View Full Version : Pathfinder/Terrano/QX4
Pages : 1 2 3 4 [5]
  1. how to get off the gas charge lifts for the tailgate
  2. 95 pathfinder fuel pump
  3. 1994 pathfinder power/stall problem
  4. knocking sound on uphills / check engine light flashes
  5. Dome lights flickering
  6. Alarm on 1997 Pathfinder goes off randomly
  7. 1995 Pathfinder stater motor
  8. 93 Pathfinder Keyless Entry Programing Info
  9. squeak/squeal in 97 pathfinder
  10. Changing Pathfinder timing belt
  11. 01 Pathfinder rotors
  12. Ticking sound, like a Motorcycle
  13. Annoying loose tail license plate
  14. Idleing high
  15. Radar instillation 2000 PF, where's hot wire
  16. selling my '87
  17. lost 98 pathfinder key fob
  18. Tranny swap - help!
  19. keyless entry
  20. '02 Pathfinder key fob questions
  21. Audio Question
  22. cuttin out
  23. '89 PF auto tranny problems
  24. 1989 Pathfinder power locks....I'm confused
  25. adding Bose system
  26. '01 Pathfinder, ECU questions
  27. Swapin The Bose Out
  28. IFS or Straight Diff conversion for a 90 Path
  29. 87 Pathfinder Starter
  30. 94 Pathfinder lock problem
  31. 1999.5 pathfinder tranny stuck in reverse
  32. 92 headlight problem
  33. steering squeak.. TSB
  34. pathfinder cylinder misfire-code 0701
  35. 94 P'finder, starter, how get to bolts?
  36. starting problems
  37. 94 pathfinder burning black
  38. They`re not makin the QX4 anymore
  39. adjusting headlights
  40. Owners Manual In Pdf Format???
  41. adjusting headlights on 2000 Pathfinder
  42. 1990 Pathfinder: Engine Problem/Questions
  43. 2001 Pathfinder: Nissan stereo alternatives?
  44. Turbocharger for VG33E!
  45. Turbocharger for VG33E!
  46. Need help installing a headunit
  47. engine swap help...
  48. sometimes it starts sometimes it don't
  49. Wood Dash for 2003 QX4, does any kit match Perfectly???
  50. 95 Pathfinder - will not crank over
  51. Squeeking brakes
  52. 1994 XE Instrument cluster/gauge problems
  53. pathfinder's stock alarm
  54. 1996 or 1998 Pathfinder fuel filter help
  55. Pls Help: Removing Bose System Installing New System...
  56. LSD Oil
  57. 2000 and up pathfinder, xterra keyless programming
  58. 1997 pcv valve replacement
  59. Leather Seats on Ebay
  60. Any lowered Pahtfinders/QX4s out there?
  61. 1991 pathfinder fuel problem
  62. Looking for smoothest ride possible
  63. Best Repair Manual For 93 Pathfinders ??
  64. 93 SE Stereo HELP!! ASAP!
  65. Low power in tight turns--normal?
  66. Pathfinder auto transmission swap
  67. Running On 5 Cylinders ....Help
  68. 97 Pathfinder Tire Squeal
  69. 2003 Headlights
  70. Pathfinder offroading music video
  71. Easiest/best way 4 running wiring thru firewall?
  72. 18" Detata Profiler 6 LUG Wheels On Pirelli Tires FOR SALE!
  73. rusty step up bars on my 92
  74. Used QX4 Recommendations?
  75. Stock Amp
  76. Questions on 1990 Pathfinder SE: timing belt, CV boots, ball joints etc...
  77. trip meters
  78. Resetting AirR Bag Warning Light?
  79. BOSE Speakers
  80. Motor Needed! 1996 V-6 XE Auto/Air
  81. 95 pathfinder keyless entry
  82. weird brake trouble
  83. Idle
  84. 5 speed PF tranny wanted
  85. EGR Valve
  86. bad, leaky, fuel injector
  87. 2001 pathfinder cd changer
  88. grille guard
  89. power antenna
  90. located the sensor odometer
  91. 4x4 How?
  92. Rim Question?
  93. Over Heat
  94. Brake Rotors
  95. '95- Automatic Tranny Swap
  96. parting out a 94 pf.
  97. 1997 the Engine light problem....
  98. Front end popping noise.
  99. oxygen sensor replacement
  100. ECU Location/Diagnostic Procedure
  101. Looking for LSD
  102. sun roof
  103. 93 wiring diagram- door locks
  104. Question.....
  105. 2001 Pathfinder A/C problem
  106. Wheeling In Seattle area
  107. wiring on locks
  108. Big Big Problems Help Please!
  109. Lemon ?
  110. door lock
  111. Mechanical Problems
  112. Street Scene Grille
  113. Pathfinder 2001 front end hitch
  114. Was there a 3.5 is some 2000 PF?
  115. 2000 Pathfinder SE gauge problem
  116. Need help with speakers
  117. Help !! P1140 OBD2, what is it?
  118. 97 Pathfinder wont start
  119. cheap mods for 93 pathfinder?
  120. Key less
  121. Best place to buy off-road gear for Pathy's
  122. 20020Infiniti QX4 Sludge Problem
  123. Pathfinder LE 2002 rims
  124. Wont Start....
  125. 2001 Pathfinder Noise
  126. 2001 Nissan Pathfinder - Installing Stereo
  127. My Path
  128. 97 path-checkengine/airbag light
  129. a/c leak on 95 Pathfider
  130. 97 Pathfinder transmission error???
  131. you know you want my pathfinder!!
  132. '01 Pathfinder gas + towing
  133. 92 Pathfinder power locks broken
  134. 97 QX4 Diagnostic help!
  135. Yellow Pathfinder
  136. 97 pathfinder remote programming
  137. Dash & Tail lights not working
  138. 2000 Keyless Programing
  139. pathfinder hitch
  140. engine swap
  141. 95 Pathfinder electrical problem
  142. brake pads - ceramic or OEM
  143. Pathfnder Radio Problem
  144. Stereo
  145. swap engine in d21 pick up 88
  146. i got a problem...
  147. changing a 93 pathfinder starter
  148. remote reprogramming
  149. Need Help With Shocks
  150. Keyless entry
  151. Rims?
  152. Keyless Remote
  153. 99 clear corners
  154. Wiring path for Rear speakers in 90 Pathfinder
  155. XM for 2003 Pathfinder...
  156. no reverse manual trans.
  157. 89-95 Uhaul tow hitch for sale $100.00
  158. 2001 Jeep Sport engine light
  159. VQ35 Supercharger???
  160. Radio Gremlin
  161. Electrical Mystery
  162. transmission cooler
  163. 90 Pathfinder For Sale
  164. Newbie Here
  165. wiring through firewall
  166. 95 Pathfinder, no reverse
  167. 2002 QX4 remote programming
  168. Adding RCA jacks to the original unit
  169. Helpppppppppp
  170. Changing the roters
  171. 95 SE no reverse
  172. hookups for my 96 pathfinder!
  173. xterra roofrack for the pathfinder
  174. Installing starter on 97 pathfinder
  175. '94 Pathfinder keyless remote instructions
  176. Motor Swap possibilities?
  177. PERformance upgrades
  178. 87 auto trans problem
  179. wiring a new stereo
  180. Need Help - Real problems finding OEM Fender Flares
  181. Resetting Check Engine Light
  182. frankenstein pathy
  183. rims for my pathy
  184. trailer hitch for sale
  185. Looking for a Indy shop in S.D. CA
  186. color code for the wiring harness (radio) 93 pathfinder
  187. electrical or battery problems
  188. Help me locate blower motor resistor.
  189. Hook up Playstation or N64 to Mobile Entertainment System
  190. 3" Body Lift 4 dr auto
  191. Old School Rims for Sale
  192. Tune up for my 98 Path
  193. Lighting
  194. MY Pathfinder
  195. Is there a supercharger for the QX4?
  196. PATHFinder pics
  197. Intake for 99 Pathfinder.
  198. Commercialism . . .
  199. my lemon
  200. Lemon QX4
