Our Community is 662,000 Strong. Join Us.
View Full Version : Sunbird/J2000/2000 Sunbird
  1. hide-a-way headlamps
  2. 1993 Sunbird 2.0 Coil pack issue
  3. 1993 Sunbird 2.0 5speed. Aftermarket Parts?
  4. power steering fluid 91 sunbird
  5. 1994 Pontiac Sunbird failing on NO PPM.
  6. 1990 sunbird key is stuck on run
  7. 84 Sunbird Low Speed Wheel Noise
  8. 84 Sunbird Leak when hot
  9. 90' Sunbird NO SPARK
  10. Replacing Starter on 1983 Sunbird
  11. Oil Pressure drops at warm idle
  12. '94 Sunbird dies when I get off the highway
  13. '92 Sunbird Died!!!
  14. '94 Sunbird 2.0 OHC 5-Speed
  15. '93 sunbird won't shift all the time HELP!
  16. '92 Sunbird SE EGR Valve??
  17. 1991 bird ONLY idols ??TPS?? 3.1L
  18. 94 Sunbird timing belt issues
  19. uncontrollable high idle with no throttle...
  20. High Idle speed
  21. Headbolt Locations
  22. Sunbird quit running stumper
  23. 1990 sunbird
  24. 84 Sunbird Front Swaybar Removal
  25. Rear shock absorbers!
  26. 89 Sunbird runs poorly when engines warms up
  27. wiring diagram for a 1994 pontiac sunbird
  28. 2002 Sunfire Ecotech Engine
  29. HELP replacting a cv boot 93 sunbird
  30. Master Cylinder Bleed
  31. 90 sunbird transmission
  32. 91 sunbird wont start
  33. 1992 sunbird se heater core
  34. 93 Bird , no heat-blows fine
  35. 88 sunbrid turbo 2.0
  36. 92 Sunbird - Dieing
  37. Well had to say good bye to my sunbird :(
  38. selector cable manual tranny
  39. '94 Sunbird Rocker Arms
  40. engine runs rough at idle
  41. First Timer/92 Sunbird/help!
  42. Sunbird GT headlight eyebrows covers lids problems
  43. Rod knock n oil light on when cold start
  44. 1991 Sunbird "Sometimes Starts and runs Sometimes Not, Stalls sometimes too! HELP
  45. Solenoid question
  46. Sunbird problems
  47. Extremely High rev when start.HELP PLEASE
  48. 1990 Pontiac Sunbird----Motor Oil-Did I put too much
  49. Pontiac Sunbird 1978
  50. Getting the Px dash off
  51. interior lights drain battery
  52. <<<<<just bought a 93 sunbird 2.0L / is this a good car?
  53. Clicking noise in head
  54. Stalling Problems
  55. Belt Tensioner
  56. 91 Sunbird- Arrggghhh!!
  57. 93 Pontiac Sunbird died and wont start
  58. weird electrical problem
  59. where is the Neutral Safety Switch located on 94 Sunbird?
  60. Help I have a huge problem ignition stuck
  61. Battery light flashes off and on
  62. fuel pressure regulator
  63. 1979 Sunbird Suspension Upgrade
  64. 91 sunbird 4cyl..died wont start help!!!
  65. Weird problem?
  66. problems with Battery not even 1yr old
  67. 1993 Sunbird Heating/Vent Problems *PLEASE HELP* chicago + winter= COLD!
  68. 92 Sunbird Running Rough
  69. engine swap
  70. need pontiac sunbird radio wire colors diagram
  71. 92 sinbird overheating
  72. pontiac 91 sunbird oiling problems
  73. Winsheild washer pump
  74. Stereo
  75. Very Fast idle only on startup?
  76. 1990 sunbird le acting strange
  77. 91 Sunbird 3.1L Stalls won't restart
  78. 1990 sunbird
  79. 93 sunbird not charging (new batt and alt)
  80. 84 Turbo Sunbird - No Throttle
  81. 1993 Sunbird A/C Not Working
  82. 94 sunbird unable to locate blinker relay
  83. Audio help on 91 Sunbird LE
  84. 91 Suinbird leak under dash -passenger side
  85. help - convertable top wont work
  86. 91 Sunbird- Failed Emissions
  87. replace oil sending unit
  88. 93 sunbird harmonic balancer HELP!
  89. 1990 sunbird, 2L, no heat
  90. Radio
  91. tcc and speedo problems, 89 sunbird
  92. Wheels
  93. Color matching
  94. if i were to install a turbo charger?
  95. 92 Sundbird won't start.
  96. Overcooling??
  97. Hybrid Swap
  98. 1989 pontiac sunbird SE help please
  99. 93 Sunbird Conv
  100. Sunbird Engine Clean
  101. 94 sunbird speedometer stops working
  102. Squeaking/Chriping After Wash
  103. Site for
  104. No Fuel To injector!!!
  105. 85 J2000 / 94 Sunbird swap
  106. 92 Sunbird losing coolant
  107. 1991 sunbird not starting
  108. Vapor lock in engine?
  109. how to set timing?
  110. 88 Sunbird 520,000km
  111. help with a 86 sunbird
  112. Metal against Metal Sound
  113. Sunbird Electrical Problems
  114. 92 Sunbird No Spark/No Start
  115. Electrical Schmetics
  116. Not Starting
  117. 91 sunbird
  118. starter removal?
  119. random stalling / won't restart
  120. starter removal problem
  121. Sadly, I must leave you...
  122. coolant leaking
  123. Not Starting....
  124. Cooling system
  125. WHat is wrong?
  126. Starter selonoid
  127. coolant
  128. oil pressure
  129. looking for some general info
  130. cracked head?
  131. my sunbird have no heat HELP
  132. Leak under dash/ 88 pontiac sunbird
  133. rear shocks
  134. RPM guage/tachometer
  135. official end to the Sunbird/Sunfire
  136. 88 pontiac sunbird update
  137. 92 sunbird no start!
  138. from post birds
  139. major oil leakege!
  140. gas guzzling
  141. Can anyone please help
  142. Need Help Cat Bad!!!!!
  143. Sunbird Help
  144. Hot Sunbird on eBay!
  145. cherry bomb turbo muffler?
  146. 93 sunbird running rough after gasket change
  147. '91 Sunbird Convertible window problems..
  148. Sunbird won't stay running except in Park
  149. 88 sunbird right window not working
  150. Engine cuts out... Sunbird 2.0L
  151. 1991 Water Pump
  152. 88 Sunbird having trouble starting
  153. 1991 sunbird advice
  154. Weirdest problem I've ever seen and I'm desperate for advice...
  155. Hmm... Headlights/Turn Signal/Windshield Wipers help
  156. Door Problem
  157. '93 3.1 cuts out until up to temp
  158. Radio?
  159. weird thump noise and code 14
  160. Sunbird no start
  161. 1994 Sunbird, 3400 SFI!!
  162. 91 Pontiac Sunbird
  163. Starting issues 91 Bird 3.1?
  164. Sunbird stalls after driving....
  165. 84 Turbo Sunbird Check Engine Code 42
  166. There's no way I can let go of my Sunbird !
  167. high idle?
  168. Possible project car
  169. 1984 ragtop
  170. timing
  171. head bolt torques
  172. A/c
  173. Post your birds!
  174. Hell yeah!
