View Full Version : Sentra/200SX (USDM FWD)
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12
  1. Honda to Nissan Wheel Swap?
  2. 95-99 B14 Sentra/200sx KYB GR2 Shocks/struts BRAND NEW FS
  3. 1995 Nissan Sentra
  4. 1998, 1999, & 2000 Sentra SEs
  5. Fuel problem with '84 Nissan Sentra?
  6. crankshaft seal replacement costs
  7. 90 Warms Up=no Fuel
  8. Can Someone Help Me With My Stereo Problem???
  9. 1997 Sentra not getting fuel
  10. Body Kit Questions For My 03 Spec V
  11. 200sx upgrade path?
  12. new sentra owner
  13. replace timing chain(s)
  14. 04 spec v
  15. I don't know how to race my spec v. Advice please
  16. cv axle
  17. crankshaft seal replacement on sentra
  18. 92 SENTRA HIGH NOx Emissions HELP!
  19. water pump replace
  20. B13 Bumper Question
  21. car makes noise at high speeds
  22. drive belt replacement
  23. What size is my air filter tube?
  24. 05 Sentra
  25. Front Bumper Swap
  26. Sentra Mod. Parts
  27. 2000 sentra gxe keyless entry reprogramming
  28. Whats a good clutch kit for my 2.5Lspec v ser 03?
  29. 2004 Sentra has occasional hard start
  30. bad cv joint on 1993 nissan sentra
  31. how much to replace a cv shaft
  32. sr20det drop in 88 sentra
  33. shift kit for auto ser
  34. cv joint on 1993 nissan sentra
  35. broken gauges... (suggestions?)
  36. Starting Probs - Mechanic Thinks We're Crazy
  37. 2000 Sentra OEM alarm not working, Help
  38. my 88 nissan 200sx will not start
  39. FOR SALE WRECKED Nissan Sentra 2001 GXE
  40. Knock Sensor in '02 Spec V
  41. Rotor REmoval
  42. shift knob help
  43. 86 nissan sentra tranny installation problem
  44. Sentra Swap Help
  45. wiper blade confusion
  46. Tune Up
  47. water pump on 1993 nissan sentra
  48. '02 SE-R (Spec-V) Won't start.
  49. 97 Sentra Parts forsale
  50. please help me sentra 87
  51. NX Troubleshooting
  52. Rumor or not
  53. Sentra Cap and Rotor HELP!
  54. B13 se r for sale in miami FL
  55. Car Wont Start
  56. Idling issues with '97 Sentra
  57. more power in a 94 sentra
  58. drifting with a sentra
  59. 98 200sx SE-R swap question
  60. changing shift knob on 969 sentra
  61. tach spasms
  62. SR20DET Swap into '04 Sentra 1.8s
  63. Split Hood and Lambo Door Kit'Z??
  64. Getting power to an Amp.
  65. ECU mods?
  66. stuck gear shift?
  67. 1993 sentra overheating
  68. engine
  69. 1995 Interchangeable Parts
  70. hi new to the sentra forum. may purchase 1
  71. wiper fluid
  72. stereo removel
  73. Windshield Wipers Won't Work, Help!
  74. 88 sentra engine swap
  75. Wheels & Deals
  76. 2002 Gxe
  77. WTB: 1995 Sentra GXE Sun Visors (FOR TAN INTERIOR)
  78. My 96 Nissan Sentra would not start
  79. Halogen Lights
  80. 2001 Sentra GXE power windows problem
  81. Need 2004 Spec-V Stock Front Wheel
  82. 200sx performance
  83. b13 models (90-91 sentra)
  84. 96 Sentra moans & groans during steering
  85. 1.8 Sentra intake
  86. ser spec v ??
  87. selling headlights brand new
  88. trying to help a friend of a friend
  89. 200sx
  90. 92 Sentra Vibrating noise
  91. Limited slip differentials???
  92. 2003 SE-R car probs...any help?
  93. Nismo CAI Nissan Sentra SE '00
  94. 96 200sx Drive Axle seal installation--help
  95. should I buy or not
  96. SR20DET Engine swap
  97. Help me mod my 97 Sentra XE please
  98. Need new tires.. what is good?
  99. 98 Sentra GXE Console
  100. car outa commission parting it out
  101. 2002 Sentra GXE to bluebird GTir motor swap
  102. 1996 Nissan Sentra Alternator replacement
  103. 200 SX SE wheel size
  104. 96 sentra keyless remote
  105. Sloooow wipers and then nothing
  106. How does a Starter look? (1997 Sentra GXE)
  107. sentra se-r vs se-r spec v
  108. Normal Sentra To SR20det swap
  109. fuel computer chip
  110. Winter car.
  111. A question about converting specs..
  112. Slow motion windshield wipers?
  113. Spec V vs. 3000GT SL
  114. 2004 Spec V Clutch Problems
  115. Just wondering about my clutch
  116. Is my ECM Bad???
  117. Gear lube 5 speed manual
  118. my dash lights wont work
  119. 96 - 99 1.6 Senra owners: HWY gas mileage
  120. Sentra & remium Gas
  121. Ser Spec-v Nismo
  122. 99 1.6L GXE gets 28 mpg hywy. Why so low???
  123. Anyone try Turbonator???
  124. 1996 sentra w/ 200sx engine into sr20det
  125. 92 sentra se-r 2.4L
  126. Engine Swap
  127. Sentra dies while driving
  128. Let's geedum, guys...
  129. 2004 sentra remote keypad for sale
  130. HP Question...
  131. damn sentra
  132. this sux
  133. FS: 1991 Sentra XE Great Beater 5-Speed Manual
  134. How hard to replace door speakers in a '93 Sentra?
  135. coilovers for my 94 sentra
  136. 2005 spec-V
  137. Sentra NISMO Sway Bars
  138. struts on 1993 sentra
  139. Remove fuel injector
  140. just some quick advise please
  141. got a question about nitrious kit for fellow spec v owner
  142. EVAP error codes P0440 & P1448
  143. Spec V mods
  144. How much A/C oil and Freon
  145. Intake question
  146. question bout oil leak
  147. Govenor?
  148. Coolant leak into oil
  149. 1988 Sentra wheel question...
  150. Car wouldn't start when cold
  151. b13 1.6 se brake upgrade
  152. How Is Your 02/03 Se-r/spec-v???
  153. FS: 1997 nissan sentra gxe
  154. sentra 88' oil pressure?
  155. high flow fuel filter, and AFPR Q's
  156. '92 sentra trunk leaks
  157. Lowering 2001
  158. VTEC vs CVTC
  159. still having problems and not the fuel pump
  160. Parting Out 03 Yellow Nissan SE-R Spec V
  161. PARTING OUT: '97 eclipse RS
  162. stillen header for sale and stainless cat back for spec v
  163. Read only if you have removed the Balance Shaft
  164. Nissan TSURU headlight conversion
  165. sound system
  166. bank 1
  167. Check engine light question
  168. Trading in my '02 spec V
  169. 2004 Se-r Spec V Stock Rim
  170. FS:1996 200sx Se-R Drift Bodykit, Tein, Rims, LOWERD PRICE
  171. ACC relay?
  172. Spec V Suspension Upgrade Q's
  173. 88 nissan - last ditch effort
  174. WTB: 17" 02-03 Nissan Sentra SE-R Spec V Rims/Wheels
  175. 2004 Sentra SE-R Spec V after accident
  176. Engine Swap Please Help Me With what I Need
  177. 1993 1.6 nissan sentra
  178. How do you replace the drive belt in a 98?
  179. Sentra Flooded during hurricane
  180. 1993 sentra 1.8
  181. 2002 Sentra GXE Won't Start - Sometimes
  182. i want to blow up my car
  183. Help with replacing alternator belt on my 94 Nissan
  184. help!cannot get sentra to start!
  185. Got it all>?
  186. ?
  187. 1992 classic
  188. Bodykit Help!
  189. SE-R intake/exhaust question
  190. coilpack ?
  191. feul pump maybe?
  192. Sentra SE Question
  193. Eating up oil
  194. QR25DE engine
  195. For Sale: 94 xe w/jdm sr20 swap
  196. question bout fuel pump
  197. 89 nissan sentra-idle problems
  198. fuel pressure regulator
  199. Bracket
  200. block work
  201. advice on wheel/tire combo
  202. STILLEN QR-PRO ecu upgrade
  203. Removing Decks
  204. kalip
  205. The List
  206. H-e-l-p
  207. location of starter on nissan sentra 1993
  208. bad starter? where is it?
  209. 2001 Sentra...Bad Fuel Pump?????
  210. problem
  211. Basic Parts to Improve my XE
  212. Sentra 1.8L Intakes
  213. 96 nissan sentra
  214. 92 se fuel pump location
  215. Stereo
  216. gauge bezel
  217. 88 nissan sentra se turn signal ?
  218. door panels headers/exhaust where to find?
  219. Extra Juice
  220. anyone have experience w/ GTI's
  221. >Removing badges<
  222. F/S 2002 sentra spec v (blue)
  223. Flywheel Q's.....
  224. Chips?
  225. Whats the best next MOD?
  226. B-15 Trunk Mat "Sentra" Carpet NICE LIKE NEW
  227. Sentra 1.6l 1991 - where's the starter
  228. heater control
  229. bogging ga16
  230. 1989 Sentra wont start
  231. LED windshield washer jets
  232. tinting tail lights, legal?
  233. fluid leak
  234. program car remotes nissan200sx 96
  235. checj engine light
  236. horse power
  237. 97 GXE Stereo Install
  238. S7 Gauges for Auto trans?!
  239. problems :(
  240. my sentra giving me problem.
  241. Post the best-looking Sentra!
  242. oh god help me!
  243. Front Caliper Mounting bracket for 1997 GXE
  244. Lambo Doors on '00-up Sentra
  245. shoting out
  246. the story of my sentra....
  247. Anything you can do to a 1.6?
  248. Sentra E (2 Dr.): getting a 2.0
  249. sr20de to det ecu?
  250. Check engine light on/off
