View Full Version : General Discussions
Pages : 1 2 3 [4] 5 6 7
  1. 02 Sunfire- Revving While Stopped or Idle
  2. The turbinator?
  3. car driving problems, timing chain?
  4. PLEASE HELP ME - 2001 Sunfire Won't Start
  5. ignition coil housing comparison
  6. Engine mounts?
  7. 1996 sunfire loses power and dies
  8. NADA vs. Kelley Blue Book price
  9. anti theft
  10. cabin air filter
  11. Engine chuckles during cold start??
  12. AutoLoc power windows installation?
  13. 2002 Sunfire intermitently stalls
  14. for sale
  15. dim headlights
  16. Help! Popping Noise in dash when ignition is turned on
  17. found problem for head lights
  18. Used oil question...
  19. any thoughts on this turbo
  20. Sunfire/Cavalier Stereo
  21. Creeking door???
  22. Fuel Filter location for 2001 Sunfire 2.2
  23. Sunfire: Rear speakers work intermittently
  24. rear brakes
  25. front speakers
  26. 2001 Sunfire Fuel Pump Reset
  27. sunfire no start
  28. Spark plug replacement
  29. Lights in Radio starting to go
  30. f/s air bag for 95-99 sunfire
  31. problems starting 02Sunfire after 6 weeks
  32. Odometer Messed Up on 2000 Sunfire
  33. Changing ATF/FILTER O-RING HELP!
  34. removing a 95 sunfire dash.
  35. Loud humming sound from fuel pump or gas filter
  36. Loud humming sound from fuel pump or gas filter
  37. Does a non-cruise control car have the workings installed?
  38. 2002 brake drums
  39. air bag light stays on
  40. 2000 Sunfire For Sale
  41. Spark plugs
  42. Engine Whine - Based on Engine Speed
  43. Adjustable coilovers
  44. Camber kits?
  45. can u put a v8 in a 2001 Sunfire?
  46. 97 Sunfire GT 2.4L 90k miles.
  47. 95 2.3 dohc engine repair or replace
  48. Instrument panel 1997 question....
  49. 2.4L starter
  50. Transmission wont shift into 3rd or 4th gear
  51. 98 sunfire has no pickup... whats going on?
  52. cd player help for a newbie
  53. sunfire mileage
  54. smoking in steering column
  55. smoke in steering column
  56. 95 Sunfire AC Stop Leak
  57. Hey all New member
  58. transmission
  59. key stuck anti-theft light on
  60. Which impedance of resistace i need to up some HPs.
  61. Governor
  62. 2000 GT Engine Noise
  63. 2000 sunfire 2.2l Not starting
  64. Price Estimate, Transmission, Starter, Signal Problem
  65. 2000 sunfire - coolant leaked and overheats ?
  66. Tried all that I could think of, HELP
  67. Location of stock module alarm.
  68. Not Working remote entry.
  69. Coilpacks/spark plug removal
  70. Positive or Negative?
  71. 1999 sunfire need help
  72. need motor
  73. 99 Sinfire radiator fan replacement
  74. 2000 sunfire mysterious problem
  75. Looking to buy soon and wonders about common problems
  76. My sister wants to upgrade her sunfire.
  77. 1991 Sunbird LE - High Idle
  78. 98 sunfire needs jump to start
  79. 02' sunfire speaker upgrade?
  80. PCV Valve
  81. 1999 Sunfire Buzzing Noise Behind Dash
  82. 2.4L throttle jumps and sticks
  83. 2.4 twin cam
  84. popping sunfire
  85. 95 Sunfire hesitates while driving!
  86. misfire
  87. 2003 Sunfire Rear Brake Issue
  88. Car bogging out when accelerator pressed
  89. how much is my car worth?!
  90. Dipstick is broken?
  91. p-flow of 2.4L
  92. Muffler hanger
  93. Sunfire - Needs New Engine
  94. 2001 Sunfire...Radio help!!
  95. music
  96. Need to Change PVC Valve? Where is it?
  97. A/C for 98 2.2 auto sunfire
  98. 98 Sunfire 2.2 automatic-motor mounts?
  99. Wheel Bearings going bad
  100. 1998 Sunfire 2.2l code PO301 misfire cyl. 1
  101. Electrical System Problem
  102. Sunfire Radio Display Hot
  103. 2005 Sunfire - fan runs after engine off
  104. 2000 pontiac sunfire keeps running hot
  105. any help?
  106. 2000 Sunfire needs new ignition key ?
  107. is it a fuel pump?!
  108. 1997 sunfire gt keyless entry
  109. body interchange years for 02 sunfire gt
  110. R134a Can Orientation
  111. 1996 sunfire stalling in warm weather
  112. Want to drop...
  113. annnoying drill noise from stereo
  114. Pontiac Sunfire 90,000 mile service is it a rip?
  115. 2005 Sunfire engine question
  116. died on interstate
  117. noisy chain
  118. 96 pontiac sunfire engine just stopped at stop light then turned over on restart
  119. Sunfire Error Code Help...
  120. 96 Sunfire w/00 2.2 Cavy engine
  121. CD player installation on a 95 sunfire
  122. 2005 M/T Sunfire Intake?? Does It Exist????
  123. 2000 pontiac sunfire- starting problem
  124. 1995 Sunfire 2-Door SE PLZ HELP!
  125. 96 Sunfire- transmission problem?
  126. sunfire revs to high when i start it
  127. 98 Sunfire Baffling Problem...
  128. 2005 at dealership
  129. Cluster light isn't working...
  130. 2002 sunfire Airbags.. WHat fits? PLEASE HELP!
  131. bad day
  132. A/C Help, New Compressor, no power to it
  133. 2002 sunfire 2.4L a/c compressor problem
  134. 1997 Sunfire Stopped & Won't Start
  135. Sunfire fuel problem
  136. howto remove window rollers
  137. 97 Sunfire Horn Problems
  138. need help with racing
  139. Rattling noises
  140. o2 sensor, bank 1 sensor 2?
  141. help
  142. 2001 Sunfire fuel problem....Will not start
  143. AC problems
  144. RK Sport Dual Exhaust System
  145. 98 sunfire 2.4 lifter question
  146. 02' Sunfire
  147. 1998 sunfire 2.4 engine knock
  148. 2000 Sunfire FOR SALE...
  149. Sunfire GT engine swap
  150. A/C Recharge
  151. Looking for cylinder head
  152. My emissions box fell off...
  153. Remote Start Stopped Working?
  154. Convert from Power to Crank
  155. 00 Sunfire OEM/Wires & Color Codes Help
  156. intake
  157. ETS and Check Engine Light
  158. 1998 sunfire gt light
  159. 95 sunfire... lack of power when cold?
  160. Wanted: Sunfire Body Kit
  161. 1995 sunfire-stalling,pick up weak and burning smell
  162. 1998 pontiac sunfire
  163. Engine rattling noise
  164. New Members Please Read!
  165. ignition still on when you remove the key
  166. CD Player 01
  167. Intake install on Manual Tranny
  168. Leaky trunks
  169. my vibrant performance intake doesnt make ANY noise
  170. Which Pulley
  171. 97 sunfire, clutch = funny noise, crankshaft bearings??
  172. heel toe-ing
  173. Pulls to the right
  174. Turn Signal Fuse Shorting Out in Reverse
  175. suspension problem?? help!
  176. '96 Sunfire SE Convert -- Whole Host of Problems!
  177. 97 sunfire fuel issue
  178. buzzing noise
  179. Dumb question from dumb fat man
  180. brake calipers
  181. WTB - Ash Tray
  182. 99 Sunfire Headlight Change
  183. CD Player Error
  184. New timing chain
  185. new short ram intake messus up sensor 02 sunfire
  186. tranny or electrical issues?
  187. '96 sunfire hard starting
  188. Programming Connector?
  189. Tranny Issue 01 Shitfire 2.2
  190. Oil light and battery light came on, car quit running
  191. 1997 sunfire keyless entry
  192. Turn ignition and doesn't click-won't start
  193. Car stalling for no reason, help
  194. Love an honest mechanic!
  195. installing a blower motor for a 2001 sunfire
  196. test
  197. has anyone installed a blower motor in a sunfire prefer 2001
  198. car stalls at stoplight
  199. 1997 Sunfire AC
  200. 98 sunfire gt overheating
  201. Hey! I'm the new guy!
  202. 02 Sunfire starting problem....
  203. 97 Sunfire Cigarette lighter
  204. alarm and serivice lights are on
  205. wont start
  206. fuel leak at the injector
  207. My exhaust droped to the floor all of a sudden.
  208. 97 sunbird license plate lights help?
  209. HELP!!! Radio wiring harness colors
  210. Car won't start FUEL PUMP?
  211. Sunfire fuel pump / gas gauge. Need help
  212. help me with this car!!
  213. Sunfire Gt Check Engine Light
  214. Engine Swap for 1994 Sunbird
  215. 2000 2.2 into 98
  216. A/C Problems 99 Sunfire
  217. sunbird stall
  218. Sunfire wiper problems fixed!!!
  219. mods available
  220. question about 'Fire radio loc
  221. Note to self
  222. Im New .hello Everyone
  223. After Makret shifter
  224. Hit a curb with my car.
  225. wipers
  226. loss of power, dash lights flicker
  227. Replacing Head!!! Need help ASAP!!!!!
  228. 1995 Sunfire oil light and transmission trouble
  229. stiff steering at slow speeds (2000)
  230. Please Help if u can
  231. just making an observation
  232. cavalier trunk
  233. 2002 sunfire wont start
  234. 2004 Sunfire Check Engine Light / Bad Trunk
  235. '99 Sunfire Radio in LOC
  236. cracked exhasust valve
  237. Check engine codes
  238. My 97 sunfire has no pickup plz help
  239. 96 sunfire will sometimes crank but wont start
  240. '98 Sunfire SHUTS OFF while driving
  241. 2004 Sunfire stereo replacement
  242. window roller removal?
  243. 1995 sunfire recalls
  244. 95 Sunfire Jerking/Bucking
  245. Caliper Removal
  246. radio problems
  247. '96 Sunfire horn location
  248. Cannt get my 89 sunbird to start!
  249. changing headlight bulb on a 98 sunfire
  250. power windows for 2000 sunfire?
