View Full Version : General Discussions
Pages : 1 2 [3] 4 5 6 7
  1. Codes
  2. Rough shifting
  3. Door Hinge Bushing Replacement?
  4. Fuel line leak
  5. DRL headlights: please help!!!
  6. rotor or bearings
  7. how to check codes
  8. 2003 Sunfire Repair Manual
  9. Sunfire Wont start
  10. Headlights
  11. Help! Noise coming from tire area
  12. Another alternator dead
  13. 1998 Sunfire need help fast
  14. new radio
  15. Radio antenna
  16. Cold at 2500RPM+... doesn't quite overheat?
  17. Terrible noise
  18. Remote Replacement--warning!
  19. idle speed control motor
  20. 1997 Sunfire Non Shifting Transmission
  21. Light problem
  22. oil light
  23. 1999 Pontiac Sunfire Question
  24. 97 SF overheating and blowing coolant
  25. 99 sunfire
  26. Door won't open - wind whipped door back
  27. Problem with one of my power windows
  28. 99 Sunfire misses at idle speed
  29. 97 Pontiac Sunfire Xenon 9007 Bulbs
  30. How to Remove Air Trapped in Radiator
  31. 98 sunfire rad fan not coming on!
  32. 96 Sunfire GT rough Idle no power and sucking gas
  33. Bunch of small problems
  34. 2000 Sunfire GT with noises! PLEASE HELP!
  35. Check Engine Light
  36. '96 Pontiac Sunfire Losing Power
  37. Koni Shocks (Rear) Install
  38. help with 98 sunfire 2.2
  39. ABS, Trac Off, Service lights
  40. do i have a plugged cat.?
  41. Fog Light Relay?
  42. Warped rotor
  43. power steering pressure hose line question
  44. 2002 Sunfire Gauges going crazy
  45. drivers side doesnt defog
  46. rear defrost switch buzzing
  47. Fluid leak-weird place
  48. new air intake
  49. 2001 sunfire
  50. Theft code car will not start
  51. 98 Sunfire P440 Code
  52. Safety Feature
  53. 1997 Pontiac Sunfire GT FOR SALE
  54. Engine coolant light comes on
  55. first car help
  56. Thermostat Housing - 95 Sunfire
  57. No wheel lock key
  58. Desperate need of a wiring diagram
  59. Ecm
  60. for sale
  61. V8 Sunfire
  62. 03 Sunfire Headlight wiring problems
  63. Annoying Problem
  64. Bumper repair
  65. No high beams or daytime running lights
  66. Loose BOLTS!!!!!
  67. Transmission Dipstick
  68. MAP senser
  69. dash dimmer switch
  70. 1997 Sunfire Pontiac
  71. 2002 Sunfire VLX
  72. 1996 Sunfire Engine Wiring Harness
  73. press. test
  74. fuel pump relay going crazy
  75. 94 Sunfire/sunbird that sounds like a lawn mower
  76. 2002 Sunfire Wont Turnover
  77. Intermittent Starting problems
  78. 2002 sunfire help needed
  79. Low idle problems
  80. 1997 Sunfire start problems
  81. Engine Swap
  82. 96 Sunfire...fuel pump isn't coming on
  83. Eco-Tech oil filter cap
  84. 98 Sunfire Stalls On Slow Left Turn
  85. 2000 pontiac sunfire just bought yellow light on wont go off circle w/slash though it
  86. oil light comes on and check engine light comes on
  87. remote start help
  88. Did I break something?
  89. A/C Blows out of all Vents. Why?
  90. '96 sunfire Daytime running lights help
  91. interior leak from rain
  92. Blower Resistor
  93. 2003 sunfire headlight problem
  94. 1995 Sunfire GT won't start
  95. Frosty windows
  96. 2002 Front Door Woofers
  97. 96 Sunfire, 2.4, auto
  98. Door Switch
  99. Im thinking alternator problem
  100. radio problems
  101. Starter/Solenoid how to?
  102. 2000 Sunfire GT
  103. Light problems
  104. 2003 Sunfire stalls while driving
  105. 1996 sunfire starts and dies
  106. Installing air intake
  107. Do I have a blown head gasket?
  108. Sunfire transmission problem
  109. fuel needle
  110. Seat belt replacement
  111. Wont come out of park
  112. Crankshaft Position Sensor
  113. can i
  114. 2.2 ltr questions
  115. 2002 Sunfire Coupe door speakers
  116. How reliable are 03-05s?
  117. monsoon?
  118. Rear Brakes
  119. engine swap
  120. where is electronic flasher
  121. Faster
  122. 2001 sunfire wont start!!!
  123. Upgrade to a MP3 player
  124. Door window replacement
  125. question
  126. OK Need Serious Advice Major Engine Problems
  127. What is good gas mileage for a Sunfire
  128. Fuel Filter
  129. New owner for 1 month
  130. Are These Two Related?
  131. Manual Door Locks completely stuck
  132. heater fan making lots of noise
  133. Fumes & burning oil
  134. 97 sunfire heating
  135. 99 sunfire w/o driving lights no high beams
  136. 2001 Sunfire Windshield Washer Reservoir
  137. How do I take off my Dashboard on my 2000 Sunfire
  138. 99 pontiac sunfire, check gage light on
  139. Dash Removal
  140. 1998 Sunfire 2.2L, charging system problems
  141. removing interior door panel
  142. hard to start
  143. 1999 sunfire braking problem
  144. Alarm won't stop going off
  145. How do you remove a Pontiac Sunfire Head Rest
  146. 03 Sunfire all dash gauges gone beserk!
  147. broken timing chain = bent valves? 2.2L OHV
  148. trunk release
  149. grinding noise coming from hood
  150. 2000 Sunfire Engine Noise (HELP!!)
  151. Tranny problems ...
  152. 97 sunfire won't start sometimes
  153. 1997 Sunfire engine dies when standing in hot condition
  154. trany fill up on a manual 2.2L
  155. Trunk latch broke
  156. 1996 Sunfire engine miss at 4000RPM
  157. 1995 sunfire, looking to buy it but have questions
  158. 96 Head Gasket - Removing Intake Manifold?
  159. Changing plugs and wires on Sunfire
  160. fuel pump problem
  161. 2000 Sunfire turn signal flashing rapid...
  162. 91 Pontiac Sunbird 4 cylinder
  163. 1999 sunfire problems need help bad
  164. Strange trans shifting on cold mornings
  165. Strange shifting on cold mornings
  166. Sunfire 03 huge steering problems
  167. Steering sounds like rubbing vinyl
  168. Air conditioning comes on when on defrost
  169. 2001 Sunfire Sqeak or Rattle from Front Strut Bearing Mount
  170. 98 GT Pcv Valve And Fuel Filter Loctions???
  171. No defrost
  172. J-body Parts 4 sale from a reputable member!
  173. Failed Emission Testing
  174. OBDII code problem
  175. 95 sunfire engine prob
  176. 1997 Sunfire - washed car now wont start
  177. 2.4 sunfire GT turbo
  178. 2003 sunfire check engine light
  179. braking problem
  180. Changing the thermostat.
  181. What to look for when buying a 1996 Pontiac Sunfire GT??
  182. Gear shift and check enine light
  183. performance parts
  184. Door was frozen to car with this mornings frost....TIPs???
  185. Power Window problem w/ my 02 Sunfire GT...
  186. 2000 sunfire heade light out dur to wiring
  187. fuel injectors
  188. Start up is sounding harsh... (2000 2.2L)
  189. 2001 sunfire GT problems engine problems
  190. 1998 sunfire o2 sensor
  191. Monsoon Sound System
  192. 2002 Pontiac Sunfire Clutch Problems
  193. cig lighter
  194. 1995 Pontiac Sunfire problems
  195. 96 Sunfire electrical wiring diagram
  196. passlock and security light comes on while driving
  197. Selling A 2.2 2002 to 2005 coil pack
  198. po401 code
  199. Altitude?
  200. 2001 Sunfire check engine light on
  201. can you help
  202. No heater blower, no power windows, no rear defogger?
  203. plug wire hook up
  204. '96 Check Engine Light on
  205. Sunfire 2.2 lifters noisy when warm
  206. noise during deceleration
  207. 00 sunfire sputtering constantly
  208. '98 pin found in oil pan
  209. 1996 pontiac sunfire 2.2 4cyl. 5 speed
  210. Fender/Bumper Replacement
  211. Help Electrical/Ignition problem
  212. 2002 Sunfire wont start on occasion
  213. rear break lock up help
  214. 2002 Sunfire GT Manual Trans Fluid?
  215. 2001 Sunfire. Alternator question
  216. 97 Sunfire GTX General Questions
  217. 95 sunfire, transmission problem?
  218. won't start
  219. Grinding Noise in 99 Sunfire
  220. 99 sunfire not starting
  221. Odd problem
  222. Starting problem
  223. Sunfire won't start
  224. Squeaky Wheel
  225. What Exhaust to get?
  226. No Daytime running or Bright Lights
  227. Need help to german Sunfire: clutch partnumbers
  228. keyless entry 99sunfire wiring?
  229. factory alarm wiring?
  230. Reprogram Keyless Entry 2003 Sunfire
  231. 95 sunfire passenger airbag
  232. 95 sunfire Computer problem
  233. Alarm System Driving me Insane
  234. 97 GT P0303 3cy. misfire HELP!!
  235. 97 Sunfire, Wet Floor
  236. 99' sunfire acting up PLEASE HELP!
  237. exhaust hanger p/n
  238. abs and brake light
  239. First Post - Introduction/Question
  240. Stock AM/FM Stereo to Stock CD Stereo
  241. Sunfire rear speakers
  242. Manual recommendation Sunfire 2004
  243. Automatic Transmission
  244. This is a nice looking Sunfire
  245. How to remoce the headrest ????
  246. Hazards work but no turning signals
  247. I need a belt diagram
  248. No power to fuel pump
  249. Rear strut towers
  250. back seat wont "snap" back into place
