View Full Version : Pathfinder/Terrano/QX4
Pages : 1 2 3 [4] 5
  1. Decoding VIN number or what model did I buy?
  2. changing brake shoes
  3. Opening rear window(and locking doors)
  4. 2001 Pathfinder SES Codes
  5. Alternator noise and failures
  6. Trip Odometer
  7. Passenger side, inside door panel needed
  8. 1995 Pathfinder Keyless Remote
  9. 87 pathfinder Turn signals and gauges stopped working can't find fuse.
  10. Radio howls when turned on..
  11. KBBV on Qx4s
  12. 2001 pathfinder LE Help
  13. Nissan Keyless For 200 Pathfinder?
  14. 1991 Pathfinder Grinding Noise
  15. Pathfinder fob
  16. rpms?
  17. Pathfinder Dashboard lights
  18. QX4 failed emission inspection
  19. one piece headlight
  20. Price Check: Rotors, Pads and Calipers $710?
  21. Hole in head?
  22. tire carrier
  23. '96 pathy speed issue
  24. need help with vacumm lines on Z24 engine for 89 nissan
  25. Boat towing
  26. Cd Play Installation Trouble
  27. Speaker removal (tweeters) on bose system
  28. Airbags
  29. Picked up an Armada on Saterday
  30. speaker removal in '97 Pathfinder
  31. Car Amplifier Help!
  32. Swaying Pathfinder/Replacement of Upper and Lower Rear Trailing Arms
  33. fluctuating hum in neutral and park
  34. replacing stock radio light
  35. 1999 vs 99.5
  36. '95 Pathfinder speakers not working
  37. 2004 Nissan Pathfinder - Cornerlamp Socket
  38. 94 Pathfinder A/C malfunction
  39. Windsheild Fluid
  40. hitch question for '01 SE
  41. 99.5 automatic transmission
  42. 93 Pathfinder SE rear speaker size and removal instructions
  43. *NEW* Pathfinder Mats,Foglights,Hood Mask NO Reserve!!
  44. Im about to start my install but need some help!
  45. Smittybilt Nerf Bars - Install Questions
  46. New Pathfinder site
  47. Question on 4x4 shifter 90 Pathfinder SE-v6
  48. Need info about the stock stereo
  49. Power Windows and Locks
  50. manual hubs for 94 pathfinder
  51. will bigger tires work with 94 XE
  52. '01 Pathfinder Cargo Cover
  53. **NEW** FOUR Genuine Nissan Pathfinder Center Caps!!
  54. 2004 Nissan Pathfinder Clear Corners
  55. Body lift kit???
  56. Playing with my Pathfinder's guts - new toys
  57. 95 pathfinder speaker sizes?
  58. 91 Pathfinder AT trans wont shift till warm.
  59. air intake??????
  60. Perma Cool Tranny Filter and Tranny Cooler
  61. 98 Pathfinder - starting problem... thoughts?
  62. sunroof is jacked up in my 98 pathfinder
  63. 98 pathfinder, can't get alarm out of silent mode
  64. i gotta question
  65. 1995 nissan pathfinder
  66. Steering wheel vibrates while applying brakes
  67. Mine got repoed
  68. Tire life on 22 inch rims
  69. disarming the alarm
  70. pwr window problems
  71. '91 Pathfinder speedometer needle
  72. Truck Club
  73. Just bought a '99 Pathfinder LE, any heads up?
  74. 1990 Pathfinder not starting
  75. Problems with new stereo in '94 Pathfinder
  76. high pitch sound at 20mph?
  77. I cant find 20" rims for my 4wd 90 pathy
  78. 98 SE Shock problems
  79. metallic rattle???
  80. Programming keyless remote
  81. Turn signal not working - hazards neither!
  82. Brake Lights are Stuck ON
  83. Changing The Rear Seal
  84. '95 Pathfinder Fuel Odor PROBLEM :(
  85. Pop/clunk sound in front with brakes on turns
  86. Fading Reverse in Transmission
  87. Steering wheel
  88. speedo
  89. NoN Pathfinder..
  90. sticking gas pedal
  91. 1987 V6 Pathfinder, front brake help!
  92. timing belt
  93. 87 Pathfinder Help !
  94. Fan only runs in high position.
  95. Is there such thing....(??)
  96. Front Brake repair HELP!
  97. **FS: 95 Pathfinder cheap, project
  98. Looking for an updated GPS CD ROM
  99. Head Light Relay?
  100. Where to find used interior trim pieces?
  101. Power window motor for 96' pathfinder
  102. my mechanic wants to replace the computer on my 95 pathfinder
  103. Brand new forum JUST for WD21 1st & 2nd gen Pathfinders. Come check it out!
  104. 2001 5th door trouble
  105. 2001 Pathfinder loud audible sound in rear axle?
  106. tray in center console
  107. overdrive probs
  108. bose stereo upgrade
  109. High Output Alternator
  110. 90 Pathfinder speedo needle.
  111. starter/electrical problems- Help Please!!
  112. Starter for 88 Pathfinder
  113. thin metal piece left off front disc pads
  114. Rough Idle with 51 code
  115. Pathfinder 2wd 5 speed
  116. Dashboard rattle
  117. 01 pathfinder transfer case
  118. Camshaft position sensor, Code p0011
  119. +Size tire inflation pressure ?
  120. intake install, now service engine light on
  121. '94 Pathfinder Lift Kit
  122. Engine Mods
  123. 95 Pathfinder fog light prob.
  124. 92 pathfinder starter help
  125. my 95 pathfinder has 2 problems. Please help MPH/TACH
  126. Bose stereos
  127. 2000 Pathy....Rough Ride
  128. 94 Stereo Problem
  129. Question about programing keyless entry
  130. '94 Pathfinder 4x4 w/5spd Standard (starter replacement)
  131. 2001 pathfinder electrical problem
  132. newbie needs help here......please
  133. 1992 Pathfinder rear side door access
  134. Is this the computer?!?!?!?
  135. motor location of power antenna
  136. Help Please!!!!!
  137. one fog light works, other doesn't
  138. fixing a dent
  139. '02 center console removal?
  140. 1991 Pathfinder Cruise Control
  141. spineless thugs
  142. 3rd party cruise cont for 94 pathy?
  143. starter or something else?
  144. this is a repost, still searching
  145. fan control and AC control
  146. snorkel
  147. jerking and sputtering at 2000 RPM - clues?
  148. low fuel indicator light stopped working
  149. 2 Issues if someone can help?
  150. deactivating alarm on 95 pathfinder
  151. HELP with an Unusual Window Rattle?
  152. Tires
  153. 05 Pathfinder
  154. jump start pathfinder
  155. '01 Path interior upgrade?
  156. lights is dash coming on then off
  157. Buying a second hand QX4
  158. 95 Pathfinder Alarm Remote
  159. 87 Auto Trans Swap
  160. battery or alternator problem, or weird voodoo?
  161. specs. 1995 pathy V6 help
  162. 95 pathfinder bucking really bad when warm
  163. Door open light always on. Which wire?
  164. turn signal and Hazard light flasher location
  165. 1997,1998 qx4,pathfinder exh manifold
  166. computer/relay- location?
  167. 1989 Nissan Safari windshield wiper inop
  168. Overheating when towing a boat
  169. Intermittent wiper speed not working
  170. Speedometer Problem
  171. transmission overdrive in and out
  172. If you have ever pulled codes from your '96 or similar>
  173. could someone please help?
  174. Pathfinder 99 Timing Belt
  175. wiring problems
  176. 95 path all lights on dashboard on
  177. 1994 Nissan Pathfinder stall problem
  178. 97 Pathfinder headlamp assembly
  179. Dome light doesn't come on when door opens
  180. 1995 Pathfinder LE Speedometer/Odometer Malfunction. Need help?
  181. 94 factory alarm
  182. F/S:LE Wheels
  183. can't get to 2500 rpm
  184. Wiring Brake Controller
  185. help please
  186. QX4 oil consumption
  187. California emissions and 1995 Pathfinder?
  188. '02 pathfinder for sale
  189. The TRUE way to program your early 90's keyless remote
  190. 95 Pathfinder Gauges Cut out...
  191. 92 Speedometer
  192. 99 Ignition locks
  193. 97 Cd Player
  194. 1997 Pathfinder Electrical
  195. Thermostat
  196. Castrol Syntec
  197. 1990 Pathfinder parts to be replaced
  198. Keyless entry
  199. 91 pathfinder gas gage and temp gage
  200. Pathfinder Quiz
  201. Howdy! 90 Pathfinder Fuel Guage Problem?
  202. 97 Pathfinder Oil Pressure
  203. 2000 Pathfinder Leg Room
  204. Brake Problems
  205. Adjustable shocks.
  206. MP3 in 2003 qx4
  207. 2002 pathfinder se for sale
  208. 1987 pathfinder
  209. Oil loss (1 quart in 2,800 miles) 2002 Pathfinder
  210. Looking to Purchase 2002 or 2003 Low Mileage Qx4
  211. Is this possible? Cracked Block)
  212. air filter adapter
  213. adding an amp to power new speakers on top of the stock bose amp
  214. 8 thread and 10 thread ??? locks for 99 Pathfinder
  215. 96 Pathfinder Oil Pump
  216. QX4 Bose display light.
  217. QX4 Keyless difficulty 2001
  218. 88 Pathfinder trans. buzzing noise
  219. 2000 Pathfinder lift ideas
  220. 2002 pathfinder stereo
  221. Insert Switch in 01 Pathy Interior
  222. 96 Pathfinder Sparkplugs?
  223. Reseting the "check engine light??
  224. Battery drain & blowing fuel pump fuses
  225. Keyless entry auto-lock 01 Pathfinder help
  226. owners manual
  227. 2000 Pathfinder Fault Codes
  228. Custom Subwoofer box - 01 Pathfinder
  229. 4x4 stuck in 4HI
  230. cruise control
  231. 97 Pathfinder Heater Blower
  232. Dashboard Light Problem
  233. Looking for switches.
  234. Wiper Motor on my 97 pathfinder
  235. Did this piece fall off of an 01 Pathfinder?
  236. 2001 Pathfinder Fuel Filter location?
  237. auto tranny problems
  238. 94 Pathy Gas Smell Via Heater
  239. HELP: 92 PF strange noise (tranny?) at coasting speed.
  240. Factory stereo stolen! - Need help for replacement
  241. Few questions on 2002 QX4
  242. 94 Pathfinder Problems
  243. taillights not working for 2000 pathfinder
  244. 4x4 might be stuck
  245. Center caps
  246. need help..crank but no start
  247. Pathfinder horn
  248. Clunking Sound After Braking on 97 LE
  249. Fluid Changes
  250. gauge CLUSTER 4 SALE
