View Full Version : General Discussions
Pages : 1 2 3 4 5 [6] 7
  1. parking lights
  2. sunfire 2001 trouble removing rotor
  3. Pontiac Sunfire 97 2.4L Engine.
  4. radio wires???
  5. 96 2.4L Manual Trans - A couple problems
  6. theft systems and new decks
  7. cd player locked
  8. Ricer Mustang
  9. 2003 Sunfire stalls...
  10. Replacing a bulb above the license plate
  11. 99 Gt Burnin oil like mad
  12. new here
  13. 1995 Pontiac Sunfire
  14. Really rough idle problem...
  15. pontiac sunfire gauges
  16. adding power windows
  17. Fan Belt ? on a 98 Sunfire
  18. AC Compressor + Clutch
  19. Radio Display
  20. Need Help
  21. 3400
  22. How do I Install a Cold Air Intake System on my 95 Sunfire?
  23. cd player problems for a 2001 sunfire
  24. 98 GT Tach Wire???
  25. Trading Up?
  26. New radio for car
  27. Error Code PO502
  28. Igniton Module and Coil
  29. body modifications and engine upgrades
  30. '03 Sunfire GT BIG PROBLEMS HELP!
  31. 2000 Sunfire radio swap procedures...
  32. Would?
  33. Who would win?
  34. Exploited Racing Turbo
  35. Transmission Problems
  36. car doors freeze shut in winter?
  37. 1997 CD error message E23
  38. '98 CD Player Help
  39. Odometer Driving Me Nuts!
  40. Internal lights??
  41. Defrost wiring broke free
  42. PVC port
  43. GM recalls
  44. A dumb question...
  45. 2004 Sunfire Stock Radio Help
  46. 97 sunfire headlight/turn signal switch replacement: how hard is it really?
  47. Window crank Knob
  48. '97 Sunfire 2.4 dies without warning
  49. i need some help guys, motor questions
  50. 2.2L OHV engine knocking noise
  51. 95 sunfire wont run in drive
  52. Projector Headlights
  53. EGR valve question
  54. 2 part ?
  55. New Girl
  56. Back speakers common problem?
  57. Vacuum cannister
  58. wuts a gt run?
  59. CD player error message...
  60. Optimal Shift RPM
  61. Cutting out at 4,000 rpm
  62. WAter pump question
  63. Lights & Speakers Installation
  64. programming remote for 96 sunfire
  65. Weapon R Breather
  66. 2000 Sunfire 2.2L engine potential problems
  67. Good place to get Sunfire parts online
  68. sunfire
  69. Keyless entry programming for 2001 Sunfire
  70. Anyone else?
  71. 1997 Runs Sometimes, sometimes not?
  72. Key stuck!
  73. 3.8s/c
  74. Help needed for color coding on stereo
  75. Shifting Problems
  76. 96 sunfire gt v.s. 95 dodge neon sport
  77. cam?
  78. Anyone else think the 01 is a p.o.s?
  79. 96 sunfire engine swap
  80. ?
  81. Turbonator?
  82. Motor Mounts
  83. How to change Reading lamps?
  84. need help with a/c problem
  85. sunfire shirt
  86. transmission fluid dip stick
  87. Sunfire for sale
  88. 96 sunfire gt transmission dip stick
  89. 98 sf couple probs...
  90. Newbie needs help
  91. is rubber tube safe for transmission fluid
  92. Massive coolant leak ...maybe water pump?
  93. New to the forum.
  94. a little push
  95. Coolant fan won't work
  96. Body Kit or Stock Bumper?
  97. new gm
  98. Timing chain replacement
  99. Headlight bulb replacement
  100. Sunfire 2003 Automatic Shift Light problem
  101. check oil light
  102. turbo or supercharger
  103. Lighting problems... Need Help B4 I get another ticket
  104. CAI/short ram?
  105. Where to buy interior paint
  106. 98 Sunfire keyless entry programing
  107. Best CAI??
  108. 2003 Sunfire
  109. clutch fluid
  110. help on the drive belt install
  111. fuel filter location???
  112. Rpm Limiter
  113. fed up
  114. ac makin funky noise
  115. issues starting sometimes
  116. 98 Sunfire GT Transmission problem
  117. New Engine
  118. I got a sunfire !
  119. check engine light will not go away
  120. Yay For me lol
  121. New here
  122. possibly engine work?
  123. My car is chugging badly pls help!!!
  124. bulbs for dimmer and window switch
  125. a sad story.
  126. Friends a/c is making grinding noises :(
  127. Possible engines
  128. Clicking sound from A/C fan?
  129. Suddenly poor mileage
  130. 2003 pontiac sunfire electrical problem
  131. ABS light stays on on 96 Sunfire...
  132. Car seems to stall while driving and all cluster lights come on
  133. Lambo door conversion
  134. timing chain replacement
  135. Found a new kit for 2dr sunfire
  136. alternator
  137. Rad Fan Problem?
  138. Selling Canadian/do I need to switch speedo to American?
  139. 2004 sunfire shifter knob
  140. help...transmission problem!?
  141. possible loose connection?
  142. timing belt or chain?
  143. Carbon Fiber
  144. 1996 pontiac sunfire door lock
  145. rolls(a little) in Park
  146. 2000 Sunfire sound system help
  147. Sunfire GT 2.4L?
  148. ignition problem PLEASE HELP!
  149. Horn problem
  150. 96 sunfire making weird flapping noises
  151. Pontiac Pursuit
  152. 99 Sunfire Odometer Out
  153. AC Fan problems
  154. 1995 Sunfire Factory Antenna
  155. need help installing 6x9s in the rear
  156. Question about ac not working?
  157. 97 sunfire auto transmission shift problem
  158. 98 Sunfire - Where's the block resistor?
  159. my brand new 04 sunfire burned up in my driveway
  160. back seat
  161. Diagnostic trouble codes.
  162. error code 440
  163. 97 Sunfire .....3k Rpm Sounds Like Tap Dancer
  164. 1997 sunfire timing chain
  165. Removing stereo in a 2001 Pontia Sunfire
  166. 1998 4dr body kits?
  167. sensor problem?
  168. fuel filter
  169. 95-99 Sunfire Questions
  170. Need an aluminum wheel (16" 2 spoke) in Vancouver BC
  171. having trouble with my belts
  172. FS: Factory in dash CD
  173. Sunroof Won't Close
  174. Can any one help with a Drive Belt Problem
  175. List Performance/suspension Upgrades
  176. jacked up radio
  177. speed limit
  178. valve cover torque specs
  179. Theft system light on , no theft sysytem
  180. Please HELP!!!!!!!!
  181. getting a bodykit WEEEE!
  182. How hard is this going to be?
  183. interior
  184. track off?
  185. timing chain in 2.4
  186. engine is hard to start
  187. 1995 Sunfire Needs Help
  188. 85 olds stalls when hot
  189. Reactive Strut Bar?
  190. pedals
  191. Sounds Like Motorcycle!!
  192. More horse power
  193. 2002 sunfire
  194. 1997 sunfire No headlights
  195. help shifting plz
  196. How bad is it...?
  197. Drain plug
  198. '99 Engine
  199. Engine Issues with 2001
  200. 2001 Sunfire GT High-pitched whistle
  201. fuel problem
  202. Doesn't look good for me
  203. Sounds like...grinding?
  204. strange noice, maybe the axle?
  205. Parking light problem
  206. Brake light not working
  207. What Engine can fit for 96 Sunfire
  208. Theft system causes no start
  209. Putting rims on 2001 2.2L
  210. poor mileage 2.2L
  211. "ETS Off" light. Can Someone Help me?
  212. 1991 Sunfire Stereo Replacement
  213. 1998 Sunfire Stock Deck Wiring Specs
  214. Radio won't turn off after door is opened.
  215. Odometer display flickering
  216. Passlock alarm problem
  217. how do i get to the oil filter on 98 sunfire 2.2l
  218. 1998 sunfire 2.4 quad engine
  219. fog light problem
  220. odometer cannot switch
  221. Lights working now
  222. Exhaust Questions.
  223. Can't Handle It ~ No Music
  224. HELP:Does anyone know the firing order for spark plugs?..
  225. anyone know how to change air filter DIY
  226. Door Panel Removal
  227. Check engine light! need parts
  228. 2 sets of sunfire tribal letter decals
  229. Squeak in dash. Do I have a mouse?
  230. Parking Light problems????
  231. 1997 Sunfire Cigarette Ligther Cap and Gas Cap
  232. Sunfire steering noise
  233. Installing a CD Player in a 2000 Pontiac Sunfire
  234. 2.4 L engine timing chain noise
  235. another prob
  236. Front End
  237. rotten egg smell
  238. ETS AND ABS light on. Any thoughts?
  239. defrost
  240. Euro Gauges for 1998 sunfire?
  241. Brake pads wearing out fast???? Help
  242. Daytime Running Light Failure
  243. creaky front end
  244. 1998 Sunfire acting strange
  245. Pic's of there Sunfires
  246. Selling any accessories for sunfires?
  247. KYB AGX Shocks and Struts
  248. Bumper Inserts
  249. no spark after engine rebuild
  250. spark plug wire diagram!!..help me!
