Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Pontiac
Sunfire
> General Discussions |
View Full Version :
General Discussions
Web
AF
Pages :
1
2
3
4
5
6
7
Door speakers on "upgraded" stereo
00 Strut Mounds
Motor swaps
Sunfire trunk help!!!
95 sunfire ABS
good cams
HELP! 98 Sunfire Cams gone!!!
cruising control problem
What Body Kit?
radiator leak, noisy fan
95 sunfire coils
97 Sunfire Number 1 cylinder no spark
97 sunfire number 1 not firing
Parts required for a 3800SC v6 swap
adding cd changer to factory deck?
fuel pump problems
driver window
98 Sunfire GT... is there a rad cap?
Fuel pump?
Engine Warning Light On/ Gear Indicator Not
96 Headlight intermitant Mystery
Headlights are SCREWED!
Shift at High RPM
Its official GM NEVER AGAIN
DRL problem plus radio problem
Help Me!!!
gears
water coolant light
More problems with 2001 Sunfire
Help
DRL relay frustration
fuel pump
Fuel Pump
head gasket
Odometer Problem - Lights out
well, been a while, I gots updates
2001 trac & check lights ??
D D D De Frost.
Washer Fluid
ETS light came on.
Break Problem
2003 sunfire DOOR & fender rubbing HELP PLEASE!!!
2001 Digital Odometer
Please Help Me With My Coilovers
2000 sunfire check engine light
2003 Sunfire radio replacement problem?????
Coolant in snow
Question about the windshield washer bottle
02 sunfire dies while driving - clutch is IN....
96 Sunfire GT Idle / Power Problem - Question...
95' Sunfire Help
Ecotech?
cold start
DRL and Headlights out HELP!!!!
Bodykits
Transmission Help!
2001 Sunfire stalls_will not start
High compression heads
Question Urgent Please Help!
1997 Sunfire wiper problem
Teenager in need of help
Sunfire GT '99 Lock Question
96 2.2l Timing Chain Noise
95 sunfire 2.2 Clutch help?
Location of Water Pump in 2.4L Sunfire?
Heater not quite right-any ideas?
Fuel problem??
Coolant in oil problem source?
Need help
Changing shifter knob
Oooh ....ADMIN?
Engine Swap
RPM drops below 1k when wheel turns
98 sunfire se stereo problems
Sunfire 1998 rear struts
tail light terminal
Yeah please someone help
Looking at getting a Sunfire...
1999 sunfire transmission dipstick
Won't crank/coolant problem...related?
transmission problems
1996 pontiac jerks a little......
Removing side panel
99 Sunfire Something's Up With My Brakes!
Dashboard Lights
98 sunfire DRL problem
Need some input (about car audio)
Thermostat
JVC KD-S5050 displays "See you" then turns off
CD Receiver issues
installation instructions for coilover kit
Headlights-wiring harness
Body effects
ABS and BAT light
driver door locks
Car running missing at times
Ets
Clutch Plate Drag
98 sunfire GT brake problems
1996 sunfire w/ 2.2 running real cold
2000 sunfire question
2002 power steering
Pont. Sunfire Backup lights
2000 Sunfire - engine light on/flashing
Help Please!
2003 sunfire need help fast
heater in 97 sunfire
2002 Sunfire GT and Doors/Locks Freezing :-(
1996 Sunfire GT starting problem
Real Stupid question.
96 sunfire wipers
04 Sunfire
service and abs light always on
04 Sunfire
Fuel pump relay
95 sunfire grinding noise
need help!!!!!
sunfire radio
needles don't work help!!!!!!
New Car Troubles
Monsoon Stereo Calibration 02 Sunfire-
engine dress up
Help on 1994 Sunbird LE
Ignition misfire
monsoon Stereo Install on 2002 Sunfire
Keyless entry pad programming 2002 Sunfire
2001 sunfire hood
Water Pump Leak 1997 Sunfire Gt
shifting problems
2000 Pontiac Sunfire coup
I have no idea. You have to read thread to understand.
New problems after the -35 degree weather
NO REAR Defrost, need major help
Serpentine Belt Replacement Tip
96 Sunfire stalls for 15min, starts agian
Replacing Amber Turn signals with clear
Cat... removed
1998 sunfire cd player registers "E 20"
2000 SE: AC Compressor/blower motor/speakers
forum woes
New Subforums
Overheating
Magical Mystery wiring 95 Sunfire
clutch i think
RPM and Milage gauges go haywire
code P1887
2000 sunfire timing problems HELP
Recently got a 95 Sunfire
96 Sunfire Acceleration problems
Bright Headlights
96' Back light for insturment cluster won't work
95 Sunfire Passenger Seat won't lock in place
headlights very dim
plz help me out!!!
bolting up?
My '96 Sunfire...
02 SF Service Engine soon & Enhanced Traction Control indicators on ?
1996 sunfire
i would like a reply to my problem
1997 2.2 questions-->plz help
sunfire+RS=flashing airbag light
Installing Rear Speakers in '95 4 Door Sunfire
>>>ATTENTION!! Need Feedback!!!<<<
engine swaps
rusting problems
headlights are out
96 sunfire runs cold
Gas Smell
Water Pump replacement on a 2000 Sunfire 2.2L
Coolant Level Sensor
engine ticking
03 pontiac questions
J-Body blower climate control disease
Car wants to bog at light
overheating 1996 sunfire why???
Something funny about my heater
radio is on loc
Headlight adjustment ??
1995 Sunfire Stuttering Problem
Pontial 2000 Sunfire Trunk Won't Close
Who Would Win?
"headlights"
Window won't crank up
2.3 Engine Block Cracked
turn signals not working
fm stereo not working
AC just wont keep cool
2.3 intake on a 2.4
changing break pads need help
2001 sunfire trouble
Ticking noise when i turn
My new 98' sunfire sound system
New to the Forum
98 Wiper Arms
Little door pin that shuts off radio not working
2200 motor
set me straight on this..
Error code PO300
Alternator Wiring
Right signal keeps blowing out...advice?
2000 Sunfire GT
HELP! Odometer went from 180K to 64K...
car won't start at times
03 sunfire wont start
Signal Lights not blinking
'97 sunfire gt = bad shocks?
2001 GT Won't Start..
Need help - All electrical cuts out while driving!
Changed Alternator/Battery Now No Start
need tail light for 96 sunfire
Best engine to boost?
Aftermarket Torque Link???
Black deposits on the muffler tips
Couple of Questions
Factory Stereo
'97 Sunfire GT + '97 Buick Regal
replacing heater core
2000 Sunfire Lights flicker on/off while car is turned OFF!
tornado air filter
Interesting and new here
Manual Transmission Oil
road noise high
Engine over heating
sunfire 2.4gt trouble code #P0172-system rich
adjusting parking brake
2003 euro light installation
'96 Sunfire Water Pump
Hiya, just joined :)
Warm still, no AC. Winter coming no heat!
97 sunfire gt probs
wierd noise at 2000rpm's
HELP! I need to disarm the stock alarm Right Now!
Service Manual Recommendation?
03 Sunfire Upgrades
problem driving car when cold
Really low Idling
day time running lights are spazzing
1997 Sunfire Gt intermittant squeeling Problem
Computer from automatic
Auto to Manual tranny swap.. HELP!!
gage lights
Question
Engine light currently on won't go off
03 ecotec 5 speed sunfire have troubles
Any good sunfire websites?
Help Required. Frustration Level Exceeded
What happened to my remote entry?
2003 mitsu eclipse GT AT vs 1999 sunfire gt
99 sunfire ashtray
Drum brake return spring '95
Web
AF
