Our Community is 662,000 Strong. Join Us.
View Full Version : Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
  1. 01 qx4 transmission surge
  2. Startup rpm ?
  3. transmission problem
  4. QX4 AC Fan will only blow full speed
  5. 2005 pathfinder lift
  6. Wiper Motor on 01 Pathfinder
  7. Sparkplugs
  8. 2000 Xterra Automatic Transmission Questions
  9. 2004 Pathfinder fuse for 12volt
  10. free-running or not?
  11. Xterra Power steering issue
  12. Shocks for '06 Xterra with 2" Lift
  13. 2005 Pathfinder Issue
  14. Adjusting headlights 2001 QX4
  15. Charging Sytem Help !
  16. cracked intake manifold?
  17. 2006 Xterra Shocks
  18. '91 Pathfinder electrical problem
  19. 99 pathfinder front brakes
  20. 02' Pathfinder LE problem
  21. '01 QX4 Fuse Problem
  22. Nissan Pathfinder 2005 Sensor Problem
  23. MAF sensor
  24. Automatic transmission problem!
  25. 2000 X Terra ABS problems
  26. help!!!
  27. To good to be true?
  28. 07 nissan stereo for 01 Xterra?
  29. 97 Pathfinder alarm and door adjar problem
  30. New Xterra - preventative maintenance
  31. optional gauges
  32. OBD Freeze Frame help P0171
  33. Tranny Overhaul
  34. 88 pathfinder rear brakes
  35. '00 or '04
  36. 97 QX4 Front End "clunking" noise
  37. Clunking sound under X: Solution
  38. 96 Pathfinder Problems
  39. Frontier Help.
  40. 1999 nissan pathfinder HVAC control head
  41. How do you read the service engine codes on the Xterra?
  42. Ack! '01 Xterra won't start
  43. Lift kit question?
  44. Deal or not??????
  45. fuel injector connectors
  46. Fix for bad Xterra seats
  47. Help - 95 Pathfinder High Idle, Rough Idle
  48. how much should this cost?
  49. 94 Pathfinder restored
  50. Electronic Adjustable Suspension
  51. Need help!!!
  52. Car Lift!!
  53. Can any one suggest Automotive Car Lift?
  54. QX4 Grille Guard or Brush Guard
  55. locking doors
  56. Substitute Tire Options for Pathfinder
  57. replacement fuel tank with extra capacity?
  58. How to you remove the rear strut springs?
  59. looking to buy a pathy, what to look for??
  60. miles per gallon
  61. cb installation, where did you put it?
  62. 2000 Spark plug Question
  63. 16" rims for spares?
  64. Hauling extra fuel and tires for long trip
  65. pulls to the right
  66. 98 pathfinder - no low beams
  67. "New" '01 X. Mods for Baja trip?
  68. 87 Pathfinder
  69. 17" sc rims
  70. Just Stopped Running
  71. 98 Infiniti QX4 Idle Control Valve Malfunction
  72. 2000 Xterra - lighter won't work
  73. 00 QX4 Idle problem when stopping
  74. QX4 burnout
  75. 98 Pathfinder wheels on a 2001
  76. front wheel 4W lock
  77. One headlight is dimmer than another
  78. Replacing Fluids
  79. brass core cap and rotor
  80. '91 Pathfinder
  81. test pipe
  82. Andys New SLR Stage V & Modified ARB Pics...Enjoy
  83. 94 smoking!!!! ADVICE? Thanx!!!
  84. Gas Smell at startup 94 Pathy
  85. How to remove rear fender flair (2004 Pathfinder)
  86. High idle problem.
  87. Is SLR racing still around?
  88. 2006 tire wear
  89. '91 Pathy cruise
  90. knock sensor problems
  91. Fuel Injectors
  92. 2001 motor mounts
  93. 00 Pathfinder - Change Drive Belts
  94. 2005 Armada Stalling
  95. 2005 Armada Stalling
  96. Severe Side-to-Side Rocking on '97 Nissan Pathfinder
  97. 2007 Nissan Xterra- 3000 miles
  98. 2007 Nissan Xterra- 3000 miles
  99. Brake noise on 95 pathfinder
  100. '91 Pathfinder runs rough
  101. Starting problem 1990 Terrano TD27
  102. Bleeding ABS Brakes ??
  103. '91 Pathy rear speakers
  104. '93 Pathy issues
  105. Weird metal vibrating sound?!?!?!?
  106. 92 Pathfinder replacing the starter
  107. bright white bulbs
  108. Gibson Install
  109. '91 Pathfinder fuel guage problem
  110. '91 Pathfinder starts rough
  111. '91 Pathfinder SE
  112. Terrano stalls when throttle applied
  113. Newbie Audio Questions Size/Type?
  114. Manual Locking Hubs
  115. Fog Lights Wiring Mod
  116. Ping Pong Ball in Dash
  117. Minor Issue
  118. Plz Help Subs Install
  119. 2001 Pathfinder - Brake Trouble
  120. Spark plug gap for 3.3?
  121. Is this a good price?
  122. 1995 pathfinder turn signal trouble
  123. need help
  124. Timing Chain
  125. 88 Nissan Pathfinder V6 Driveability problems?
  126. 01 Xterra Mod Questions
  127. 2001 Xterra with rough when first taking off
  128. Is a 31x10.5 to large for a 15x7 stock rim?
  129. Wheel and Tire Help- Question on Sizes
  130. 91 Pathfinder XE
  131. Replacing O2 Sensors?
  132. 92 Pathfinder sputters a lot when starting to move.
  133. Heater blower confused
  134. '91 Pathy intermittant blower motor
  135. '94 Nissan Pathfinder ABS brake light reset
  136. white smoke coming from vents... help!
  137. how to change front signal bulb
  138. more problems
  139. Interface to Xterra on-board computer
  140. Halo Instalation
  141. 3.0L Upgrade 87-95 Pathfinder 4x4
  142. 2000 Xterra brake light problem
  143. Service Plan? (and way more)
  144. Poll: Owning A Xterra
  145. 2000-2001 Xterra Fog light covers
  146. Rear Speakers
  147. 4wd conversion
  148. Hub too large
  149. What could it be?
  150. Crossbar suggestions for toting surfboards..
  151. 1st post: noise diagnosis
  152. Cabin air filters 98 pathy
  153. '93 Nissan pathfinder...Only starts when it wants to.
  154. 1995 pathfinder se, no reverse
  155. QX4 blower problems
  156. 94 pathy timeing belt question
  157. PIAA 520 Driving Lights
  158. Window Washer Pump?
  159. Differential Fluid
  160. Northern Winter doorhandle problems???
  161. 2002 oem cassette stereo?
  162. special steps/tool for torqueing spindle nuts?
  163. specs for 2k spindles....
  164. pathfinder Compatability
  165. need help in removing a 2002 nissan xterra stereo
  166. 92 pathfinder won't start
  167. After Market Xterra Mods
  168. '05 Speaker Replacement
  169. 93 Pathfinder AC Trouble
  170. What battery would you replace it with ?
  171. Fog Light only switch conversion???
  172. Broken torsion bar - '02 4WD Xterra
  173. Nissan Terrano
  174. 95 Pathfinder -WONT START - AUTO TRANS
  175. 07 high idle
  176. do i have keyless entry on 2002?
  177. Do - It - Yourself UCA Bushing Replacement?
  178. Airbag light blinking
  179. Airbag light reset
  180. cap distributor....
  181. tool for differential plug?
  182. new round here
  183. 2000 xterra suspension air bags
  184. 2000 Pathfinder needs transmission fluid change.....
  185. TPS or Transmission--URGENT
  186. Transmission delays
  187. 94 Nissan Pathfinder Remote Programing Instructions
  188. New Engine High Idle
  189. 2003 Nissan Xterra Modifications
  190. Radio and dome light out
  191. Repair Manuals
  192. 1995 Aurora Fender Replacement
  193. Hidden RUST
  194. 1999.5 Pathfinder Keyless entry programming questions
  195. clunck noise
  196. pathfinder compatability
  197. 2001 Pathfinder SE 4x4
  198. 97 Pathfinder P0305 & P0325 - Need Help
  199. Identifying Speaker leads in 05 Xterra
  200. Replacing fuel filter on a 2002 xterra
  201. 05 xterrs se 58k clicking from front
  202. 1989 pathfinder 3.0l petrol, need new starter
  203. 94 pathy jiggle to start.. mechanics out there HELP!
  204. Spark Plugs upgrade required for SC?
  205. 99 pathfinder idle
  206. How to Install White Gauges in 2001 Xterra?
  207. Slipping belts?
  208. factory cd changer? where!
  209. Regular versus Premium
  210. 93 Pathy. Urgent 10-18. Fuel Injection
  211. ABS Light
  212. Radio Remote Wire
  213. 00 Removal Help
  214. tune up
  215. 99 Pathy turns but won't start
  216. hard starting
  217. td27t into d21 pickup
  218. pathfinder Advice
  219. Timing Belt or timing chain?
  220. Pop Sound In Reverse
  221. speedometer and tac not working
  222. Happy with X-Trail
  223. 2004 Pathfinder Shifting Lag
  224. General & Long term PROBLEMS with QX4's -01-04
  225. New threads not being identified
  226. 00 Full Stereo Install!!??!!
  227. 1988 nissan pathfinder-won,t fire!!
  228. jakes_mom
  229. Is this normal
  230. 2002 Pathfinder LE
  231. 02 Pathy no start
  232. Squeaking Brakes
  233. Replacing Foglight bulbs
  234. Dean mud terrain
  235. Noise when Clutching
  236. Terrano wagon - creaking spare
  237. 94 td27t nissan terrano help
  238. 98 pathfinder wont start after stero install
  239. Tire pressure warning light
  240. Motor / AC belt Squeal
  241. '85 Pathfinder Intermittent fuel cut-out
  242. 97 Pathfinder brake bleeding?
  243. 97 Pathfinder Spark Plug Replacement - Help
  244. Terrano Round Headlight
  245. Infinity QX4
  246. '91 Nissan Pathfinder XE runs cold/cool heat?
  247. Blower on high only
  248. 2000 Pathfinder - bumper repair
  249. U Joints
  250. 2002 Pathfinder Bose Issue (CD skipping, no error message)
