View Full Version : Problem Diagnosis
- blazer wont start
- blazer wont start
- dummie lights
- 1996 4.3 GMC Jimmy voltage drops
- vibration problem!!!
- Desperate! - Stumble above 2200 RPM
- Gradual Overheating
- Fuel Gauge not reading correctly
- Striped Distributor shaft???
- REAR turn signals and brake lights not working
- 1999 sonoma lugging [cutting out]
- 89 s10 blazer TC question..
- 99 keyless entry troubles
- 98 Blazer, Tranny problems or something else
- 89 S10 Blazer a/c-constantly cycles
- 88 Blazer S10 Tranny
- abs & break light
- Lights on 4x4 panel stay lite ???
- idle problems
- Front end Vibration?
- 99 brake sticking issue
- Broken starter, corroded wires, or seized engine?
- Reasonable cost fuel pump
- Directional flasher
- Downstream O2 sensor?
- 86 s10 tbi trouble I'm stumped please help
- 1995 Blazer 4x4, Re-Install Distributor, Help to set timing pls. TDC, BTDC
- map sensor 1999 blazer
- s10 engine rebuild question : pistons
- 2001 Blazer Code P1870 HELP!!!!!
- Oil pressure switch or not? HELP! 1996 v6 s10
- torque specs 99 4.3L
- engine cuts out over half throttle
- Cost Of Replacing 98 Blazer Intake Gasket & Lifters ??
- 2000 Blazer cruise not working, skicky pedal
- 93 bravada fuel line replacement
- 1999 Blazer LT and lower ball joints? Help, Please!
- 96 bravada keyless reprogramming
- vacuum problems
- '92 Blazer dies after 2 seconds
- Problem with blower,,i think
- 03 possible blower problem..
- 01 bravada, engine dies on decelleration
- 96 blazer stalls and abs/brake idiot light comes on
- Sounds like a Vacuum Cleaner 97' pickup
- Power Seat Fix?
- reprogramming with GM Tech 2
- Can't get the key out
- NO A/C in my Jimmy
- 1998 Sonoma SLS 4x4 4.3 Auto P0404 Code
- running hot
- Heeellllp!
- 98 S10 PU 2.2l Voltage Fluctuations
- 95 Blazer wont start
- 88 S10 a/c problem
- tranny swap?
- keyless entry, how to disable horn chirp?
- Need help with antifreeze leak
- How to test a sending unit
- 02 testing
- 2005 CRV Accessory Plugs not working
- Temp and Fuel Guage not working
- 97 Jimmy intermittent cranks but won't start
- Did anybody fix there misfire problems????
- 2000 Blazer Fuel pump ?'s
- Misfiring Woes
- Misfiring Woes
- 2000 S-10 Engine chugs, then dies
- AC 1996 4 cyclinder S-10
- 1994 chevy s10 starts idles good but when u give little gas back fires.
- "ABS" and "Brake" lights come on same time
- Did I kill the blue box
- 1995 jimmy transmission and possible motor change??
- No 4WD-1995 Blazer
- body work help
- 00 blazer, taillight problem
- stalling when stopping
- Banging noise when turning left
- '98 just flat died one day
- 2000 blazer accel problem
- don't buy this.. it doesn't work
- Wheel bearings?
- Digital dash dims with headlights on.
- Speakers cut out when car is on or running. Ideas?
- no second gear
- 97 Jimmy Transmission
- 1995 Blazer Needs New Power Steering Pump
- Coolant Temperature Sensor
- S10 stalls at traffic lights & spark knock
- OBD-II, data logging on a '95
- Optima Yellow Top died suddenly after only 3 years
- 96 Blazer codes (what do they Mean)
- a/c compressor swap
- transmission
- Pinion Seal Replacement ?'s
- 97 Bravada windshield wiper problem
- 96 GMC Jimmy
- 2004 Chevy Blazer headlight bulb replacement
- Rear main seal question
- Bank Repo Ignition
- Do I need to replace the thermostat?
- Front drive axle on smart track
- 97 Bravada reset OBD II codes
- 98 Blazer no a/c light flashes 3 times
- 93 Blazer A/C Doesn't Work
- door locks unlocking when keys shake
- 2001 blazer rpm going crazy
- 2000 jimmy voltage gauge fluctuation
- Electrical Problems
- 4WD problem
- Aircon/heater fan problem - '94 Jimmy
- Where is the oil filter?
- 93 s-10 blazer signal lights won't work
- S10 2.2 liter electrical problem
- EGR test?
- 95 Blazer and 96 Cavalier Battery or Electrical problems?
- 97 s10 drivetrain issues
- 89 jimmy won't rev high
- 97 blazer stalling
- 98 blazer trailer wiring
- 1984 s-10 Overheating problems
- 91 sonoma starts, but sputters out, see if you can figure this one out!!
- Losing Oil Pressure
- 95 Blazer no start
- Smoke!!!
- 4wd again on 98 Blazer
- Neutral Safety Switch
- Check Engine light
- New brakes trouble
- PCV Problem on a 1997 Jimmy
- Front End
- '94 blazer brake issues
- Fuel pump and sending unit oddities
- 94 Blazer won't crank over
- 01 S-10 Idle and power missing problem
- 2000 jimmy key removed beeping sound
- Air Conditioner Accumulator replacement
- 99 Blazer ABS light staying on?
- snow plow
- O2 Sensor test
- 2000 Sle Ecm/pcm
- i got a rear problem with my bravada
- Shocks: 99 Bravada
- my truck won't star after intake gasket. timing problem?
- Proramming Needed
- 00 Jimmy runs rough after start up
- 97 blazer long crank won't start cold first try
- OBDII codes P0101, 131 and 143 on 2000 S-10
- blazer not starting (no dash lights)
- check the engine lite flickering then on.
- 91 will not go in rev. or park
- codigo P0756 shift selenoid ``B`` Blazer 98
- Full Size 1991 Chev Blazer
- 4.3w low power
- Hatch and Power seats
- Squeaking noise from front right wheel
- Starting Problems
- 1994 olds bravada possible bad transmission
- 1992 GMC Jimmy Runs BAD intermitently
- Cat. converter test
- 92 Bravada digital display problem
- 92 Bravada automatic no 3/4 gears
- 1992 Jimmy
- Rear Brake Shoes 96 LT
- 00 S-10 won't start
- '93 Blazer check engine light on....help!
- '93 Blazer...check engine light on
- Starts then dies
- Passing Smog Test
- Starter problem?
- 4x4 Engages by Itself
- Rust inhibitor
- 4wd
- P0122 TPS - Replaced, No Dice, Now What??
- missfire
- HEI coils going bad..
- trans fluid in vacuum lines
- KC Lights - tapping into Highbeam 12V
- Got a question, 98 4wd Blazer
- 2001 ZR2 wheel noise?
- S-10 Emission Problems
- 98 blazer
- 95 4x4 problem
- 85 4.3 into 95 blaz 4.3 vin w
- Hey people s10 -throttle sticks..
- Oil Issues and tapping sound
- 98 Blazer Turn signal/blinker problem
- Air conditioning flow.
- 2000 bravada a/c
- Fuel Problems in 96 Jimmy
- fuel problem no start on 89 4.3
- 1997 s10 blazer high mount brake light (chmbl)
- 2000 transmission
- 96' Replaced Oxygen Sensors
- Trans swap checklist
- vacuum diagram 95 blazer heater controls
- fuel pressure
- Where is the fuel pressure regulator 2001 4.3
- Oil change in 2000 Bravada
- 2001 4x4 Hub Bearing Assembly Stuck HELP
- brake problem, VERY hard brake pedal but VERY little braking power
- keyless entry
- 4l60E Solenoid problems
- 1998 Chevy Blazer PROBLEMS
- Fuel problem - Long post
- starting problem
- multible misfire problem please help!!!!!!!!!!!
- 2000 Bravada, new shocks causing clanging noise
- Anyone replaced a 96 transmission before
- Hard starting cold
- transfer case control module
- 2000 S-10 Rusted front shocks
- Need Opinions on my '98 S10
- exhaust leaks
- wiring problems?
- a/c problem
- can these tires fit?
- oil hose
- A New One
- 2000 Blazer short in the stop light system, help :(
- 1995 4.3 A/C compressor clutch problems
- 94 s10 blazer 2wd oil cooling lines?
- 98 s10 2.2 running rich
- Turn/Hazard Switch Clicks all the time.
- runs good on idle and when there is strain on the motor
- 98 Blazer heating problem
- Body Mount Repair
- truck dies @ stop light or brake a little to hard
- 95 s-10 blazer shakes when I reverse...
- Chevy 92 Blazer 4x4 HELP!
- Is this an ok price?
- 1996 s10 blazer dieing
- $$Cost$$
- Fan clutch question
- clock on the radio
- 1999 4cyl PU no power.
- low oil press, valve tap '99 4X4
- 95 Blazer 4WD 2D Fuel Mystery Challange
- electric window going off track....
- Blazer Tranny Fluid and Smoking Engine
- Battery drain
- Check engine light
- 97 blazer - no start confused
- dust covers
- 4WD not engaging
- programing my homelink in my 98 blazer
- Possible alternator issue???
- mass air flow sensor
