View Full Version : Elantra/Avante
Pages : [1] 2 3 4
  1. 2000 Elantra low speed stall
  2. 98 Elantra radiator
  3. 1999 Elantra Rear Defogger not working
  4. 97 Elantra Problems
  5. 2002 Elantra revs too high
  6. key wont come out
  7. Eating O2 Sensors
  8. 2000 Elantra hesitation and engine misfiring
  9. buying 2005 Elantra-pls help with these queries
  10. Check Engine Question
  11. 01 Elantra only goes 5MPH!!!!
  12. fixing OBD Code: PO441
  13. hyundai stays in 3rd gear
  14. '02 Elantra Head Lights dont work
  15. need help for keyless entry pad
  16. 2009 Hyundai Elantra Touring
  17. 07 Elantra rear wheel noise and rim heat
  18. idle speed
  19. Manual Transmission Torque Specs
  20. PPD Circuit Open air bag code B1462
  21. cooling fans on 1999 elantra still not working
  22. Car keeps dying with lots of codes..
  23. 97 elantra gls starting problems.
  24. timming belt
  25. 1999 Elantra Automatic Transmission Problem - No Movement - What to Check?
  26. check engine light comes on
  27. Transmission Problems
  28. po135 /po131
  29. power steering noise
  30. 2002 Elantra 1 & 4 cylinder backfire
  31. 08 Fuel Issue
  32. 2003 Elantra code P0140
  33. Outer cv joint removal dilemma
  34. 2004 Elantra audio wiring diagram
  35. misfire + random dieng at stops
  36. Loss of power after changing timing belt
  37. Replacing timing belt on 2005 Elantra
  38. 2004 Elantra VE audio
  39. 2000 Elantra electrical problem
  40. Need experience tech help with my car not getting spark or fuel
  41. Elantra timing belt
  42. Elantra Not Starting
  43. rough idle after fillup
  44. Check engine light problems fixed, not fixed?
  45. Manual Trans Fluid Replacement
  46. wierd power problem?
  47. 02 Elantra exhaust
  48. Frost buid-up inside of windows
  49. 2002 Elantra GT Shift Knob (manual trans)
  50. error code p0116 need help
  51. Front disc rotor
  52. 2005 Elantra Belts
  53. How to replace 2000 Alternator
  54. 1999 elantra with error codes
  55. no heat after installing new cd player
  56. ses light
  57. Heat/AC control problem
  58. '06 Elantra GT w/ 51K Miles What Should I Check Before Buying?
  59. How Can I Test a clutch for Slippage?
  60. 2002 Elantra Auto Tranny Noise
  61. clutch
  62. FYI-Notes On Clutch Replacement, Removal, or Remove
  63. 2007 Elantra timing belt
  64. Going to Buy '08 Elantra & Have Questions
  65. '06 Elantra: play in steering wheel with wind gusts
  66. wheel cover (Elantra 2004)
  67. Clutch Slipping Big Time
  68. Car won't Start in bad weather. (smell Gass)
  69. 2002 Elantra Cold Air Intake
  70. What can happen??? Potential project...
  71. Timming Belt
  72. Voluntary recall on Elantra Exhaust Manifold...
  73. brake Caliper Piston
  74. 2003 Hyundai Elantra GT engine light warning and car has acceleration problems
  75. Popping out of gear
  76. 01 Elantra P0105...P0705..Anyone??
  77. hyundai elantra hard to start
  78. Suspension?/Tires? Help!
  79. 2002 Elantra WIRING issue
  80. 2002 elantra problem
  81. Power Windows
  82. Key Fob for 2006 Elantra
  83. 2008 Elantra Tranny problem
  84. Need opinion on switching to an Elantra
  85. 2000 Elantra kicks out of overdrive when it doesn't need to
  86. thermostat issue
  87. What should I look out for
  88. 2005 elantra gls and servicing question
  89. Odd Power Loss
  90. Clunk in Friont End When Turning
  91. 01 Elantra fast idle problem
  92. 2002 Elantra No electrical working
  93. iPod noise issues
  94. How to replace the front wheel stud
  95. Seatbelt not retracting
  96. Wiper problem, ETACM
  97. 2000 Elantra transmission troubles?
  98. 97 air bag light
  99. Thinking about 2002 Elantra Gt
  100. Cant get Bell Housing off to replace clutch, why?
  101. 2005 elantra gls 4dr and brake issues
  102. Hyundai Elantra year 2000
  103. Timing chain replacement
  104. Oxygen Sensor
  105. 05 clutch howl when cold
  106. Car Alarm Goes Off
  107. Radiator
  108. Oxygen sensor for 02 Elantra
  109. Oil pressure sending unit thread
  110. 2003 Elantra Cam Positioning Sensor
  111. '05 Elantra Electrical Issues
  112. clutch slipping??
  113. 96 hyundai
  114. Replacing the rear bearings on an '02 Elantra
  115. By-pass filtration
  116. Parking Pawl Broken
  117. Car wont go into PARK
  118. HMA Service
  119. Speed Sensor
  120. Programe for 2006 Elantra fob
  121. steering wheel vibration
  122. car starts, nothing else works?
  123. Catalyst effeciency
  124. Output Speed Sensor
  125. General Info on '99 Elantra
  126. P0449 Code on 2003 Elantra
  127. Dash Lights
  128. 2005 elantra trans fluid
  129. Weird Elantra power loss
  130. Cabin air filter
  131. rear defogger relay
  132. 2001 Elantra Oil Drain Plug
  133. rear dwfogger
  134. Steering squeel
  135. Sun Visor
  136. Elantra shifting down hard! forcing to almost stop! maybe tranny issue?
  137. Power steering squeel
  138. Repair manual
  139. wont start
  140. front brake pad shim
  141. 02 Elantra Overheating
  142. "Passenger Air Bag Off" light is on- Why?
  143. 97 hyundai elantra ecu question.
  144. car won't take gas!!
  145. help needed
  146. OEM brand parts
  147. 2000 Elantra cyclinder positions
  148. Transmision Problem or Other?
  149. 2000 Elantra with engine fan problems
  150. newbie needs help
  151. 2003 Elantra - Overheating
  152. 2003 Elantra Tranny service details?
  153. What is the problem
  154. elantra relay
  155. 2000 Elantra - Hard steering
  156. 1996 elantra wont start
  157. front rotor probs?
  158. Possible '05 Elantra purchase.....
  159. Checked Fuses now Air Bag Light stays on
  160. 2002 Rotor removal
  161. REPLACING HEADLIGHT on 2004 elantra
  162. Electrical Wiring Harness
  163. Help! Neon Windshield Washer Nozzles
  164. Transmission removal
  165. 2002 Elantra valve noise?
  166. 2000 Hyundai Elantra 5th gear pops out
  167. 95 Hyundia Trans Trouble
  168. Hyundia accelerates slowly
  169. '99 Elantra Killing/Tranny issues?
  170. 2002 Elantra clutch/tranny issue
  171. 2000 Elantra with Electrical Gremlins
  172. 2005 elantra gls alarm issues??
  173. Parking brake question
  174. Transmission problem 2002?
  175. 2000 Elantra stereo - how to program?
  176. Cil Po420
  177. minor clutch issue
  178. Power steering
  179. Detonation on a 2004 Elantra
  180. looking for trailer connector on my 2004 hatch
  181. Thinking of an Intake system
  182. 2004 elantra gls brakes issue
  183. no rpm and no codes
  184. Brake Problem. Anyone heard of this
  185. 1996 Engine Rattling/Grinding Noise
  186. Brakes... Should I drive or tow?
  187. Random Lock
  188. 2000 elantra wont start
  189. 99 Elantra strut problem odd can not figure out.
  190. hyundai elantra 2000
  191. News of the Weird
  192. 1999 Elantra need help with strut install
  193. Gas Gauge not working right
  194. i replaced my alternator and now my car is ready to die again!
  195. Outside Humming Noise
  196. 2005 Hyudai Elantra Idle Engine Noise?
  197. Malfunction Indicator Light
  198. Please help real Quick - What's the rear speaker size for 03 Hyundai?
  199. how to remove driver side fender???
  200. 92 Lantra
  201. Thumping in front wheel, jerking when stopping
  202. Wipers Not Working
  203. Hills
  204. 05 Thermostat location
  205. Should I buy 05'/06' elantra GT hatch back?
  206. Front brake help and replacing Wheel Stud
  207. For BOB Rohrman
  208. noise at idle
  209. Elantra fuel filter
  210. 2005 elantra, hearing a noise??
  211. Cel
  212. Parking Brake
  213. Can't remember how my remote starter works!
  214. Check Engine Code PO136
  215. 2002 Elantra fuel filter
  216. 1999 Elantra Exhaust Noise??
  217. timing belt
  218. 93 Hyundai elantra trany vs 94 hyundai accent trany?
  219. 2000 Elantra Intermittent Stumble
  220. 2002 Elantra P705 P715 and P1529 Codes
  221. shimmy at slow speed
  222. Hyundai windows
  223. 2000 Elantra, what to look out for
  224. lantra gearbox
  225. headlight aiming
  226. 95 Elantra Air conditoner just shuts off and will not cool for short time
  227. 02 Elantra Overheating
  228. 2006 Elantra front seat covers...
  229. Problems after switching 99 engine/trans in 98
  230. 2000 Elantra Overheating
  231. Fuel Pump
  232. Fuel Pump(I think)
  233. Need programming instructions for keyless entry remote - 2004 Elantra
  234. I am tired of this WHAT YEAR IS THIS CAR?!
  235. Engine choises for a 93?
  236. Speed Sensor Problem? Help! P1529, P0501, P0500
  237. 2000 Elantra Battery HELP!
  238. navigation system
  239. Any modifications needed
  240. Tail lights?
  241. Manual Transmission install
  242. What AT Fluid
  243. 2005 reliability=?
  244. AT Slow to Respond
  245. Waht Spacer
  246. Should I buy?
  247. 2000 elantra codes P1624 and P0713
  248. 2000 elantra squeaking
  249. 2003 Elantra overheating
  250. 2000 Elantra SW radiator fans quit...
