View Full Version : Prelude
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20
  1. installing a clutch
  2. Any clue on cost
  3. How to Make ur Lude weigth LESS?
  4. 2000 Prelude rpm speeds.
  5. drag tips needed
  6. Jdm?
  7. Celica GTS vs Prelude
  8. 93 Prelude Si vs. 93 Prelude vtec
  9. Problem with VTEC
  10. anyone know the code for check engine light
  11. 98 Prelude SH 4 sale in Indy In. $9995
  12. carbon fiber side skirts
  13. Clutch H22A & Flywheel
  14. Skid Plate??
  15. 6x9 Speakers on 93 Prelude Rear Shelf? Possible?
  16. problem in starting
  17. technical info regarding emissions failure
  18. good deal?
  19. Noise When Shifting
  20. how much would YOU pay?
  21. Has anyone heard of this?
  22. Finally
  23. '91 SI Timing Help Please
  24. Turbocharging my '98 Lude
  25. trunk leaks in 88 lude
  26. H23 engine H22 transmission?
  27. Wings West Question
  28. '87 Prelude Alternator - stuck
  29. no fuel pressure after engine swap
  30. The elusive V6 Lude actually does exist
  31. 92 prelude Si vs. 88 Mustang 5.0 GT
  32. 1996 Prelude 2.2LS SOHC nonVTECH
  33. swapping transmissions?
  34. tap
  35. 88 lude suspension
  36. From Sofast to Soslow
  37. 86' prelude question
  38. WTB: Prelude SH Wheels
  39. got 2 ridiculous tickets
  40. SH's harder to mod?
  41. Switching from a CRX to a 97 prelude
  42. prelude got me in trouble
  43. Thermostat problem
  44. '91 Prelude SI 2.05 ECU Identification Help!
  45. Transmission/clutch fluid??
  46. won't reverse
  47. 99 f-150vs s2000
  48. possible engine swaps for 89' prelude?
  49. Rims FOR SALE!!!!
  50. Spindle nut size
  51. A few questions
  52. Problem with gauges
  53. Timing, help please
  54. 1989 Prelude SI for sale.
  55. Paper racing help please!
  56. 89 Prelude Window probs.
  57. Who makes the ABS for the 92 Prelude?
  58. exhaust problem
  59. How bad is insurance?
  60. dumb question
  61. rear wheel drive Prelude
  62. Trans 4 sale
  63. Need new Engine
  64. slow wipers
  65. 88 Honda Prelude Timing Belt. . . bad luck
  66. white spark plugs
  67. Cost of Body touch ups??
  68. 95 Prelude No Start Condition
  69. h22a rebuild
  70. Distributor shorting out
  71. S beats a Vtec.. Unbelievable
  72. Mugen vs. Wings West R.S.
  73. wheel bearing
  74. Prelude F-----D
  75. Need alot of INFO on turning the SH into the Type S
  76. OEM body kit! where do i get one?!?
  77. prelude emblem?
  78. Any other good place to buy cars ither than Ebay?
  79. Cat. Converter
  80. V6 Camaros no threat
  81. Idling problems
  82. can't find prove
  83. idle control valve
  84. Wicked Headlights
  85. Car Parts on Ebay ???
  86. My POS Prelude
  87. 92 lude problems
  88. Upgraded ECU
  89. Need heater/AC controls before winter
  90. door lock cylinder??
  91. Camber help
  92. AXIS Reverb fitment
  93. Matrix coilovers
  94. New Dilemma.
  95. Fuel running rich/trim malfunction
  96. Keeless Entry/Alarm System Remote Doesn't Work
  97. main fuel relay (cant find)
  98. RSX Wheels fit the Prelude?
  99. rs-r exhaust
  100. problem w/turbo
  101. VafcII & Rom can make more hp ?
  102. jdm engines from ebay?
  103. prelude suspension question
  104. Headlight removal
  105. help on JDM engine
  106. Dash lights/ climate lights HELP please
  107. Head or Block problem??
  108. Honda Antifreeze/Coolant
  109. type of headers
  110. JDM Sir S-Spec Wing
  111. timing belt
  112. 4th gen h22 swap hesitation
  113. 6th Gen Prelude?
  114. OEM brake pads for 01 lude
  115. 91 h22a?!
  116. ricer in s-10
  117. stock wheels or 18's
  118. Need HElp aDjusting RPMs
  119. old dude's lude
  120. Rims's
  121. lsd vs. stock tranny?
  122. Remove A-pillars on 4th gen
  123. blown headgasket? hope not... 93' lude
  124. engine running HOT
  125. 92 si 0r s?
  126. Valve cover paint
  127. R34 Urethane Body Kit?????
  128. f20b or h22a
  129. is this authentic?
  130. 92 prelude..timing problems PLEASE HELP!!
  131. Where to find a 97+ prelude JDM front cut
  132. engine build confusion
  133. small question on the prelude types
  134. What's the weight on 3rd Gen's??
  135. From Neutral to Drive, takes 2-3 secs
  136. 90 Prelude Si 2.05liter Gas Mileage?
  137. A Discovery: More Ponies after I/H/E
  138. Prelude wallaper request
  139. Just got my pistons!
  140. buying ATTS or adding
  141. Bouncing Techometer
  142. h23 crankshaft
  143. rebuilt driveshafts
  144. ECU Upgrade
  145. 2nd best in show
  146. good quality kits???
  147. Trouble Code: po505.... need info!!!
  148. Lude Exhaust, looking for a quiet one
  149. 93 lude idle to low
  150. prelude 2.0S upgrades
  151. Head gasket problem on 88 Si?
  152. supercharger options?
  153. 5zigen Exhaust
  154. Can use Ecu B16 with an h22a
  155. turbo help
  156. h23 tranny durability?
  157. white smoke coming out of tail pipe
  158. Turn Signals on 5th gen prelude
  159. Tranny Problem . . Hydrolic System going bad?
  160. SR20 powred RWD prelude
  161. interior buttons... what goes in these holes?
  162. Need help WitH intErior Neon lights
  163. Weight Reduction
  164. low price costume
  165. wanna get the answer to your questions?
  166. head torque
  167. tips on 97 prelude
  168. Prelude 5th generation
  169. i need help in a very important decision!!
  170. h23 swap questions HELP!!!
  171. #3rd Gen HID question
  172. Shopping around for Lude rims . . any ideas?
  173. How To Turbo Ready My Lude
  174. Cam tutorials
  175. I'm tired of getting exhaust TICKETS!!!! HELP!
  176. prelude headlight conversion
  177. R34 Tailight Conversion for the Si...
  178. buying the type S
  179. H23
  180. What Exhaust to get, that is the question?
  181. 01 lude SE
  182. Prelude vtec, installed CAI, rough idle now! help!
  183. difference in sh and base model?
  184. Dallas Texas body shops needed
  185. Japanese engine swap
  186. What do you think?
  187. 99 civic EX vs. 97 prelude sh
  188. carbon fiber hood?
  189. Need to replace Airbag! Help!
  190. White vs. White
  191. Reset codes ?????? 96 Lude
  192. Performance ECU for 5th Gen Prelude?
  193. '92 Lude blowing fuses...HELP!!!!
  194. Venom 400
  195. I need speakers--PLEASE HELP!!!
  196. Good price?
  197. I just need some advice...
  198. Brethren , I need your collective heads of knuckle
  199. swaping tail light
  200. Prelude O2 Sensor
  201. 90 Prelude 2.05 liter DOHC looses power sometimes
  202. headers
  203. 96 Prelude Questions ??????????
  204. Please help, 87Si with battery or wiring trouble
  205. printable white gauges
  206. 2nd or 1st?
  207. best year for preludes?
  208. 1988 honda Prelude 2.0 Si 4ws
  209. In process of buying 97 Prelude
  210. help with a 93 lude vtec
  211. repair weatherstripping
  212. clearing 5th gen taillights
  213. 4th Generation Red Line
  214. Big Question for all you engine buffs
  215. Car Power
  216. please help ASAP
  217. little confused about my lude?
  218. autometer oil pressure gauge help
  219. need advice please
  220. Prelude SH shocks/struts
  221. speed sensor linkage???
  222. trans
  223. 3000GT vs. 97 Prelude SH
  224. fuel relay/main relay
  225. Time for an oil change
  226. fuel pump
  227. h22 sh transmission used as a regular transmission
  228. 94 power glass sunroof
  229. highway rpms
  230. need some advice...
  231. mugen bodykit
  232. Suggestions On Mods
  233. Apexi N1 vs. Greddy Evo
  234. Cyber Predator 2 kit
  235. Steering Rack for a Prelude Si VTEC
  236. Intake Manifold for H23
  237. bad shifting
  238. i need help installing my cd player
  239. Iat?
  240. Greddy Turbo
  241. Apexi AFC II
  242. Are these the same?
  243. Clutch - *56k Warning*
  244. catback exhuast
  245. Buying Prelude
  246. to all the turbo'd h22 ludes out there
  247. h23a vtec
  248. Resetting ECU on 1995 Si
  249. Does boosted VTEC work well?
  250. Ultimate h22 swap guide
