View Full Version : General Discussions
Pages : 1 2 3 4 5 6 [7]
  1. spark plug wire diagram!!..help me!
  2. what to replace to get smooth engine?
  3. Antitheft Deterrent
  4. o2 sensor and ohter questions
  5. odometer
  6. backup light sensor location
  7. need help
  8. How do you reset the dash lights?
  9. Please help me with an oil change
  10. replacing fuel filter - tips?
  11. sunfire head gasket $700 to $1000 to replace? AHHHHH!
  12. 99 Gt ETS light on
  13. HELP! injector replacement gone bad....?
  14. car cutting out
  15. High Beams not working????
  16. Gauge cluster
  17. throttle body temp sensor
  18. throttle body temp sensor
  19. ceramic brake pads and new rotors
  20. Preventing lettering from rubbing off
  21. 1997 Pontiac Sunfre ABS Brake problems
  22. carbon fiber hood
  23. 3.5 V6
  24. '96 Sunfire cranks in park but will not start
  25. 3.8L Supercharged Sunfire?
  26. Theft System 99 sunfire
  27. 2000 Pontiac Sunfire
  28. Installing new car deck
  29. Power Window Switch for Sale?
  30. transmission dipstick
  31. body kit
  32. Stupid Question from a beginner
  33. 1995 Sunfire fails to start occasionally
  34. Headlight Help
  35. Oversize oil filter
  36. !997 Sunfire Speedometer
  37. Is it possible to do this with a Sunfire
  38. Where is the headlight fuse? (98)
  39. 98 sunfire bogging out when idling
  40. easy ways to improve 0-60 time frame?
  41. I need a windshield for a 96 sunfire
  42. Back speakers giving me troubles
  43. Am I on the right track with my SunFire??
  44. Whats wrong with my car?
  45. 3.8L Supercharged V6?
  46. Interior light delay
  47. head gasket problem?
  48. Whats up with the seats in the new Sunfire?!!
  49. 1997 Pontiac Sunfire Headlight Replacement
  50. head light buzzer out
  51. new ignition switch 97 sunfire
  52. Timing Belt Change??
  53. 2002 4dr body kits
  54. why wont i accelerate
  55. car won't start
  56. Break Problems, ABS and Break Light
  57. 97 sunfire parts
  58. car acting odd
  59. 99 Sunfire Transmission
  60. underbody car kits
  61. ETS and Engine Light and head lights
  62. Where Is The Spark Plug??? 2002 2.2l 4 Cyil. Sunfire
  63. Car Stalling
  64. Oil leaking from oil filter....PLEASE HELP
  65. jbody site
  66. Keyless entry problem
  67. 2003 Sunfire, Headlight Problems due to a small accident...
  68. Oil Light Keeps Coming On!
  69. 1996 remote keyless entry
  70. ABS, BRAKE, AIR BAG light stay on
  71. stupid 4 door!
  72. Blitz Body Kit
  73. crank sensor?...more
  74. Shocks / Struts Upgrade?
  75. Sunfire headlight help
  76. engine removal
  77. breaking problems
  78. More Rear speaker Q's..
  79. steering noise
  80. Accessing/Clearing Fault Codes From OBD-II Connector On 1998 Pontiac Sunfire GT
  81. 2K SunfireSE Few help questions...
  82. Just Joined!
  83. Several problems...can anyone help?
  84. check engine light
  85. turbo...anything else needed
  86. Heat/AC Fan Works in only 1 of 4 Positions
  87. 2003 Sunfire
  88. Chip for the fan?
  89. noisy lifters
  90. Air Bag light on 97 Pontiac Transport Montana
  91. coolant light
  92. Mysterious clunking sound when braking
  93. 2003 sunfire car mounting kit
  94. Pontiac Sunfire gt Parts for sale
  95. Help...Car is shutting down after 2-3 kms.
  96. 1996 Sunfire Headlights
  97. Stiff steering
  98. Car glass fogging up deffoger not clearing
  99. clear turn signal for 2000 sunfire
  100. Lookin for a few pointers, Plz help
  101. '96 Sunfire dies at stoplight !HELP!!
  102. no heat
  103. 2001 sunfire abs light comes on
  104. Should I buy?
  105. Radiator plug problem - 1997 sunfire
  106. 1996 Sunfire Headlight Disassembly??
  107. major problem.. please help
  108. Cold air intake
  109. wire harness problems, PLEASE help
  110. Car Wont Start?!??!
  111. remote starter/headlight fuse problem
  112. 1996 engine hum
  113. MP3 Player
  114. Remote car starters
  115. Car stalls when put in gear
  116. Wheel speed sensor
  117. Haynes manual
  118. Need a new engine for 95 GT fast, please help!!!!!
  119. Air fuel meter
  120. 2004 sunfire sound system,annoying feature(cd player)
  121. Headlight Adjustment Guide?
  122. Possible Alternator problems??
  123. 2003 sunfire oil filter!
  124. installing new seat covers
  125. sunfire seats/mounting brackets
  126. removing headrest: 2dr 2001 Sunfire
  127. Rear Speakers
  128. Where can I get an ECU chip for my 1996 Sunfire GT?
  129. whirring noise when starting
  130. Late Model Sunfire Custom Interior Trim
  131. Exhaust Tips
  132. Transmission Trouble
  133. Painting Interior brushed metal look
  134. Cheap Speed Chip Mods
  135. 95-97 intake vs. 2000+ intake
  136. Cold Air Intake
  137. Transmission vacuum whine?
  138. Passenger Side Mirror Installation
  139. need info from manual, PLEASE!
  140. transmission problems
  141. 1996 sunfire
  142. Engine Swap
  143. Water Pump
  144. HELP! 95 GT cuts out while driving?!?
  145. Trannys!
  146. Wiring Diagram
  147. ABS & ETS
  148. Sunfire Torque Converter Problem
  149. Banging sound when turning
  150. Restrictor Removal?
  151. Boost my Sunfire's output?
  152. Dim Right Headlight?
  153. steering noise
  154. Need Sunfire Part!
  155. fuses keep blowing
  156. Trunk won't close
  157. New "Sunfire" Website
  158. Sunfire Odometer
  159. Free Mods
  160. Anybody have Pics or Installation Instructions for Dual Exhaust on a 1994 Sunbird
  161. Display Panel Replacement???
  162. Sunfire Forums
  163. stereo unlock codes
  164. Oil filter on 2k3 Sunfire
  165. Blitz Kit Info
  166. FS: Blitz Body Kit - Sunfire - WOW!
  167. Knocking sound
  168. are there any engine swaps you could do to a sunfire?
  169. sunfire mods?
  170. 03 Sunfire
  171. 2000 Sunfire remote keyless entry
  172. Add-on Remote Starter
  173. Headrest Removal?
  174. Help with Nology Power Core (ignition boosters) Installation
  175. need help?!?!?!
  176. manual shift knob removal
  177. ETS light wont go out?
  178. Spit, sputter, cough, gasp.
  179. Coilovers????
  180. Venom 400 for a 1997 Pontiac Sunfire 2.2L???
  181. instrument panel
  182. sunfire inner door panels
  183. hey need some advice im new
  184. Replacing Sunfire Spoiler
  185. Replacing Taillights...
  186. Interior Vents & What Not...
  187. Say so long to the sunfire
  188. sunfire passenger window
  189. 3rd Gear Engine Bog
  190. Automatic Shift Knob Replacement
  191. Program Keyless remote for Sunfire
  192. Removing 2002 dash...
  193. Looking at Buying a Sunfire...any advice?
  194. oil filter
  195. Body Kits/ Ground Effects?
  196. Suggestions for custom tailights
  197. www.conceptsinmotion.net
  198. What Mods Are Best In A Engine
  199. wheels for sale
  200. speakers for rear
  201. I need Help with a RPM Limiter
  202. Installing new 6x9s in the rear deck
  203. TX Bash Pre Meet
  204. VIN Decoder
  205. needs engine help
  206. 2002 sunfire Delco Removal
  207. Just Purchased Sunfire
  208. "Service" light
  209. Shift column light
  210. Sound System
  211. RKSport Streetfire Body Kit
  212. phantom headlight covers
  213. RPM Limiter
  214. Heating problems
  215. sunfire fix up
  216. sunfire engine swap
  217. Bumper inserts
  218. Programming Keyless Entry 02 Sunfire
  219. 1999 Sunfire Sedan. What mods?
  220. Clear side markers
  221. Adding Power Windows?
  222. Quad 4 H.O. specs
  223. Help me out here...
  224. Rookie
  225. Vote on my poll in the Cavalier forum!
  226. breaking in/stealing
  227. poniac
  228. Passlock I
  229. fuel odor
  230. Sunfire GT
  231. Wassup!?
