View Full Version : Sentra/200SX (USDM FWD)
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12
  1. Sentra E (2 Dr.): getting a 2.0
  2. sr20de to det ecu?
  3. Check engine light on/off
  4. Wheels and Deals
  5. Sub Placement
  6. New. NEED ADVICE
  7. Got a spare intake manifold.
  8. Engine question...
  9. SpecV Lip kit...Where???
  10. nismo header w/ cat
  11. 2000+ halogen lights
  12. Help!!:Start noise
  13. SER20 Turbo or NA???
  14. Spec V adjustable Coilovers
  15. 04 SE-R Spec V vs. 93 Honda Del Sol
  16. Knock Sensor
  17. interesting find...
  18. sr20det vs ca18det in b12
  19. 1991 Nissan Sentra E dying while idle
  20. 99 sentra...where is the starter?
  21. 02 Sentra SR Spec-V?
  22. SR20DET in 91 Sentra
  23. Best engine swap of 04 SE-R Spec-V
  24. Trouble Code P0171 System too lean (Bank 1)
  25. where is throttle pressure cable?
  26. Foreing questionings, Sentra b13 Ga16Des (carburator)
  27. Help With Power Please !!!!!!!!!!!!!!
  28. SE-R engine for sale
  29. 91 sentra auto tranny won't shift
  30. Hose connected to fuel filter
  31. Where can I get a pre-made mesh grille?
  32. Are Sentras for girls?
  33. (iat)
  34. Got a few nissan sentra spec v questions??
  35. Are '84 and '85 tranny's interchangable
  36. new 98 Sentra owner...need advice on upgrades
  37. 1991 Nisan Sentra SE-R 2.0
  38. Make it fast
  39. Engine Swap / Sentra to 200SX HELP!
  40. 94 sentra xe gauge cluster swap
  41. radio prob
  42. 2004 Sentra 1.8S
  43. I'm Looking for some parts
  44. Spec V Exhaust...
  45. whining noise from engine area?
  46. 95 sentra air compressor belt replacement
  47. Does a bad IACV affect smog check ?
  48. sentra 92 1.6 cat back
  49. Front Door Pannel Removal ( Speekers! )
  50. 94 Sentra SE shake
  51. JWT CAMS and ECU
  52. Drum To Disc ???
  53. 5 spd tranny
  54. nissan sentra - check engine light
  55. 04 Spec V, SR20DET SWAP???
  56. svt focus 2door vs 04 spec
  57. 2003 nissan wont start help me please!!!!
  58. 96 Sentra trouble code 94?
  59. 98 sentra - fan problem
  60. Oil leak?
  61. Steering shakes, Car pulls to the right and Noisy..
  62. Nissan SE-R Stock 5 Spoke Rims for Sale!!
  63. Stereo system question
  64. How to clean IACV ?
  65. How to change starter on 98 Nissan Sentra?
  66. Turn-off check Engine Light ??
  67. coolant control valve?
  68. Question
  69. airbags on a 96 nissan sentra
  70. keyless
  71. Stuttering, Possibly Hesitation
  72. se-r vs civic si
  73. Dealer lost my key...Any Advice?
  74. My headliner is falling
  75. 2 questions bout 01 SE
  76. correct way to drive auto?
  77. power locks acting up
  78. Crazy turn signals
  79. Bad Fuel Pump?????
  80. weird noise after header installation
  81. motor
  82. would the 1.6 make the trip
  83. intake-air-temperature sensor
  84. GB: JWT s3 cams
  85. Official SE-R Video Thread!!!
  86. ?
  87. 97 Sentra XE
  88. Ga16i into SR20
  89. *NEW* 91-92 Nissan Sentra corner light
  90. *NEW* Genuine Nissan Sentra SE/SE-R Bra!
  91. 94 nissan won't start
  92. what are the gears top speeds?
  93. What's the P.S.I. on your tires???
  94. What do do with extra dash slot
  95. video of ser
  96. ser , spec-v engine difference
  97. K N filter Burns out mas sensor
  98. ga16de swap out
  99. Thermistat location?
  100. help with turbo!!
  101. 1999 Sentra GXE ATX - Shifting Hard & fuel filter
  102. Radiator fan not switching on
  103. How do you launch your classic se-r's?
  104. Exhaust Smoke and Hesitation-Help!
  105. sr20vet?
  106. Soon To Be A Sentra Owner?
  107. timing marks
  108. techinical questions
  109. nx2000 to sentra
  110. Wheel hopping with the Spec V
  111. carbon fiber trunk
  112. SE-R vs Sunfire[video]
  113. buyin sentra
  114. valve order???
  115. Headlight options
  116. 94 sentra problem
  117. no start - no check engine light
  118. all possible performance mods,and hp gains?
  119. Replacing third brake light on 2002 Sentra
  120. intake
  121. Nissan Sentra Cold Air Intake
  122. assdrag
  123. sentra spec v vs rsx-s vs celica gt-s?
  124. 1992 Sentra tach???
  125. Installing Altezza Taillights
  126. 91 sentra
  127. 92 sentra se wheels
  128. quick mod question
  129. 1991 snetra se-r questions?
  130. Tail Light Wiring Guide Needed
  131. Spec V torque steer gonna kill a noobie?
  132. passing smog
  133. overheating.......
  134. sentra sleeper
  135. sr20det on gas
  136. 1987 nissan sentra rear hub/brake assembly
  137. Torque vs Hp
  138. Anybody kits would fit possibly?
  139. 1988 nissan sentra sputtering and stalling
  140. Passenger side door lock ?
  141. engine website
  142. Are these all around good cars?
  143. JDM body kits for 89 sentra
  144. new grille for my 04 specV?
  145. Newbie question about a B13 and Nitrous
  146. Parting out a 1994 sentra xe
  147. For All Sentra Engines
  148. sr20det
  149. '94 Sentra starting head scratcher
  150. whats spec-v's best mod
  151. What happens if you get caught with illiegal mods on your car in the us?
  152. I am geting my grandma's sentra
  153. Some minor probs i hope
  154. 2002 Spec-v Rack and Pinion Problems
  155. Changed motor and now no spark '87 Sentra
  156. A Quick lesson for b13 owners
  157. Pop Sound From Muffler !!!!!
  158. r-34 kit for my 2000 sentra
  159. Changing IACV ?
  160. Sentra SER : ABS Problem
  161. Brake Question
  162. Which Air Intake???
  163. 1999 Sentra GXE - Suspension problems?
  164. Good First Mod?
  165. 1996 nissan sentra dashboard lights
  166. Nissan Sentra Wiring Diagram
  167. oil problem on 89 sentra
  168. Se-r ???
  169. Gauge cluster swap
  170. poping sound from SE-R sub
  171. got killed list
  172. engine swap
  173. 13.7@108mph in my 04 Sentra!!
  174. Ga16de wiring problem
  175. Nissan H8Rs
  176. The new Front end!
  177. 94 Sentra Question + Problem
  178. 01 sentra se
  179. question on 96 sentra parts
  180. nismo parts for the b12
  181. how much HP 93 SE-R
  182. Alternator compatible with stereo?
  183. 2005 spec-v
  184. 93 sentra deck installation help
  185. looking into getting cams???
  186. exhaust for SE 2.0?
  187. b13 update
  188. 92classic
  189. Turbo 2000 Sentra FS---->PICS!!!
  190. has anyone upgraded there brakes on the sentra se-r
  191. wiring a 200sx tach into a 96 sentra
  192. what should i get? help plz
  193. full pillar gauge pods
  194. a/c help pls!
  195. AEM CAI filter removal
  196. why am i losing power?
  197. RSX-S or SE-R Spec V
  198. 83 sentra
  199. Help 89 Sentra
  200. buton on gearshift 1990 XE
  201. e-check in Ohio?
  202. ga16i
  203. Performance Parts
  204. Faster Signals ???
  205. Want an SE-R in Gran Turismo 2?
  206. F/S: SER Rims & Tires
  207. Greddy EVO II + HS Header?
  208. '04 spec V second gear whining noise
  209. IAT Sensor Location
  210. ECU coding?
  211. Drive train / timming belt
  212. Msd Ignition Help
  213. '04 Spec-v performance parts
  214. Got my first ticket in my Spec V
  215. I hope you all are not like this guy.
  216. I got a good little scare today
  217. Picture in Threads
  218. GAUGES PROBLEM >>>>
  219. auto-tranny leak ?
  220. 93 XE, power steering?
  221. Transmission Help !!!
  222. help with a cracked intake manifold...
  223. 94 Nissan SE-R or 92 Honda Accord EX
  224. Are those intakes on ebay any good?
  225. r34 lights on a b12?
  226. Just put my 93 back on the road and it drives like its choking...
  227. 2002 specv...need info
  228. sr20ve or det
  229. Balance Shaft removal
  230. Help with my sentra pleaseeeeeeee !!!
  231. 89 Sentra...Able to be SR20??????
  232. How much is it worth??
  233. bodykit
  234. turbo charging an 89 g16
  235. '04 SE-R better than '02-03' SE-R???
  236. Tranny Sticking in 2nd
  237. replacing front main crank gasket, anyone have a clue?
  238. stereo question
  239. brake bias
  240. 1988 sentra xe
  241. Good name brandes anyone know the best one??
  242. First Brake/Battery Lights on - Now Won't Start
  243. need ipod install help
  244. SELLING: Stillen Front Spoiler for 00-04 Sentra Non SE-R, Brand New
  245. squeaky sound when accelerating from stop
  246. extra hp suppressed in the stock exhaust?
  247. Tomei SR22DE in Australian FWD N14 SSS Pulsar
  248. What does "SE-R" stand for???
  249. sentra headlights
  250. 1992 Sentra Strereo Wiring Guide?
