View Full Version : Sentra/200SX (USDM FWD)
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12
  1. turbo spec-v help
  2. 1998 nissan sentra trans slipping. Please Help
  3. 1994 Sentra coolant system (1.6)
  4. Help
  5. need help with a name
  6. bogging
  7. SES light
  8. help
  9. problem with head lights
  10. 96 200SX SE-R Motor Swap
  11. 2002 Sentra with stays at high rpm
  12. gas gauge goes up and down
  13. Bump......
  14. Blower Moter Resistor...
  15. Scraping Sound
  16. 2001 Sentra. MIL/DTC falsely condemn O2S. Why?
  17. help needed with 2000 nissan sentra
  18. Looking to buy '02 Sentra SE-R
  19. 2002 Starting Issues
  20. The rack?
  21. Strut Problem ~I Think~
  22. 93 Sentra Starting Problem
  23. torn cv boot
  24. Cobra Maf 65 shipped+3% PayPal
  25. 50lb MSD injectors 180 shipped+3% PayPal
  26. rear motor mount
  27. Turbo Kit for the 1.6L ?
  28. Eating brake pads and discs: 1999 Sentra GXE
  29. Recently Purchased Used 02 Spec V, Questions
  30. For Sale: exhaust parts
  31. i have a nice blue nissan
  32. 96 sentra sputter/shake
  33. 95 Sentra Power Steering Return Hose
  34. Sentra timing chain
  35. Purchasing question
  36. Muffler Smaller than exhaust
  37. Short!
  38. 94 XE - White smoke comes out of exhaust
  39. Help Me Make A Decision!!!!!!!!
  40. 92 sentra tranny
  41. Vacuum Hose Leak?
  42. 1997 Rear Speaker removal/install
  43. Prices for cylinder head work '02 Sentra
  44. Sun Roof Stuck Tilted
  45. major help needed!!!!!
  46. i need a programable engine managment
  47. safc
  48. help with cold air intake anyone??
  49. '97 200sx SE-R, Governer disable????
  50. No Parking Lights
  51. No Parking Lights
  52. filter adapter
  53. Washer Nozzler Removal "Help"
  54. odometer
  55. 96 GXE side mirror????????????????
  56. Its leaking!
  57. 95Sentra GSX AirBags
  58. Final Cosmetic Stage
  59. How do I remove...Help
  60. Sentra 2005 1.8s gas tank reassembled
  61. Recalls
  62. 92 sentra..clutch cable recall????
  63. catback question....
  64. '97 SER anti-theft problems...
  65. Shocks or struts
  66. 97 Se-r A/c
  67. 07 se-r /cvt
  68. 92 Sentra..idle switch..where?
  69. Trimming teh shifter knob. (93 Sentra XE)
  70. My Spec vs. Mustang GT, top end
  71. '93 Nissan Sentra XE won't start.
  72. 93 sentra E won't Start
  73. Hard to fill gas tank
  74. 1998 Sentra axle replacement strut problem
  75. 96 200sx performance????
  76. '98 Sentra rear wheel thumping noise
  77. Gas Pedal Stuck!
  78. '97 Sentra GA16DE How to replace alt/AC Belt
  79. Rough Start
  80. FS: Boosted 1995 nissan 200sx se-r
  81. nissan etesting (sentra)
  82. Drive Axle Replacement
  83. 03 Silver Spec, new wheels
  84. Headlights
  85. won't start
  86. sr20 question
  87. Running sliggish.
  88. 1995 200sx se-r for sale cheap!!!!
  89. 1996 200 sx se-r
  90. 02 spec v tow hooks???
  91. Wrong Drum Brakes on My Car????
  92. Coolant bypass on throttle body.....?
  93. Valve Cover Installation Torque and Sequence
  94. For Sale: Turbo 200SX SE-R
  95. For Sale: Turbo 200SX SE-R
  96. oil leak
  97. Not Getting my MPG & Gauge Problem
  98. 6 speed
  99. 205/40/17 rim 125/45/17 tire??
  100. lowering?
  101. 2000 Sentra 2.0 SE - MAF Problem?
  102. Clutch chatter ftL?
  103. gear oil?
  104. N1 cams for sale
  105. 92' sentra motor swap
  106. Fuel Smell from Car Cap Tank
  107. 2004 Sentra SE-R Spec V
  108. Advancing timing on 06 specv
  109. Cai
  110. stereo questions
  111. calif smog laws anyone
  112. synthetic oil?
  113. Game...name this part...please
  114. Aftermarket Tachometer?
  115. timing advance without light
  116. making mine look different?
  117. knock sensor relocate anyone.
  118. Testing the TPS on a B15
  119. 2006 Nissan Sentra SE 1.8S
  120. 2004 1.8 Sentra A/C Compressor issue
  121. pulling up codes....92 Sentra
  122. F/S 96 Nissan 200sx...
  123. '93 Sentra XE starting rough
  124. Spec-V Newb...
  125. boosted 200sx se-r question?
  126. questions about map sensor and about manifold?
  127. wont start
  128. Good place to get interior parts?
  129. Strange Electrical Problem
  130. still trouble....92 sentra
  131. still trouble....92 sentra
  132. 94 sentra exhaust ?
  133. whats involved?
  134. 06 ser mods?
  135. 1995 200sx se-r questions?
  136. 2001 Sentra Keyless Remote Programming
  137. 92 sentra...help!
  138. carbon fiber engine cover
  139. 1 quart over filled in engine
  140. Supercharged?
  141. Help - Identify some loose connections
  142. 1995 Sentra cranks/no start P1320
  143. swap
  144. Parts Pleasee!
  145. Torque Specs
  146. Problem or Not
  147. Need help please New Valve cover gasket
  148. progress technology sway bar clearance
  149. progress technology sway bar clearance
  150. progress technology sway bar clearance
  151. Engine light on ...Evap Canister Vent Control Valve:
  152. Freeway Rev
  153. wat are da specs for a 2002 spec-v
  154. 98 200sx sunroof help
  155. Damn Wipers!!!
  156. No Horn
  157. Please HELP!
  158. problems with 03 sentra spec v
  159. 02 spec v dash light problems!!! Help..
  160. Brake & Battery idiot lights on, slow wipers
  161. When turning right thumping or rubbing sound
  162. 2002 Sentra GXE with weird no heat issue
  163. 1995 200SXSE gets 35mh - Is this typical?
  164. Nismo Coilover Drop Pics
  165. Looking at a 1996 Sentra GLE
  166. Is adhesive needed when installing weatherstripping?
  167. Brand New 2.5 Spec-V 6 speed QR25 Tranny
  168. Service engine soon light??
  169. Burning smell.
  170. Rear main seal
  171. Spec-V promotion CD in 02'
  172. 02 Sentra cam sprocket removal
  173. 97 Sentra needs your help
  174. 02 Sentra Using lots of water
  175. Is it difficult to remove SR20DE from 96 sentra SE-R
  176. BS removal/Nismo SS results:
  177. Can't Find Hotshot
  178. Sentras with stereos
  179. 95 Sentra Starting issues
  180. 98 Setra - Doors lock when starting - Is this normal ? Can I disable ?
  181. Rattling while stereo is on
  182. 1984 Sentra stalling...
  183. 96 200sx se....
  184. New Rotors
  185. 94 sentra good deal?
  186. Please help SR20DET GTi-R
  187. 1989 Sentra door speaker
  188. Should I buy this SE-R?
  189. Feels like iam running on 3cylinders
  190. 02-06 Spec V vs 07 GTI
  191. Spec V Turbo for 1k?! This has gotta be bullshit...
  192. Question(s)
  193. '87 200sx sudden power loss at 3500 rpm
  194. Prooooojector
  195. 96 Nissan Sentra
  196. b13 se-r
  197. Spec V Owners: Cheap Nismo CIA
  198. 92 Nissan Sentra reliable?
  199. CD Player Question
  200. Incase anyone is interested
  201. Brembo conversion(spec v)
  202. New to nissan section
  203. Taillights flash but don't?
  204. Ok, I've got a challenge for you guys!
  205. just making sure...?
  206. 3.5VQ hmmmmmmm
  207. Currently New
  208. i need help
  209. 2 weeks plus and no part???
  210. start + die = wtf
  211. ga16de to sr20ve swap questions
  212. Sentra Door Trim Removal
  213. 97 200SX CV Question
  214. 1986 nissan sentra h'back fer sale
  215. Windshield wipers won't work
  216. 1993 Sentra 2-Door Weatherstrip Part Number
  217. tail light and windsheild whiper dont work
  218. Any idea?
  219. 1989 Nissan Sentra 2 door
  220. Anyone selling parts?
  221. NISMO Oil Cap... wow
  222. can someone give me a ballpark collision estimate?
  223. 99 Sentra Window Regulator
  224. Spec V Quality (venting/advice)
  225. Oil goes missing....
  226. Help diagnosing power loss / smoking
  227. Anyone else have this problem?
  228. New SE-R + SE-R Spec V
  229. NO DASH or INSTRUMENT LIGHTS 96 Sentra GXE
  230. knock sensor replacement
  231. lol check this out
  232. will it fit
  233. air bag light flashing
  234. heated miror not working well
  235. O2 Sensor Problem with 01 sentra 2.0?
  236. need help bad!!!
  237. paint job?
  238. 2001 Sentra 2.0
  239. Tire choices '98 200sx se
  240. Help Please!!!!!!!!
  241. Oily Sparkplug
  242. side skirts
  243. 94 sentra battery problem
  244. Exhaust Flange to Manifold Broken!
  245. Subs and car health
  246. 93 Nissan Sentra NSS Problem?
  247. front sway bar only?
  248. front sway bar only?
  249. Strange transmission problem
  250. Strange engine problem
