View Full Version : Elantra/Avante
Pages : 1 2 [3] 4
  1. 96 Elantra, makes clanging noise when starting
  2. 94 Elantra Radio Code
  3. Slow start 2000 Elantra
  4. How to remove seats with airbags.
  5. how do you change the fuel pump on a 97 elantra?
  6. Availability of Fog Light option for '05 Elantra GLS?
  7. Cleared code, and air bag light is still on?!?
  8. Speed sensor/misfire problem - 2000 elantra
  9. 2002 Elantra GLS - Door Lock Question
  10. 2000 Elantra code p0455
  11. engine troubles
  12. Please Help Troubleshoot Engine Noise
  13. Problem 96 Elantra daytime running lights
  14. 4G67 Engine Swap to a 91 Eclipse
  15. Which Transmission Fluid to use?
  16. 99' Elantra - Fuel Pressure Regulator question
  17. Gas Smell from Heater - 2001 Elantra
  18. Sound from underhood when AC on
  19. 04 elantra brakes?
  20. Did engine swap now get PO455 code, engine misfire and smell
  21. Door trim panel
  22. 99 Hyundai Elantra
  23. Is it the coilpack?
  24. 2001 Elantra electrical smell
  25. 2005 hyundai elantra gls warning light
  26. wrecked frt end
  27. '95 Elantra 1.8 "Sport"
  28. 2000 Elantra, slow start and gas smell
  29. Seeking. Person who knows alot about problems
  30. cracked exhaust manifold
  31. Changing Hubcaps?
  32. changing headlights?
  33. car
  34. car
  35. 2003 Elantra Front Brakes
  36. window problem/door panel removel
  37. big problem
  38. 99 Elantra Window Crank Removal?
  39. Airbag Light
  40. Instrament Cluster lights
  41. Rough idle only when stopped in gear with lights on
  42. Elantra MOLDY smell wasn't the AC unit
  43. rear end cause mechanical damage?
  44. MPI fuse keeps blowing
  45. 01 Elantra GT Emergency Break problems
  46. IS there a way to reprogram the remote on a 2003 Elantra
  47. airbag recall
  48. tie rod ends
  49. Wheel bearings
  50. 5 spd swap
  51. engine problem
  52. 1994 vs. 1995
  53. Korean manufacture complaint!!!!
  54. how much?
  55. is it gona make it?
  56. wuts this?
  57. 1993 elantra, wat do u think?
  58. oil wieghts ?
  59. spark plug cover 1996 elantra
  60. Hey hows it going =)
  61. 1999 owners manual
  62. 2000 elentra gls speaker replacement
  63. shoot redline help
  64. Piston Rings
  65. 2003 Elantra radio question
  66. '96 Enantra Wagon brake rotors
  67. Overdrive/Transmission Issue
  68. 16” and 17” Wheels
  69. Elantra 2001 Overheating
  70. 97 elantra engine problems
  71. Funky Smell
  72. K&N Air Filter
  73. Headlight
  74. Elantra Stereo & Satellite Radio
  75. 2000 Elantra outer CV boots gone
  76. engine compression
  77. How do you fix a sunroof?
  78. Stiping Tires?
  79. How many miles to a tank?
  80. Who has the most trouble free miles?
  81. Timeing belt question
  82. New owner 2005 elantra gt
  83. Hyundai died
  84. 2005 Elantra GT
  85. 94 elantra engine troubles
  86. Auto transmission issue
  87. Bitter owner
  88. Rear springs
  89. How long can a 02 elantra last?
  90. Intermittent Hesitation
  91. how do I remove window crank - 94 elantra
  92. 2 bad window motors, 1 bad lock motor
  93. help with overdrive 94 elantra
  94. 1994 sonata will not shift overdrive
  95. Wanted: 2002 passenger front fender
  96. Why so week motors at the power windows?
  97. Cleanest Elantra Engine I've seen
  98. Replacing Stock Radio
  99. Delaying 2001 Elantra
  100. 98 elantra running wierd
  101. please help
  102. air conditioned Filter
  103. engine spec?
  104. Daytime Running Light
  105. unexpected shift to neutral
  106. An off the wall request
  107. Elantra hesitates
  108. Side View Mirror
  109. HORRIBLE Gas Mileage...HELP!
  110. No power
  111. Rear Strut access
  112. Need Help ASAP
  113. Rear Brake noise
  114. Exhaust Manifold
  115. air bag light
  116. 2004 Elantra
  117. Class Action on Elantra Air Bag Sensor Problem
  118. Please Help Asap
  119. Horn Puked
  120. Drivers window
  121. Front end noise
  122. How do I turn off the annoying chime??
  123. Noise coming from throttle body unit?
  124. How to Change spark plugs?
  125. Check Engine Light and Loss of Acceleration
  126. 2001 zefiro body kit
  127. evap canister
  128. Funky Odor
  129. Gas slow to fill and check eng light
  130. rear window cable
  131. changing color of instrument panel lights
  132. 2001 Elantra poor handling on turns
  133. 2002 Elantra GT Hesitation
  134. locks
  135. 1996 elantra 5spd. gear oil question...
  136. 2000 Elentra trouble
  137. Quick Paint Question
  138. Brake Problem
  139. help
  140. front right wheel rub
  141. 2004 Elantra Passenger Airbag Light
  142. Sport Bra Deflector
  143. 04 Elantra Gt Lights going out
  144. suspension
  145. how to make custome kick panels
  146. Engine Destroyed on Elantra
  147. K n N Typhoon for 94-97 accord on my 2000 Elantra ?
  148. fried anyone else out there
  149. Extended warrenty / horsepower
  150. Fluids and othe stuff
  151. 2003 elantra what is actual gas mileage
  152. ELANTRA ve 2002 troubles
  153. 92 elantra idling trouble
  154. clock
  155. New Elantras good?
  156. 2001 Elantra remote starter
  157. brake lights
  158. Help with codes 705 & 455
  159. '92/'93 Elantra baffling problems
  160. 98 Elantra Check Engine Light
  161. Recall Campaign 066 - Fuel Tank Assembly Valve Installation
  162. 97 elantra w/ 18" rims
  163. HELP: Mold in Air conditioner
  164. Please Help 2002 Elantra
  165. SS Brake Lines *60 BUCKS with 15 people!!!*
  166. noise from front brake?
  167. help with taillights, instrument cluster and fog lights!
  168. PLease help me!!!
  169. brake lights keep blowing fuse
  170. 92 Elantra Condenser Fan/Radiator Fan
  171. 92 Elantra GLS-How do I replace my Water Pump?
  172. 2000 elantra crappy gas millage
  173. 03 accord projector glaring problem need help
  174. 97 elantra change stock car stereo
  175. Instrument Panel/Fog Lights
  176. How Do I change my sunroof Motor?
  177. How do u remove rear speakers on a 99' Elantra GLS
  178. OCS Indicator
  179. 2000 Elantra Overheating.......
  180. Rearview mirror replacement?
  181. Hi all!
  182. instrument Gauge Light
  183. Wanted, Elantra GT Wheels
  184. check engine light
  185. Help me out please
  186. location of automatic transmission filter
  187. M&S Carart Body Kit
  188. Valve clattering 2002 Elantra
  189. K&N Filters and the Mass Air Flow Sensor (MAFS)
  190. Wipers not moving
  191. Elantra GLS 2004
  192. Help! How to remove stock stereo unit on '04 Elantra?
  193. Problems with a 92
  194. 2002 elantra bad gas mileage...help!
  195. 2002 Elantra Exhaust Manifold
  196. 2002 Elantra Exhaust Manifold
  197. 1999 Elantra??
  198. 04 GT parking lights
  199. Hyundai Elantra Diamond SP III Trans. Fluid
  200. fuse ?
  201. First time to the site
  202. Lowering 97 Elantra
  203. 99 Elantra Exhaust Manifold
  204. euro?
  205. excess fuel consumation, please help me!
  206. Spark Plugs Question
  207. Air bag question in a 01 i think it was def.
  208. Need help elantra 93
  209. lANTRA 1996 1.6 BODYKIT
  210. 2002 Elantra engine blew up
  211. 1999; 104,000; Engine Light On When Warm
  212. Hyundais consumer affairs dept
  213. Hyndai Elantra tranny
  214. 1997 Hyundai Elantra Axle Seal
  215. 22,500 mile inspection
  216. Inputting Radio Code
  217. all elantra forum
  218. tire problems with 17's
  219. Check engine light is on. How can I pull the codes?
  220. silly question, perhaps (my first keyless)
  221. 2222 displayed on stereo
  222. 2000 elantra cruise control
  223. power lag at 4k
  224. please help.. problem with 93 elantra engine
  225. Need trans for 95 Elantra, what fits?
  226. transmission problem with 97 elantra
  227. 97 - auto - gas mileage ?
  228. are elantras good>
  229. Help With Elantra 98 GLS Brakes & Rotor
  230. Intermittant "check Engine" Light
  231. '92 elantra fuel pump blues
  232. new board
  233. 2003 Elantra problems
  234. Airbag Light
  235. rear speakers
  236. What's the gas mileage on your elantra's?
  237. new hyundais better than 99's??
  238. 2000 elantra timing belt
  239. blown headgasket
  240. Air Bags for Elantra 2000
  241. Washer not working
  242. MS carart Metaphor Lip kit Available US & Canada
  243. 2000 Elantra - hesitation prob/MAF sensor?
  244. How do I Seperate the trans from the engine?
  245. FS: brand new radiator for 99 elantra.
  246. Looking at buying New Elantra in 2004
  247. Mass Air Flow Sensor Elantra 2001
  248. Steps needed to test Compression
  249. 2002 Elantra GLS
  250. Lantra '96 Engine problems
