View Full Version : Altima
Pages :
1 2 3 [ 4]
5 6 7 8
- 2002 2.5 Sl
- 95 nissal altima linkage
- 1994 Altima GXE fuel in the oil
- bad idle
- 1993 nissan engine misfire #4 cyl
- Altima '03 brake light replacement
- My car dies...
- 2003 headlight and taillight strobes
- Electrical Problem?
- 2000 Altima-Got a few questions!
- struts
- troubles with a 93 Gxe altima
- fuel filter
- PCV Valve location?
- Replace power Steering Fluid on 99 Altima GXE
- washer sprayers
- Windshield sprayers
- 98 Nissan Altima can't open trunk
- Timing check?
- odometer stopped?
- Check Engine Light
- Valve cover
- Valve Cover Gasket
- 2.4 L 4cyl Altima engines are KA24DE.
- Temperature gauge
- Engine Code KA24DE, how do u know
- New Wires
- Switch to turn on vents doesn't want to work
- Newbe to nissan altima with a few ?'s
- URGENT: Accelerator Pedal sticking
- Urgent: Body Kit
- 2001 Altima Belts Squealing...
- General questions Altima 3.5 SE
- Turbo GXE
- how much are you paying for 2006 Nissan Altima
- 99 altima speakers
- 96 GXE Altima "oil smell coming from A/C vents
- 93-97 5 speed shift knob removal??
- Engine Replacement Due to Internal Oil Consumption
- air bag light on all the time
- 96 altima miss fire
- 2001 Altima Turn Flasher
- HELP...99 Altima Sony CD player problem
- Floor Jack and Jack Stand Locations?
- I'll never buy another Altima
- 99, low RPM problems, MAF sensor?
- Radiator drain plug location
- 99 Altima intake & filter installation, PLEASE HELP!!!
- Change 1995 GXE 5 Spd Rear Drum Brakes
- Re:rondegx problem with brakes (1995 GXE rear drums)
- Cleaned throttle body, now PROBLEMS!
- 2000 altima too rich
- proper rotor wear
- Service Engine Soon Light '06 2.5
- 2003 Crankshaft Sensor
- problem with brakes
- 93 Altima Runs Poorly- Black Smoke
- 2001 altima gxe remote problem
- 1st gen Altima for sale in local paper..
- an entertaining story for those who are bored
- altima hesitating ALOT
- 1999 Altima design differenet from 2000???
- 94 Altima Tires and Plugs
- HELP!!! Timing marks???
- Rough shaking in Idle, but fine when accelerating
- 94 Altima Oil
- 94 Altima Oil
- Engine Oil
- 96 model 2.4 throttle position sensor TPS
- Shaky at Idle
- Timing chain kit- replacement
- 93 Altima Auto Seatbelts wont work
- 93 Altima hard starting when warm
- Scan Tool
- whats 1st for an upgrade??
- 96 Altima stuggling to stay on
- reflashing the eeprom
- flasher relay
- Hoods?
- 94 altima idle
- 94 altima
- Knock Sensor
- 2001 altima/ Dash inop, jerky shifting?!
- Drums To Rotors ...
- Engine layout?
- 93 altima tach
- Power Door Lock Problem
- 94 Altima Sitting for 6 years
- Installing 2003 altima tail light
- 95 Altima GXE Fuel Problem or Electrical?
- What do you do when you lose neutral
- Air Bag Light
- replace head light bulb
- 99 Nissan Altima, car bucking, oil gasoline smell
- HIDs for non-hid 02+ altima
- 94' Altima Lock and Key cylinder replacement
- 96 altima skip just off idle, then smooth
- PLEASE HELp
- Vents hot air Altima 03
- 98' Altima AC squeaking noise with AC off
- 94 Altima PCV & Intake Problems
- 93 altima starter
- 1993 gauge cluster compatibility ?????
- Hit a pothole and now I hear a noise when I turn sharply
- Tranmission Selector
- 93 Altima throttle sticks
- 1993 Altima GLE, few common problems need help
- Timing chain/belt help?
- Redline Power Chip
- 94 altima clicking sound
- Misfiring
- i need help installing an R33 kit
- Installing sub woofer
- 2003 Altima injector noise?
- 2003 Altima Wheels
- tail light bulb holders
- Keyless Remote Programming
- 96 altima intake gasket
- 93 injector replace
- 02 altima transmition sensor
- 94 altima brake lights stuck-draining battery
- Knock sensor code
- 96 altima gxe
- 94 altima stock radio removal
- anoying windshield noise 2006 altima
- 96 Altima air bag light flashing
- 98 Altima: Continuous Shrill noise from under the hood during idling
- 1993 Altima GXE won't start
- 1996 keyless entry remote programming
- Emission failed - p0325, p1446, p1444
- 94 alarm locking out ignition - car won't start
- 96 altima rpm/idle problem
- 99 altima injectors not spraying
- Fuel filter removal problems
- 2000 Nissan Altima
- Throttle cable ball and joint
- Skipping 96 Altima
- Advice, please....
- EMERGENCY -- need to repair oil pan NOW
- 02 altima airbag deployed
- burning oil
- 02 Altima Head Gasket Blown
- 94 Altima Speakers
- Shifting
- Radio pin out for 96 Altima
- coolant leak
- 1999 Altima GLE temperature gauge
- 98 Altima RPM issues
- 98 Altima Amp Install
- Polyurethane engine mounts
- nissan altima timing belt
- altima turn signal constantly on
- Smart Entrance Control Unit
- 2002 altima wanted
- 94 altima tends to hesitate sometimes
- Possible purchase-96 Altima w/75K, auto,leather- what should.....
- Electrical
- 96 Nissan Altima Parts wanted.
- 96 Nissan Altima Driver Side Door Refuses to open
- 97 Altima - Grumbling noise
- 2002 nissan altima seat belts locked!!!
- Keyless-2000 Altima
- 2003 Altima, Ticking noise, idleing rough
- 1997 Altima clicking noise and bad mileage
- Rotten egg smell 2005 altima 3.5se
- Need to Replace Air Temperature Sensor
- Motor mounts on a 2000
- No RPM's over 2500
- won't go in reverse
- Idle Surge
- throw bearing
- Does it matter
- 2001 Altima has a mind of it's own....
- 06' Altima - Aero hood deflector's?
- Nissan 2000 Altima running sounding like a lawn more
- Replacing the factory Fog Light Bulbs?
- Wanna trade....(sweet hitch for 93-97 altima)
- Paint Jobs @ Maaco
- How to get that nasty film off your plastic headlamps
- maxima vs altima 3.5 se
- '06 Altima reading wrong outside temp?
- Looking for '98 Atima CATBACK! PLS HELP.
- 05 Altima VS. SRT-4
- 2003 Nissan Altima idle problems
- 2002 Altima Howto aim the Headlights
- 1995 Nissan Altima DOHC exhaust camshaft
- Engine Vibrations, 2001 Altima
- 2000 altima pinging
- Looking for '02 or newer Altima
- Window Dropped Out
- oxigen sensor
- Headlamp malfunction
- 99 altima idle drops (help please)
- 93 altima fuel smell
- best buy for oil change parts
- Tune-up
- Headlight Problem
- Changing taillight bulb in '02 Altima.
- Wanted: Right Side Engine Mount for 2002-06 Altima 2.5
- Headlights assembly
- Hissing sound/Passenger Side/Behind Intake
- Gxe, 97, speedometer,odometer,cruse,thermometer problem
- 2003 Altima Factory Alarm
- Passenger rear view mirror (needed)
- Mildew odor in A/C--2005 Altima V6
- 97 o2 sensor code
- Certified used
- 97 altima
- 93 altima running too rich
- anyone install an aftermarket cd deck into a 95 altima?
- How to replace '06 Altima Headlight Bulb (H1)?
- headlamp cleaning
- 1995 Altima fuel pump location.
- 2000 altima catalytic converter
- 2000 Altima
- opinion rqst: 4Cyl altima?
- noise when steering
- car will not shift
- 2003 Nissan Altima 2.5 S takes several times to turn over
- exhaust problems
- getting stuff painted
- crazy unknown hose HELP!!
- Axel seal problem
- Oil leak(?)
- 93 altima won't start/catch
- Supertech Pistons
- changing stock deck
- Rattle top of engine
- blown brake light fuse in '98 Altima
- I messed up (Inside distributor)
- 2001 Altima brake replacement
- 97 Altima loss of power while driving
- Rims For Sale!!!!!!!!!!
- Head lamps
- Suspension Issues
- radiator support assembly
- brake light & battery light always on
- My alarm system (factory) doest not work. Help asap, please.
- Driver's door won't open
- Car won't start, even after replacing bad part
- Service Engine Soon on, Altima 2000-HELP..
- Will Doors from a 03 fit a 05
- Removing 2001 Altima CD Player
- 95 altima caliper help wanted
- 2003 altima
- injectors
- belt replacement questions
- 240 cams?
- differences between '99 SE and SE-Limited?
