Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Hyundai
> Elantra/Avante |
View Full Version :
Elantra/Avante
Web
AF
Pages :
1
2
3
4
Elantra 'o4 changing brakes and rotors
Replace '05 Brakes Already??
Elantra fuel filter
iPOD interface install to Factory EGT head-unit.
Torque Specs
Replacing Suspension on a '99
problem with borrowed friends '02 elantra
Big quality problem!!
02 Elantra over heating thermostat????
Vent Guards/ Rain Guards
2000 a/c controls
1994 elantra
air bag control modual help
Disc Brake Rotor Removal
How Do I Hook Up Subs In The Trunk
Fuel filter placement '99 Lantra (Oz model)
suddenly my car's gone crazy!
Problem with a 03 Elantra GT
2002 Elantra Gt Rear Seatbelt
Please Help
Need Help!
Wierd Noises???
help needed
Question - Didn't know where else to post
CD Player Installation
Shakey Breaks
01 themostat location
wrecked 2000 Elantra, years parts exchangable
Idle revs and drops on '01 Elantra GT
2001 Elantra automatic shifting trouble
Deposit on dip stick
2001 Gear Shift Light
Replacing Shocks
One radiator fan runs, the other does not
Idle revs and drops
Trouble with starter
front brake rotor stuck
Pulling Front Brake Rotors on a '99
Engine Coolant Temperature Sensor
Fan switch
$750 estsimate for brake overhaul?
Pop Pop! Like someone's knuckle cracking...
1993 Elantra
engine and ecu codes ?
weard light problem
OBDII Codes
Cooalnt Bleeding
2005 Elantra Engine Light Question
2001 Eleantra
Head lights
2002 Hyundai Elantra Headlight
97 elantra headlight problem
Front-End Noise Under Braking and Turning
Engine Swap
Want Wiring diagram of 1997 Elantra
Bumper removal
What to do after lease end
Cracked exhaust manifold
Fuel gauge problem
Fan problem
'04 elantra performance???
How do you know when to change the transmission fluid?
air bag light
And the Beat Goes On
Need a Air Bag Module Elantra 2002 GLS
2002 Elantra Keyless Entry
my vehicle claim history: what does it mean?
Is Elantra a good car to buy?
Rumbling Rear End Noise on 2002 Elantra GT
Wheel Bearings 98 Elantra
'99 elantra common software errors: oil change?
window tint estimate?
headers on 1999 elantra?
wheel/rim/tire compatibility? want to swap wheels...
Vents - air doesn't blow out at all (at any fan setting)
2002 elantra 76000 miles still wont stay started
car starter
Elantra 2001 - how to replace tail light relay
groan noise when step on brake pedal
front end groans when stopping;brake noise
elantra brake lights remain on
Brake switch replacement
my 2004 elatra died while i was pulling into a parking spot
Elantra 2001 - instrument panel lights go off and on
car is going crazy
Elantra Trans Shifts from 4th to 3rd
Loud noise when driving/bearing?
1992 elantra water pump
76,000 mi told I need an engine cel on
Cold Air on 98-00 Elantra?
'99 Elantra Fuel Filter Location/Replacement
2000 Elantra Speed Sensor Location???
2001 elantra and oil smell?
2000 Elantra
Should I buy this Elantra?
Timing Belt Replacement
60 MPH Shimmy Resolved
Thermostat location 2002
easy elantra starter removal?
Brake light replacement - HELP
60 MPH shimmy
2002 elantra rear drum removal
01 elantra Exhaust?
Both Regular Headlights Out!?
removing stock radio on 99 elantra
like child safety lock BUT front driver door
Alternator Replacement
remove stock radio/ install new one
Rear Brake Caliper Broblem
Scan Tool Recommendations
First Gear In Automatic Transmission
99 model Elantra
Removing Front Rotor's 2002 hyundai elantra
Timing Belt Replacement ( How To )
Rear Seats on 97 Elantra
Your thoughts on jacking/jack stand placement
P0422 Diagnostic Code
2001 Elantra stock radio
fuel filter 2001 elantra gls
1996 Elantra Air Bag Light On
BIG engine and electrical probs HELP!
idle problems/stereo wiring problems
2000 Elantra overheating...
2OO1 Elantra GLS
2000 Hyundai Elantra Stumbling!
I Only Have Until Sunday!!
97 Elantra check engine light and transmission control module - SOHC?
Accessory Din Socket
What kind of mileage do you get?
1994 lantra suspension?
How do you get this drum off?
Elantra Recall
Fuel and temp gauge needles...
Can Anyone Identify This CD Player?
99 Elantra Engine Noise
2001 Elantra Wheel Bearing problem
95 Elantra intake
2000 elantra caliper bolts
No dash lights and more...
Elantra GT
2000 Elantra
1996 elantra, Alternator or voltage regulator?
2001 hyundai elantra po456 code
raising compresion on 98
2001 Electrical Meltdown
Air conditioning
Type of power door lock
How to get out the battery?
Computer Gone BAd!!!
steering wheel wiggle
Eectrical problem
down to 14 mpg on my 02 elantra
Hood spacer bolts
HMA Service site...
'99 power window problems
97 Elantra: Where is airbag control module located?
Power Window (PLEASE HELP)
timing belt replacement
Elantra 2001 in accident. Check out the pictures
Spedometer Cable
starter
I just got a 2004 Elantra GLS
Taking advantage of 100 octane fuel?
02 elantra cluster question
F/S Elantra Sunroof wind deflector - Lets Discuss
window problem/door panel removel
I've noticed
2000 Elantra horn problems
Elantra 92 1.6i DOCH ECU pictures
1997 Hyundai Elantra Differential Torque Specifications
95 elantra wont start
Hyundai Elantra
Noises coming from front brake area
Aftermarket Shift Knob Help
Aftermarket CD Player
Should I get Hyundai CD Player?
replacing clutch
Cruise controll... and clock =)
Idle surging? idle problems
Oil pan bolt size...
considering purchasing 2005 Hyundai elantra gls... anything i should be worried about
Horn Location
AC problem?
Dreams
bleed point for coolant/radiator, if there's one. 98 Elantra.
Where can I find the Cast # for a 1992 Elantra head?
92 Elantra Power Steering and Brakes die out when driving.
'94 Elantra shift points?
Frozen Left Rear Wheel
Elantra failing to start
2001 elantra transmission filter location
Identifying motors
My 2001 Elantra
2001 Delay on acceleration
1996 hyundai elantra OEM Engine G4CN
bargain prices
helpppp
Deck problems...
2002 used elantra...only 37k but worn out brakes...... is it possible or ...??!!?
2003 Hyundai Elantra Check Engine Light
Wheel bearing buzzing
where are the spark plugs located?
Rear drums
Computer? Throttle Stays On
Synthetic oil
Purchased a 97 Elantra at an auction
Stereo wiring diagram
02 Elantra calipers
More Problems
Mirror glass replacement
Hot CD
Help with rear brakes on 2002 Elantra GT
driveline whine
My 04 Elantra GT
'02 Elantra exhaust manifold recall???
Garage to Garage
custom cat back
Programing a keyless remote
Fuel Pressure Regulator or Fuel Pump?
How do I reprogram a keyless remote?
I need a big help
2001 Elantra GT: Problems Starting Car
Engine ticking
Automatic 97 Hyundai Elantra starts but not without a little hesitation
Latest from my car. Help me out......
backfire,rough idle,no power...Help!
Shud I sell it????Confused !!!!!
aftermarket support?
thermostat on the elantra- where is it? follow which hose?
Faulty Injectors?????????
hiundai elantra avante tunning
Ashtray for Elantra 4 dr sedan
Elantra Body Kit
manual swap questions
gasoline gushing on rear tire when filling up
Cap & rotor
Working On Rear brakes
Recommed tires for 99' Hyundai Elantra?
Hyundai Warranty
Does this harm my tranny?
Wheel bolts
Pronton WAJA or Hyundai Elantra?
3rd upstreem 02 sensor fail in 6 weeks??
hyndai elantra 2000 check engine signs after change spark plugs
RPM's go down when gas pedal pressed
Elantra turbo??
brakes wont depress
Intro and maintenance questions on 96'
Web
AF
