Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Nissan
> Sentra/200SX (USDM FWD) |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
Help How to change power steering belt 96 sentra
04 sentra advanced timing
Plans for my Sentra, I need opinions.
Various problems with my 1992 Nissan Sentra XE (4 door)
1996 200sx 1.6, i need mod info~!!
Blower only works on super high
2000 sx will not start
How to get into ECM Diagnostics mode
power steering pump question
Sentra caliper paint
Needs GA16DNE Workshop Manual
Need Timing, new head gasket installed.
2004 Sentra rough start/SES light on question?
2006 Nissan Sentra, Carmax- 11500 (30k mi) (ripoff?)
For Sale: Turbonetics Spec V turbo kit 04-05 $3400
FS: Turbonetics Spec V turbo kit 04-05!! $3400
1.6 and 2.0 used in sentra
changing a starter
Power Window Master Switch
Whining sound from Nissan Sentra engine
inop gauges,2000-up
Big problem with my transmission
Lowering Springs Installed
Whether car frame was damaged in an accident when it was hit on the rear bumper?
Where is the oil filter?
odometer and trip meter dont work
change alternator in 95 nissan sentra
rebuilt ECm
95 200sx when the car warms up smokes?
Looking for info on the VCT system
A/C problem
Canadian Nissan owner: Warranty question
1997 engine swap
need help....
03 Sentra GXE Fuel Pump Assembly
Oil light on with full engine oil
'08 Sentra rim sway-what fits?
grinding??
shock installation wowes
what body style is my car
2002 Nissan Sentra Noise Advice
Head gasket/timing advice
Do all 95 1.6 Sentra's come with the NVTCS?
revs high then back to normal.
B13??
Can anyone provide advice?
Quick Question
blue smoke and a sputter at start up
2001 Sentra ECM Replacement, What to do?
Sentra 2006 Bearing change
Please help, stumped.
2008 Sentra
Nissan Sentra intermittent reving while driving.
Exhaust Opinion...
Sporadic Charging Dummy Light - Loose Connection?
fuel gauge not working 2006 sentra
Fuel Pump Relay Location 95 Sentra???????
1993 Sentra 1.6 Surging
car lock
** 2006 sentra transmission service **
Upgrading my '93 Sentra XE
Need info. can anyone help?
Front Cranksahft Seal
Dead in the water
ebay turbo spec v
93 Sentra 1.6 misfiring
New to the site
2003 Sentra SpecV Brakes
motor and trany swap
97 Sentra Electrical problem
2002 Nissan Sentra GXE No heat
se-r spec crankshaft sensor
SR20DE Turbo Manifold
94 SE-R steering problem
Nissan Newbie
Hoe do i restart computer
Will these tires work?
fans dont turn on.
Fuel Pressure Test Port
Re: Steering problems
nissan sentra
Cooling Problem
01 sentra air/fuel sensor
14 inch tires on 204 sentra
Replaced MAF sensor and ODB code still comes out as P0171
08 Sentra: Good buy?
Want To Wire Alternator To The Battery
'03 GXE Axle Nut Size??
'03 GXE Front Wheel Bearing Question
89 sentra removing radio
Ignition timing and Distributor Question.
Posting for a friend...couple questions to people who know their SR20's
2004 Sentra timing belt replacement?
95 200sx se-r dash lights not working?
oil leak
abs on '05 sentra se 1.8
Help failed smog check, 99 1.6 Sentra
no crank no start.
code
90 sentra cooling fan not working......
02 Sentra Speakers
Help, loose hose 99 Sentra, Pictures inside.
Best place to pick up some brake parts
87 Sentra
...educate me?
2001 Sentra jerking problem
93 sentra problems
Car dies when on idle in the morning.
how do i improve horsepower on 2007 Sentra 2.0?
vacuum hose diagram,00 sentra 1.8
Power Window Relay Help
Cruise Control Not Holding Speed
2008 Sentra - Larger Oil Filter ???
WTF! My 2000 Sentra Did NOT Pass Smog
Power door lock - defroster - interior lights, Not working =(
car makes white smoke but not overheating
Need help reattaching the side mirror
96 200SX SE Auto Timing Belt issues
2003 spec v head bolt torque value
04 Sentra right front rattle/noise
Wtf?
99 Sentra engine rotates but will not start
Did Nissan offer a NISMO edition of 2003 Spec V
whistle sound when turn on and off
hydraulic lifters
93 Sentra charging issues
Flashing O/D light
96 common a/c problem=??
cut the 96 cat converter=??
Turbo?
Inside Door handle bent
Is this true?
2006 Sentra Radio Help Sirius Radio Hook Up?
Sentra project
2004 sentra se-r spec v stalling help!!!
Pilot Bearing Repair - Shop or home mechanic?
Overheating!!!
Window freaking out!!!
2002 nissan sentra gxe key won't turn in ignition
How can you figure out what CAT is going out?
HELP!!! Sentra 2001 ECU Problems
Gutless 97 GXE, can't figure it out
Gas Grade Question
nissan sentra hard starting
Cruise Control
turbo sentra?
Front end vibration
91 sentra AT shift issues
Revs Drop and Engine Stalls Out???
An Absolutely Hilarious Story!!!!!!
clutch issues after a 4 wheel replacement and front end alignment
97gxeMT 1'st gear wont work
Engine Squeal!!!!!
New Sentra SE R torque peak...
Cam gears reverse thread?
87 Sentra Q:
92 Sentra Govenor Gear?
head swap?
Wtf!!
Headgasket issues perhaps?
Knocking in front suspension
2001 sentra 2.0
Nos
2005 transmission flush *need advice/info*
Bolts for caliper bracket
kaminari body kit
'03 Rear Brake Question
96 Sentra alternator draining battery
FYI: Brake lights and Cruise Control not working
2000 Sentra SE 2.0 Engine Idle problem STALLS OUT!!! HELP!!!
Bogging Down
Bogging Down
96 200SX Won't Start
1991 Sentra
1991 Sentra no start
hard starting
01 Sentra SE Idle Fixed
air intake problems
2005 nissan sentra 1.8l problems
01 Sentra Won't Start
Idle Problem - Sentra SE 01
O2 sensor on 96 sentra
Fuel Filter Flow Direction
Any idea of what this sound it?
programming keyless remote.
Please help!!!
2002 Nissan Sentra engine dying.
94 Sentra Help
04 sentra factory radio question...PLEASE HELP!!
Tires Sizes and Suspesion Kit.
Stalling only during idle...
HELP for a 1999 Nissan Sentra
Idle , hesitation problem 2000 sentra
I need another Ga16
thread size on ball joint nut?
Are new wheel bearings necessary when installing new axles?
FS Cams + WRP Variable Exhaust Cam Sprocket
2007 se r
B13 Injectors
Need Help My Only Car
Launch control
Launch control
Stripped Spark Plug ?
Remote Keyless
wheels spin when accelarating full throttle
Sentra "freezes up" - Please help!
2001 Nissan Pulsar(Sentra)Aircon HELP Please!!!
t3h shennanigans thread
1991 Nissan SER half shaft
Code P0183 Fuel Temp Sensor??
1999 sentra 1.6 wont start
SE-R rim advise
Overheating/out Of Oil
driver's side mirror popped off
Resident Technician
Shifter boot
tranny doesn't shift outta 1st
A Few New Pics
1.6 sentra racing fuel rail
Not sure what this is.
new to nissan
Stock Steel Rims
Gauge faces...
Service Engine Soon - Air pressure in gas tank
nissan sentra miss out
91 sentra coupe 1.6
Oil dip stick broke off
How Do you Turn Off the CEL Light
water leak
wont stay running...
1990 sentra performance help
Nissan Sentra SE 01 Fog lights
92 sentra 1.6 swap to sr20de
Belt issue . . .
Problem Starting.
Leaky windshield glass/roof
2003 Sentra question: Low fuel Pressure
Opinion's Please
Should timing chain be replaced?
Short Ram Intake for SpecV?
Knocking Sound in Right Front Wheel
Rust Prevention/Undercoating
Need help with power locks
FS:02 Spec V in socal
1998 Sentra GXE: Replacing speakers, stereo, maybe fan switch.
Atf level----does anyone know?
turbo spec-v help
1998 nissan sentra trans slipping. Please Help
1994 Sentra coolant system (1.6)
Web
AF
