View Full Version : Problem Diagnosis
- 1998 Blazer Strange noise in drive
- 91 S-10 no fuel
- 2001 Jimmy sometimes shifts into 3rd gear high
- 95 4.3 w engine miss
- turns over but wont start--1997-4.3
- Slop in rear axle
- Sloppy Steering Questions
- Service 4WD light lit up last night
- 95 blazer will not start HELP PLEASE
- 96 Blazer runs cool is this typical?
- Service 4wd Light lit up yesterday
- transmission removal 2000 2.2l
- Sonoma 98 king cab 2x4 unknown vibration ?
- Miss on #6
- Steering Box
- 96 Blazer defroster
- PROBLEM now 98 blazer 4.3 v6 just replaced fuel pump
- 1998 starts then stalls 2-3 seconds
- inline fuel pump vs intank fuel pump
- slight engine miss, 1st 2nd gear shifts hard
- turn signal and brake lights dont work
- Leaking fuel filter
- Late 80's s10 starting problem
- Brake code 14 ---- DOA???
- 94 s10 blazer 4.3l v6 vortec engine troubles
- couple of questions
- 93 s10 Blazer, error DTC-35, idle air control
- 96 blazer runs good to it warms up
- 99 blazer
- high voltage reading
- 92 S10 4x4 4.3L Motor Mounts
- '05 Jimmy Long Crank but Won't Start Cold
- White Smoke and Water from Tailpipe
- 98 s-10 blazer I NEED HELP ASAP
- 86 s10 blazer - ecm (1) fuse
- PC/Mac ALDL OBD-I Software
- Brakes not working
- 98 s-10 Blazer When i take my foot off gas pedal or in idle battery power goes down.
- 1992 S10 blazer problem
- 4.3 ZR2 Fuel Pump Replacement ??'s
- 01 Olds Bravada SmarTrac
- 1993 Chevy S-10 Blazer - Hard starting
- 94 S-10 Blazer Not Firing
- 91 s10 idle speed
- brake light on in my 1988 gmc s-15 jimmy
- 96 Jimmy won't start
- WhAt ElSe Is ThErE!!!!
- 2000 Blazer Shifting Into 4WD On Its Own While Driving.
- 96 Chevy Blazer -4x4 not engaging
- 2002 Chevy Blazer Locks do not work after locksmith
- 88 S15 Idles too high when put in gear
- Pads Gone in 20K
- Running Problem
- Flexible plastic brake line?
- PLEASE HELP NO HEAT IN NY2000 cevvy blazer not heat brown chucks
- 92 Bravada (Blazer) stalling on shift
- Transmission stuck in park
- problems with aftermarket cpi unit
- Erratic RPM's when stepping on gas
- 98 Blazer running problem
- Funky Tire Wear
- 2000 LT 4WD Blazer grind noise on acceleration
- 95 chevy s-10 blazer 4x4 stuck in 4w low
- Exhaust Maintenance
- 2004 Blazer 4x4 Issues
- tbi s-10 fuel no fire
- crumby gas mileage please help
- 96 S10 2.2 Idle Issues - Pulling my hair out
- 91 Blazer totally dead
- NEED SERIOUS HELP NOW!!!! please!
- '98 Blazer - Air Not Blowing Through Floor Vents
- 2002 blazer no 4x4 CODE- C0308
- 98 S10 lack of power
- 92 4.3w idles high, no vac leak, new tps, clean egr,code 22
- trying to find away around the speed limiter
- 136K miles on the original brakes!
- Interior Chime and Dome Light issues. Please help
- 97 jimmy transmission problem
- Will not engage in 4WD
- Assist in phone diag.
- thottle body spacer
- Huge error- I put blue autotrac II in the front differential
- Axle code?
- I'm Stranded
- 1999 Blazer trans. issue
- 2000 Jimmy stalls on highway
- 91 s10 air ride.
- Coolant leak
- 99 blazer dash problem
- Starter problem just clicks/HAD NEW INSTALLED
- Airbag Impact Sensor?
- Again transfer case switch failed
- need help ?
- Replacing locks in 85 blazer s10
- '96 Blazer 4x4 problem
- 2000 Blazer Power Window
- How Do I Correctly Test a Relay
- Testing a Diode
- Seatbelt stuck
- Where is the rear fuse box???
- Bypassing A/c compressor
- 2000 s10 ZR2 leveling kit
- 1999 S10 2dr Blazer 4x4 brake fluid master cylinder???
- 85 gmc jimmy v6 manual, cranks but won't start
- 1994 CPI Engine Problems. Please Help.
- fuel pump
- 2004 Instrument panel lts stay on
- Dead 1998 Sonoma
- Service Engine - P0410
- Another Cold weather starting problem
- trans switch wiring
- Problems with 98 Blazer Suspension..Help!
- error codes (2)
- Universal Joint Diagnosis and replacement
- 4.3 motors
- 2001 GMC Jimmy
- 1985 blazer died and locked up
- 2000 LT Blazer Dome/Reading Lights not working
- 98 s10 4x4 wont engage blows fuses
- 2002 Blazer window leak and wind noise
- no fuel on start up
- S10 Crewcab High mount Brake light
- no fuel pulse on start up??
- 01 s-10 blazer blower motor
- 97 Blazer Front Differential Problem
- Gas gauge acting weird. 06 Jimmy 4x4
- 2000 Blazer LT service engine soon
- blower motor 87 blazer
- 95 S10 Heat/Vent problem
- Gap on spark plug?
- 4x4 question
- 97 Jimmy 4x4 3&4 gear shifting problem
- 95 jimmy no start
- 99 Blazer LT 4x4 will not engage
- clutch bleeding
- 99 Blazer without heat
- Throttle Body v. Intake Spacer
- Difference between 2 door and 4 door fuel pump?
- 98 blazer stuck between 4hi & 4lo
- 2000 blazer vibration problem
- PCV noise
- Carb problem?
- 2000 LT Blazer is the worst car
- 01 bravada
- I balancer mark is not set to the timming cover notch
- 97 S10 Blazer 4x4 Problem
- 2000 Bravada front end whine
- Power Mirrors 2003 S-10 Blazer
- miss in exhaust at idle and acceleration
- Jimmy signal light sticks
- Engine swap
- Sonoma O2 Sensors
- Little heat
- 98 S-10 *** Poor Gas Mileage
- P0101 Problem
- 2000 Blazer no start,has spark and fuel help
- I want to check the wires at the BCM
- 1997 S10 PU Vortek
- 4x4 problems...
- How do you check spark?
- coolant leak
- 1998 Chevy s10 P0141 4.3 v-6
- are my calipers siezed
- How Much Labor for FPR Changeout ?
- rpms surge
- EGR Valve Help PLZ!!
- 95 blazer no injector pulse
- s-10 missfire
- 2000 Blazer NOT going into 4-HI
- Need help...replaced the Ignition Switch but now...
- Another 4wd problem
- 95 Blazer Ignition Switch
- stinking ABS light
- 2000 2 door 4x4 5speed manual blazer 4 wheel drive issues...
- Speedo why off, 99 Blazer 4x4
- Where is the Ignition Switch on 99 Blazer LT 4.3?
- Tie Rod troubles.......
- 2000 blazer loss of power pls help!
- 1994 S-10 Blazer loss of power
- 1999 4.3 Sonoma Missing Under Acceleration
- oil leak problem
- 2001 olds bravada off-road & performance ?s
- ???Fuel Line Details Needed???
- 1993 S-10 Blazer Transmission Slipping?
- 1985 s-10 blazer: power loss
- blazer tranny
- Rear wiper problem
- 92 S-10 anti lock warning light on
- '93 GMC Jimmy 4.3L Vin 'W' Running issue
- 93 S10 Blazer 4x4 problems...
- 94 s-10 blazer 4x4 transmission shifting problems
- 1996 S-10 Blazer Lower ball joints
- 1994 S10 Fishtailing
- 95 Blazer 4.3 Vortex
- Driver Side Power Window Not Working - 99 GMC Jimmy
- Fuel Injector Problems 1995 Blazer
- 99 blazer heater core removal pics
- 99 blazer rear discs not applying
- Stuck in 4HI after replacing TC shift motor...
- Brake Problems
- 96 S-10 Heater Blower Problem
- 1991 S-10 4x4 "Check Gauges" light
- 97 Jimmy won't fire/ no lights
- lost in neutral
- My Brother's S10 4x4
- 2002 s10 4.3lV6 won't start
- 86 S10 Blazer noise
- 97 Blazer Shift Solenoid
- Hard to start in the mornings
- 97 Blazer code PO507 replaced IAC still high rpm
- 97 Blazer won't start
- Transmission Question
- Engine light came on, then went away...
- 4x4 problem
- Power Loss
- 4X4 stuck between 2 hi and 4 hi
- 98 s10 starter
- idle oil pressure jumps
- p0147 code-no start/shift trouble-help meee
- Just bought
- 2001 blazer
- 99 blazer 4x4 help
- 4wd noise
- 1999 Blazer 4.3 no spark
- torque converter slipping
- '99 Sonoma 2.2 2wd Flooding?
- 96 S10 2wd 4.3L starting problems
- 97 Blazer - No Heat
- HELP... No sound from speakers!
- Rollover accident! Need help
- Trans flipp'n out
- P0402 Code Now Will Not Start 2000 Blazer
- 1998 blazer 4x4 problem
- 98 Blazer rpm fluctuation
- 2000 BLAZER Ground Strap Question
- 88' S10 Blazer dies in cold.....
- 99 S-10 Pickup won't start
- 87 S-10 blazer 4wd
- 2000 Blazer Starting Issues
- 2001 blazer /wont start
- Ignition Module
- "Service engine" light not coming ON
- 94 GMC jimmy battery gauge drops
- 99 Blazer Battery keeps going dead
- 2000 Blazer LT 4WD Problem
- 96 gmc jimmy 4 wheel drive
- 96 jimmy blower motor
- Need 2000 Blazer s10 4x4help
- Questions on cost for repairs
