View Full Version : Prelude
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
  1. Looking for 92-96 with blown motor
  2. Lowering Your Car W/out Getting New Springs
  3. boost a H23 or swap or a jdm h22
  4. Need help with clutch
  5. Installing new racing seats, help!
  6. Transmission for sale on Ebay
  7. H23 tranny in H22
  8. funniest vid ever!!! must watch
  9. What Motor Can I Put In My Car
  10. DIY grounding kit
  11. h22a with h23 tranny
  12. advice on a prelude
  13. fx100 vs. act heavy duty clutch
  14. H22 tranny
  15. New Clutch
  16. Need help with tie bar
  17. Fuse diagram
  18. ABS Light
  19. 4WS good or bad?
  20. boosting H23 or H22?
  21. uninstalling a/c compressor & need help
  22. Need Head Now
  23. rough shifting
  24. abs
  25. 95 prelude Si to V-tech?
  26. engine code info
  27. psi compression 91 lude?
  28. Prelude Headlight Problems
  29. Oxygen Sensor ??
  30. clutchmaster fx100
  31. 1989 Honda Prelude Leaky Sunroof
  32. Wont stay running HELP
  33. Cylinder #4 not firing...causes?
  34. HELP!! No AC light
  35. low end hp gains
  36. AC pressure switch connection
  37. Tokico suspension
  38. driving technique
  39. AC Question. AC Compressor!!
  40. idle problem with 86 si
  41. Cleaning your Air Filter
  42. No Ac!!!!
  43. Body Kits For 4th GEN
  44. Fuel system help
  45. offset for wheels and tires
  46. fan not turning off
  47. Whats wrong with my clutch?
  48. 95 rear caliper/piston
  49. ...how about it...
  50. 86 prelude help
  51. 92 Prelude wont start!!
  52. f22a swap to f22b
  53. how do I remove front speakers on a 93 lude. please help
  54. Fuel Injector Cleaner on 93-octane
  55. H22 bearing problem. please help
  56. accord to prelude A20A3 swap
  57. plugs and wires noticeable difference?
  58. wow! dont buy g-force sport
  59. TWO QUESTIONS: o2 Sensors and Dash
  60. Missing Tweeters???
  61. studs?
  62. 1989 honda prelude rotor removal?
  63. %th Gen Clutch
  64. 92 prelude idle problem
  65. E brake handle location by year
  66. Need a rear bumper cover.
  67. WHAT ENGINE IS IN THIRD GEN 2.0Si?
  68. 1999 bmw 330xi vs 5th gen prelude
  69. What do you think about this engine?
  70. 98 prelude vtec or 95 prelude si
  71. painted interior opinion and aluminum floor mats
  72. 93 si will not start
  73. R.i.p.
  74. clutch goin out?
  75. idle issue
  76. Changing Rotors
  77. Tornado Gas Saver
  78. How much does aPrelude weigh (please help)
  79. 97 Prelude Auto trans. shifting delay/hesitation from 1st to 2nd DTC P0700 HELP??
  80. anyone used nology plug wires?
  81. ECU or wiring?
  82. 92 Prelude brake rotor and Auto Tranny questions
  83. 92 Prelude FOR SALE
  84. 98 SH Engine Problems
  85. trading my car?
  86. Upgrade costs
  87. just wanted to say whats up to everyone
  88. ABS wheel sensor
  89. quietest exhaust setup
  90. problem with clutch
  91. getting a 89 prelude si
  92. FOR SALE! - CUSTOM 5gen Prelude TV Visors (could work in civic too)
  93. h22/h23
  94. VTEC Prelude Vs. Type SH
  95. Right Headlight(s) not getting power
  96. are there any 5th gen aftermarket headlights?
  97. Trouble Code Trouble
  98. 1982 'Lude Brake Light Stuck On Since in Storage
  99. Nology Wires
  100. H23a transmission for sale
  101. wheel well fender water guard thingy-ma-bob
  102. What can the Prelude Really Do?
  103. Clock Question
  104. cylinder head on ebay
  105. HID 6500K Conversion Kit vs. H1 Xenon Bulbs
  106. best year?
  107. H22a SWAP ACTin all Funny!
  108. removing speed limiter
  109. What exactly is a Prelude Tune-up
  110. Confused
  111. Knock Sensor/Running Lean
  112. Timing issue on a Mazda B2300/1994
  113. quick question
  114. Prelude Production Numbers
  115. h23 Vtec conversion kit
  116. Voltage Regulator
  117. Two questions
  118. atts
  119. key wont turn in door lock
  120. prelude rev limit
  121. AEM CAI Rev limit
  122. How do I install aftermarket Pedals?
  123. New to the forums - Basic questions
  124. Timing Belt Replacement
  125. click here for a good laugh
  126. 91 prelude 2.0 si for sale
  127. recall
  128. windsheild washer pump
  129. is Tokico a good brand?
  130. Need help replacing oil pan on 92 Prelude S
  131. Timing Belt Whine
  132. prices
  133. h22
  134. timing gun settings for a h22
  135. honda prelude question
  136. Prelude v-tech gas type
  137. Long Sleep
  138. other cars w/same lug pattern? 4x114.3
  139. Hub Centric Rings
  140. timing belt
  141. speedometer is slow to turn on
  142. changing rotors
  143. changing rotors
  144. Hesitation/Rough idle
  145. 87 Lude 2.0si
  146. z3 Steel Fender
  147. Help me decide - Apexi N1 or GReddy EVO2
  148. Immobilizer locked me out after swapping ECU
  149. Immobilizer activated
  150. prelude pix
  151. Rough driving at lower Rpms. only taching out at 6500
  152. 92 prelude body type
  153. buddys prelude missing bad!!
  154. PreludePower.com
  155. lost lug key!
  156. fuel issues drivin me crazy
  157. exterior mods program?
  158. How long to get Crower Cams?
  159. Rough Idle Question
  160. "Breaking In" new clutch
  161. skipping speedometer
  162. MSD Ignition / SS Blaster coil??
  163. I Need A New Tranny!!
  164. 4th gen question
  165. strange screatching noise
  166. new 1/4 time
  167. Request for your help
  168. wiper fluid motor?
  169. Performance between SI and VTEC
  170. It's time to bid farewell to my '00 Prelude
  171. Am I being ripped off? Clutch job?
  172. 92 prelude engine??
  173. H22A vs H22A4
  174. I need input from the Prelude community, especially H23ers
  175. Does it matter if camshaft company matches valve spring?
  176. GTECH pro
  177. just installed my AEM v2
  178. HKS, Greddy, Tanabe... which would be best?
  179. How much (approximate of course) would this cost?
  180. Standard vs. SH
  181. problems with vtecH
  182. weird knocking?
  183. help my friend as a 91 lude need idea's
  184. chk eng light 98 lude
  185. hey guyz..Oil Change question..
  186. lude bumper.
  187. front lip
  188. radiator
  189. Locating the Knock Sensor
  190. Shifter Vibration
  191. where can i find a b20a5 motor?
  192. Check Engine LIGHT! "EGR Valve" lift sensor
  193. clutch issues!!
  194. fluidyne radiator/flexalite fan
  195. body kit
  196. Please buy me.
  197. Exhaust Installed!
  198. egr valve on 92 lude
  199. please help.. trans problems
  200. Good bye Prelude
  201. Exhaust Sound Clips
  202. Where can i Find a REALLY GOOD air filter??
  203. Need Some Help
  204. anyone selling 5th gen parts?
  205. Help! How to prep my JDM mirrors
  206. My Car doesn't PULL!!
  207. '84 Prelude Project
  208. 89 honda prelude prodject help wanted.
  209. wheel bearing
  210. My car wont start
  211. OEM body kit
  212. 94 prelude - cold air intake help!!
  213. h22 auto to manual
  214. I need lights for my 1 piece JDM's
  215. f22a to h22a engine swap
  216. f22a to h22a engine swap
  217. Is it Posible???
  218. Pics of my '01 Prelude - Look
  219. new shift knob
  220. Just a story (Kinda long)
  221. Camshaft Knowledge
  222. turning coilover sleeve upside down?
  223. h22 transmissions
  224. need an inner fender
  225. AEM or Injen CAI?
  226. Noise when turning?
  227. Help please!!!!
  228. 3rd gen Mods?
  229. brake light/abs light
  230. nice thread by the way....
  231. PSPEC, forbidden, adaptor, whatever..
  232. Ford 302 In A Prelude!
  233. 92 gauge cluster to 94-96 cluster
  234. Quarter Panel Rust
  235. 84 Prelude specs
  236. 1993 Prelude Si
  237. JDM Headligh Conversion
  238. New Lude
  239. **important**what Cat Do You Use For Your Lude?
  240. time for a new clutch!
  241. FIRE! H22 motor?
  242. need new tires for my 4th gen si rims
  243. flex pipe needed on a 4th gen vtec
  244. coilovers
  245. G/f's 92 lude losing oil like crazy
  246. Need Advice
  247. anyone have a ViS Evo Style CF hood?
  248. Gas Mileage?
  249. Atts Problem!!!!!
  250. ebay turbo kit, take a look, whatcha think?
