View Full Version : Problem Diagnosis
- Rear Diff. Filler Plug!?!?!
- Coolant leak from top of motor/intake
- P0785
- air injection system
- gauges in cluster working/stopping/working
- Flooding
- 4.3L V6 Timing Issues.....
- 94 s-10 no fuel pressure when hot 4.3 cpi
- brake rotor min thickness
- rpms fall off at cruising speeds
- 98 s-10 blazer tranny leak under drivers side door
- help!!! Will Not Start!
- Performance Parts for 2002 Blazer ls
- 06 chevy malibu fan speed control
- dies after 10 minutes
- No wiper fluid 2001 Blazer
- 1999 GMC Jimmy climate control problem
- 89 Blazer Intermittent/Wash Wipe Module
- tranny problems???
- 95 blazer stalled and won't restart
- trailering/towing
- Popping Noise in Tight Turns
- 01 blazer
- 96 Blazer, 121k miles, Starting w/o Key
- 92 blazer shifting issues
- 87 jimmy wont start
- 02 silverado 4.3 to 5.3 engine swap
- trans fluid
- s-10 hot starting problem
- Throttle Control Relay
- front clip swap.....
- 99 radio code #
- Runs rough
- 97 blazer won't start at certain temps.
- Scraping/screeching in tire area on '98 blazer
- which distibutor do I have?
- 2001 blazer noise under distributor cap
- Front Driveshaft removal?
- 2000 Transfer Case
- 96 gmc jimmy no start
- 1996 Blazer... Seized-Broken Calipar Bolts
- '00 Won't Shift Into 4-Low
- 91 S-10 2.5 won't start HELP!
- 1997 2.2 fuel problems
- power is very low..............
- 97 Blazer 4.3 cranks but won't start
- 01 blazer only starts with starter fluid
- Shocking Behavior! (A question about shocks)
- Tachometer for 1996 blazer
- ODM II scanner will not operate on blazer
- 2004 Blazer No Start
- Hard start, run, idle, it doesn't do anything right.
- ac, fuel pump connection??
- 97 Blazer radio problem
- 4x4 not engaging
- 2001 Chevy Blazer Loosing power / coughing
- 2000 GMC Jimmy
- PO455 2004 Blazer
- 02 silverado 4.3 timming retards (sometimes) during hard acceleration
- What else to look at?
- 01 Bravada SES light
- 1996 Bravada wont start
- Wiper Fluid leaking from tailgate
- HELP!!!LOUD whistle on drivers side of carb ...
- door roller popping - not hinge pin
- Tail lights won't work
- stalled while driving/wont start
- 2000 blazer 4wd, 4.3l low oil pressure? HELP!
- Check Engine light on/CODES PO101 & PO174
- 1989 Blazer hard to start when cold and.....
- non-hinge pin door noise roller help!
- rattles your teeth
- timing marks/balancer Top Dead Center
- a/c
- Help! Starting issue
- 95 blazer 4x4 wont go in 4 high?
- 95 Chevy S10 fuel pump relay switch
- 99 Blazer
- Blown Head Gasket???
- 2001 with fuel problems
- 99 sonoma 4x4 front hubs
- 2000 Blazer, belt Squealing, loss of power.
- 1994 S10 Blazer confusion
- 97 Blazer acting up need help
- V6 Blazer won't hold fuel pressure
- Brake Switch
- What hose is this?
- Replacing Nut Kit and Fuel Pressure Reg. ??
- Shift cable replacement
- gas filling problems
- y-pipe challenged!
- High fuel pressure
- Cruise Control Cable
- ABS light causing big problems!
- 1998 Blazer,ABS problem
- Replaced Distributor FUBAR
- 2003 s10 transmission problems
- Fuel Pump or Relay ??
- starts fine then warms up, then no start
- Noises from 95 s 10
- 2001 blazer
- bravada bogs down and bucks when hot
- door locks constantly doing something
- YIKES!!! Bad whine while driving '99 S-10 ZR2 4x4 w/4.3, auto trans...
- 99 blazer turns over no start
- Wiring up a trailer light plug
- 1988 s10 runnin rough
- jimmy idle and airbag
- 98' Chevy Blazer Cranks but wont Start
- 1992 Chevy s10 pickup / Transmission need help
- 1994 Blazer wont start
- 1998 Jimmy problems
- 99 Blazer Bad gas millage fast idle
- Jimmy Running Crappy?
- 99 Jimmy SLS would not start this morning
- 96 blazer tune up need help....
- Starting problem
- Hard to start when warm 2001 4.3l 4wd
- Main seal leaking slightly
- 99 Blazer Auto transmission problem
- 97 JIMMY SLT Won't shift out of 4HI/4LO to 2HI
- 92 state truck
- 99 Blazer won't go into gear
- ECM replacement
- 91 4.3 Injectors Will Not Pulse
- 2000 GMC sonoma surging at idle and stop signs p1133+1153
- How do you time this thing?
- 96 blazer new radiator still over heats
- 91 4.3v6 keeps burning up coil
- Power locks not working 97 Blazer
- No start 1991 sonoma 4.3 2wd
- Pinion seal -92 s-10
- S-10 hard 1 - 2 hard shift
- headlights dead?
- 92 Jimmy Dies When Idling
- 1996 s10 swap to a 1995 s10 won't start
- 97 bravada backfire won't start
- audio, dome light problem
- grinding
- 94 s10 blazer 4.3 high oil pressure
- truck serging and hard shifting
- Gotta' pull the blower, '98 Jimmy 4.3. Tips?
- 97 Jimmy engine swap
- Front driverside brake locks.
- Total shutdown after 5 seconds.....
- 04 blazer with a strange noise from the transfercase
- o4 Blazer
- rear brake problems again and again
- S-10 running rough
- no spark at coil 2000 bravada
- Low speed brake failure
- 99 zr2, pulling engine with transmission easier on zr2 vs non zr2?
- hints:? on replacing 97 d Dr. fuel pump
- 87 Blazer TBI no fuel
- 97 Chevy Blazer, Possible Ignition Trouble
- vacuum lines?
- 1988 s10 vacuum?
- acceleration problem
- Emissions test
- vacuum lines?
- ABS Sensor Broke Off inside Hub----HELP !!
- Signal Lights not working.
- 99 blazer 4wd
- 97 blazer
- Rear disc brake Plates
- 1999 Blazer Gas Gauge Reads Empty!!
- won't clear codes
- 2002 Blazer transmission slipping
- Blazer Stalling
- Hub Assembly Diagnosis
- Key in alarm
- 1989 4wd Blazer, solid axle... please help me!
- 98 blazer new problem lol
- Rear Diff OIL WEIGHT 98 blazer
- Rebuilding a steering box
- Pulling Heads for Exhaust
- Rough starts - poor mileage
- 95 blazer stuck in 4lo and keep blow 4wd fuse
- 1999 GMC Jimmy hesitation issue
- fire no fuel
- s10 Blazer only starts when cold
- Knocking sound under Jimmy during cold weather
- Blazer Grunts when going over Speed Bumps
- 96' Blazer - Starts and Dies after 30 Seconds
- 2000 Blazer electrical shutdown when starting
- Codes 0171 and 0174
- Spark Plugs for S10 4.3
- '99 Fuel Pump??
- 98 Jimmy 4.3l blows batteries? I hate electrical lol
- Mass air flow?
- 2000 blazer stuck in auto 4wd
- 95 Jimmy #4 cylinder misfire
- 95 blazer fuel problems.
- 99 Bravada many problems
- 1995 blazer Engine Performance problem
- ABS light on after changing hub
- 2000 Blazer Wont Start
- Replacing S10 Blazer Starter Solenoid Question
- '03 Blazer wont start...tried everything I know
- 92 blazer dies when put into gear
- About how long and any tips on replacing front pass fender?
- TPS Problem
- leak in oil pan 2000 chevy blazer LT 4WD
- Locked front brakes, brake light out, headlights gone
- 2000 blazer won't start after major oil leak
- code 43
- Rear hatch window struts
- 98 blazer power problems. need blazer expert!!!!
- 2001 S10 blazer
- 97 S-10 blazer front drive shaft
- 2000 jimmy p0122 again.. help
- Chevy s-10 Knock sensor problem
- S10 Blazer Transmission Code and Serial # decoding...
- 2000 Blazer 4wd Question...
- 97 Blazer potential flooded engine?
- Transmission Problem Please Help
- 2002 4.3 blazer misfireing at level speed only( PO 128 Code)
- Transmission problems
- Just crappy parts?
- 91 s-10 2.8 TBI eng.
- 99 Chevy Blazer Pitman Arm
- s10 4.3 w
- GM1O GM8 block 96 s10
- 2005 Blazer, 6 cyclinder, 4x4
- Driver's side crank window fell off it's track, UH OH
- overheating, no heat
- electrical problem...sometimes
- 1998 Blazer Strange noise in drive
- 91 S-10 no fuel
- 2001 Jimmy sometimes shifts into 3rd gear high
- 95 4.3 w engine miss
- turns over but wont start--1997-4.3
- Slop in rear axle
- Sloppy Steering Questions
- Service 4WD light lit up last night
- 95 blazer will not start HELP PLEASE
- 96 Blazer runs cool is this typical?
- Service 4wd Light lit up yesterday
- transmission removal 2000 2.2l
- Sonoma 98 king cab 2x4 unknown vibration ?
- Miss on #6
- Steering Box
- 96 Blazer defroster
- PROBLEM now 98 blazer 4.3 v6 just replaced fuel pump
- 1998 starts then stalls 2-3 seconds
- inline fuel pump vs intank fuel pump
- slight engine miss, 1st 2nd gear shifts hard
- turn signal and brake lights dont work
