off
- LATCH in the 2002 Pathfinder
- Gas smell
- 98 Pathfinder
- 95 Terrano wiper problem
- 97 QX4 brake light issue
- 2003 pathfinder SE 4D 4WD Q's
- 2000 Nissan Terrano 3.0 Diesel Cooling Problems
- 95 PF Brake light issue
- Brush Gaurd Instillation
- 95 pathy tranny problems
- Need remote programming instruction - 96 pathfinder
- 1998 Pathfinder SE FOR SALE - Only 45,000 Miles IMMACULATE
- Compatibility between 02 Pathfinder and 04-06 OEM Bose Stereo?
- Instructions for Remote Keyless Entry '05 Pathfinder
- resetting SES light w/o disconnecting the battery
- 93 se-v6 heat problem
- 92 Pathfinder engine knocking/suppention problems
- 96 PF fusebox help
- help dealer don't know
- Upgrading Navigation in QX4?
- Squeaking Noise with QX4
- Pathfinder Audio Set ups
- '92 pathfinder se keeps dying
- 02 Pathy Specialized Tool
- Manifolds
- Remote starter question:
- Need some help
- Performance
- Qx4 Spare Tire Accessories
- 2001 pathfinder EGR valve location
- 1993 pathy electrical issues PLEASE HELP
- 1998 Pathfinder Fan only works on high?
- 88 pathfinder engine swap
- Noise from tires, not brakes??
- Weird Lights flashing and staying on 95 Pathfinder
- 92 Pathfinder won't start...
- '93 how to test ECM ?
- Potential HUGE HP gains...
- 1988 pathfinder power steering pump removal ???
- '91 nissan pathfinder SE missfiring
- Whats Causing This????
- 1989 Pathfinder Fuel pump question
- 96 pathy foglights
- 01 Transmission Control Module
- HELP-1st the cd player NOW the alarm system
- Considering a 99' or 00' Pathfinder. Any Advice?
- Tire Recomendations
- Finally...A lift for 96-04 Pathfinders and QX4s
- Air intake for 96 pathfinder
- Can't get out of 4x4
- Pathfinder Headlight Replacement
- 93 Pathfinder Tranny Fluid
- Daytime running lamps
- 2002 pathfinder - loss of power and noisy engine when warmed up!!
- 96' Pathfinder, Air Bag light blinks
- Xtarra Supercharge Engine Swap
- 95 Pathfinder-PRNDL light bulb
- 96 Pathfinder, changing brakepads
- 95 pathfinder questions
- 99 Pathfinder oil pressure sensor location
- PCV valve
- Dead 1996 Pathfinder
- Suspension
- QX4 2001 air conditioning problem
- check engine light on after a clutch replacement
- 97 pathy rear end sway
- Intake Valve timing Sensor (Right side)
- 93 Pathfinder Clock
- 2001 pathfinder catalytic converter - still searching
- 2003 Nissan Pathfinder - Oil and Engine
- Keyless Remote Programing instructions needed for 2000 Pathfinder
- Pathfinder Fuel Filter
- '03 Pathfinder SE fuel mileage
- Auto locking hubs stuck?
