View Full Version : General Discussions
Pages :
[ 1]
2 3 4 5 6 7 8
- 2000 pontiac sunfire starts and shuts off
- Broke off old crank sensor trying to get out on 97
- 2004 Sunfire Trunk Light
- 99 sunfire poor acceleration
- 97 engine runs after key off and then cant start after
- Passlock question
- 97 rear brakes stop on and off and car lifts too
- 97 engine reves up and down around 1000 after fuel injector change
- 1996 SUNFIRE Air Bag Light
- 1996 Sunfire (Pontiac lettering and reverse lights not working) Trunk Lid
- 99 sunfire rear brake issue
- 00 sunfire replace strut bearings?
- whats the purpose of the rear rubber brake lines?
- 1999 sunfire 2.2 engine
- leak
- 97 2.2 abs light on can scan tool tell what sensor
- 03 hard to shift
- 2 questions
- Hard shift/Odd idle
- 95 pontiac sunfire. URGENT
- 1997 Sunfire Knocking While Turning Only
- Dakota dribble
- cylinder no.1 misfire
- 2000 Washer fluid pump
- 98 sunfire--stuck in Park
- Alarm going off (red light flashing) and engine isnt starting.
- 2000 sunfire 2.2 engine won't start
- 2003 Heater Control not working or no power to it
- thermostat (p0128)
- 2001 sunfire obd2 not ready
- headlight issue
- 2002 sunfire 2.2 spark plugs
- Problem removing IDI Cover
- passlock 1 bypass help please
- broken linkage?
- 95 Sunfire throttle issue
- How easy is it to remove the door panel?
- 99 Sunfire - Misses
- 97 sunfire sparkplugs
- 2003 2.2 serpitine belt install problem
- Leaking oil between engine and .....
- a/c hose
- 2003 ecotec 2.2 A/C Problem
- 2003 2.2 EcoTec Sunfire clutch pedal issue
- 2003 2.2 EcoTec Sunfire head light issue
- 2003 2.2 EcoTec Sunfire A/C charging
- 2003 2.2 EcoTec Sunfire cooling fan removal
- Sunfire Rear Speakers Intermittant Sound
- 2003 2.2 EcoTec Sunfire curious where thermostat is
- 2003 2.2 EcoTec Sunfire Cooling Fan wont run
- Need help! I have an 2.2L Ecotec Engine for 2004 Sunfire - what cars will this fit?
- Need help with 2001 sunfire
- 95 sunfire wiring diagram
- Cylinder inspection and cleaning
- newbie from south carolina with a 95 sunfire
- need wiring diagram for tail lights
- Tuneup ideas ?
- squeek in steering colum
- 2003 sunfire
- 02 sunfire SE - WINDOW PROBLEMS
- Vacuum problems
- need help.
- crankshaft and camshaft position sensor locations???
- 99 Sunfire - Cylinder misfire - popping sound on Highway
- 95 Pontiac Sunfire 2.3L stutters
- o2 sensor
- Cruise control kit
- 97 sunfire, 5 speed, manual; rough idle, hesitation
- '97 sunfire please help me on this, I am a girl and know nothing about cars!!!!!!
- problem with ABS
- 99 Sunfire starts but shuts off after a second or two
- 2003 sunfire 2.2 auto, trunk problem
- 2002 sunfire abs reset?
- headlight wiring diagram
- How to drain coolant ?
- Help please
- 2.2 liter head bolt torque
- 97 Sunfire GT trans jumps out of 2nd gear
- 98 sunfire cutting out and stalling
- Need fuse panel diagram
- .8 amp drain on battery w/ all power turned off
- sunfire motor swap
- keyless remote help!!!
- BCM? Short? who knows?
- Up and Down Pipes
- 96 sunfire radio problem
- 2002 Sunfire Electrical Issue
- Motor Mount Diagram
- P0141 and P0171 codes 99 Sunfire 2.2L
- 97 Sunfire GT 2.4L having problems starting....
- AC problem
- Broken Shifter / Hand Break
- 2000 Sunfire SE 2.2 minor probs
- Sunfire GT quick questions about painting, stereo and lights
- cylinder filling with fuel
- 2002 Sunfire question
- 99 sunfire gt 2.4l tc a/t IDLE ROUGH
- 95 Sunfire Halfshaft Keeps breaking! Please Help!
- 97 sunfire pwr windows.
- 97 2.4lt serpentine routing/install tips
- Sunfire is stalling at idle: 1998 Sunfire 2.4L Twin Cam Engine/Automatic Transmission
- My story and my questions
- swapping steroes
- 97 sunfire..AC comp. swap
- 1998 Pontiac Sunfire GT 2.4L
- 96 Sunfire Fuel Filter disconnect fitting
- 96 sunfire questions
- A/c
- Need help on my sunfire -- Code - P0122
- stabilizer bar
- 97 Sunfire Engine Problems
- Tune up question
- help
- 2001 sunfire cooling fan
- Automatic transmission fluid
- GM 2.2L OHV DOHC: Interference or NON-Interference
- engine compatibilty
- muffler
- 99 Sunfire GT engine compatibility
- Rear wheel cylinder question
- Request for 98 Sunfire advice.
- Oil light/oil pressure problem
- installing aftermarket cd player
- factory alarm
- 2001 bumper removal
- 98 sunfire 2.2 no compression on all 4 cyl.
- 96 Sunfire Convertible Tack Strips
- rapid flashing turn signal 99 Sunfire GT
- Hole in water cap - Why?
- New Sunfire Driver
- 97 sunfire ...clutch pedal to the floor to shift
- 97 sunfire rough idle mystery??
- 2001 pontiac sunfire exhaust hanger issue
- 97 sunfire shift problem
- 2004 Sunroof and AirBag questions
- trying to pin it down
- Remote Keyless Entry Module (RKE)
- Sunfire balancing unit timing
- windsheild wiper won't work
- 2000 sunfire cooling issue
- Clutch HELP MEEE!
- Please help 2000 Pontiac Sunfire 2.2 Auto
- Turn signal mayhem
- 01 Sunfire Won't Start
- fuel Pressure
- 1997 Sunfire heating problem
- 2002 Sunfire No Reverse
- Windshield Wipers Park Pointing Up
- A few questions
- Dashlights on a 97 Sunfire
- Odd problem - no chimes, no radio
- some warning lights on
- Brakes dragging after install of new Driver side Parking cable.
- Timing problem
- Body kit question
- 2D/4D trunk lid swap
- can anyone help????
- Radio failure
- 2001 Sunfire rough running intermittently
- just curious
- 2001 Sunfire ETC ???? what is this?
- 03 ignition lock cylinder
- radio static question
- AC system oil when replacing parts
- Water Outlet/ Thermostat Housing
- 2 questions
- Ponitic sunfire lock code HELP
- im looking to buys a sunfire - need advice
- Starter Won't Engage Flywheel
- 99 Sunfire GT Overheatin - I think i know
- Starts intermittently
- Sunfire GT engine SWAP
- Lowering springs and struts
- Reverse lights
- 99 sunfire brakes
- could it be the starter
- replacing the windshield
- Power steering Line Leak
- Need Help With This P.S. Pump.
- I have a 1997 sunfire gt 2.4 litre twin cam
- 05 Sunfire cold start rattle
- 95 sunfire...All Dash lights on, dim lights, ect. HELP =[
- 2000 Pontiac Sunfire SE 93,000 miles. I need a new car. Is it reliable
- 96 Sunfire 2.2 key wont turn
- tranny output seal probs
- 99 Sunfire Parking brake Question and engine question
- High RPMs on interstates
- Removing backseat of a 2002 Pontiac Sunfire
- Overheating after new head gasket
- problem after install header
- 96 sunfire 2.4 starter wires cut
- Problem with headlights, windshield wipers and door locks - 2001 Sunfire GT
- sunfire 2000 cd player
- 1999 sunfire injector problem
- Check Engine light on In 2002 Sunfire
- Loud Ticking
- used sunfire code/dealer problem need help
- oil filter remomal 2000 sunfire 2.2L
- Head lights work but NO rear or dash lights
- a/c light / hvac panel
- 1996 sunfire start problems
- New Sunfire needs Modded
- 2.2l Timing (how to) and 180 Degree out prob.
- Looking for RPO code list for 97
- 97 with no fan 1 or 2. 3 & 4 OK
- Wifes 2000 Sunfire Engine Shaking
- 97 GT bad trans, diff
- Sunfire 98 GT 2.4L jerking
- 99 Sunfire NO BRAKES
- 2000 Sunfire - What to do?
- 2.4 twin cam sunfire..any good??
- Sunfire Transmission Dipstick
- Need Chilton Manual 01 SF Coupe
- electrical smoke
- 97 sunfire drums
- 97 Sunfires need help w code P1336
- Is a 96 the same as a 97??
- tranny
- cooling system/overheating
- Wanting To Buy Led Lights Or Angel Eyes
- 99 sunfire A/T tranny rpm's question???
- 1996 Sunfire Will Start Check Engine Light Is On, And Will Sometimes Just Stop On you
- New tail lights
- 1998 Sunfire turn signal
- 97 Sunfires DIES AT STOP SIGNS
- 96 Sunfire keeps dieing when driving!
- 2001 pontiac sunfire cranks but wont start
- engine swap
- 1997 Sunfire cranks won't start
- rear signal light replacement
- 2002 sunfire= a/t 4 speed??
- INteresting sound
- sunfire interior
- Just bought a used '99 sunfire
- 1997 sunfire standard engine life
- 99 Sunfire Problems
- Repainting Front Left Fender
- Signal, DRL, headlight possible ground issue???
- Questions about Passlock I
- Adjusters for Sunfire Headlight
- Turn lights "orange" law???
- 1999 sunfire NO high beams
- Tail lights
- dash lights not working
- Problems with sunfire maybe bypass? or ignition?
- 98 sunfire gt engine swap
- Will a 2.4 liter RT4 engine from a neon fit into the 99 sunfire gt?
- 96 sunfire air lock
- Car won't start...
Automotive Network, Inc., Copyright ©2012
