View Full Version : Altima
- 5-speed shift knob
- Updates on the Altima
- 2001 Nissan Altima GXE overdrive
- Need to know size of stock brake line
- looking for doors for my 93 altima
- altima 01 starting problem
- 94 Altima wont start
- 02-04 altima black taillights
- 2001 Altima GXE Stock Speakers
- What is an O/D ? Mine is OFF
- WTT: My 200sx Se-R For Alty
- 98-99 Altima Engine
- 2001 Altima Alarm Sounds For No Reason
- 94 Altima IDK
- engine idiling rough when in gear
- torque steer 2005 3.5se manual tranny
- Altima Mods??
- altima
- Mechanic Charges
- 93 altima transmission change
- What's the Bolt pattern?
- 2002 altima stock oem rims and tires
- Altima 03 Body Kit
- Maxima muffler
- Pennies in the Steering Wheel!
- I need help ???????????????? 1999 maxima
- Cost for Cad Converter 2002?
- 93 Altima alternator problems...
- 99 altima - water temp gauge bouncing around
- Alty Gas Mileage
- JunkYards/NJ
- Fixing an OBDII code
- What's involved in replacing rear crossmembers?
- for sale, local ny/nj area only
- Sensor Problems??
- 96 Altima rough idle
- my first time here
- 1993 Altima
- Plugged Cat?
- Engine light
- Engine Dies +Radiator Leaks
- 2001 Altima GXE Limited "grunting" noise
- 99 altima catback
- Just bought a 93 Altima, need advice/tips/info/etc..
- disc brake conversion for 97 altima
- ALTIMA PROJECT - 1st GEN
- 93 alty wont start please help
- oil in distributor
- Left Axle Drivers side
- RB25DET into the 00 Nissan Altima?
- 96 Altima performance trouble
- Struts
- Keyless Programming - Damn Horn
- Installing new gauges on 2002 altima
- 95 Tranny
- 1996 Nissan Altima
- n e 1 race n e more
- Altima suspension!
- is there a way to make the rear windows of a 05 2.5s go all the way down?
- new 2005 altima, need help hooking it up
- my car wont' start!!! help!!!
- 2003 nissan altima 2.3 body kit!! help!!
- 95 altima timing belt
- 92 altima problems
- Anyone help me out?
- trunk braces?
- 98 Altima Keyless Entry Problem
- Smoked a Bmw in moms altima
- 95 Altima manual transmission
- is-it a GXE or XE Model?
- 95 Altima Radiator Installation
- Altima blowby, is this normal?
- Coolant Leak / Intake Gasket bad?
- Engine replaced, No spark or start since!
- Rim advice please
- 95 Altima O2 sensor going bad?
- Possible recall?
- Question about Denso plugs
- Does my 98 have keyless entry
- Starting problem
- Audio
- is there more then one engine type??
- Can someone answer this questions about the Altima and the Maxima
- i need a engine
- mpg?
- Replacing a starter
- suspension mods
- Replace ignition system?
- Just a word of advice
- 94 altima - someone explain this
- Radio and whippers are malfunction
- 98 Altima whine question (and wreck story)
- Parting out 95 Altima
- Nissan Altima 95 - need to replace my sway bar link
- Altima CAS Distributer . Built in coil . 4-sale
- how much forthis?
- speedometer
- Maxima gas door problem
- 2001 Pathfinder
- 2002 POS Altima 2.5 SL
- Altima 93 no Start.Kindly help.
- Help w/ 94 Altima
- Leaky fuel tank in 03
- they fixed my head gasket and
- Misfire
- Stillen header
- trouble codes
- Programming 2002 transponder key
- New exhaust, need help, very urgent!!
- Altima SE/SSE Difference?
- Help with"Service Engine soon" light
- Turbo Altima prep?
- 95 Altima, possible engine swap?
- 98 Altima!Need help
- Putting a new timing chain kit
- 2002 Altima S
- '94 manual/auto transmission
- 97 Altima (changing dash lights)
- Turbo Kits
- 94 Altima Manual Transmission
- **NEW** Genuine Nissan Altima Floormats!!
- **NEW** Genuine Nissan Altima Bra!! Fits 98-99 and maybe 00-01
- Engine won't turn over.
- Altima 02-04 Poly Urethane Body Kit by eRacings
- 3.5 SE tire pressure
- Air Conditioning problem
- '93 Altima-Ticking Noise
- CAI danger?
- Interior Painting Problem
- more reliable? altima or maxima (95-99)
- Altima gas door problem
- 2004 HeAd LiGhTs
- aLtImA rImS oN 2004?
- Where's the test lamp on 95 Altima ECM?
- Coil Overs or Springs
- 2002 Altima tires?! No Michelins
- 93 Altima Seatbelt not working
- Cost effective upgrade
- loud screaching sound
- Brake noise on 96 Altima
- I need instructions on how to change my gauges. Thanks
- 94 Altima
- '96 Altima skips???
- 01 Altima ground kits?
- Metal casing around air filter housing
- 0-60 on altima?
- *NEW* Altima Armrest and Cargo net for sale
- 1999 Altima misfire
- Clock dims
- 2000 altima exhaust
- 2001 Altima GXE problems
- Altima Killz - wanna hear about em
- Altima performance
- Altima tranny swap
- Black Widow Altima?
- 93' Altima Fog Lights
- 93' Altima Over heating...
- check engine light on
- much needed power
- Olds 92 88 data link probe 54 ?
- Optima Yellow Top Battery
- Low Idle - Need help!
- Serious Starting Problem!!
- Help with 2001 to 95 motor swap!!!!
- 93 Altima Alarm
- 2002 Altima Bumper 2 Bumper
- oil leak
- Speakers
- Control arm bushings
- 95 Every power window out
- Oil Change Destroys Engine !!! 1996 Nissan Altima
- First ever 2005 Altima SE-R
- swap or turbo?
- Drop in Rpm's when shift to Neutral
- '99 Altima Lettering
- Noise and gas problem
- RB26det
- 97 altima motor swap????
- Engine running wierd error codes
- Why does my gas mileage suck???
- 2001 stock stereo
- 95 nissan altima, check engine light on...
- 97 altima timing chain
- 97 Altima. Possible to turbo?
- Where's the airconditioner fuse???
- Tire vibration - Help!!
- 93 Alty Problem?
- 97 Altima(manual) help
- how low for 20 in. rims
- indiglo gauges
- Some help with rough idle, please
- 1997 altima
- Purple?
- 94 Altima Headlight replacement
- Wrecked front end
- mass airflow sensor
- Car Shuts down After Few Minutes
- 2000 Altima front bearings
- Need Help with 2001 Altima Tail/Brake Lights
- 93-01 Altima HS header
- what does my knock sensor do?
- What is that rattling noise when I accelerate?
- No Spark
- error code p0171
- Faulty Ignition Switch
- Headlight Bulb Replacement 1998 Altima
- Budget/Efficient power adders for 96 Altima
- Stillen Altima Project Car
- acceleration problem
- need help with brake lights
- Check Engine Light 96 Altima
- 97 Altima weird non-continuous monitor problem
- need info on 2005 stereo
- F/S: Springs, Grill, & Intake
- Altima fuel fill problem
- 99 Altima GXE mods??
- 97 Altima (gas mileage???)
- '94 Altima Problem
- 97 Altima GLE Keyless Entry / Alarm
- 94 Altima Speedometer trouble
- Set Nissan Altima 98 clock
- Firewall hole
- 99' Altima Reverse Shifting Problems
- Got some 16inch White Konig Traffiks
- 94 Altima Complette Injection Intake Assembley for sale swap or modification
- 94 Alt Auto w 87k Woul'd You bother to upgrade Automatic Car
- speedometer non functional
- NO electricity on A/C compresser
- 1994 altima GXE i want a 2002-03 QR engine is it possible to fit?
- FS: 2003 Altima 3.5 SE Black Low Miles, MANY EXTRAS
- Shift Knob HELP
- Body Kit for a 1997 Nissan Altima
- Drivers Mannual Nissan Altima GXE 98 ???
- changing bulbs in head lights altima
- Turning off Check Engine light
- need help with interior light problem 99 GXE
- Driverside visor problem 98 Altima
- Car alarm installation
- 98 altima stereo install
- 2k5 ALTIMA!!
- A/C not cooling after crashing in the woods!!! HELP ME!!!
- You Might Be A Ricer If...
- There's something wrong w/ my car...
- Specs on cold air intake filters?
- help! altima factory alarm
- Another wiper problem
- 1999 radio into 1997?
- 93 Altima?
- Peice fell while I was driving!!!!!!
