View Full Version : Prelude
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20
  1. AEM v2 Intake
  2. Used prelude had some issues.. Any suggestions?
  3. Prelude PArts for sale
  4. h23 head weight?
  5. 88 Prelude Si Frakenstein swap????
  6. timing belt price
  7. My 89's repair estimate
  8. Prelude h23 parts
  9. H23 vtec
  10. 17 Inch Tires on a 1997 Prelude
  11. Putting a b20a into an '83 Lude????
  12. 1995 Prelude Vtec vs CRX (K20 engine)
  13. Questions
  14. maybe someone could be of some assistance!
  15. ideal compression ratio
  16. 1996 Prelude Turbo Help
  17. Prelude vs. S2000 [56k beware]
  18. help finding parts
  19. 2nd Generation Preludes rock
  20. Help!!!! Big Problem!!! Confused!!!
  21. Rust!
  22. 1995 300HP Prelude
  23. Going to look at a 5th gen Prelude any suggestions of what to look for?
  24. **Help please!** Big bore for 87 Lude
  25. 91 Tails 88 Lude
  26. 93 Prelude dash & gauge conv.
  27. how do i take off the h23 head>?
  28. Mileage Hint
  29. Road Trip
  30. Need a Tranny / miscellaneous
  31. Selling 95 Prelude w/V-Tech 5-speed
  32. Fuel problem diagnosis
  33. Which engine swap is easier?
  34. Axils And Engine Mounts
  35. Parts
  36. skunk2
  37. Timing questions!!!!
  38. whats the difference in the 86 prelude and 86 prelude si?
  39. VTEC Solenoid
  40. camshaft question
  41. Oil in a turbo lude
  42. 4th gen JDM foglight install
  43. my buy
  44. Loud CLunk Sound! 3rd Gen.
  45. jdm swap problem
  46. Buying an Prelude
  47. Replacing Valve Keepers
  48. whats the best fuel pressure
  49. trim
  50. h22 swap
  51. buying a head online
  52. Noise from my 3rd gens rear driver side
  53. Question regarding fuel pump
  54. Cleaning out the head
  55. Repair Manuel
  56. Timing ?
  57. 92 Honda Prelude
  58. What are the Differences?
  59. 4th gen hp issue
  60. 90 prelude si sometimes doesnt want to start
  61. Brake Light Problem
  62. Back Deck rattling
  63. Sensor Question
  64. 1993 SI for sale
  65. 98 prelude sh for sale
  66. 5th gen lude rear seat room
  67. Swapping a H22 trans with a H23 in the H22A1
  68. info for 4th gen 5-lug conversion?
  69. stuborn lude
  70. blown engine?
  71. Engine swap from October still not working PLEASE HELP
  72. h22a/h23a hybrid
  73. are their any differences?
  74. blacktrax.net
  75. few questions
  76. new car looking for advice
  77. Wanting to buy need some advice
  78. Need Engine H22 H23?
  79. 92-93 console -> 94+ conversion
  80. '93 Prelude Door Buzzer
  81. VIN Numbers??
  82. Help! Clunk Sound! 88 3rd Gen Lude!
  83. tranny heading south??
  84. obd1-2conv auto?
  85. 1988 lude..ignition module?????
  86. 5th Gen Prelude Colors
  87. best clutch?
  88. S2000 digital cluster swap...
  89. performance chip
  90. Revs go up and down will cold!!
  91. h22 engine not running right
  92. Installing a V-afc on my 93 lude
  93. clutch installation
  94. how do i host pics?
  95. i need some help plz - tranny
  96. Oil Leaks
  97. will PIAA 9007 fit 4th gen prelude?
  98. 97 Type SH problems
  99. Engine Question?
  100. conversion on a 1992 prelude si F22B engine
  101. h23 distributor on h22a...
  102. 18's for prelude?
  103. 93 runs rough when warm
  104. Anyone want to get the JDM Hiro kit
  105. Best place to buy engine
  106. pick one
  107. automatic fuel cut-off
  108. increase maximum mph
  109. profromance upgrades for a 1988 honda prelude
  110. Crankshaft Pulley
  111. Fuel Supply System
  112. What are 2001 Honda Preludes worth?
  113. Accident
  114. will h22 turbo kit work
  115. Knock Sensor
  116. Vote on Taillights
  117. Ecu fuse blowing
  118. 92 gen 4 body......
  119. 4th & 5th GEN tranny's
  120. Door hinges welded...mom helping son with door alignment! YIKES!
  121. timing belt change.. opportunity to upgrade cam gears?
  122. So Pissed
  123. Quaife and Kaaz LSD
  124. Supercharged WHP
  125. Hemi in Prelude?
  126. i need a prelude
  127. h22 swap or h23 turbo
  128. 88 2.0 si prelude won't start in cold
  129. 88 prelude 2.0 si wont start when its cold
  130. OEM Rear bumper
  131. Need help finding 4th gen prelude
  132. wideband oxygen sensor
  133. has this happen yet
  134. is this true
  135. is this true
  136. '91 Prelude Si Brake Swap
  137. whats better
  138. Arrghh!!
  139. SMSP headers vs Mugen headers
  140. SMSP headers?
  141. did i do the smart thing
  142. finding ignition coil wire under the dash board
  143. 94 clutch swap
  144. s tranny in a si
  145. Best header for H22A?
  146. RPM gage
  147. Supercharge a prelude
  148. is this all I need for a working turbo?
  149. at what RPM do you guys drop the clutch?
  150. 4th gen springs vs. 5th gen springs
  151. A'PEX Super Ground: Worth It?
  152. Jdm H22a With P28 Ecu
  153. 5th Gen Prelude FIRING SEQUENCE
  154. electric supercharger/the turbonator
  155. Draining coolant in 1995 Si
  156. what RPM do u SHIFT??
  157. whinning noise from buddies prelude
  158. need seat brackets for prelude seats!
  159. HELP my 90 2.0 si won't go above 4200 rpm
  160. I need help BAD
  161. turbine trim question
  162. setting amount of boost
  163. h22 swap
  164. help
  165. 4.27 to 4.06 ratio..how bad?
  166. Hondata
  167. Hondata s200
  168. Misfires in 3 cylinders.
  169. Preludes
  170. Which Boost Controller Is Best?
  171. Port and polish
  172. APexi VAFC vs Hondata
  173. Hey
  174. Auto Transmission
  175. prelude ignition timing
  176. which turbo is best
  177. Anyone who has used valve spring compressor on Prelude
  178. Prelude Si and Prelude Vtec?
  179. Prelude faster takeoff
  180. CRX vs Lude
  181. Management system HELP!!!!
  182. daytime running lights 1990 sr
  183. thinking of buying a 91 prelude 3.4 liter man tranny is it worth 1500.?
  184. what do you think of this
  185. Prelude DC Sports stainless steel header problems
  186. What make of rims are these..??
  187. lude vs. rsx
  188. Prelude burning oil problem
  189. how to get the bleed the clutch?
  190. Lock mechanism failed
  191. 93*prelude*h23 -vs- 04/05*scion*tC
  192. Thinking about getting a 99 Prelude SH
  193. h22 swap/eg
  194. 87 Prelude SI - 2 problems
  195. Cam guidence needed
  196. FORUM RULES AND GUIDELINES - MUST READ!!!
  197. slight knocking in h23
  198. clank sound in reverse
  199. venom module
  200. 90 Prelude Lossing compression in Cyld 1
  201. quarter mile times!!!
  202. wont go into gear in
  203. new fuel injector
  204. Engine Swap
  205. 98 prelude auto to manual swap
  206. Changing Headlights
  207. Neuspeed short shifter
  208. How to take off corner lights
  209. Fast Idle after installing SRI
  210. ***oil Leaks Everywhere Someone Please Help***
  211. 92 Prelude leaking oil bad
  212. new lude
  213. dc header 2.5" collector vs. smsp header
  214. Help! O2 Sensor installation...
  215. Cheapest Website to Buy From??
  216. Denso Iridium Power Spark Plugs
  217. head work
  218. Upgrade Help
  219. 98 h22 P5M-003 M/T ECU
  220. Cold Air Intake Help
  221. hunting idle
  222. what do you think
  223. GReddy Header Vs Dc Sports
  224. Solving Intermittent 4ws on 92+ preludes
  225. need help with lude
  226. Type SH vs. Type S
  227. 92 prelude si has starting/electrical problems, can anyone HELP!
  228. headlights for lude
  229. Aceshigh Helpppp
  230. 5th Gen SH vs Non SH
  231. Hayame exhaust
  232. prelude exhaust system
  233. Some new comparison site for import performance stuff
  234. occasional cylinder misfire
  235. Clutch & Flywheel 5th Gen
  236. Hey, guys what's the CAUSE...
  237. Syncros going?
  238. Choke Has Mind Of Its Own
  239. Prelude F22 to H22 swap help
  240. Oil Coming from Exhaust??
  241. Venom 400 Computer Module
  242. How hard is it?
  243. Worst Honda Ever
  244. whats the best NA headers...
  245. Clutch Installation
  246. taking off my shiftknob
  247. Name Brand Vs Ebay Intakes
  248. clutch question
  249. Would it be wise to...
  250. AC wiring harness
