Nissan
> Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
2005 Xterra - tickling sound
2000 Xterra General Questions
best way to lift my X
Tow Hitch Wiring Questions on 05 offroad.
99 path seat belt warning light
tire size
o1 pathfinder SES code P1135
Trouble Cold Starting After Injector Cleaning
clicking noise on the drivers side
Trailer Harness?
FS: 02 charcoal Xterra 16" 4-spoke wheels.
Rugged Trail P265/65R17 8000 miles-5
Factory suspension for 04 Xterra
jdm engine
Front Tow Hooks
Pathfinder 02 LE - Front Ringing trrring
1994 Pathfinder Part-Out
95 Pathfinder Sputters, stalls at low rpm
hot truck
can't pass smog test 97 pathy evap code
oil pump, engine
01 Pathfinder Rear Entertainment
91 Pathfinder ???
stereo
weight of 16x7 alloys
Trailer Hitch Wiring Bracket
Can an 04 X have a Cadillac ride?
service engine soon light
Calmini lift-tires not aligning correctly
Paragon
Bad Vibration
how much $$$ for a 00 xterra?
A/C Drain
Looking for SE wheels 16" charcoal
help, help!
Buying 98 Infinty Qx4????
Power point fuses
Need help with starter removal in 94 Pathfinder!
Xterra 2000 emission failure CO too high
i am new to this
new
actual towing capacity
Headlight Adjustment
Auxiliary input for my Bose
heat shield
coil over long arm conversion
2005 tire and rim
Poor Stock Stereo Reception
Air horn install?
Cruise Control/Idle Speed srvc bul. NTB01011
Power window amplifier
ACC hot wire wont come on
brake shoes wear
Milking every ounce of HP from 2001 pathy
Tow Hitch Advice For Newbie
Tire size
97 QX4 Leather Seats / 2003 leather seats
2000 pathfinder key FOB
Can someone explain tire specs
Trans problem??
Blower stuck on
Which mods for a man on a budget?
01 Pathfinder Left Lower Oxygen Sensor Wiring Diagram?
Cabin microfilter info
4 - 16X7 Tires & Rims (wheel) 265/70/16
For Sale: 6 disc in dash cd player $200
02 how to change the rear brake shoes
squeaky suspension
2001 Xterra SE
00 Pathfinder Code P0500
a/c compressor
AC problem
Supercharged 45,000 mi. check
Switching from 4wd to 2wd
FS: '00 Xterra SE 4x4 auto
Really brighten up the road
Dealer Horror Story - RPM Nissan,Durham NC
Shuddering below 2000rpms & grinding noise during start
difrence in XE & SE
16x8 wheels for 2001 SE?
WTB: CL, IA & PA
Suspension mods on 2005 XTerra
Drivers Seat Track Issue
Nismo Intake filter only
rpm
2005 Xterra (Nissan' ain't thinkin')
Air Conditioing Prob
96 nissan pathfinder CD player problem draining the power
Has anyone change the steering wheel off a 97 QX4 to a 2001 QX4 steering wheel-?
Horn Stopped working.
2000-2001 Xterra V-6 A/C High Side Hose
Step rails for sale
oem air filter 2001 Pathfinder
Fuse Box
2wd
1990 Inter lock
problem with SLR
90-95 chrome grill and chrome corners for sale!!!
cLUNKING nOISES
Vibration in Drive and Reverse
tire size
air dam mod
jammed tailgate latch '97
Strokes at idle and slow speeds
2001 Pathfinder starter(?) noise
95 Pathy a/c won't engage
Wacked headlight
O2 Sensor
Dashboard Lights
Odometer Slightly Off...
Grille color?
Odd Electrical issues
1st Xterra, 1st post - Cargo Liners
Exhaust Manifold Replacement
Rust Solutions
Death Valley Xterra
parking brake
spacers
Seeking stock step rails (charcoal grey)
Winding noise-Help!
inventory of 2005 xterra 4x4 offroad 6sp
My 04 Granite Xterra
01 Pathfinder 4Wd light comes on
Is this Xtrerra worth it
Brake rotor removal
after-market siderails???
stereo
should i buy an ex-terra?
POwer Antenna Motor? QX4
Hot Temp
Supercharger upgrades
Storage?!?
AC Problems
Engine parts.
Ses
Imporved Gas Mileage
Anyone have success installing a supercharger?
Part Numbers
05 Xterra in Tahoe
01 Pathfinder P420 P430 SES code
'01 BOSE 6-disc error2 code on display
'97 code P0420 (catalyst efficiency)
Fog Light Installation
2001 Xterra: XE vs. SE
Question about 2003 Xterra XE 4x4
Rear Wiper
Floods out
Knock Sensor Location
Aftermarket foglights
New dealer-installed bolts???
Tps
Axle Ratio/tire Size Calculator Etc......
Accessory belt replacement procedure
Super slow power windows
Power Seats
Sony Tv Diversity Unit For Navigation, Xt-200v
Tokico
metallic scrapping noise under the car.
97 Pathfinder Tranny Stuck
4x4 Advice requested
QX-4 Entertainment System
2005 Xterra, Any Problems?
265/70/16 General Grabber Tires w/1634 miles on them.
Fog Light Switch
auto hub:manual hub, difference?
94 PF Power Window Problem
Vibration at idle in drive & rear seal leak
headers
center differential
'05 Xterra
Turbonator or Super Charger?
Head gasket replacement 95 V6 pathfinder
High pitched whine from engine area
help?
Other compatible year cargo cover for 97 Pathfinder
Rattling noise
master cylinder
pathfinder or 4runner
Service Engine soon
95 Pathfinder doors lock automatically
swaying 96 pathfinder
Cold Air Intake
01 Pathy P0171 & P0174 O2 codes SES
Need Help on XTerra Jack and Jack stands
Service engine light
Alaskan Xterra
Removing Front Drivers Seat
3" Body Lift
Advise
Out With The Old... In With The New...
Where is the transmission fluid tank?
just bought new 2005 xterra
Seat Removal
Aftermarket Supercharger Kit Available For X
Skid Plates
parking lights stay on constantly
Premium gas?
CHEAP seat covers??
Advice requested on brush guards
seat covers
Clutch or Throw Out Bearing?
Tachometer needle bounces / 95 Pathfinder
Heater/AC blower running on highest speed only
turn signals and emergency flashers
SC rims and tires anyone?
Warranty Issues Update = Can-spec '02 Xterra
2005 Xterra Receiver Hitch
Ecxc
PVC Valve
vg30det swap in a pathfinder
2002 Pathfinder Electrical ?
I am looking for Keyless Remote Programming Instructions for 1997 Infinity Qx4
Tire Pressure?
Need Help
Rear Towing Point
6 disc cd changer with fosgate amp
Changing Front Bumpers..
white face gauges
SES Engine code P1140
95 Pathfinder Alarm problems
1997 Infinity QX4/ pathfinder Performance parts
speedometer
Body roll/lean... any fixes?
BIG disappointment in 05 xterra
Windshield Wipers
oil in radiator
01 Pathfinder engine codes
Aftermarket Fog Lights
A/C evaporator
02 Pathfinder
f/s 20" Black rims with chrome lip ((700$)) that use to be on my pathfinder
95 Pathfinder - checking oil level
Chassis Damaged - BREAK
solid front axel
intake
noise from front driver side shock
Typical Dealership
new X
help!!! with dash removal
Has anyone done a 00 to 02 front end conversion?
Problem With Dash Lights
2000 Xterra XE Rims and Tires
Help-won't stay running
Debating buying Xterra. Opinions needed!
I4
i got another one...
Intermittent starting problems
Removing Front Passenger Seat - Easy?
Clutch Change on last manual generation
