View Full Version : General Discussions
Pages : 1 [2] 3 4 5 6 7
  1. 96 sunfire 2.4L dead
  2. 1998 2.2 rough running on cold start
  3. Quad4/Twin Cam/Ecotec owners!!!
  4. Side Mirrors
  5. Injector question
  6. no power to temp sending unit
  7. Strut or something worse?
  8. 96 sunfire with a few problems
  9. How gullible do mechanics think people are..
  10. I'm New Here.
  11. 1999 Sunfire headlight bulb repacement
  12. 2005 Sunfire - Programming Key Fob
  13. Rear end sagging a lot, with weight in it!
  14. knocking at bottom of engine...
  15. 96 Sunfire 2.2L Head Woes
  16. 2000 2.2 sunfire wont start
  17. R.I.P. Sunfire
  18. GT Wheel Bearing ??
  19. Heater blower motor?
  20. looking to buy a sunfire
  21. 96 Gt Brakes ??
  22. ETS Light ??
  23. HELP! Sunfire Rough Idle/ Dies, Hard Start
  24. Please help me diagnose this.
  25. Oil cooler hose leak
  26. headlights not coming on
  27. Stalling
  28. '99 Sunfire Engine Question
  29. intermediate steering shaft
  30. Sunfire Bearing??
  31. 98 Sunfire Gas Tank Leak
  32. Sunfire Rotars???
  33. 98 GT Control Arm???
  34. 2001 Sunfire se fuel filter
  35. Bicycle in trunk
  36. Need manual for settings!
  37. Cooling fan
  38. 1996 sunfire is giving me headlight problems
  39. 1999 Sunfire GT?
  40. 1999 sunfire stall problem
  41. 96 Sunfire GT
  42. brakes and rotors on 2001 sunfire gt
  43. What a father will do for his daughter...fuel pump change-out..
  44. 00 2.2L 5Spd. 3 problems
  45. Stupid question
  46. 1997 2.4 sunfire starting problem
  47. 1997 Sunfire gasoline smell any ideas?
  48. 1999 2.4L Sunfire GT overheating
  49. How do I replace a 96 sunfire oil pan
  50. Best Performance Upgrade For 95 Sunfire
  51. Loose Back End
  52. Sunfire Convertible - need weatherstripping
  53. Anyone here have a Carfax account?
  54. Transmission question?
  55. Convert OBD 1.5 To Full OBD 2
  56. Aftermarket car alarm installation
  57. Whats The Difference...?
  58. Looking for info
  59. Sunfire Body Kits
  60. Rear Speakers
  61. How To Replace Thermostat?
  62. 95 sunfire se 2.2L emissions failed
  63. 2002 sunfire underbody lights
  64. 96 2.4l ignition problems
  65. A few problems.. 98 Pontiac Sunfire
  66. FS 2003 Pontiac Sunfire FS
  67. fuel injector
  68. 2002 sunfire
  69. Sunfire 98 problem after replacing water pump
  70. 2003 trans fluid change
  71. odometer
  72. air condotioning
  73. 2002 check engine light
  74. hesitating
  75. 2.4 engine swap
  76. something wrong?
  77. odomter ligth
  78. BIG exhaust problems!!!!
  79. 98 Sunfire Coupe - How do you disable airbags
  80. Key ignition problem.
  81. F/S: 1998 Pontiac Sunfire
  82. changing spark plugs on 03
  83. Sunfire Dash Lights
  84. washable paint
  85. dashboard removal
  86. How do I know when to replace brake pads?
  87. water pump
  88. 2001 Starting problem
  89. projector headlights
  90. which ECM does a 1995 has
  91. Help to Test, maintenance or replace Sunfre 2002 Sensor's
  92. Replacing fuel filter on 2000 Sunfire
  93. Service Light - 03 Sunfire 2.2L SLX
  94. Help to Reset or Restart original computer value
  95. i need some help on a few questions
  96. Overheating ...now wont start
  97. '99 Pontiac Sunfire No Brake Lights
  98. ANyone use SeaFoam?
  99. Where are the o2 sensors located?
  100. questions for a friend
  101. radio hooking up from factory.
  102. AC mileage & overheat
  103. 97: New engine or total it?
  104. keyless entry not working
  105. Help!!
  106. Roll call kit
  107. Set up for supercharger/turbo.
  108. Need Help 1996 Sunfire GT Auto Tran
  109. A/C..02'Sunfire
  110. Need Help on 98 Sunfire alternator wiring
  111. install a cold air intake on my 97 sunfire
  112. WTH muffler hook
  113. power steering return line
  114. engine knock
  115. Ground straps on a 2000 Sunfire
  116. 03 front defrost dont work all air blows in front
  117. how do you remove the plastic piece
  118. Radiator Cooling Fan
  119. Found headlight defect in Sunfire and Cavalier.
  120. in need of a 2.4L crank
  121. How Hard is it too...
  122. Fuel Line Replacement!! Where do I start???
  123. Please Help Me!!
  124. 97 2.4 with steering and rad fan issues
  125. For Sale 2000 Sunfire
  126. 02 sunfire speaker connections
  127. Only ETS Stay on
  128. Interior Painting.
  129. where is the oil pan on a 99 sunfire
  130. Suggestion on Fuel smell in cab
  131. Sunfire help
  132. '99 Bad starting
  133. How do I replace a ignition key cylinder?
  134. Where is the EGR valve on a
  135. Will a 98 Sunfire interchange with a 97?
  136. Side Sunfire decal
  137. Sunfire 2000 Stub Axle Carrier?
  138. What should I do with this 2000 Sunfire
  139. rear light
  140. 1999 Sunfire Headlight For Sale
  141. Sunfire Head Gasket.....
  142. 2001 SunRoof Motor..
  143. 1996 Sunfire won't start. Dash acting
  144. Lomero
  145. Sunfire/Cavalier performance parts
  146. Hubs and Bearings, Eh? EH?!?!
  147. Hello? anyone on this board?
  148. Light bulbs/stereo display
  149. Power window motors 2002 Sunfire
  150. 97 pont sunfire overheats...HELP
  151. Question for Hotbug, Engine Swap
  152. 2003 Sunfire 2.2 start up noise
  153. Oxygen sensor replacement
  154. Resistance on Plug wires
  155. 1999 sunfire 2.2L wont start
  156. cylinder head replacement
  157. 1996 Stalled then No start situation
  158. rear struts ?
  159. 1999 2.2 sfi electrical problem
  160. 97 sunfire needs engine
  161. Engine problems, 01 2.2L sunfire
  162. auto to manual
  163. 1997 Sunfire Wiring Question
  164. spark plug
  165. Shifting issues
  166. 2002 Sunfire arm control bushings???
  167. Thermostat? 97 2.4
  168. 1997 Sunfire Starter Wiring Help
  169. 2.2 01 Sunfire Power Loss
  170. Tcc
  171. back-up lights
  172. headlights 80 / 100
  173. 1998 Sunfire: one dim headlight ?
  174. Overheat!!! 1999 sunfire
  175. Leaky injector 2
  176. '97 Sunfire AC Vibrates!!!!!
  177. New computer for my 98 sunfire...
  178. 2000 sunfire lights and starting problem
  179. Not 1, not 2, but 3! 97 Sunfire 2.4, alert lights
  180. 2003 2.2L ecotech oil capacity
  181. 2003 2.2L ecotech oil filter
  182. Pontiac 2.2L head change?
  183. blowen head gasket or cracked head?
  184. power loss 2.2L
  185. 97 Sunfire 2.4 Signal Control Arm
  186. Bleeding Air from Radiator
  187. Tires
  188. 1997 Sunfire, 2.2L Check engine light on..
  189. 96 Sunfire Difficult To Start in Rain
  190. 97 Sunfire 2.4L Wont turn over
  191. auto vs standard again
  192. new exhaust
  193. 1996 - no tach, no temp & all dash lights lit up
  194. Alternator in 97 Sunfire, 2.4
  195. 2002 Sunfire Trouble
  196. Someone?? Anyone w/ knowledge? Please??
  197. sunfire 1997 speakers
  198. How do I know my water pump needs to be replaced?
  199. 96 Sunfire Convertible SE 2.4 stalls constantly
  200. FS: 1996 sunfire 2.2 ohv
  201. Switching Turn Signals from a '99 GT to a '02 SE
  202. Is 2.4L engine a bad engine type
  203. need help with 2.2 sunfire
  204. wheel bearings
  205. 97 sunfire problem with antitheft
  206. 98 sunfire 2.4L missfire when ideling
  207. Sunfire GT for sale low miles 8900
  208. e85
  209. wheels
  210. klunk when starting.
  211. rad fan problem
  212. Leaks!
  213. '99 Sunfire GT questions
  214. 2001 sunfire trans problem...
  215. question
  216. Trouble Codes
  217. enging missing or something?
  218. need 2.2l engine info.
  219. Re-Mounting Rear Speakers '02 Sunfire
  220. Need help replacing front struts on 01 sunfire
  221. 2.4 numbers
  222. Cavalier For Sale (so i can buy another one lol)
  223. New and Clueless (no back up lights
  224. ETS problem
  225. Exhaust Leak
  226. overheating problem
  227. '96 Sunfire 2.4L, Auto tran. Is this a problem worth fixing?
  228. Removing calipers on 01 sunfire
  229. 2.4L Tranny Fix
  230. 2003 Sunfire
  231. Stereo Problem
  232. Sunfire Wiring Problems (I think)
  233. 2002 Sunfire, Speaker Removal
  234. where is the tcc solenoid?
  235. No Spark
  236. 1998 Sunfire GT ?'s
  237. 95 sunfire, bad gasmileage and low coolant light
  238. Adapter for 5 1/4" door speakers
  239. Momentary hesitation at highway speed (2001)
  240. Clutch Problem 99 Sunfire
  241. Gas Tank Question
  242. "96" sunfire rough idle no power
  243. Are Sunfires fairly reliable & good to buy used?
  244. high RPM
  245. Heater control not working on low
  246. Chick with no clue
  247. Shaking/jerking at high speeds
  248. misted windows
  249. stall
  250. Codes
