View Full Version : How-to/Technical Info
  1. How to replace head gaskets
  2. How to find Top Dead Center and set your distributor and rotor when it has been out
  3. How to change your lower intake manifold gaskets and valve cover gaskets
  4. HOW TO: Diagnose Heater A/C Blower System
  5. Remote Oil Lines Modification
  6. Ball Joints - Which Brand is the best for the money???
  7. Basic Cooling System Advice - Updated
  8. Headlight Resto
  9. Transmission Filter ('95 4x4)
  10. how do I know if ball joints are failing?
  11. Clearing up oxidized headlights
  12. 4X4 Remidy for stupid encodor motor
  13. New to the blazer/suv world, any advice?
  14. Life of a Blazer Engine
  15. floppy steering wheel
  16. '98 Heater blend door groan/squeek cycling hot cold hot cold
  17. Fuel Pump Replacement
  18. Brightest NON HID bulbs
  19. -98 Blazer lifters
  20. HOW-TO: remove the front and rear panels w/pics
  21. Steering Stabilizer (How to)
  22. The Truth About The Auto Repair Industry
  23. Products that should be avoided.
  24. Table of Contents
  25. all season tire suggestions
  26. Broken Hazard Switch Repair How-to
  27. OBDI/OBDII/CAN Code Readers
  28. 1997 S10 Blazer outside rear view mirror replacement
  29. cleaning your multi-function switch (LOTSA pics)
  30. Blend Door (with pictures and the common problem)
  31. 4wd system operation 98up Blazers
  32. DTC P0410 Sec Air Injection - How to Repair and Part#s
  33. Fuel Injector/spider How To
  34. DIAGNOSTIC TROUBLE CODES. Check engine light on? Read this.
  35. How do I reset my computer?
  36. BALL JOINT REPLACEMENT HOW TO (w/ pix)
  37. 4.3L Engine Information
  38. HOW TO: Add an Image to Your Post.
  39. How to improve your ride quality
  40. runing lights
  41. Change your heater blower motor, a How-to
  42. wiping my rear (a how-to w/ lotsa pics)
  43. Tight and responsive steering: Another How-To! YAY
  44. gas mileage...
  45. 93 S10-Blazer Spark Plug Installatiion
  46. Another CPI How-to (focus on regulator)
  47. How-to change the PITA #3 spark plug
  48. How to: replacing the 4x4 front differential actuator
  49. 96+ Water Pump Replacement
  50. Vacuum Hoses on 4.3 TBI replacement
  51. how can i post a picture?
  52. Rust repair around windsheild
  53. First Gen Instrument Cluster Conversion
  54. Lower Manifold Gasket
  55. Door pin and bushing repair How-To!
  56. 4.3 CPI Injector replacement pictures
  57. Got air in your heater core? Need help getting rid of it?
  58. PCV Oil Catch Can, see what your engine is burning!
  59. ***92 - 95 CPI Engine Info.***
  60. Truck Not Running Right? Hard On Fuel And Sluggish Power? Try These First.....
  61. 96+ Hard Start, No Start, Rough Idle Info
  62. A Little Info About Fuel Trims
  63. Restore your weathered plastic how-to
  64. Convert Your Cluster & Control lights to LED's How-to!
  65. Drum to Disc brake rear end swap how-to!
  66. Facts about steering slop....
  67. 98 Blazer heater core replacment (I just did it)
  68. Hot butt how-to!
  69. 2000 Blazer headlight replacement
  70. Replaced Door Pin's and Bushings Today
  71. Factory fog lamp switch with non factory fog lamps.
  72. Picture Detailing all 11 Grease Zerk Locations
  73. 1995-2003 S10 & Blazer Front End Clunk Pop Fix!!! Read!!
  74. Ignition Switch replacement procedure
  75. Water Cylinder Decarbonizing... Should I?
