View Full Version : Pathfinder/Terrano/QX4
Pages : 1 2 [3] 4 5
  1. QX-4 Entertainment System
  2. 94 PF Power Window Problem
  3. headers
  4. center differential
  5. Head gasket replacement 95 V6 pathfinder
  6. help?
  7. Other compatible year cargo cover for 97 Pathfinder
  8. pathfinder or 4runner
  9. 95 Pathfinder doors lock automatically
  10. swaying 96 pathfinder
  11. 01 Pathy P0171 & P0174 O2 codes SES
  12. parking lights stay on constantly
  13. Premium gas?
  14. Tachometer needle bounces / 95 Pathfinder
  15. turn signals and emergency flashers
  16. vg30det swap in a pathfinder
  17. 2002 Pathfinder Electrical ?
  18. I am looking for Keyless Remote Programming Instructions for 1997 Infinity Qx4
  19. Tire Pressure?
  20. Changing Front Bumpers..
  21. SES Engine code P1140
  22. 95 Pathfinder Alarm problems
  23. 1997 Infinity QX4/ pathfinder Performance parts
  24. Body roll/lean... any fixes?
  25. 01 Pathfinder engine codes
  26. 02 Pathfinder
  27. f/s 20" Black rims with chrome lip ((700$)) that use to be on my pathfinder
  28. 95 Pathfinder - checking oil level
  29. help!!! with dash removal
  30. Help-won't stay running
  31. Intermittent starting problems
  32. Clutch Change on last manual generation
  33. RPM Surge
  34. high rpms at low mph
  35. slow power window
  36. Infiniti QX 4 transmission Problems HELP
  37. Planning on buying 2005 Pathfinder XE
  38. Floor Mats for my 1995 Pathfinder?
  39. Towing with 87 pathfinder
  40. 2001 Pathfinder LE 4WD and ARMADA/TITAN WHEELS
  41. Factory radio 98 chilkoot
  42. pathfinder lift kit
  43. cigarette lighter unit
  44. Computer chip tuning
  45. rear end "pop"
  46. axle boots help
  47. Noisy Motor During Acceleration
  48. starter went today on 97 pathfinder.
  49. Just ordered my 05 today
  50. Backup lights not working/compass/temperature reader
  51. Radio light replacement
  52. Rear end bump after stopping
  53. new nissan buyer :)
  54. 2001 Pathfinder cargo cover for sale
  55. Dealer Sales Teams
  56. 1999 pathfinder ECU location??
  57. '01 Pathfinder PCV Valve
  58. Gas Milage Survey
  59. Mass air flow sensor??
  60. CV Driveshaft & CV Shaft Part of Safety?
  61. 96 Pathfinder XE 5-speed - CLUTCH HELP!
  62. 1988 Pathfinder revs up to 6000 when started
  63. door panels
  64. 2001 Pathfinder, engine missing at high speed
  65. Can't pass emissions!!!!! Help!!
  66. SES light code read
  67. 91 pathfinder fuel hog about 8 mpg
  68. Brake Rotor Upgrade
  69. 99 QX4 Jerky Tranny
  70. Patherfinder 01SE Engine Code
  71. ABS Light
  72. Should I buy 94 Nissan Pathfinder XE
  73. Emergency Brake prob!
  74. Is there a way to receive video in the navigation screen on 2005 nissan pathfinder?
  75. 2001 pathfinder bose system information
  76. Windshield Wiper Transmission
  77. Programming a Keyless entry remote.
  78. 2001 Pathfinder Questions
  79. how to install a starter?
  80. 01 brush guard in 96 Pathy
  81. Engine runs fine until 2800 RPMS!
  82. automatic fluid
  83. Key release?
  84. trailer wiring??
  85. nissan pathfinder 96
  86. 99 pathfinder window trim rusted! how to replace?
  87. 99 pathfinder, replacing bumper endcaps..
  88. Fuse location
  89. Remote Starter - New Key - FOB now not working
  90. installing corner/tail lights
  91. 96 steering & noise issues
  92. need engine advice
  93. nissan tried to stick it to me
  94. QX4 VCR player controls?
  95. 2000 Pathfinder key programming
  96. how do the hubs lock and unlock?
  97. HELP need Wiring Diagram
  98. 2000 pathfinder service manual
  99. 2000 pathfinder fault code P0158
  100. Brush guards and stuff
  101. Dash lights and Radio lights out
  102. Installation of Tow package for 1999 QX4
  103. 95 Pathfinder Battery/Alternator???
  104. Hard shifting in cold / synthetic ATF
  105. dual exhaust
  106. 93 Pathfinder lock won't lock
  107. Starte Problems
  108. 93 pathy no move
  109. MP3 Player/Radio
  110. 98 Pathfinder Spark Plugs
  111. f.s..00-01 pathfinder parts
  112. engine overheat
  113. brake problem
  114. 2001 shift race uphill
  115. 91 pathfinder starting problems
  116. 1994 Nissan Pathfinder Radio Problem
  117. Cold Air Intakes
  118. 95 Pathfinder Auto gets stuck in 3rd
  119. brakes
  120. corner light problems
  121. My 1996 Pathfinder XE won't start
  122. gas millage
  123. I cant stop!!
  124. replacement middle muffler for 98 pathfinder
  125. Bad fuel filter in a '95 Pathfinder?
  126. Brush guard compatibility for 96 Pathfinder
  127. Do pathfinders have metal skidplate on front?
  128. rear seat headrests for 90 Pathfinder
  129. 03 Pathfinder low fuel light
  130. 2003 Pathfinder Exhaust leak from Catalytic Converter
  131. '98 Pathfinder - Torque Converter Clutch
  132. 2003 Pathfinder plug location?
  133. Fuel Gague and Temp Gague Stopped Working
  134. 2000 QX4 - Where Do I Get Skid Plates From?
  135. Rocker switches
  136. changing headlight lens 97 pathfinder
  137. Tranny Fluid Leak From Prema Cool Filter
  138. 2001 Pathfinder OBD2
  139. 96 Pathfinder tire noise during slight turns
  140. Wiring
  141. QX4 Dash Lights
  142. Towing Capacity of my 87 Pathfinder
  143. Brush guard and tire for 96 Pathfinder
  144. Anyone interested In buying a chrome front grill, corners, signals?
  145. v belt size for alt/water pump???
  146. manual transmission fluid change How to?
  147. 96 pathfinder driver electric mirror
  148. fab belt tensioner bolt size?????
  149. Oil Pump failure
  150. SES light and fuse questions
  151. Installing speakers on the rear door panels
  152. 2001 Nissan Pathfinder LE Flashing SES Light
  153. Oder smell in the cold
  154. How to reset 95 Factory Alarm/Keyless Entry
  155. 95 Pathfinder Security System...Arrrgh!
  156. ABS and 4x4
  157. Where does wire go from battery??? 2001 Pathfinder
  158. 2004 Pathfinder - Poor Mileage
  159. ABS / brake light indicator always on
  160. Xenon Headlights
  161. cv joints
  162. Strange Problem
  163. Strange Problem
  164. tps adjustment
  165. driver seat will not move
  166. rear end swaying
  167. weird noise when i turn the wheel
  168. Remote Starters
  169. Replacing a headlight on a '97 Pathfinder
  170. Visor Remote 97 Pathfinder help
  171. Another 2002 Fob Q
  172. Where can I find info on Original Paint Colors...
  173. sticky gas pedal
  174. tires
  175. I need some ideas
  176. 97 Path Misses @ 4000 RPM
  177. 01 Pathfinder OBDII DTC P0340
  178. Compass Calabration
  179. Pathfinder Air Con
  180. 1997 Nissan PathFinder Car Stereo Fuse#
  181. pathfinder doors automatically unlock
  182. CA: Looking for a 03 Pathfinder/QX4, $200!
  183. 98 pathfinder flasher fuse location???
  184. Need Help with Alarm Problem ASAP!!!
  185. Turbo for 95 xe-v6 nissan pathfinder
  186. 2002 Pathfinder or 2004 Trailblazer
  187. replacing gearbox
  188. need help
  189. For those who want to addon to factory audio system....
  190. O2 related service engine light
  191. tires
  192. 01 Pathfinder SES code P1140
  193. 95 nissan pathfinder tach/rpm problem
  194. Striped Sparkplug
  195. 87 pathy
  196. Idle/Tach drops suddenly almost to zero
  197. Outside Temp. Sensor/compass
  198. suspension lift
  199. Pathfinder '95 gearbox problems
  200. suspension
  201. oil in the air filter
  202. Foglamp
  203. Xenon
  204. Cruise Control Units.....OEM or After ?
  205. new hks supercharger
  206. I want to replace my spark plug wires.
  207. Startup chokes after sitting a few days
  208. rear window lowering
  209. High Altitude Probelm,pathy 1988,please Help Me!
  210. power window not working
  211. 1996b Nissan Pathfinder license plate light
  212. Prob w/ 1999.5 Pathfinder that Nissan can't figure out?
  213. Pathfinder 88 High Altitude Problem
  214. Hole in the Drive floor board
  215. 01 PF periodically not starting?
  216. need some help...I'm stumped
  217. 98 Pathfinder timing chain or belt?
  218. If U have 1999.5 Path remote , can U tell me the number on back,please
  219. Front brake repair... HELP
  220. abs light
  221. Qx4 Plastic Skid Plate
  222. 95 pathfinder wiring problem?
  223. www.pathfinderpages.com back up and running
  224. Exhaust manifold
  225. grinding sometimes when I accelerate.??
  226. aftermarket stereos for pathfinder
  227. squeeky brakes
  228. Service Engine Light
  229. Program instruction for 2001 QX4
  230. Signal lights blinking 5x as fast!
  231. Replacing front struts on 96' pathy
  232. wtb rear emblem from ~97 QX4
  233. 4 wheel drive
  234. Keyless Programming Brain
  235. Service Engine Soon light question
  236. Bad Brake Squeal
  237. won't start clicking noise fix with pics
  238. WTB:// VG33 heads
  239. 93' Pathfinder cargo cover?
  240. Wheel offsets & tires.
  241. Rear Brake Light
  242. 1989 Pathfinder cold idle fluctuation
  243. Keyless Entry Remote Programming.
  244. Motor swap to 1984 300 ZX turbo. What pathfinder 4x4 trans. To use?
  245. automatic window problem
  246. Wheels
  247. Windshield removal
  248. Purge Volume Control Valve
  249. Ses
  250. 97 pathfinder, i need a computer
