Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Honda
> Prelude |
View Full Version :
Prelude
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
Horsepower!!!!!!!!!!!!!!!!!!!!!!!!!!
turbo h22 del sol help!!
h22a wieght?
REDline
Please help me!!!!!
debating whether or not to buy this prelude...NEED INPUT!
turn signal
heater problem
Turbos Turbos Turbos
Mugen
honda parts
Body kit
Look!!!!!!
swap problems
How do I hook up my Autometer Oil gauge?
How do I drain my tranny?
Best Performance Catback Exhaust For H23 95 Prelude
auto-bumps in 4th when throttle pushed
'96 honda prelude SI --looking to sell
Found a car but a little sceptical
Trying to find 92-96 Prelude
body kit
Help buying a new Injen filter
h22 oil pan gasket
setting the timing
Short Ram Intake
actual horse power
Where can I order a Type-R (SiR) H22A
clutch question
Skunk2 Intake Manifold
Does ECM control A/T shifting?
H22A TPS Setting, how to!!
91 SR engine
Need help on engine swap please~!!!
h22
h22
3000gt vs. 4the gen lude
Bad Shift/power loss
H23 compression ratio??
is it my choke, or what?
95 lude or a 96..So confused
i need an answer!
Loud Engine
compression and leak down testing?
Ebay Speed Chips...
Sylvania Silverstar...NIB...5th gen headlights
Am i getting ripped off with "camber needed"
H22A EGR deleted & what works!!
H22A distributor issue!!
4th gen chip
weird sound comin from engine
2000 'lude headlights
94 Honda Prelude Si... what can I do
What 2 Do?
h22 info
Skunk 2 manifolds. Any good ?
Fuel system or pulleys = more power?
Help need HEADER INSTALL INSTRUCTIONS
Vafc: worth it?
so who would win
5th gen honda prelude speaker upgrade
jdm engine question
Suspension Question
msd ignition
Difference in 97 and 98 H22, PLEASE HELP
Reving Itself when idle
overheating
DC Sports Short Shift Adapter Kit
94 Prelude Si-VTEC Head
honda Prelude problem 97
5 lugs conversion
92 Prelude Si need sum advice
Stalling!!!
lifting the car (for mechanical, not appearance)
paint job cost, cigarette lighter prob, and antenna question
mugen reverse gauges
air filter question
engine swap 87 prelude
clutches?
Rattling sound from wheel arch area. 92 Prelude!
89 Prelude Electrical wackiness - help!
hid conversion
How to tell the diff. from JDM type S H22?
91 lude
Prelude Overhaul
Only CLICK sound from starter.
for sale 96 prelude si
Can I keep my intake resonator in? will it affect anything?
94 si bright gauge lights?
carbon fiber hood
Suggestions for mods
Additon of AWD
Should I go back to Prelude??
New Clutch-need help!
No clue.
02 Sensor??
Dome Light, 92 Prelude
16's or 17's
for sale prelude 93 vtec
95 Si front seats for sale
Check Engine Light??!!
built h23 without balance shafts???
H23 vtec horsepower?
for sale: prelude 93 vtec $4000
2.2L exhaust help
Digital Display When Ignition On??!!
wheel size and tires
type s lip
1995 Prelude For Sale
JDM b20a and USDM b20a5
evo2 exhaust system
Temperature Gauge rises to H
fs: 2000 crystal metallic blue prelude
turbo 98 lude
This prelude worth getting?
wtb 1996 vtec ecu
h23 to h22 swap; AXLES
ABS Light????
Elusive oil leak
little help with an injured prelude?
Door/rear speakers
prelude conversions
is this a good deal?
spoilers on FWD cars?
1985 prelude ecm
stock amp
new deck
Hard starting
MAP problems (code 3 reading)
which ecu is right for the h22?
Brake Pads
H22 motor w/ h23 trans||h23 wired for vtec? ||h23 2 h22 any ac problems?||H23 axles o
88-89 motor parts for sale
clear bumper lenses
Thermal R&D Exhausts
4th gen internals help!
1985 prelude stereo and equalizer
drive your 92 - 96 jdm vtec please (:
H23A transmission gear ratios?
Painting Questions
Buying a prelude help plz!
Quietest Exhaust
Funny smell coming from the car...:{
widebody prelude
Prelude Owners: Help!!!!
H22 Swap Guide
SUSPENTION for a BODY KIT.
HID Lights
big brake upgrades
Help prelude weight reduction
Clicking Noise from Fuel Pump
92 Prelude Si cuts out at full throttle??
Type S engine components
Let's geedum, guys...
85 PGM FI Problem!!!!
350hp goal
carbon hood
clutch makes squeeky noises
1995 prelude si
5 lug suspension
JDM h23 engine troubles
FS: 92 Prelude Gauge Cluster
Voltage Output Issues
prelude/crx engine swap
Lean Racing True Short Shifter
headers
rear speakers
how much horse will i get
k20a2 engine swap
h22a rods and pistons
how do i change my profile name
Oxygen sensor
Wiring?? HELP!!
Anyone know any good sites to find lip kits?
bottom-end buildup for turbo
rear wheel conversion?
Help!!!!
prelude engine
Newbie needs advise on buying a 1991 Prelude SI
how much does it cost to get a lip kit painted?
Oil light issue
Honda prelude 97 ..WHat the!? Help.
How much horsepowere increase from...
HELP! VTEC doesn't work at all anymore
2nd f***ed Radiator Hose
what's wrong with my car???
'91 with ALB/SR question
Obdii-obdi Cel
World Sport 1 or 2?
Honda Prelude Big Problem
turbo/psi quetion
No Spark on '97 Prelude
engine swap
vertical engine conversion
Stock Rims for SALE!!!!
Supra engine!?!?!?
which supercharger is best?
94 prelude S-what you all think?
what gen is my lude?
engine types?
Camshaft break in lubricant?
Coilover/stock height
Can you burn out your VTEC???
engine
body kits
Header for BT/A20A3
Help!!!!!
whats the best wheel offset for a 4th gen?
100 Octane!
Is this a good deal
My Vtech is burning oil OUT OF CONTROL!
flowmaster on a prelude?
New family member.
does any one have a cheap ecu for an 89 prelude si
Rear Calipers are Woofing
h22 tranny problems
CLUTCH KIT for eurpean prelude?? will it work
transmission, atts maintenance
'Ode 2 a 2nd Gen'
New Headers?
1989 Prelude SI for sale. check it out.
for sale fully built h23 for boost
Prelude eng swap
My Check engine lights on i need step by step instructions on how to trun it off
Turbo h23 vs. Turbo h22
91 SI swap?
Start up problems
Crank Gear Removal
nothin better than smoking civics
s-afc 2 on prelude
car jerks and stuff...?
High Flow Cat
93 Prelude for sale: Indiana
Which hood?
'94 prelude lambo door conversion kits
'94 lude horsepower upgrade question
stock lsd in a base
FOR SALE cold air intake
h22 for sale
im looking for shop manuals for prelude 88-89 auto and manaull
h22a internals
'91 Si(2.1) starting/stall problem -- ECU codes
I got Accord & Prelude 84-95 Manuals
90 Prelude Motor swap
JDM P13 ECU and VTEC controller
WTB: 89 prelude donut/bolt thingy.
Front brakes sticking???
performance throttle bodies
90' lude B21A1
Distributor maybe?
Web
AF
